2005-06-18 by Robert Hedan
Aaron's site is back up by the way.
http://www.aaroncake.net/circuits/
I'm going over his schematic getting myself familiar with how things work
and I have a question concerning the motor wiring.
http://www.aaroncake.net/circuits/stepper.htm
There are 6 wires on a unipolar motor, 2 sets of 3 wires. The center wire
of each set appears to be a common power source. But how do you go about
deciding the order of the other wires in relation with the schematic?
Ok, I've uploaded a picture in the photo section of the group. I've created
my photo album and I can't figure out how to add a picture. It doesn't give
me the add photo icon like it does in the main photo section. It's a pic of
a unipolar stepper motor wiring. It should be easy to see, it's the only
pic there 'cause everyone else was smart enough to know how to upload pics
properly.
It's the order of the yellow/orange and black/brown wires that I'd like to
connect properly. I'd like to avoid creating any magic smoke if at all
possible.
Robert
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBs
If Files or Photos are running short of space, post them here:
http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
Yahoo! Groups Links
2005-06-18 by bob_ledoux
An ohmmeter is the easy way. Make a table of 6 rows and 6 columns.
Each row and column represents a colored wire. Take resistance
readings between each combination of wire pairs. Some readings will
be open. Other readings will show a resistance. The three wires
sharing a reading are a pair of windings. One wire will be a center
tap. Lets suppose two of the readings are about 100 ohms and the
third reading is 200 ohms. The two wires with the 200 ohm readings
are the end taps, and the other color shared by the 100 ohm readings
is the center tap.
--- In Homebrew_PCBs@yahoogroups.com, Robert Hedan <robert.hedan@v...>
center wire
about
schematic?
Nevermind, I've just noticed something on the schematic that matches the
wires with the motor wiring. Instead of trying to make heads or tails of
the colours, it's the drawing on the right of the motor wiring that held the
answer.
The 1st 4027 has Q and /Q, so that matches with A and /A.
The 2nd 4027 has Q and /Q, so that matches with B and /B.
Robert
-----Message d'origine-----
De : Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] De
la part de Robert Hedan
Envoyé : juin 17 2005 21:40
À : Homebrew_PCBs@yahoogroups.com
Objet : [Homebrew_PCBs] Unipolar stepper motor driver wiring
Aaron's site is back up by the way. http://www.aaroncake.net/circuits/
properly.
possible.
Robert
Yahoo! Groups Links
Yahoo! Groups Links
2005-06-19 by bob_ledoux
Once the two pairs have been identified, hooked them up to a
controller. Send the motor a control sequence activating each of the
coils. If the motor rotates, its hooked up correctly. If it doesn't
rotate correctly, reverse the end taps on one pair of the windings and
it should work properly. A full step (wave drive) sequence is probably
the easiest to use for testing.
--- In Homebrew_PCBs@yahoogroups.com, "bob_ledoux" <bobledoux@p...>
> is the center tap.
<robert.hedan@v...>
> center wire
go
> about
> schematic?
> > Yahoo! Groups Links
2005-06-19 by James Newton
<robert.hedan@v...>
center wire
about
schematic?
There is a lot of information about stepper motor wireing including
an
online "expert" system that helps you figure out the wireing based on
resistance measurements between the wires at
http://www.piclist.com/techref/io/steppers.htm
2005-06-20 by Robert Hedan
I've done what I believe are improvements to the 12V stepper motor driver
schematic I had in the Photo section. It's no longer there, I moved it to
the CNC folder of the Files section.
I've added opto-couplers between the CMOS chips and the transistors, lowered
the CMOS voltage down to 5 volts and increased the motor voltage to 24 volts
(which is what my motors are rated).
Comments please on the modifications.
Robert
Yahoo! Groups Links
2005-06-20 by Stefan Trethan
On Mon, 20 Jun 2005 14:59:04 +0200, Robert Hedan
> lowered
> volts
24V motors? they are going to have a lot of inductance and resistance.
Probably OK for simple drivers, but if you ever plan to use chopper
drivers you are looking for low voltage low ohms motors.
