Mellotronists group photo
Mellotronists
Archive for Mellotronists.
Index last updated: 2026-03-30 01:07 UTC
Re: [Mellotronists] Re: Chamberlin 300, SOLD.....The bar has been reset to ne...
2007-09-28 by lsf5275@aol.com
In a message dated 9/28/2007 6:48:21 P.M. Eastern Daylight Time, jkorb@... writes:
Maybe I'm full of it, or worrysome, or whining, whatever.
"But time will tell, of prices that fell,a short short time ago....."
No, I think your point is valid, Jerry. The same thing happened about 10 or 15 years ago when rich Arabs started a run on French wine futures. They dove the market out of site. It made buying great first growth wines nearly unaffordable for most people.
I was astonished that it went for this much. But hey, my friend paid a pretty high price for the 4-Track a while back. He felt really good about that today. We were going to bid on it. We did, up to 3600 or so but we knew that it was going to go high. We figured about 7500.00.
So we all suffer and we all benefit, depending on who "we" are.
Somebody fell for it.
See what's new at AOL.com and Make AOL Your Homepage.
2007-09-29 by chris.dale@primus.ca
Someone I know was offerred $11,000 for an M-1 recently, so maybe that has something to do with it, but who knows for sure?
Could it be a coincidence? It's really hard to say.
Guess it depends on what you value.
Sent: Friday, September 28, 2007 7:15 PM
Subject: Re: [Mellotronists] Re: Chamberlin 300, SOLD.....The bar has been reset to ne...
In a message dated 9/28/2007 6:48:21 P.M. Eastern Daylight Time, jkorb@.... com writes:
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.488 / Virus Database: 269.13.33/1036 - Release Date: 9/28/07 3:40 PM
2007-09-29 by Mark Pring
Well I would personally settle for an M4000, which I
think are about 5000 pounds ( not sure what that is in
dollars these days). I suppose having an original
historic instrument is worth something but how much
time would you spend playing it as opposed to trying
to keep it working? Speaking admittedly from very
limited experience, I don't think trons are like some
acoustic instruments, they don't improve with age. I
would value an instrument which sounds great ( the
M4000 does) and is reliable and doesn't need enormous
maintenance ( Well Martin did convince me of that )
Mark
> From: lsf5275@...
> To: jkorb@... ;
> Mellotronists@yahoogroups.com
> whatever.
> people.
> who "we" are.
> Homepage.
Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545469
2007-09-29 by lsf5275@aol.com
In a message dated 9/28/2007 8:22:02 P.M. Eastern Daylight Time, markpringnz@... writes:
A properly restored and set up M400 is no different than a M4000... In fact (Martin, hang in there) it is probably more reliable in that there is less to go wrong. You can put the same motor in it, the same PML1 preamp/line amp, etc. The only thing you don't have is the cycling mechanism, which is one less thing to go wrong.
NOW... The M-4000. Streetly has put consummate time and effort into squaring away that little gremlin. But still, the fewer the issues, the fewer the problems. Does that make sense?
The Chamberlin that just sold. It can't cycle. They admit that. It was always the weakness of Harry's machines. This one you have to crank by hand... Like a Model T Ford.
Imagine buying a 1959 T-bird that would not start with the turn of a key. You have to hand crank the motor.
Bwahahahahahaha! Fuck that!
Mellotrons do improve with age if we improve them. No, they aren't like pianos or guitars that develop tiny warps or subtle changes in the neck or in the sound box that may influence the sounds they produce over time, sometimes for the better. But how much better do Hammond organs sound over time? None... That's how much. They just may sound a little different. But no one could tell because the subtle changes over time are indiscernible. It's just that some Hammonds sound different from others of the same models. This is more likely due to the subtle changes in wiring and components over the years.
What improves a Mellotron over the years is that someone takes one and makes it be all that it can be. We bring it into perfect alignment. We give it the upgrades that are available. We make our own improvements. We carefully adjust and perfect it.  The end result is a Mellotron that sounds and performs far better that it did when it left the factory.
I know this to be true, Jerry Korb knows this to be true and Streetly does as well. We have all made this happen, many times over.
Frank
2007-09-29 by Rick Blechta
Actually, most of the sound of Hammonds is due to how close the magnets are to the tone wheels. I was at Goff Professional near Hartford, CT a few years back and they claimed they could make a B3 sound like "Born to Be Wild" (still love that sound Goldie got) to Jimmy Smith at his mellowest simply by adjusting the magnets. Then they proved it to me on an instrument they were rebuilding.
