Mellotronists group photo
Mellotronists
Index last updated: 2026-04-03 21:42 UTC
Solo trons
Solo trons
2007-04-22 by Mark Pring
Do many of the group play the mellotron as a solo instrument? I only have access to M-tron, a situation I am hoping to remedy, it sounds ok used as a backing instrument using block chords with lots of reverb but I spent quite a lot of time this morning trying to use it as solo instrument and I realise that most of the group is right, it sounds terrible and not just my playing! The left hand drowns out the right really easily and anything played at higher end of the keyboard is as irritating as finger nails on a blackboard.
Is a real tron useable as a solo instrument? I ask because I don't play in a group and am not likely to do in the near future.
Mark
Send instant messages to your online friends http://au.messenger.yahoo.com
Re: [Mellotronists] Solo trons
2007-04-22 by kinchmusic@aol.com
In a message dated 22/04/2007 04:26:39 GMT Standard Time,
mellotronmadness@... writes:
Definitely! Mk2 Flutes are brilliant with a bit of key click. My
favourite?..... Elton Johns brilliant cover of Lucy in the sky with Diamonds.  Wonderful!
Actually, there's also Daniel which is equally as memorable.
Andy K
2007-04-22 by Jerry Korb
> Wonderful!Actually, there's also Daniel which is equally as memorable.Andy K
> Greetings Andy and gang,  Equally brilliant but relatively unknown
> is Rod Argent of Zombies prominently using MK-II flutes in "Changes".
> This is heard on LP/CD  "Oracle and Odyssey" . Same release as their
> pop. hit "Time Of The Season."    The track just prior is also
> replete with MK-II flutes,strings, and sounds like MK-II rock guitar
> lightly sprinkled within.   Have a listen !
> Thanks Martingle  Smythe  for sharing that info some years back .
> Cheers, -- JK  (lawn still sprinkled with traces of snow and pine needles )
Re: Solo trons
2007-04-22 by Doug Berg
--- In Mellotronists@yahoogroups.com, Mark Pring
> Thanks
> Mark
> Hi Mark   Need to mention this is just one person's opinion so for
what it's worth:
   Solos, yes, ,and off the top of my head King Crimson's Lizard Lp
is packed with tron leads, most of the Tron work of Passport,
Kraftwerk's Trans Europe Express, come to think of it Neptunes which
I believe also uses the M-tron.
Most depends on how you shape the sound you are playing, that is if
you are using the 400 3 string patch you can eq some of the highs
down and boost the mids a little to sweeten it up.  The flutes on
the other hand you may add some highs. Again if you are using
strings or brass patches and playing 3 note chords with the left
hand and one note lead on the right, the lead will be drowned out.
Answer here, overdub the lead.  Maybe in a live situation, again
since you are in the sampler domain, you would assign higher volume
for the right half of keyboard. Again this depends on the
flexibility of what you have to shape the sound with.  Processors
with  only preset definitions are almost useless.  You need infinite
control of delay or reverb to make it work. Another thing to try is
layer your lead part to male it stand out. Detune each layer
slightly away from the source.  The E4 sampler is outstanding  for
this.  Try experimenting like this instead of "just out of box" and
see if there is a difference,  and if you haven't yet heard, check
out the "dueling mandolins" recently posted here.   Take care, Doug
Re: [Mellotronists] Re: Solo trons
2007-04-22 by jeffc@netaxs.com
> what it's worth:
not to pick nits, but kraftwerk's TEE is actually an orchestron, and
not a mellotron. see:
http://www.optigan.com/tidbits.html#6
it's an easy one to mistake for a mellotron, and for years that's
what i thought it was also. another is popol vuh's "Aguirre". it
sounds like a mellotron choir, but it's some oddity called a
"choir organ" or something like that [or WAS it?]:
The music sets the tone. It is haunting, ecclesiastical, human and yet
something else. It is by Florian Fricke, whose band Popol Vuh (named for
the Mayan creation myth) has contributed the soundtracks to many Herzog
films. For this opening sequence, Herzog told me, We used a strange
instrument, which we called a 'choir-organ.' It has inside it three dozen
different tapes running parallel to each other in loops. ... All these
tapes are running at the same time, and there is a keyboard on which you
can play them like an organ so that [it will] sound just like a human
choir but yet, at the same time, very artificial and really quite eerie.''
this same sound seems to turn up on a number of german prog albums. makes
me wonder if it was in a studio that a bunch of these bands recorded at.
conny plank had a mellotron in his studio, and that turns up time and
time again on different records.
sorry... drifting off-topic for this thread...