(The idea is to drive like a 3V motor with 30V, to quickly increase the
current in the motor to the level you want, and then reduce the drive
voltage. For speed.)
ST
2005-06-20 by Roy J. Tellason
> lowered the CMOS voltage down to 5 volts and increased the motor voltage to
> 24 volts (which is what my motors are rated).
What are you using for driver transistors there?
TIP31, I've included a parts list on the schematic in the CNC folder of the
Files Section.
Transformer 24V 1.5A
4070 XOR
4027 Flip-flop
MCT6 opto-coupler
1K 1/4W resistor
TIP31 100V 3A
1N4002 100V 1A
Steppers 24V, 36/72ohms, unknown amperage, obsolete model SP57B by COPAL.
Robert
Yahoo! Groups Links
2005-06-20 by Phil
maybe this has been discussed but why not use mosfets instead of the
NPNs? If you can turn them fully on they will run a lot cooler with
little voltage drop.
Also, how are you limiting current?
Will the 1N400x be fast enough to supress the spikes? I thought one
needed to have schottkys for that.
Reasons to use a PIC (or other micros) is so you can do microstepping
which makes for a much smoother running stepper and you can use PWM
(aka chopping) on the coils to allow higher voltage and thus more
power. But I'm sure that's all been discussed before. by the way,
some of the newer 8 pin Z8s have a tansimpedance amp build in for
current sense - perfect for a stepper controller. I'm thinking of
prototyping with one.
The allegro chips do this pretty well also and allegro is very easy
when it comes to samples. I'd look at the A3982, it's new and comes
in a soic package which is much easier to solder than the older A3977.
They'll send 3 units if you ask nice.
Phil
of the
> Files Section.
> 4070 XOR
> 4027 Flip-flop
> MCT6 opto-coupler
> 1K 1/4W resistor
> TIP31 100V 3A
> 1N4002 100V 1A
COPAL.
> Robert
Photos:
2005-06-20 by KD5NWA
Those puppies are faster than grease lightning, they use the structure used
by pin diodes. I use the 1N4007 to switch rf signals by controlling the bias.
>Phil
>of the
> > Files Section.
> > 4070 XOR
> > 4027 Flip-flop
> > MCT6 opto-coupler
> > 1K 1/4W resistor
> > TIP31 100V 3A
> > 1N4002 100V 1A
>COPAL.
> > Robert
>Photos:
> > Yahoo! Groups Links
>Yahoo! Groups Links
>No virus found in this incoming message.
>Checked by AVG Anti-Virus.
>Version: 7.0.323 / Virus Database: 267.7.8/22 - Release Date: 6/17/2005
Cecil Bayona
KD5NWA
www.qrpradio.com
'Never argue with an idiot. They drag you down to their level then beat you
with experience.'
2005-06-21 by Phil
why do most hbridges and stepper controllers use schottkys?
structure used
the bias.
> >Phil
> >of the
> > > Files Section.
> > > 4070 XOR
> > > 4027 Flip-flop
> > > MCT6 opto-coupler
> > > 1K 1/4W resistor
> > > TIP31 100V 3A
> > > 1N4002 100V 1A
> >COPAL.
> > > Robert
> >Photos:
> > > Yahoo! Groups Links
Photos:
> >Yahoo! Groups Links
> Cecil Bayona
> KD5NWA
> www.qrpradio.com
beat you
> with experience.'
2005-06-21 by Robert Hedan
"maybe this has been discussed but why not use mosfets instead of the NPNs?
If you can turn them fully on they will run a lot cooler with little voltage
drop."
'Cause the original schematic was configured with NPNs, 'cause MOSFETs
weren't included in alternatives and 'cause I lack experience in
substituting NPNs for MOSFETs. :) If you have a suggestion, please post a
pic, I'm a visual person.
"Also, how are you limiting current?"
See, this is something else I need more information. I have no idea what
you mean by limitting current.
I started with a schematic from Aaron's site which he had gotten from
someone else. I'm just trying to make the circuit stable to use the 24V
steppers that I happen to have on hand.
Robert
Yahoo! Groups Links
2005-06-21 by Stefan Trethan
> used
> bias.
