Re: [Mellotronists] Re: The M-Tron...Low and High notes
2006-04-09 by Jerry Korb
mettalliccasucks wrote: > > I would like to know how Mike Pinder got all those low notes ... > > I get some exceptionally L O W notes when the power company "load > sheds" and drops the 120VAC to 60-80 volts. > > Whenever that happens the "bass tron" makes some pretty interesting > sounds, but being afraid of encountering a dreaded whisp of black > smoke or burning smell and having to call Martin for parts, I turn it > off and wait until the ceiling fan is back to spinning at normal speed > ... Jim ___________________________________________________________ Greetings Gang, Mike Pinder's MK-II's were upgraded to DC motor controls in the late 1960's. Same time as release of "ISOTLC, Threshold....., and To Our Children's........" First-generation CMC4 motor-control used. Quite possible that the Tronmeister used the centre-speed control instead of regular pitch knob to achieve those low notes , way past the normal +/- 20% pitch variation. Rick Wakeman did the reverse on "Tales From Topo....Oceans." He cranked-up the CMC-10 to max, and doubled the brass/choirs on portions of the last last two sides. Result was a choir section sounding more like the Three Chipmunks..... Finally, Good 'Ol Harry incorporated a dimmer control on some Chamberlins to give 0-100% motor-speed change. Stable, Harry only knows...... Signed, --Dave Seville