...jeff
Re: Solo trons
and
>Re:   Thanks for that one Jeff, could that mystery choir be a
Roland 330 vocorder?
Back in the radio days when Kraftwerk brought out their 2nd lp, Man
Machine, we were playing "We Are The Robots" both on air, and in the
Clubs and got to see them in N.Y. courtest of Capitol, and I
remember seeing a 400 on stage, or so I thought. But who remembers
the 70's?  Doug
Solo trons
Thanks everybody but what I meant was actually playing one on it's own with no band at all rather than as a solo instrument. Does any body sit in their living room and just play on an M400, the Mark II s would I guess be more suitable as a solo instrument there can't be many M300's out there.
Mark
2007-04-22 by Andy Thompson
To: <Mellotronists@yahoogroups.com>
Sent: Sunday, April 22, 2007 8:09 PM
Subject: [Mellotronists] Re: Solo trons
> and
> the 70's?  Doug
Er, 'The Man Machine' was something like their 7th album, Doug... And while
they used an Orchestron extensively, there's also some 'Tron on
'Trans-Europe Express' - compare the two different string sounds. The
'choir-organ' seems to've been an early European one-off attempt to use the
Chamberlin/Mellotron idea, with infinite sustain. Also used by Amon Duul II.
Andy T.
M400 #1145
> and
nope.
i own one of those [bought it brand new many years ago] and
i know the sound quite well, and both of those recordings FAR
pre-date the vp-330 vocoder plus. though i DID actually buy it
as a mellotron substitute, thinking i would NEVER be able to
actually own one.
> the 70's?  Doug
jeez, i feel like real jerk for pointing this out too,
but "man machine" was not their 2nd lp. radioactivity,
autobahn, ralf and florian all pre-date man machine.
[i think even TEE was the release before that one]
[and there were 2 very rare and somewhat oscure releases
prior to ALL of them, plus the one called "organisation"
which was them before the name kraftwerk was theirs]
sorry man :=)
call me a jerk - it's okay.
i remember the 70s well enough to recall some amazing
drugs back then... but that's all in the distant past.
[hash oil? anyone remembr that stuff?]
i saw them in, i think it was, 1975 at the tower theatre
in upper darby pa, then again [year unknown] for the
computer world tour at a disco in new jersey. the 1975
show is a total blur [thanks to the drugs] so i have
no ideawhat theywere using [and i was not as into the
gear as i am now, or even was just a few years later]
the computer world tour was one in which all the gear
was built into a large semi-circular console, so other
than the "toys" used for pocket calculator, all of it
was totally obscured and hidden. the 1975 show was the
tour they did for autobahn - i recall hearing that track
played IN ITS ENTIRETY [all 22.5 minutes of it!] on a
radio station hear in philadelphia when it was new.
it changed my life forever.
[not necessarily for the better]
...jeff
[who needs to use the rubber conditionaer to annoy
the wife with, but i'll wait until she is over
her cold for maximum impact - see what a jerk i am?]
2007-04-22 by NormLeete@aol.com
In a message dated 22/04/2007 23:02:29 GMT Standard Time,
andy.thompson@... writes:
I thought it was a modified Mellotron...
Norm
2007-04-22 by L. Richards
Check out this solo multi-lead tune from Ken Leonard and Lee Richards from the Moneypit Feb '06 site.
Flute and choir from Lee's 400, strings and spanish guitar from Jerry Korbs Mark1. Just mellotron and Ken's Korg piano.
Not quite as famous as kraftwerk and King Crimson, but......
