digital recording
2002-12-19 by ceccles_ca <clay123@rogers.com>
Index last updated: 2026-04-03 20:43 UTC
off topic? What is the topic? Does anyone know of audible differences between recordings made at 44,100 sample rate and recordings made at 22,050 sample rate? Are all MP3's 22,050 ? At 44,100, SoundForge allows equalization up to a 16K band, and when recording at 22,050, SoundForge only allows equalization up to an 8K band. Why? Has anyone had poor results with MP3 conversion? Some recordings convert well and sound great, while others have a pronounced flange / warble effect. Clay
2002-12-19 by fdoddy@aol.com
HI folks,
I personally do not care for 22.5khz as a sampling frequency if it is to represent a full bandwidth recording. Bit reduction and lower fs are great for "lofi" stuff. I have sampled my tron and converted to a number of bit length/sampling rates and 22.5 sucks. Mp3 encoders are not all the same. I rely on Bias Peak for mp3 encoding and I always make 'em as large as I can, they still end up being pretty small. Interestingly, itunes does a pretty good job of mp3 conversion.
Just bought the Yamaha CRW-F1 cd burner with "Audio Master recording" mode and yes, the difference is stunning compared to a cd burned on a conventional drive.
Fritz2002-12-19 by kenmerb@aol.com
In a message dated 12/19/2002 1:19:03 PM Eastern Standard Time, fdoddy@... writes: > Subj:Re: [Mellotronists] digital recording > Date:12/19/2002 1:19:03 PM Eastern Standard Time > From:<A HREF="mailto:fdoddy@...">fdoddy@...</A> > To:<A HREF="mailto:clay123@...">clay123@...</A>, <A HREF="mailto:Mellotronists@yahoogroups.com">Mellotronists@yahoogroups.com</A> > Sent from the Internet > > > > HI folks, > I personally do not care for 22.5khz as a sampling frequency if it is to > represent a full bandwidth recording. Bit reduction and lower fs are great > for "lofi" stuff. I have sampled my tron and converted to a number of bit > length/sampling rates and 22.5 sucks. Mp3 encoders are not all the same. > I rely on Bias Peak for mp3 encoding and I always make 'em as large as I > can, they still end up being pretty small. Interestingly, itunes does a > pretty good job of mp3 conversion. > Just bought the Yamaha CRW-F1 cd burner with "Audio Master recording" > mode and yes, the difference is stunning compared to a cd burned on a > conventional drive. > > Fritz > > To unsubscribe from this group, send an email to: > Mellotronists-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > Speaking of all this digital recording stuff, I know that there are a lot of you out there who would like to know more about the ins and outs of digital recording so that you can record your mellotrons. There's a new CDROM from Synth-Tek for $20 which goes over the setup and use of a digital home studio in great detail. This company puts out similar CDROMs for learning how to use Kurzweil keyboards, and they do an excellent job. I've used them, and they are much more interesting than reading the manual, and are a very effective training tool. The graphics are accurate and the tutorials are worth every penny. If they have done a similar job on this "Digital Home Studio" CDROM, it will be well worth the 20 bucks. It's on my Christmas list. Here's the link: <A HREF="http://www.synth-tek.com/mhs.html">http://www.synth-tek.com/mhs.html</A> Then, once you learn how to do all this, you can record a tune for the <A HREF="http://www.tronsounds.com/updates1.htm"> Mellotron Project CD</A>. Ken M.
2002-12-19 by sdavmor
From: kenmerb@...Sent: Thursday, December 19, 2002 1:49 PMSubject: Re: [Mellotronists] digital recording
[snip]
Here's the link:
Then, once you learn how to do all this, you can record a tune for the Mellotron Project CD.
Ken M.Indeed! And y'all had better start submitting mellotron drenched tunes, or Systems Theory will be obligated to contribute another new tune, just so we can see the project completed and out the door!--
SDM -- a 21st century schizoid man
http://systemstheory.net internet music project
http://thecleanersystem.com software for dry cleaners
NP: nothing
2004-09-21 by JMoore6397@aol.com
I am in the process of creating a digital recording workstation. I have come across a Presonus digital interface that has 8 class Mick pres headphone stereo out and cubase software. It works with mac and pc and you can "daisy chain" them together to create 16, 24, etc. tracks.
Best of all it is 599.00. I also have presonus mic pres which are great sounding with a very low noise floor.
Does anyone one the list have any experience with one?
I am not digital savvy and I know alot of you are.If you go to Presonus.com and highlight firepod you can see it and the specs.
Jimmy2005-06-09 by ceccles_ca
I keep hearing the myth that mellotron sounds are always degraded in some way when using digital recording methods. It may have been always true 25 years ago. (using poor converters, low resolution filters, short word length and low sample rates). With modern, good quality digital recorders, you can still end up with a cold / harsh "digital sandpaper" recording. (degraded). OR you can get results that are pure and sweet. The initial recording at 24 bit / 96k sample rate will always sound great. The trouble is, engineers fuck with the recording over and over and over again....and the sound quality deteriorates ever so slightly each time it's processed. (There may be no generation loss when making digital copies, but there is generation loss when processing the signal). In addition, some of the processing that's intended to improve the sound, degrades it. EQ, gain adjustment, Downward compression, reverb, upward expansion, EQ, upward compression, downward expansion, more EQ, more gain adjustment, a pinch of Q sound, a dash Aphex Exciter....run it through the DA - AD converter just one more time and presto! Harsh digital sandpaper! No problem... We can always use an Analog tube (valve) emulator to fix it. Clay
2005-06-09 by tron@blackcat.demon.co.uk
> I keep hearing the myth that mellotron sounds are always degraded in > some way when using digital recording methods. Crap. All the Mellotron parts for SFIM were rcorded digitally and I think they sound outstanding. As you say, it's post-recording fucking about (PPFA) that messes up the sound and *that* is because digital recording makes PPFA that much easier. Mike Dickson (tron@...) M400 #996 The Official Cynic of Streetly Electronics Streetly Sample Library http://www.blackcat.demon.co.uk/tron/
