QTR-Quadtone RIP
Index last updated: 2026-04-28 23:12 UTC
How to make a custom calibration file?
2015-10-23 by ctb@...
I have been trying to make my own QTR calibration files. By investigating the existing ones I found out that the magic of the calibration happens in the Red and Green channels while the Blue channel is empty/white.
The red channel defines the ink density layed down. In the 6, 8 and 10 inkseparation files this is represented by 6, 8 or 10 normal stepwedges with 5% intervals in density from 0-100%.
The Red channel seems to define what ink is used. This, as far as I have understood, is not the actual K percentage but the (3x identical) RGB value. Where the K is represented by R127 G127 B127, C=> 191, M=> 223, Y=> 239, LC=> 247, LM=> 251, LK=> 253, LLK=> 254. Last one is also used for gloss optimizer on printers with GO.
There's also the inkseppatch.psd file that has all the individual inks as 100% patches and 2 and 3 ink combinations. They come each with their own RGB values. The G channel value is also changed when 2 or 3 colors are mixed. It changes from 100 to 50% for 2 inks or 33% for 3.
That's where my understanding of the underlying principle takes a halt. Are the RGB values for the individual inks and the 2/3 ink combinations from inkseppatch.psd hard coded in the software? Are other combinations possible. Can I make my own mixes of inks for calibration. I was interested in making a CY patch for example but could not figure out how to do that.
Kees
Re: How to make a custom calibration file?
It's even more complicated with the 10 ink printers where the orange and green strip are both represented by R255 G255 B255 in the red channel, but for these colors the blue channel strip changes to RGB127 (orange) and RGB191 (green).
Re: [QuadtoneRIP] How to make a custom calibration file?
2015-10-24 by Roy Harrington
You've got the general idea. Red and blue channels are bits (convert to binary)
determining which ink(s) are to be used. Green channel determines the "value".
It's completely general but works well for calib page.
Roy
On Friday, October 23, 2015, ctb@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
Sent from Gmail Mobile