Enjoy
Aloha from Lee, and M400 #541
Sent: Sunday, April 22, 2007 10:41 AM
Subject: Re: [Mellotronists] Re: Solo trons
> and
nope.
actually own one.
> the 70's? Doug
sorry man :=)
...jeff
Re: Solo trons
--- In Mellotronists@yahoogroups.com, "Andy Thompson" <> Er, 'The
The
to use the
Amon Duul II.
> Andy T.
> M400 #1145
 Re:  My apologies for not doing Kraftwerk homework. Those were my
radio and club years and with all the records that came my way
really didn't have time for extensive research. Thanks for the info
though..Doug
Sent: Sunday, April 22, 2007 11:18 PM
In a message dated 22/04/2007 23:02:29 GMT Standard Time, andy.thompson@... writes:
Norm
Norm
What little I've been able to find out about it seems to indicate that it was built in the '50s! It also sounds unbelievably complex to play, making the 'MkII rhythms' technique dound like a doddle. :-) It allegedly resides in 'a west German museum' now, so if ANYONE has any idea which...
Andy T.
Re: Solo trons
2007-04-23 by charel196
let's not forget the "Singing Keyboard" from the 1930s, which was a tron/Chamberlin idea
using movie film as the medium and light to read it a/la Orchestron. I'd love to hear any
examples of it....somebody back then had to have made a recording....
--- In Mellotronists@yahoogroups.com, "Andy Thompson" <andy.thompson@...> wrote:
>   ----- Original Message -----
>   From: NormLeete@...
>   To: Mellotronists@yahoogroups.com
writes:
>   Norm
>   Norm
>   Andy T.
2007-04-23 by Bruce Daily
Hi, all-
   Thought I would throw another wrench in the fire
(probably replete with erroneous 70's memories, too).
It seems I read once that 10cc used a large multitrack
recorder to create a playable choir of their own
voices on the song "I'm Not In Love".  Once the vocal
tracks were laid down on the same area of tape, the
section was cut out, and spliced in a loop.  It was
loaded back on the machine (with appropriate tension),
and played off a mixing console using the solo buttons
as a keyboard.  I don't know where I read this, but it
stuck in my mind for years.  Maybe a similar idea was
used by those clever Germans.
   Bruce Daily
    M400 1221
P.S. I admit to playing my 'tron "solo" in my living
room (no mixer yet).  So far my friends just smile,
scratch their heads, and mumble something about "could
be done digitally".  Oh well, what do they know?  I'm
happy.
> >   From: NormLeete@...
> writes:
> sustain
> >   Norm
> >   Norm
> >   Andy T.
Do You Yahoo!?
http://mail.yahoo.com
2007-04-23 by jonesalley
I read that same information in an article in Rolling Stone that was
contemporaneous with the release of the album, and this was a pretty concise
summary of the explanation it contained.
> Hi, all-
2007-04-23 by JMoore6397@aol.com
I don't know if anyone can help me, but I have been searching Hi and Lo for an operators manual for an Oberheim OB1? I have googled it and get no luck. Oh buy the way, it sits atop my formicatron.
        Jimmy Moore
Sent: Sun, 22 Apr 2007 3:09 PM
and
the 70's? Doug
________________________________________________________________________
AOL now offers free email to everyone.  Find out more about what's free from AOL at AOL.com.
I'd set up a "favorite search" on eBay if you can't find it anywhere else. Manuals for just about everything seem to turn up, usually on CD-rom, as copies, or as PDF printouts. I gotta go make my email font a bit larger now. I thought for a minute you said it sat atop your fornication.
Jimmy Moore
2007-04-23 by lsf5275@aol.com
In a message dated 4/23/2007 3:47:42 P.M. Eastern Daylight Time,
JMoore6397@... writes:
Oberheim OB1
Nice!
Get it on ebay, Jim?
************************************** See what's free at http://www.aol.com.
I don't know about cutting the tape and using it as a loop.
-------I overlooked that part and no, I do not recall the loop thing, just that it was channels manipulated via faders.