That would be the first time i hear that. I was much rather believing the
1n400x is a slow rectifier diode.
Using the bias of a diode to switch rf does not require a fast diode, if
you don't need to switch fast.
I would like to know where you got that information, and maybe you should
look at the datasheets again.
ST
because they are faster. all switchmode/pwm circuits use faster diodes.
In the simple controller suggested there is no chopping, the frequency is
low, a 1n400x could be ok.
ST
2005-06-21 by derekhawkins
A blast from the past....Is the obsolete Allegro UCN5804 unipolar
driver that difficult to get these days? I found 3 in my parts box and
4 installed in boards here, using anything other than that for a simple
unipolar driver is a waste of time IMO.
http://www.allegromicro.com/datafile/archive/5804.pdf
diodes.
frequency is
> ST
Jameco, DigiKey and Mouser, my favorite suppliers, have none.
Gonna check the surplus places now.
Robert
Yahoo! Groups Links
This site has "pulled" UCN5804s for $3.50 each;
http://www.alltronics.com/linear_ic_list.htm
--- In Homebrew_PCBs@yahoogroups.com, "derekhawkins"
and
simple
> diodes.
> frequency is
> > ST
Check here;
> Robert
Photos:
Make that $6.50 each...
Robert
Yahoo! Groups Links
Look at the bottom of that page;
UCN5804B pulls
Famous stepper motor driver integrated circuit (spec sheet available
see our 93I002) these chips have been discontinued and are hard to
find. We lucked onto a pile of solder pulls and they are offered here
at a greatly reduced price. These trims have all been tested. Inquire
about 100 lot pricing.
25I001 Unit Price : $3.50
> Robert
Photos:
I'm blind, can't see the pulls. :D
But I did see another model: L6506D.
What do you think of that chip? Maybe it's more readily available, haven't
checked yet. I'm busy unpacking my pillow blocks. Woohoo!
Robert
la part de derekhawkins
Envoyé : juin 21 2005 10:45
Objet : Re: RE : RE : [Homebrew_PCBs] Unipolar stepper motor driver wiring
UCN5804B pulls
> Robert
Photos:
Yahoo! Groups Links
<http://www.jameco.com/webapp/wcs/stores/servlet/CatalogSearchResultView?lan
gId=-1&storeId=10001&catalogId=10001&searchType=k&searchValue=l6506d&categor
yId=106093>
If the link screws up, search for "l6506d" on the Jameco web site:
$4.25 DIP / $4.49 SOIC, new.
Is this IC as robust as the UCN5804?
Robert
UCN5804B pulls
> Robert
Photos:
Yahoo! Groups Links
Nevermind, it's not quite the same thing. It seems as if they broke down
the UCN5804 into various chips.
"The L6506/D is a linear integrated circuit designed
to sense and control the current in stepping motors
and similar devices. When used in conjunction with
the L293, L298, L7150, L6114/L6115, the chip set
forms a constant current drive for an inductive load
and performs all the interface function from the control
logic thru the power stage.
Two or more devices may be synchronized using
the sync pin. In this mode of operation the oscillator
in the master chip sets the operating frequency in all
chips."
Robert
Yahoo! Groups Links
2005-06-21 by Phil
frequency is
> ST
It was a rhetorical question, of course they are faster. It's
completely up to the designer what he wants to do but I'd be careful
and engineer for reliability. I wouldn't use 1N400x even though they
are practically free. The 1N400x will probably work most of the time
but I'd worry about extreme cases like a high speed stall or direction
reverse.
Also, I wasn't aware that the kickback waveform speed was related to
the drive frequency. I thought it was intrinsic to the driver and
windings (and mechanical design) of the motor. To be good enough, the
diode needs to let less energy though than can damage the driver (er,
shunt it off). The reverse recovery time of the diode needs to be
fast enough for that. Some energy will get through so the issues are
driving voltage and switching time. I've heard that typical
rectifiers have a Trr of about .5 uS. Unfortunately, this isn't
spec'd. Schottkys are in the range of 10s of nS so there is a big
gap. Unfortunately no one seems to document Trr on the spec sheets
for barrier schottkys, either. sigh.