I've had my B3 since 1965 and it still sounds the same (I have old recordings to prove it). My playing sounds different, but that's the mileage, not the years.
I have noticed that mellotrons can sound subtly different when different people play them. It probably has something to do with the way the keys are depressed. Take that samplers!
Rick
Hi Frank,
I think you have just agreed with me. One of the
reasons I don't own a tron is because I live in a
fairly isloated part of the world, if something went
wrong with it, I certainly wouldn't be able to fix it
or find anyone who knew anything about one.
I play guitar, my guitar has never needed restoration,
even I can manage to tune and re string it. I am
planning to buy a piano, when it needs tuning or minor
repairs, there is a fairly local piano teacher who
will be able to fix it. A new one comes with a 10 year
garantee and most pianos will go for many years and
only need tuning.
I am convinced that the trons that have been restored
sound as good as new if not better and if I had that
kind of elctromechanical skill ( or confidence in
being able to learn it ) I would probably order one
tomorrow.
I agree with you about the M4000, the cycling
mechanism is one more thing to go wrong, although
Martin is pretty convncing and I was very tempted when
I heard one, the bass clarinet is astonishing and
would certainly annoy the hell out of the neighbours
if not cause structural damage to their house.
It's a shame that sampling doesn't work, in the end
it's only the sound that interests me, if they could
make a soild state tron which sounded as good as the
real thing I would have one, although having said that
somehow it wouldn't be quite the same even if it
sounded identical.
I think I am beginning to ramble.
Mark
> Daylight Time,
> some
> thing to go wrong.
> admit that. It was
> over the years.
> over.
> Frank
> ************************************** See what's
> new at http://www.aol.com
Boardwalk for $500? In 2007? Ha! Play Monopoly Here and Now (it's updated for today's economy) at Yahoo! Games.
http://get.games.yahoo.com/proddesc?gamekey=monopolyherenow
In a message dated 9/28/2007 11:36:09 P.M. Eastern Daylight Time, rick@... writes:
Rick
Ok so were both right. You have added some excellent extra stuff there Rick. One thing though. I never depress the keys when I play my Mellotron. I keep 'em nice and happy and well adjusted. Sure, I press them to perform well. But they're always happy, never depressed.
Frank
In a message dated 9/28/2007 11:57:16 P.M. Eastern Daylight Time, markpringnz@... writes:
Mark
Mark, if you get a well restored Mellotron, you may never have to worry about it. The Mellotron I just sold and the ones I have rebuilt require only regular maintenance. There is very little to go wrong. I give my clients about three pages of instructions on maintenance and adjustment. Anything else is only a fax or a phone call away. All you really need is a head demagnetizer, some rubber rejuvenator and a demagnetized screwdriver.
Mellotrons today are very simple to maintain and very reliable. The only reason not to own one is if you don't have electricity.
Frank
2007-09-29 by gino wong
Ones garbage is anothers gold
What I would I give for a Rose Morris Duo Fuzz or a Davolisynt
It's a Trophy tron
gw
> Mark
> Regards,
> Frank
2007-09-29 by Mike Dickson
I would really like to knock this one on the head once and for all.
Sampling a Mellotron most certainly works; I've done it with #996 on
3-violins and I will guarantee you that no one will ever be able to tell
the difference betwen one sound and the other. I'm not saying that they
are close - I'm saying that they are completely identical. How do you do
it?
1. Get one Mellotron
2. Make sure it works and that all the sounds are playing well
3. Record every note in full
4. Er
5. That's it.
Where the use of samples falls over is in the *tinkering* that goes on
after the event. Hmm. Slightly ugly timbre on that one. Let's just
re-tune one of the adjacent notes instead. Bit of a pop on the master
there. Edit that bit out. Oooh. White noise all over that one. Let's
noise reduce it. In fact, let's variably noise reduce the lot. And
tuning? Wow. Isn't that what Antares is for?
And *that* is if they are feeling charitable and give you a full
complement of 35 notes in uncompressed format, as opposed to (say) 15
interpolated notes resampled at 128kb/s or so.
It's not true to say that you cannot sample a Mellotron and get a good
result. However, it's more than accurate to say that you cannot /buy/
such a thing right now because it simply doesn't exist.
