QTR-Quadtone RIP
Index last updated: 2026-04-28 23:12 UTC
ICC Profiling Questions
2007-10-10 by Louis Dina
I am a bit confused on the creation and use of ICC profiles for
printing and proofing with QTR.  I am on a Windows machine.
If I understand it correctly, QTR uses the raw numbers in a grayscale
file for printing, and any profile tag is ignored.  The raw numbers
work with the chosen profile in QTR to determine ink loads.
Let's say I have a QTR warm profile that has a good Dmax,
linearization and tone.  I want to make a profile for soft proofing
in Photoshop, and a profile for printing, so that the soft proof
jives with the data QTR sends to the print so the two match.
1.  Do I create an RGB profile or a grayscale profile with QTR-Create-
ICC.exe, or do I need both?
2.  When editing the file in Photoshop, do I first convert from my
normal working space to the grayscale profile that mimics my warm
profile above?  I read that I use perceptual with BPC.  So, will this
remap the numbers so I have the correct tonal scale when printing
with my warm profile?
3.  Do I soft proof in PS using the RGB version of the profile, so I
can see not only tonality, but also the color of the profile, in this
case warm tones? What about 'paper gray'?  Do people use that for low
Dmax papers and not use it for higher Dmax papers?
4.  And will this process work with any RIP, driver, or process?
If I have this wrong, I sure would appreciate some help in sorting it
out so it is very clear.  I want my screen to match my prints.  I
understand all this in a fully color managed workflow (eg, when
printing color with the Epson driver), but I am a little fuzzy when
it comes to QTR.
Thanks for your help,
Lou Dina
Re: ICC Profiling Questions
2007-10-11 by joemulligan_68
Lou,
I haven't used the Create ICC function in some time since my screnn to print match
without it has been very good, I'll try to answer some of your questions.  Others who use
this function more frequently can probably give more insights.
Comments listed next to your queries.
IF YOU WERE TO OPEN THE 21 STEP FILE YOU WILL SEE THAT THIS IS AN UNTAGGED FILE.
OUTSIDE OF SOFT PROOFING THE ICC SHOULD REMAP THE IMAGE DATA TO THE RANGE OF
THE PAPER SINCE WHEN YOU MEASURE THE FILE YOU ARE GOING FROM DMIN-PAPER
WHITE TO DMAX-MAX BLACK.
NOT SURE WHAT YOU MEAN BY THIS QUESTION.  YOU ARE ONLY MAKING ONE PROFILE
WHICH WILL BE USED FOR SOFT PROOF AND PRINTING.  JUST OPEN THE 21 STEP FILE,
MEASURE THE DATA THROUGH A PROGRAM LIIKE PRINT FIX PRO 2 OR IF ON GRETAG, USE
THE MEASURE TOOL FUNCTION.  WHEN DONE MEASURING, TAKE THE READINGS AND
INSERT THEM INTO A TEXT FILE WHICH YOU CAN DROP INTO THE QTR CREATE ICC
PROGRAM.  I KEEP THE QTR CREATE ICC ICON ON MY DESKTOP FOR EASY REFERENCE.
ONCE DROPPING THE FILE INTO THIS, AN ICC WILL BE MADE AND SHOULD POP UP
SOMEWHERE ON YOUR DESKTOP WHICH YOU CAN IMMEDIATELY INSTALL.
YOU DON'T NEED TO CONVERT.  JUST USE THE SOFT PROOF FUNCTION IN PHOTOSHOP
USING PERCEPTUAL BPC.   IF YOU ARE PRINTING FROM PHOTOSHOP, YOU WILL NEED TO
HAVE PHOTOSHOP MANAGE THE COLORS AND SELECT THE NEWLY MADE QTR ICC PROFILE
USING PERCEPTUAL BPC.  TURN COLOR MANAGEMENT OFF IN THE PRINTER DRIVER.  IF
PRINTING WITH QTR ON WINDOWS YOU SHOULD USE CONVERT TO PROFILE FUNCTION IN
PHOTOSHOP BEFORE PRINTING THE FILE WITH QTR.
THE QTR ICC PROFILE WILL NOT ONLY SHOW TONALITY OF IMAGE BUT TINT AS WELL IN
THE SOFT PROOF. YOU SHOULD BE ABLE TO SEE THE WARM TONES IN YOUR SOFT PROOF.
NOT SURE WHAT YOU MEAN BY PAPER GRAY.
HAVE NOT USED IT OUTSIDE OF THE EPSON DRIVER AND QTR BUT WOULD ASSUME IT
SHOULD.  I DON'T KNOW THOUGH ABOUT SOMETHING LIKE IMAGEPRINT SINCE
IMAGEPRINT ALREADY USES ICC PROFILES TO CREATE THEIR BLACK AND WHITE.
> it comes to QTR.
IF YOU ARE ALREADY COLOR MANAGED THIS SHOULD BE EASY FOR YOU.  JUST MAKE THE
PROFILE AND USE IT IN YOUR SOFT PROOF.  YOU SHOULD GET PRETTY CLOSE SCREEN TO
PRINT MATCHING.
> Lou Dina
2007-10-11 by Louis Dina
Thanks, Joe.
I spent a lot of time the last two days getting my arms around this.
I have found that everything you described is correct.  I am used to
printing with ICC aware applications (photoshop, epson driver,
ImagePrint, and other RIPs).  My biggest problem was in understand
what QTR wants to receive and how it handles data.  Your description
is exactly what I have found, but it took a lot of screwing around to
figure that out.
Being on a Windows platform, I have to either convert the file as you
proposed, or use Paul Roark's workflow and add a curve adjustment
layer to my edited file before printing to convert a gamma 2.2 file
into a linear Lab based file.  The advantage of this approach, is
that it preserves the original file in gamma 2.2 space, but the
disadvantage is that it is grayscale only, not coloration.  The
Create ICC approach will probably be the most accurate and will allow
viewing color on screen.
I appreciate your response.
I sure wish a front end could be added to QTR to make it fully ICC
aware like other graphics programs.  This would make life so much
simpler and make the program just about perfect, IMO.
Lou
--- In QuadtoneRIP@yahoogroups.com, "joemulligan_68"
<joemulligan_68@...> wrote:
> Lou,
to print match
grayscale
numbers
UNTAGGED FILE.
proofing
RANGE OF
PAPER
Create-
PROFILE
STEP FILE,
GRETAG, USE
AND
ICC
REFERENCE.
POP UP
my
this
PHOTOSHOP
WILL NEED TO
PROFILE
DRIVER.  IF
FUNCTION IN
so I
this
low
AS WELL IN
SOFT PROOF.
ASSUME IT
WHITE.
sorting it
when
> > it comes to QTR.
MAKE THE
SCREEN TO
> PRINT MATCHING.
> > Lou Dina