2007-04-24 by chris.dale@primus.ca
I do know that they overdubbed around 100+ voices and that they played the faders for the volume swells in that song.
And of course, theyre using the Gizmotron for the cello sound and background noise as well. You can hear that same noise on the track Lazy Ways from the How Dare You album. It sounds interesting without the choir voices.
Chris
Hi, all-
Bruce Daily
M400 1221
happy.
> > From: NormLeete@...
> writes:
> sustain
> > Norm
> > Norm
> > Andy T.
Do You Yahoo!?
Re: Solo trons
2007-04-24 by Bernie
Sounds good to me! So much so that I popped over to CDBaby to order
a copy.
More samples:
http://cdbaby.com/cd/leerichards
Bernie
--- In Mellotronists@yahoogroups.com, "L. Richards" <surfbeach@...>
> Enjoy
> http://kleonard.com/mellotron/vt0206/recording.htm
>   From: jeffc@...
orchestron,
>   > and
that's
vuh's "Aguirre". it
>   nope.
>   actually own one.
lp, Man
in the
remembers
>   > the 70's? Doug
>   sorry man :=)
>   ...jeff
>   > Yahoo! Groups Links
2007-04-24 by NormLeete@aol.com
In a message dated 23/04/2007 22:41:57 GMT Standard Time,
chris.dale@... writes:
noise as well.
The Gizmotron, what a great idea. Shame the production version didn't live
up to the original prototype. I actually got to play the original once and that
 worked really well, all handcrafted and metal bits. Sadly the production
version  was plastic.
Norm
2007-04-24 by fdoddy@aol.com
I have a brand new, still in the box Bass Gizmotron that I plan to put on a frettless bass some day....now I just have to get a good bass, my current fretless is a piece of crap and I sold my 1969 fretless P-bass during a moment of insanity. I use to play fretless exclusively....sigh...the idiocy of youth
 Sent: Tue, 24 Apr 2007 5:45 PM
       In a message dated 23/04/2007 22:41:57 GMT Standard Time, chris.dale@... writes: And of course, theyre using the Gizmotron for the cello sound and background noise as well.   The Gizmotron, what a great idea. Shame the production version didn't live up to the original prototype. I actually got to play the original once and that worked really well, all handcrafted and metal bits. Sadly the production version was plastic.   Norm
2007-04-25 by pete
Nice track!I loved reading about the Wrap music coming over Lee's tron
heads and his way of fixing it!
Pete
> a copy.
> More samples:
> Bernie
>> Enjoy
2007-04-25 by chris.dale@primus.ca
Yes, that's the one I have and it's a bit of a pain to get it to work consistently all the time.
Also - I'm thinking that the cello sound and background noise I referred to are probably the same sound - the background noise being played at a slightly higher pitch with different tone. I've tried a few things recently that seem to suggest this. My apologies if this was confusing.
Some other interesting Gizmo tracks:
10CC - Old Wild Men
McCartney - I'm Carrying
There's more but that's in OT territory.
Regarding the mention of playing mellotron samples solo and having it sound week - this is my complaint about the tron sounds I've heard specifically in modern synths. An embarrassment to say the least.
If the so-called engineers who made these sounds spent any time playing the instrument and getting to know it instead of just hiring them in and doing the job quickly, it might make a difference.
Chris
Sent: Tuesday, April 24, 2007 5:45 PM
In a message dated 23/04/2007 22:41:57 GMT Standard Time, chris.dale@primus.ca writes:
Norm
Hey Fritz:
If you ever mount it, check the wheels really carefully. The problem I had with mine is that the wheels warp and twist on their axles, and will potentially ;break apart because they touch the strings unevenly.
I had to re-adjust all mine and it took a long time / much patience to do.
Good Luck!
Chris
Sent: Tuesday, April 24, 2007 7:13 PM
Norm
Re: [Mellotronists] Re: Solo trons and the 10CC endless vocals...
2007-05-02 by Jack Younger
Hello!
     This is a bit late in the game, but I only get to
this page every so often lately...
