Mellotronists group photo
Mellotronists
Archive for Mellotronists.
Index last updated: 2026-03-30 01:07 UTC
need some help with my mellotron...
2008-07-23 by Ignacio Nieto
Hi...
I need some help with my mellotron. She is not working properly. I have
had it in a warehouse for 1 year (I have to move to another place and I
had no place to keep the 'tron until now). After that year I moved the
mellotron here by my own, in a van, on its case and with care. When it
arrived, the tron sounded terribly out of tune and oscillating in a
whoaaa-whoa---wahwah.... I was so scared, but after changing it in the
room and waiting some days, it appears to work properly, except that:
1. sometimes (specially when I change the sounds) the engine goes faster
and starts to oscillate and then the tune goes off in a wah wah.
2. now when I push 3 or more lower keys, the sound after 2 or 3 seconds
starts to oscillate too like fading and the engine seems to oscillate
too. I don't think it is an issue on the tapes because it behaves
similarly on every sound.
I beg your help on this.
Thanks a lot.
Sincerely.
Nacho.
Re: [Mellotronists] need some help with my mellotron...
2008-07-23 by Ken Leonard
- Is the *sound* fading in and out, the motor speeding up/down, or
both? That would make a huge difference in what you would look at.
- What motor controller do you have? If CMC-10, upgrade.
- How's the drive belt for the motor?
- Is the keyboard seated properly?
- If you wiggle the pitch knob, does it correct or cause the problem?
Same with the volume knob? Perhaps those pots are dirty.
- Did you inspect all connectors?
- Could the adjustment pots on the motor controller be a little touchy?
- Do you have "screeching cable rot"---the fade in/out version? (Look
it up on my site if you do not know what "screeching cable rot" is.)
Just some quick ideas...
...kl...
On Wed, Jul 23, 2008 at 1:58 PM, Ignacio Nieto
<ignacionietocarvajal@...> wrote:
> Hi...
> Thanks a lot.
> Sincerely.
> Nacho.