Hmm, interesting theory, i would still think there is some relation to
drive speed.
For example, if you look at a relay, most wouldn't argue that a 400x is
not ok.
But your point makes sense.
Well, hopefully the diodes in the FETs will catch the mess (if FETs are
used)
ST
2005-06-21 by David P Harris
Allegro says they have replaced it with the 3967 and 3977.
Have a look here: http://www.allegromicro.com/sf/3967/
They might even send you a sample.
David
>UCN5804B pulls
Then buy them new for $6.50.
http://www.alltronics.com/stepper_motors.htm
93I002 $6.50 each
haven't
> Robert
wiring
> UCN5804B pulls
available
here
Inquire
> > Robert
and
> Photos:
> > Yahoo! Groups Links
Photos:
93I002 $6.50 each
haven't
> Robert
wiring
> UCN5804B pulls
available
here
Inquire
> > Robert
and
> Photos:
> > Yahoo! Groups Links
Photos:
2005-06-21 by uhmgawa
> drop."
Mosfets will work just fine. You'll need to assure
sufficient drive voltage in the case of an H-bridge
for the upper N channel mosfets. This means needing
somewhere between 2-10V greater for the drive than
the mosfet is switching. Same issue exists for NPN
bipolar drivers though not as severe. For unipolar
steppers this issue doesn't exist.
BTW the discussion of external suppression diodes for
mosfets is likely moot for devices where an internal
parasitic diode is present. The main reason to add
an external schottky in SMPS designs is that of
efficiency as the voltage drop across the internal
diode is typically greater than available via the
external schottky.
If you want to drive a stepper at maximum possible
velocity it requires a high drive voltage to the
coils. This voltage is only needed initially in
the cycle and in fact if allowed to be imposed
statically on the windings will cause excessive
current consumption and quickly overheat the works.
One of the techniques to achieve this voltage profile
is a constant current scheme which limits the steady
state winding current to a nominal value but will
allow the highest available drive voltage to be
applied initially in the step cycle.
uhmgawa@... www.gnu.org
2005-06-21 by JanRwl@AOL.COM
In a message dated 6/21/2005 9:10:54 A.M. Central Daylight Time,
robert.hedan@... writes:
why not Google Allegro's web-address, and ask them for distributors!
2005-06-21 by Bill Maxwell
Using IN4007 diodes as pin diods is a quite a well known ham radio trick
Stefan.
Bill
Sent: Tuesday, June 21, 2005 4:18 PM
Subject: Re: RE : [Homebrew_PCBs] Unipolar stepper motor driver wiring
>> used
>> bias.
> ST
> Photos:
2005-06-22 by Robert Hedan
Thanks David,
But the 3967 and 3977 are designed for bipolar steppers. I've requested a
sample of 3967 for testing on another application, but they don't help me
with my unipolar steppers.
Robert
David
Yahoo! Groups Links
My surplus source has the UCN5804 in stock. I'm waiting for a reply with
prices.
I know I'm going to get a batch of these babies. I know unipolar steppers
are on their way out, but there are still a lot in circulation.
Robert
Yahoo! Groups Links
I picked this up from the Gecko group. We will have a problem with the
power cables to the motors and must take some preventive action. Here's the
answer:
> I just found out today that whenever I have my Bridgeport with 201
> drivers turned on all AM radios in the building next door have a squeal
> that is so loud that no one can listen to them . OOOPS ! Talk about
> being a bad neighbor !
> I tried a jumper lead from the machine body to the metal box that the
> drivers are in and it helped a good bit .
> Any good ideas for RFI .
Here's what will 'take you off of the air':
1) Run your motor leads thru a 5-conductor shielded cable. 4 leads are
for the motor connections, the 5th conductor goes to the motor case,
the other end goes to the drive's power supply GND (term 1).
Ground the shields to your control box 'single-point' ground location
(usually the '-' terminal of your big filter cap). Leave the motor end
of the shield unconnected.
2) Use an AC line filter (Corcomp or similar) on the 115 VAC going into
your control box transformer.
It'll then be as quiet as a baby. No, wait; that's not a good analogy...
The Gecko Yahoo group focuses on the Gecko CNC controller/driver system.