     As far as looped and tracked "10cc" vocals, it's
really quite easy and I've used it at the studio many
times for a pad of breathless vocals.
    My method is to track about five to ten seconds of
each note you want to a 1/4" or 1/2"  2-track.  You
can maximize by recording seperate notes one at a time
on each track.  Cut and loop it.  Play the loop back
to two tracks of your multitrack and record it through
the whole song.  Repeat the process as many times as
you have track space for and then bounce the whole kit
and kaboodle to two tracks for stereo, running the
faders according to the required performance.
     The result is striking.  I call it
"create-a-tron" and it can be used for many different
sound sources.
Good luck!
-Jack Younger  (EMI 103S -the Bastard 'Tron)
> a loop.
> the choir voices.
> Chris
>   Hi, all-
> too).
> multitrack
> vocal
> the
> tension),
> buttons
> it
> was
>   Bruce Daily
>   M400 1221
> living
> "could
> I'm
>   happy.
> it
>   > > From: NormLeete@...
>   > writes:
>   > sustain
>   > > Norm
>   > > Norm
> it
> play,
>   > > Andy T.
>   Do You Yahoo!?
> protection around
Do You Yahoo!?
2007-05-03 by gino wong
What were the mechanics and how practical or loopy were the loop tron
or trons that T Dream used back in the day ?
The mixer trick is  the most practical way to implement 10cc voice
choir thing becasue you'll never have enough machines, mike stands and
pencils to do it otherwise.
gw
On 5/2/07, Jack Younger <e4103s@...> wrote:
> Hello!
>  sound sources.
>  Good luck!
>  > a loop.
>  > the choir voices.
>  > Chris
>  > Hi, all-
>  > too).
>  > multitrack
>  > vocal
>  > the
>  > tension),
>  > buttons
>  > it
>  > was
>  > Bruce Daily
>  > M400 1221
>  > living
>  > "could
>  > I'm
>  > happy.
>  > it
>  > > > From: NormLeete@...
>  > > writes:
>  > > sustain
>  > > > Norm
>  > > > Norm
>  > it
>  > play,
>  > > > Andy T.
>  > Do You Yahoo!?
>  > protection around
>  Do You Yahoo!?
10CC endless vocals... Budget Gizmotron...
2007-05-04 by Jack Younger
Yup.  Just keep trackin' an' a-bouncin'!  Unless you
have 19 machines, of course.  Or protools, but where's
the fun in that.
Oh, and in reference to the Gizmotron, I've built a
couple of contraptions that give you a motor with a
felt wheel/s powered by a 9V battery and can secure to
the strap button for bowed effects.  Somewhat limited,
but good for certain things.  Definitely Rube Goldberg
type stuff...
-Jack
> were the loop tron
> gw
> > Hello!
> many
> of
> time
> back
> through
> as
> whole kit
> the
> different
> >  sound sources.
> >  Good luck!
> it as
> >  > a loop.
> voices
> the
> can
> from the
> without
> >  > the choir voices.
> >  > Chris
> >  > Hi, all-
> fire
> >  > too).
> >  > multitrack
> own
> >  > vocal
> >  > the
> was
> >  > tension),
> >  > buttons
> but
> >  > it
> idea
> >  > was
> >  > Bruce Daily
> >  > M400 1221
> >  > living
> smile,
> >  > "could
> >  > I'm
> >  > happy.
> the
> read
> >  > it
> have
> >  > > > From: NormLeete@...
> >  > > writes:
> the
> >  > > sustain
> >  > > > Norm
> >  > > > Norm
> about
> >  > it
> >  > play,
> in
> >  > > > Andy T.
> >  > Do You Yahoo!?
> >  > protection around
> >  Do You Yahoo!?
> protection around
> >  Messages in this topic (0) Reply (via web post) |
> Start a new topic
> >  Messages | Files | Photos | Links | Database |
> Polls | Members | Calendar
> >  Change settings via the Web (Yahoo! ID required)
> >  Change settings via email: Switch delivery to
> Daily
=== message truncated ===
Do You Yahoo!?
