I actually thought about a non-ac model 37 - but given it goes into
the audio range and beyond i felt it best to keep it both sides of ground.
Push pots - no can do in an ELF: too large under the panel. The
iceberg effect would have the sides of the pot sticking out the ends
of the faceplate.
Model 10, Mk 3: A switch for both retrig and non-retrig ops: I
wrestled with this one, a lot and elected against it only becase it
would have constituted a rise in the price due to the time it would
take to wire the switch. We've already got two of themin there we're
hand wiring as it is.
If I convert the M10 to the new jacks, which means the panel hardware
would integrate by simply soldering the the part into a board, then I
will do this but in the meantime, ALL M10 MK 2's CAN BE MODDED IN THIS
MANNER. You'll need to punch a hole in the panel and wre a DPDT
switch, but it can be done - I designed the new boards so tat was
possible.
This weekend I'll publish the procedure.
- P
--- In PLAN_B_analog_blog@yahoogroups.com, "metafoetus2002"
<jan-hinnerk.helms@...> wrote:
> Hi Peter,
> yes, I guess it will be pretty packed inside the ELF LFO. Option 2
is nice, as I already have a
> Model 14. The only thing that bugged me is that I have to devote a
complete 3-in-1-
> bipolar-mixer with-offset to achieve just an offset.
> I figure that you already get more than enough proposals on this
list, but I can't help it,
> here comes mine: How an ELF Leveler MkII that (a) offers bipolar
attenuation and uses
> pull-pots? If pot is pushed in, it's a bipolar leveler, if pulled
out, it's a bipor level shifter.
> Guess it is out of the question as space is so small with the ELFs.
> So back to reality (some sort of): option 3 is also nice, as I have
long dreamed about
> adding one to my setup. I understand that there is now a Model 10
MkII around. I am
> trying to shut up here, but I can't: would it possible to add...a
switch that changes between
> MkII (retriggerable) and MkI (non-retriggerable) behavior? And how
about a three-way
> switch that switches the timebase VC into controlling T1 only, T2
only or TB (both, as it is
> now)?
> I guess I've just turned into "The very hungry caterpillar" ;-)
> Best regards,
> Jan-Hinnerk
> --- In PLAN_B_analog_blog@yahoogroups.com, "(i think you can figure
that out)"
> <peter@> wrote:
> > Second option: A model 14!!
> > Third Option: A model 10 and use that for the positive LFO
> > I wish I could have done more with all of the ELFs...but those guys
> > are small and we had to make some hard decisions in all cases.
