Re: [Mellotronists] Re: Tron on Ebay... report on 1221 - 2nd attempt
2007-03-13 by tronbros@aol.com
In a message dated 13/03/2007 04:26:33 GMT Standard Time,
franzs@... writes:
John was able to inspect the machine. How do you buy these things from a long distance?Jeff
Dear All,
You have to assume that the 'tron on offer is NOT in full working
condition and just needs light adjustment. This is
NEVER the case. When you buy any mellotron/novatron you
must expect to invest in it further to get it to peak performance and this
almost certainly involves pinchrollers, pads, headblock service, tapes, service
to tape frame, service to audio, probably some type of servo upgrade and almost
certainly a new motor. Whether you buy from us, Markus or anyone else is
not the issue. It is naive to think an electromechanical device that has
hardly been serviced since it was created 35 years ago is going to be anything
more than a total disappointment in the first instance.
To sum up, buy any 'tron you can in the prior knowledge that acquiring one
is only the first step. There are many more hurdles before it can be truly
called a working mellotron.
Best,
Martin
STREETLY ELECTRONICS - All Things Mellotronic
www.mellotronics.co.uk
www.mellotronics.com
US East Coast Agent - Jimmy Moore jmoore6397@...
US West Coast Agent - Paul Cox pjc56@...
