Mellotronists group photo
Mellotronists
Index last updated: 2026-03-31 23:14 UTC
hi everyone! + oiling the tron?
2007-05-10 by Bondage Master
Hi everyone:
I have just joined the list, and it's a pleasure to join my mellotronic
passion with you all :D.
I own a Mark VI (#48). I would like to make you a question about oiling
it. I have been oiling my 'tron in the past but never quite sure if I'm
doing it well. The problem is, english is not my native tongue, so the
explanations about the engine parts got somewhat confusing to follow for
me. Wouldn't anyone have/know a picture or graphic schema signaling the
points to oil the 'tron ?
Also, I am using a very light oil I had from an old sewing machine, and
I don't know if it's the proper oil to use in a mellotron. Any idea of
where can I buy a better one?
Hope hearing from you and best regards to all 'tronists.
Nacho.
Re: hi everyone! + oiling the tron?
2007-05-12 by ceccles_ca
--- In Mellotronists@yahoogroups.com, Bondage Master
doing it well.
I would not oil it. You should be able to play your new mellotron for
the next 20 years without oiling.
I have never used lubricant on reel to reel tape recorders or any
other mag tape machine.
Clay
MK VI #019
P.S. Dr. Jerry (the Proctologist) may recommend lubricant, but that's
another story.
Re: [Mellotronists] Re: hi everyone! + oiling the tron?
2007-05-12 by Bruce Daily
> quite sure if I'm
> doing it well.
> new mellotron for
> recorders or any
> Clay
> MK VI #019
> another story.
Hi all-
Welcome to all new members. You have chosen well.
Keep the rubber gloves close, though :)
Here's a related question. I am in the middle of
cleaning and re-positioning the motor on my M400. Got
the new grommets and washers, too. Upon removing the
belt I noticed that the flywheel/capstain turn freely.
However, the bearings make a little noise, as if the
balls are loose inside. Is this normal, or does it
indicate a need for oil and/or bearing replacement?
-Bruce Daily
M400 #1221
Sucker-punch spam with award-winning protection.
Try the free Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mailbeta/features_spam.html
2007-05-13 by Doug Berg
--- In Mellotronists@yahoogroups.com, Bruce Daily <pocotron@...> >
> -Bruce Daily
> M400 #1221
> Hello Bruce, Congrats on having the courage to tackle this. If the
bearings are making a light clicking or crackling sound, they are
probably dry inside. If it is more of a grinding sound, they need
replaced. While you are this far into it probably would be best all
around just to replace them regardless as they are an inexpensive
fix. Bearing Distributors is a good direct source, as they are
nationwide, or if you have a good Independent auto parts store, you
can measure from your old bearing and they can cross reference it.
Aside from that make sure you take the effort to make sure motor is
aligned with respect to capstan flywheel, double check this when you
place frame in cabinet. Hopefully you are going to replace the belt
also. Hope that was of help and good luck. Doug
_____________
2007-05-13 by Ken Leonard
Although rare, it's not unusual to have to replace bearings.
MRC 104KSZZ
NSK 6004VVC3
The Prof showed me the trick of sticking your ear at the other end of
a metal bar or dowel that's against the bearing block and then
turning the capstan by hand. Crunchy sound = bad---replace the bearings.
I've thrown oil at mine from time to time. I don't know how much
actually gets in there---I need to get me one of those needle oiling
things for the next time.
Regarding motor oiling...At the Philly Symposium
(http://www.kleonard.com/mellotron/philly0501/working.htm) we went
over this and observed a few motors being cleaned/oiled. In addition
to cleaning out the brushes, I do recall having to put a few drops of
oil at either end of the shaft where it runs through the motor. I've
done this on #805 when I had the motor out and on "Mark" the Mark V
(http://www.kleonard.com/mellotron/mpb050604/index.htm). However I'm
not sure how effective this is. I guess the idea is that some of the
oil works its way in there, and that's that. Again, having one of
those needly oilers might be a good idea.
Oh, I used Hammond oil. I figure if it's good enough for one of those...:-)
I'm sure the Prof or one of the other tech guys can give us some more
detail (or un-do the lies I'm spreading :-) ) if needed.
...kl...
M400 #805 - old motor
M400 #1037 - new motor
** Ken Leonard - Web Table of Contents: http://www.kleonard.com
** Get Outdoors New England: http://www.GONewEngland.org
2007-05-13 by Jerry Korb
MRC 104KSZZ
NSK 6004VVC3
Greetings KL and everyone, If bearings make a regular sounding
"clackety-clack" whilst rotating, similar to cadence of train wheels,
chances are the bearings are OK, but a bit dry. Esp. true on the older
models (MK-II,SFX/M300) . But grinding/cruching, nada ! Gotta repl. 'em .
Some "sealed" bearings aren't as sealed as others. Therefore, the
round felt washers adjacent to pillow blocks, to catch any migrating
lubricant. In those instances, a precision needle-oiler (from Rat-Shack),
will do the trick. Apply a small drop on what appears to be inner race cover,
NOT the capstan.
The metal rod trick is decades-old way that car mechanics used to
listen for faulty bearings or such in car engines. Kinda low-tech
stethoscope. Buy hey, seems to work !
...kl... M400 #805 - old motor , M400 #1037 - new motor
The orig. motors have lubed bushings which get dirty/dry from age
and/or neglect. Once cleaned, armatures should be moving freely.
Needle-oiler as Ken indicated is very useful.
Sewing-machine or 3-in-1 (has nice smell too!) are excellent too.
I've endurance tested every motor here at the M-Ranch after
Prev. Maint. by running top-speed a minimum of 24 hrs. Checking
for drift in SMS electronics, etc. See photo of one example.
....How does that old saying go ?......" A squeaky wheel ...... ? "
Cheers, -- JK-- (a bit squeaky, due to spring cold)
2007-05-13 by Bruce Daily
--- Jerry Korb <jkorb@...> wrote:
> bearings.
> > MRC 104KSZZ
> > NSK 6004VVC3
> at the other end of
> block and then
> don't know how much
> those needle oiling
> regular sounding
> of train wheels,
> true on the older
> Therefore, the
> catch any migrating
> NOT the capstan.
> mechanics used to
> Kinda low-tech
> we went
> put a few drops of
> "Mark" the Mark V
> However I'm
> is that some of the
> needed.
> #1037 - new motor
> dirty/dry from age
> moving freely.
> excellent too.
> M-Ranch after
> hrs. Checking
> one example.
> wheel ...... ? "
Thanks, Jerry-
Help abounds on this forum. I got the motor
cleaned, oiled (1/2 drop on each end) and back in
position. New rubber bushings, too. Had to flatten
the large motor mounting plate a bit, but the geometry
is now correct (the belt tension was a bit much, ya
think?). Belt now rides centered and true. I think
the previous owner was tightening the belt to
compensate for worn bearings, screwing up the
motor/belt geometry in the process. I did add a
little oil to the capstan bearings, but the difference
was minor. Bearings will be next, for sure.
Happy 'tronning
-Bruce Daily
____________________________________________________________________________________You snooze, you lose. Get messages ASAP with AutoCheck
in the all-new Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mailbeta/newmail_html.html