You can get more information about them here:
http://www.geckodrive.com/products.htbml
and here:
http://finance.groups.yahoo.com/group/geckodrive/
Just remember to say I sent you so that I can collect my regular 50% cut on
all future sales.
Robert
:D
Yahoo! Groups Links
2005-06-22 by Stefan Trethan
On Wed, 22 Jun 2005 01:55:06 +0200, Bill Maxwell <wrmaxwell@...>
> Stefan.
> Bill
I am not into radio, but i thought a PIN diode is used to get a variable
capacity by changing the bias point.
This does NOT require a fast diode, the bias is changed quite slowly.
I do not doubt it can be used as pin diode, but this does not make it a
fast diode.
a 1n4007 is a slow mains frequency rectifier diode.
ST
On Wed, 22 Jun 2005 08:06:00 +0200, Robert Hedan
> steppers
> Robert
I wouldn't be too sure 'bout that.
By the way, you can use a unipolar stepper in bipolar mode as 2 phase
motor. I've heard it works well.
ST
On Wed, 22 Jun 2005 08:32:17 +0200, Robert Hedan
If you use the 24V steppers and no chopper driver you probably will have
much less problems anyway.
I've pulled the shield from cables in the past, if you compress the mesh
together it gets rather wide and you can slip it onto existing cables, if
you can't find the right shielded one.
ST
2005-06-22 by Bill Maxwell
That's true Stefan and I now see the point you were making. My response was
mistaken in thinking you had not heard of the IN4007's PIN function. Sorry.
Bill
Sent: Wednesday, June 22, 2005 4:56 PM
>> Stefan.
>> Bill
> fast diode.
> ST
> Photos:
On Wed, 22 Jun 2005 10:35:35 +0200, Bill Maxwell <wrmaxwell@...>
> was
> Sorry.
> Bill
Indeed i had not heard of it, and it is good to know.
But fast it isn't, which you already knew as i see now.
ST
Uh, change in plans. I've been fiddling around with the 24V motors I have
on hand and they appear to be VERY demagnetized. I didn't notice this until
I picked up a set of smaller steppers and noticed a drastic difference in
resistance.
So now I have to get myself decent steppers. I'm not going back to the
local surplus store, I'll just get the same problem (dozens of steppers all
piled in the same box). I'm going to buy larger motors for the CNC machine
later, but for now, I'm looking for decent intermediate motors that will
make my drilling station work as well as machine wood and plastics.
I was checking these pulls from Xylotex:
http://www.xylotex.com/DoubleStepper.htm
Problem is now I have to reconsider a totally new driver circuit 'cause
these are bipolar steppers. Can I modify my schematic without TOO much
trouble? Or am I better using a new design?
Argh, back to square one...
Robert
(schematic in the CNC folder of the Files section of the group.
Yahoo! Groups Links
Darn,
It seems the circuit I had for unipolar steppers can be wired for bipolar
steppers as well. I found a copy of it here, but there's just one problem:
Figure 9.1: http://eio.com/jasstep.htm#translators
"I think when you reverse direction and continue stepping, the motor will
advance 1 more step in the previous direction it was going before
responding."
Ugh...
Robert
Yahoo! Groups Links
2005-06-22 by uhmgawa
You are likely thinking of a varicap which
has a change in capacitance of about 2x
when the DC bias imposed upon it varies over
a 0 to ~30V range.
Actually all diodes exhibit this "variable
capacitance" effect, though varicaps are
specifically designed to do so.
2005-06-22 by Alan King
> resistance.
LOL.. If by 'resistance' you mean cogging, that has nothing to do with being
demagnetized. Short all the wires on one of your motors together, and see if it
isn't pretty damn hard to turn.
You should forget these and get some 5V 1A or so motors, but for other
reasons rather than this.
They're usually in a can, and even if they weren't just tossing them in a box
isn't likely to demagnetize much of anything. They're shipped in boxes of 50 or
100, about as close as just tossed together.
Probably better to find some good solid 5V unipolar motors and get using them
until you've learned a bit more about steppers in general. Some of it simply
comes from getting and using all types, start simple.
