O/T- TV synth sound effect question
2007-03-24 by charel196
Index last updated: 2026-04-28 23:09 UTC
Does anyone here happen to know what instrument was used to make the "bionic" sound effect (na-na-na-na-na) on the SIX MILLION DOLLAR MAN tv series? Thanks-
2007-03-24 by Colin Crawford
> "bionic" sound
> Thanks-
Just someone hitting an iron girder then put thru an Echoplex or
similar I reckon......
http://www.s-club.co.uk
Sundae Club*
PO Box 862
Cheltenham
GL52 2XT2007-03-24 by jonesalley
----- Original Message -----From: Colin CrawfordTo: charel196Sent: Saturday, March 24, 2007 2:09 PMSubject: Re: [Mellotronists] O/T- TV synth sound effect question
Just someone hitting an iron girder then put thru an Echoplex or similar I reckon......
Sundae Club*
PO Box 862
Cheltenham
GL52 2XT
2007-03-24 by Jerry Korb
Colin Crawford wrote: > On 24 Mar 2007, at 03:42, charel196 wrote: > > Does anyone here happen to know what instrument was used to make the "bionic" sound > effect (na-na-na-na-na) on the SIX MILLION DOLLAR MAN tv series? Thanks- > > Just someone hitting an iron girder then put thru an Echoplex or similar I reckon...... -------------------------------------------------------------------------------- Greetings Colin and Gang, One of most interesting SFX was the "death-ray" used by the Martians in 1953 sci-fi classic "War Of The Worlds." So good the sound was, that Paramount used the effect 13 years later for Star-Trek's photon torpedoes. I believe that sound was created by hitting a steel guy-wire for a huge vertical antenna. ....somewhere..... Was then post-processed thru some type of early reverb or delay . The Harry Chamberlin era...... Cheers, -- Jerry Korb (can only do the classic beer-belch, Bwwwaaaa! )
2007-03-25 by MAinPsych@aol.com
In a message dated 3/24/2007 11:23:56 A.M. Pacific Standard Time, jkorb@... writes: Greetings Colin and Gang, One of most interesting SFX was the "death-ray" used by the Martians in 1953 sci-fi classic "War Of The Worlds." So good the sound was, that Paramount used the effect 13 years later for Star-Trek's photon torpedoes. I believe that sound was created by hitting a steel guy-wire for a huge vertical antenna. ....somewhere.vertical antenna. ....somewhere.<WBR>.... Was then early reverb or delay . The Harry Chamberlin era...... Cheers, -- Jerry Korb (can only do the classic beer-belch, Bwwwaaaa! ) According to SFX guru Ben Burtt, the guy wire sound was used for the Star Wars blasters, and the Martian heat ray SFX was a processed electric guitar (the ray itself was a fan-directed acetelyne torch). This information is on the DVD versions of those respective (and respectable) movies. Frank 1 ************************************** AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com.
2007-03-25 by Jerry Korb
MAinPsych@... wrote:
> According to SFX guru Ben Burtt, the guy wire sound was used for the Star > Wars blasters, and the Martian heat ray SFX was a processed electric guitar > (the ray itself was a fan-directed acetelyne torch). This information is on > the DVD versions of those respective (and respectable) movies. Frank 1 > > > ------------------------------------------------------------------------------- > > > > I'll check my old Star-Trek books . I read about > the photon torpedo/Martian heat ray SFX long ago. > Before Ben Burtt appeared on the scene as SFX information source. > > > As mentioned, the WOTW heat ray SFX was two distinct sounds. > First sounding like Chrysler starter-motor as someone else > referred to it. It's the second one I'm discussing. The one which > was used later in Star-Trek. > > > I'm 95 % sure it was a steel guy-wire for antenna support > struck with metal rod. Why ? I tried this myself once, > after reading of it..... > > > Also, topic of ST-WOTW surfaced in discussion of the classic > episode "Balance Of Terror" (Kirk vs. Romulans ). First time > photon torpedos were used, but the SFX weren't dubbed-in yet. > Rendering a "silent" effect, viusal only. > > > Can any other Trekkies on our List assist me ? -- Jerry Korb
2007-03-25 by Doug Berg
> > > > > > I'm 95 % sure it was a steel guy-wire for antenna support > > struck with metal rod. Why ? I tried this myself once, > > after reading of it..... > > > > > >Re: If you think that makes a wierd souind....I was working a welded rail train not too long ago, they haul multiple lengths of rail on flatcars, the rail usually around 2000' and they unload it through rollers which guide it outward over the edge of the flatcar and down on the ground amd when they get to the end of one rail, they weld it to the next one and so on. When the welder strikes the rail it ricochets through the entire length making an eerie star wars kind of sound, like nothing I've ever heard before. Just happened to have my video camera as that is something that had to be saved, so imagine the guy-wire sound times xx!! Also worth mentioning, A&E did a Biography on Doug Trumbull, and most of the program dealt with how he created special effects,and remember one clip showing a Fairlight. Very interesting program. Doug
2007-03-25 by NormLeete@aol.com
In a message dated 25/03/2007 15:09:44 GMT Standard Time, caddyfam@... writes: and remember one clip showing a Fairlight The Fairlight mangles any sound put through it, but in a sensitive caring artistic way... Splendid. Norm
