"I don't think the lack of a profile can be the problem. Although
using another but similar paper's profile isn't ideal, I can't
believe it would have the effect of flooding the Permajet paper with
ink to the extent that it is virtually all black!"
I don't either. But your original message didn't say you were flooding the
paper to the extent that it was virtually all black. You said the prints
were very very dark.
To: <QuadtoneRIP@yahoogroups.com>
Sent: Thursday, August 31, 2006 8:33 AM
Subject: [QuadtoneRIP] Re: Initial QTR results very poor-help needed...
Hi Brian and Jari ,
ink to the extent that it is virtually all black! There surely can't
be that much difference between two profiles for matte paper. Of all
the profiles on QTR I'd imagine there must be one that would give at
least reasonable results on Permajet. If someone knows better, can
you please put me right.
Jari, I haven't had time yet to try your suggestion of printing at
1440 but will definitely give it a go. Thanks.
--- In QuadtoneRIP@yahoogroups.com, "Brian Ellis" <bellis60@...>
wrote:
> You might try using a paper for which there's a profile.
> From: "Bruce Robbins" <bruce.robbins@...>
> Sent: Wednesday, August 30, 2006 3:54 PM
> Subject: [QuadtoneRIP] Initial QTR results very poor-help needed...
> I'm using QTR on a PC running XP. Files saved as greyscale tiffs as
> instructed and dragged to the print window. The results are
terrible. Black
> and white photographs are printing very, very dark-wasting lots of
ink
> (Eboni matt black and UT colour cartridges) in the process. I'm
printing on
> Permajet Museum Classic for which there doesn't appear to be a
profile so
> I've used the EEM profile (and tried one or two others as well with
> same results).
> Can anyone say what might be going wrong here? Using the limit and
> gamma adjustment tools help a little but prints are still far too
dark.
> Other
> than sending a very light file to QTR, is there a solution?
> Thanks,
> Bruce