Alan
Robert Hedan wrote:
> Darn,
> responding."
That is "bi-directional", as in turning the motor both ways, vs only one way
in the circuit above it. Have to keep your 'bi-'s straight, nothing to do with
running a bipolar motor, that takes two full H-bridges as in his fig 6.1. Stick
to unipolar until you have a better handle on what you're doing, bipolar has
advantages but you don't need them to start and it takes twice as much to drive,
plus other problems in the driving.
Also note that anyone can read a few other people's web pages, draw up a
circuit or two, and look like they know what they're doing in five minutes.
Says more to their web page creation skills than anything else really. 7486 is
typically a 5V chip. The upper transistors will only pull up to 5V, with more
power wasted in them than making it to the motor with a 12V supply. In other
words a crap draw up, likely it was copied from somewhere else with changes and
only a partial understanding of what's going on.
While 90% of the info on most of these basic stepper motor type web pages is
correct, 90% or more of them also have a notable error or two. It's easy to get
the basics and make a web page, but relatively few of the people who do that
tend to have a good understanding before they make their pages. Don't count on
any of them being 100%.
Alan
> ST
Have to be careful with this though, four coils on instead of two, so you
have to make sure your motors are designed to run that way as well. More than a
few will overheat if you use full power in all four coils. Definite improvement
for the ones that can run this way though.
Alan
IMHO steppers are a rather brute-force way to
address a limited set of applications. If all
you need are simple open-loop indexed positioning,
minimal/moderate static holding torque for gratis,
but without much of a velocity/torque range,
steppers will fit the bill.
I'd spend some time looking at a DC motor approach
with shaft encoder positional feedback. As a
back of the envelope estimate a 28TPI lead screw
combined with the optical encoder scavenged from
a $3 mouse can give you positional accuracy in
the 0.001" range. Physical drive requirements
take the form of a simple H-bridge without the
gyrations needed by steppers.
You aren't likely to find anything off the shelf
to address the drive and closed loop control but
nearly any uC controller will due. Direction and
velocity of the motor are proportional to the average
energy seen by the motor and is driven via PWM.
As with all but trivial stepper designs you'll need
to address velocity ramp up/down. And if needed,
an algorithm to emulate static hold of the motor
position. Though with a lead screw of sufficient
pitch and its inherent friction this may be
unneeded or at least trivial.
2005-06-22 by derekhawkins
>other reasons rather than this.
That's exactly what I found in one of my storage boxes in the garage
over the weekend. Found three 5V 1A unipolar steppers that were
hooked up to a board with three UCN5804 drivers. The power supply was
30V and there were 25 ohm high wattage resistors in series with the
coils. A poor man's substitute for chopper drives. Built this around
5 years ago. I'll probably dump these on E-bay someday.
--- In Homebrew_PCBs@yahoogroups.com, Alan King <alan@n...> wrote:
motors I have
this until
difference in
> > resistance.
do with being
and see if it
other
to the
steppers all
CNC machine
that will
plastics.
them in a box
boxes of 50 or
circuit 'cause
TOO much
get using them
it simply
> Alan
> external schottky.
The main reason for schottky is to make sure it turns on and takes the heat,
if it is not schottky then the internal diode may turn on instead and the extra
dissipation will go back into the transistor. Very important it goes through
the right one in a high powered circuit that's being run near the transistor's
limit to start with.
Oversize the FETs, make sure they have the intrinsic reverse diode, and
forget about extra reverse diodes. Big FETs will easily deal with 5 or 8 V, 1
or 2 A steppers if everything else is correct, without any extra parts helping out.
99% of general failure blown FETs come from blowing the gates either through
poor handling or poor drive, and then get blamed on every other possible failure
idea under the sun. Difficult to even blow them on purpose after they're in a
proper circuit. Always install about everything else first, then the
transistors. You'll easily damage the gates in handling the board if they're
installed first and the rest of the gate circuit isn't in place.
Alan
Just like those fooling around with toner transfer now will someday
move on to photoetching so will those on steppers now move on to DC
servos. Seems to be a natural progression, at least it was for me.