Mike Dickson - M400 #996
The Official Cynic of Streetly Electronics
Streetly Sample Library http://www.mikedickson.org.uk/tron
2007-09-29 by Donald Tillman
> From: Mark Pring <markpringnz@...>
> Date: Fri, 28 Sep 2007 20:57:06 -0700 (PDT)
Grokking the innards of a musical instrument, arguably, makes one a
much better musician. It certainly makes for a more intimate
connection between the player and their instrument.
> It's a shame that sampling doesn't work, in the end it's only the
> sound that interests me, if they could make a soild state tron
> which sounded as good as the real thing I would have one,
> although having said that somehow it wouldn't be quite the same
> even if it sounded identical.
I think you're really close to something very profound.
> From: Rick Blechta <rick@...>
> Date: Fri, 28 Sep 2007 23:35:42 -0400
And that's the same profound concept approached from the other side.
-- Don
Don Tillman
Palo Alto, California
don@...
http://www.till.com
Hi Mike,
If I had a mellotron I wouldn't need the samples! I
use mtron, its not very good, did the mellotron
company do 1-5 with the Mike Pinder CD? I might be
prepared to buy a sampler whilst I waiting to win
lotto.
Mark
> once and for all.
> it with #996 on
> it?
> playing well
> 4. Er
> 5. That's it.
> one. Let's just
> pop on the master
> that one. Let's
> reduce the lot. And
> give you a full
> opposed to (say) 15
> you cannot /buy/
> exist.
Tonight's top picks. What will you watch tonight? Preview the hottest shows on Yahoo! TV.
http://tv.yahoo.com/
2007-09-29 by ceccles_ca
--- In Mellotronists@yahoogroups.com, Mike Dickson <mike.dickson@...>
True....but the Pinder sample library was sampled well and was not
tinkered with much. It comes close enough for my LOW FI ears.
2007-09-29 by Bernie
Rick, when you were at Goff Professional, were they still located on
Asylum Ave. in Hartford, or had they already moved to their current
location just off the Berlin Turnpike (Rte. 15) in Newington (about 2
miles from my house)? Harold Goff used to personally maintain my
band's B3 in the late 60's/early 70's. I purchased my XK-3 and MS Pro-
145 from them a couple of years ago. As far as I know, they are the
best in the business.
Bernie
RE: [Mellotronists] Re: Chamberlin 300, SOLD.....The bar has been reset to ne...
2007-09-29 by David Jacques
Try these…. www.vintagekeyboardsounds.com
From: Mellotronists@yahoogroups.com [mailto:Mellotronists@yahoogroups.com] On Behalf Of Mark Pring
Sent: Saturday, September 29, 2007 2:01 AM
To: Mike Dickson; mellotronists@yahoogroups.com
Hi Mike,
lotto.
Mark
> once and for all.
> it with #996 on
> it?
> playing well
> 4. Er
> 5. That's it.
> one. Let's just
> pop on the master
> that one. Let's
> reduce the lot. And
> give you a full
> opposed to (say) 15
> you cannot /buy/
> exist.
> http://www.mikedick son.org.uk/ tron
____________ _________ _________ _________ _________ _________ _
http://tv.yahoo. com/
I'm glad you say all this with such enthusiasm................because there's a Birotron prototype nearby that seeks to destroy the spirits of anyone who dares to try restoring it!! :)
Frank
2007-09-30 by leetronhead
any chance are there photos??????????????? or audio files we can
enjoy???????????
Lee and the Aloha Tron #541
restoring it!! :)
left the factory.
> Frank
9/28/07 3:40 PM
2007-10-05 by chris.dale@primus.ca
Sorry no audio files. It's in pieces and needs a complete overhaul as well as parts but
it promises to be interesting because of improvements in the design (adjustable heads, ability to play all 4 tracks at once via two heads, etc.) Look inside the ( very time consuming / cleaned up) separated decks to get an idea.
Your enthusiasm and support is most welcome!
Sent: Sunday, September 30, 2007 11:06 AM
Subject: [Mellotronists] Re: Chamberlin 300, SOLD.....The bar has been reset to ne...
any chance are there photos?????? ????????? or audio files we can
enjoy??????? ????
enthusiasm.. ......... .....because there's a Birotron prototype nearby
restoring it!! :)
left the factory.
> Frank
9/28/07 3:40 PM
