patching VC switch? (combining sequencer rows to get more steps)
2008-12-17 by Carlos
Index last updated: 2026-04-28 23:13 UTC
2008-12-17 by Bakis Sirros
--- On Wed, 12/17/08, Carlos <bushwick@...> wrote:
Subject: [SergeModular] patching VC switch? (combining sequencer rows to get more steps)
To: SergeModular@yahoogroups.com
Date: Wednesday, December 17, 2008, 7:57 PM
Is there a way to patch a VC switch in the current m-class or with the
regular panels?
my thinking is that if I had a VC switch in combination with a pulse
divider I could send values from the sequencer or sequencer programmer
and extend the number of steps by combining rows together. (using the
clock into the pulse divider to figure out when is time to change each
row being input into the switch)
of course if there is an easier method of doing this I will like to
hear it.
C.
2008-12-17 by Skot Wiedmann
Date: Wednesday, December 17, 2008, 9:57 AM
regular panels?
hear it.
C.
> the TKB vertical clock does this up to 64 steps.
> From: Carlos <bushwick@...>
> To: SergeModular@yahoogroups.comthe
> regular panels?programmer
> and extend the number of steps by combining rows together. (usingthe
> clock into the pulse divider to figure out when is time to changeeach
> hear it.
> C.
> you can make a vc-switch (2 in - 1 out) with an ACPR.
> btw, any other ideas how to make a vc-switch with Serge modules?
> Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist
> [Doepfer_a100] group owner
> www. parallel - worlds - music. com
> www. myspace. com/ parallelworldsmusic
> www. myspace. com/ interconnectedmusic
> www. myspace. com/ memorygeist
> www. DiN. org. uk
> www. musicamaximamagnetica. com
> www. shimarecords. co. uk
> www. rubberrecords. gr
> Athens - Greece
> hear it.
> C.
Subject: [SergeModular] Re: patching VC switch? (combining sequencer rows to get more steps)
Date: Wednesday, December 17, 2008, 9:37 PM
how would you patch the ACPR so that it will automatically switch to
the other input at the end of a number of stages? would need a
constant 5 volt input to do that no? a switch just needs a pulse to
change inputs?
--- In SergeModular@ yahoogroups. com, Bakis Sirros
> www. DiN. org. uk
> www. musicamaximamagneti ca. com
> Athens - Greece
> --- On Wed, 12/17/08, Carlos <bushwick@.. .> wrote:
> From: Carlos <bushwick@.. .>
> To: SergeModular@ yahoogroups. com
> regular panels?
programmer
each
> hear it.
> C.
>inputs (staying at input 2 as long as the voltage is X volts high) and
> some vc-switches need an X volts voltage to switch between the two
>would be a clocked switch.
> if a switch needs a trigger to switch between its inputs then it
> www. DiN. org. uk
> Athens - Greece
> To: SergeModular@yahoogroups.compulse
> change inputs?
> > www. DiN. org. uk
> > Athens - Greece
> > --- On Wed, 12/17/08, Carlos <bushwick@ .> wrote:
> > From: Carlos <bushwick@ .>
> the
> > regular panels?
> > divider I could send values from the sequencer or sequencerto
> programmer
> the
> each
> > hear it.
> > C.
Date: Wednesday, December 17, 2008, 11:01 PM
I guess I am looking for a sequential switch type of device then or a
clocked switch then.
but curious what combinations of modules will give me that switching
functionality with the ACPR even if its a 5volt constant input instead
of pulse, any ideas to generate that 5 volt constant output as the
sequencer is in its second row?
C.
not a trigger to go from input 1 to input 2.
> www. DiN. org. uk
> Athens - Greece
> change inputs?
> > www. DiN. org. uk
> > Athens - Greece
> the
> > regular panels?
pulse
> programmer
> the
> each
to
> > hear it.
> > C.
>the pulse divider 1/8 output into the xfade input of the ACPR?
> inputing the sequencer clock into the pulse divider module and using
> i guess this should work...?rows to get more steps)
> www. DiN. org. uk
> Athens - Greece
> To: SergeModular@yahoogroups.coma
> clocked switch then.instead
> of pulse, any ideas to generate that 5 volt constant output as theand
> C.
> not a trigger to go from input 1 to input 2.sequencer
> > www. DiN. org. uk
> > Athens - Greece
> rows to get more steps)to
> > the other input at the end of a number of stages? would need ato
> > change inputs?with
> > > www. DiN. org. uk
> > > Athens - Greece
> > the(using
> > > regular panels?
> pulse
> > programmer
> > thechange
> > each
> to
> > > hear it.
> > > C.
Date: Wednesday, December 17, 2008, 2:59 PM
that will provide one short pulse after every 8 steps of the clock and
will only change the xfade from one input to another for the duration
of the pulse.
perhaps there is no way of actually patching this and I just need to
go get a TKB if I want anything over 8 steps. life is tough.
> www. DiN. org. uk
> Athens - Greece
a
instead
> C.
and
> > www. DiN. org. uk
> > Athens - Greece
sequencer
to
to
> > change inputs?
> > > www. DiN. org. uk
> > > Athens - Greece
with
> > the
> > > regular panels?
> pulse
> > programmer
(using
> > the
change
> > each
> to
> > > hear it.
> > > C.
