Epson 1430 QTR Support
2012-07-16 by scho_2000
Index last updated: 2026-04-28 23:12 UTC
I'm thinking of replacing my Epson 1400 with the new 1430. I assume that the 1430 is not currently supported by QTR, but is it similar enough to the 1400 so that an install script, such as "InstallR1430=R1400" could be used?
2012-07-17 by serdar_b
Yes I believe so. I am using P50, smaller version of 1400. I am using it with R280 printer settings, it works with R380 and 1400 settings too. --- In QuadtoneRIP@yahoogroups.com, "scho_2000" <list@...> wrote:
> > I'm thinking of replacing my Epson 1400 with the new 1430. I assume that the 1430 is not currently supported by QTR, but is it similar enough to the 1400 so that an install script, such as "InstallR1430=R1400" could be used? >
2012-07-18 by Roy Harrington
I'm not sure the install script will work but yes the 1430 is compatible with the 1400. Just setup the printer manually -- like doing a Bonjour printer. See Tutorial.pdf -- make a printer named Quad1400 and then run the Install1400 script. Roy On Mon, Jul 16, 2012 at 8:27 AM, scho_2000 <list@...> wrote: > I'm thinking of replacing my Epson 1400 with the new 1430. I assume that the 1430 is not currently supported by QTR, but is it similar enough to the 1400 so that an install script, such as "InstallR1430=R1400" could be used? > > > > ------------------------------------ > > Yahoo! Groups Links > > > -- Roy Harrington roy@... www.harrington.com
2012-07-19 by scho_2000
Thank you Roy and Serdar. I will set it up manually as recommended. Carl --- In QuadtoneRIP@yahoogroups.com, Roy Harrington <roy@...> wrote:
> > I'm not sure the install script will work but yes the 1430 is compatible > with the 1400. Just setup the printer manually -- like doing a Bonjour printer. > See Tutorial.pdf -- make a printer named Quad1400 and then run the > Install1400 script. > > Roy > > On Mon, Jul 16, 2012 at 8:27 AM, scho_2000 <list@...> wrote: > > I'm thinking of replacing my Epson 1400 with the new 1430. I assume that the 1430 is not currently supported by QTR, but is it similar enough to the 1400 so that an install script, such as "InstallR1430=R1400" could be used? > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > > > > -- > Roy Harrington > roy@... > www.harrington.com >
2012-11-28 by Terry
I'm a familiar user of QTR but am having trouble understanding how to Add the 1430 printer to be able to use the 1400 Profiles and also the Paul Roark Claria approach 1400 profiles. I use QTR on a PC with Win7. The 1430 is wireless but I can connect directly via USB to my computer. What specific steps do I need to do? Thanks, Terry --- In QuadtoneRIP@yahoogroups.com, Roy Harrington <roy@...> wrote:
2012-12-04 by Terry
A specific question how to set up the Install script on Win7? which I read about in the Apple tutorial for Leopard 10.5, etc Use Install Quad1430 for Quad1400-MIS or???? Thanks, Terry --- In QuadtoneRIP@yahoogroups.com, "Terry" <TerryGls@...> wrote:
> > I'm a familiar user of QTR but am having trouble understanding how to Add the 1430 printer to be able to use the 1400 Profiles and also the Paul Roark Claria approach 1400 profiles. > > I use QTR on a PC with Win7. > The 1430 is wireless but I can connect directly via USB to my computer. > > What specific steps do I need to do? > > Thanks, Terry > > --- In QuadtoneRIP@yahoogroups.com, Roy Harrington <roy@> wrote: > > > > I'm not sure the install script will work but yes the 1430 is compatible > > with the 1400. Just setup the printer manually -- like doing a Bonjour printer. > > See Tutorial.pdf -- make a printer named Quad1400 and then run the > > Install1400 script. > > > > Roy > > > > On Mon, Jul 16, 2012 at 8:27 AM, scho_2000 <list@> wrote: > > > I'm thinking of replacing my Epson 1400 with the new 1430. I assume that the 1430 is not currently supported by QTR, but is it similar enough to the 1400 so that an install script, such as "InstallR1430=R1400" could be used? > > > > > > > > > > > > ------------------------------------ > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > -- > > Roy Harrington > > roy@ > > www.harrington.com > > >
2012-12-06 by Roy Harrington
There nothing you need to do on Windows. In QTRgui just select the 1430 printer and the Quad1400-MIS for curves (assuming that's the curve you want). Roy On Mon, Dec 3, 2012 at 6:57 PM, Terry <TerryGls@...> wrote: > A specific question how to set up the Install script on Win7? which I read about in the Apple tutorial for Leopard 10.5, etc > > Use Install Quad1430 for Quad1400-MIS or???? > > Thanks, Terry > > --- In QuadtoneRIP@yahoogroups.com, "Terry" <TerryGls@...> wrote: >> >> I'm a familiar user of QTR but am having trouble understanding how to Add the 1430 printer to be able to use the 1400 Profiles and also the Paul Roark Claria approach 1400 profiles. >> >> I use QTR on a PC with Win7. >> The 1430 is wireless but I can connect directly via USB to my computer. >> >> What specific steps do I need to do? >> >> Thanks, Terry >> >> --- In QuadtoneRIP@yahoogroups.com, Roy Harrington <roy@> wrote: >> > >> > I'm not sure the install script will work but yes the 1430 is compatible >> > with the 1400. Just setup the printer manually -- like doing a Bonjour printer. >> > See Tutorial.pdf -- make a printer named Quad1400 and then run the >> > Install1400 script. >> > >> > Roy >> > >> > On Mon, Jul 16, 2012 at 8:27 AM, scho_2000 <list@> wrote: >> > > I'm thinking of replacing my Epson 1400 with the new 1430. I assume that the 1430 is not currently supported by QTR, but is it similar enough to the 1400 so that an install script, such as "InstallR1430=R1400" could be used? >> > > >> > > >> > > >> > > ------------------------------------ >> > > >> > > Yahoo! Groups Links >> > > >> > > >> > > >> > >> > >> > >> > -- >> > Roy Harrington >> > roy@ >> > www.harrington.com >> > >> > > > > > ------------------------------------ > > Yahoo! Groups Links > > > -- Roy Harrington roy@... www.harrington.com
