Re: [Logic_Cafe] faders/volumes
2007-11-24 by GAmoore@aol.com
Are you referring to the output numbers near the vertical "led" meter? Those show how close you are to the maximum level for the track (if you go too high into the red, you'll get digital distortion). On the faders themselves they are showing how much amplification is being given to each track (there are two different ways logic will display these - in db or 0-127). A track has a certain volume, and the fader either makes it loud or softer - so the fader shows what that is - whereas the meter show the overall result. Similarly for the output fader which sums everything - you can boost or cut, and see the meter affect. > Within the strips for each track, I see the volume (on the left strip) > that was raised or lowered depending upon my tastes for each track. > > But what should the output settings be for each track? Does the > output number have to equal the volume setting? > ************************************** Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) [Non-text portions of this message have been removed]