--- In Homebrew_PCBs@yahoogroups.com, uhmgawa <uhmgawa@m...> wrote:
circuit 'cause
TOO much
> uhmgawa@m... www.gnu.org
"That is "bi-directional", as in turning the motor both ways, vs only one
way
with
running a bipolar motor, that takes two full H-bridges as in his fig 6.1."
D'oh! I knew I should have gone to bed instead of kept on researching this.
"While 90% of the info on most of these basic stepper motor type web pages
is
correct, 90% or more of them also have a notable error or two."
And that's why I only 'add' to existing circuits. :) Putting in
opto-couplers and protection diodes does nothing to the overall performance
of a circuit. Either it worked to begin with, or it didn't.
I learned this real quick by reading a thread in Aaron's forum. Check it
out for yourself:
<http://www.aaroncake.net/forum/topic.asp?TOPIC_ID=2996&FORUM_ID=18&CAT_ID=1
0&Forum_Title=Power+Supply&Topic_Title=12%2F120V+inverter+again>
I needed an inverter to power the backlight of a LCD and started reading
that to find a decent schematic. 13 pages later and I still don't have an
answer, the worst mumbojumbo I've ever read anywhere, it just goes on and
on...
And that's why I show you folks these circuits. I'd rather listen to your
opinion, than buying things that won't work with money I don't have.
Robert
Yahoo! Groups Links
2005-06-22 by Steve
Would it be easier to just use the L297/L298 combo? Together they do
PWM limited current and half-stepping. They are bipolar internally,
but it's all inside the package.
Steve Greenfield
"LOL.. If by 'resistance' you mean cogging, that has nothing to do with
being
if it
isn't pretty damn hard to turn."
Yeah, I guess I meant cogging. None of the 6 steppers I have showed any
effect whatsoever from shorting all the wires, both unipolar and bipolar
(1).
"Probably better to find some good solid 5V unipolar motors and get using
them
simply
comes from getting and using all types, start simple."
I have some 3967 Microstepping Driver with Translator coming as well as
UCN5804s. The 9V Stepper400 from Melnick is interesting.
robert
Yahoo! Groups Links
2005-06-22 by Mycroft2152
Hi Robert,
Did the same thing, ordered the Steppr400's and 5804's
from Nelnick.
Good price for them ($6.99), worth $20 bucks to try
them out.
Al C
> being
> if it
> (1).
> them
> general. Some of it
> simply
> simple."
> interesting.
> robert
> them here:
Do You Yahoo!?
http://mail.yahoo.com
"Have to be careful with this though, four coils on instead of two, so you
than a
improvement
for the ones that can run this way though." - Alan
Nah, gonna go with the herd :D and stick with unipolar steppers for this
first machine. I'll probably move up to bipolar for the CNC version. Right
now with the 'discovery' of the UCN5804, things seem to be a breeze to get
going, economical to start up and difficult to screw up.
This drilling station is to help me save time when I fabricate PCBs. It was
not meant to be a project to take my attention for several weeks. Yeah
right, famous last words...
Robert
Yahoo! Groups Links
The discrete driver contained in "stepper_driver_mod.JPG"
can be modified for bipolar drive by creating a totem
pole structure of an upper PNP and lower NPN device.
E of PNP to V+, C of PNP + C of NPN becomes the drive
output, E of NPN to GND. You will need a means to
drive B of the PNP devices opposite polarity w/r/t
the NPN devices.
One of these structures will be needed for each of the
four leads of the bipolar stepper resulting in a
total of 8 driver devices. Do you actually intend to
drive 28V rated steppers off this design or are you
intending the higher voltage to enable faster stepping
rates? If the latter you will need some means of
current control to avoid overheating the windings.
Concerning the transistor base drive you might want
to check the gain (hfe) available and verify if the
optocouplers and added series resistance results in
sufficient base drive current.
Though the circuitry is minimal from a gate count
perspective, I'd prefer to see a single uC package
displace the 2 SSI packages and buy the design
flexibility of control software. IMHO I'd toss
the steppers along with half of the required driver
transistors, constant current source, add the
positional feedback and DC motor, and create if you
will a "digital motor". You are going to need the
the control software to run somewhere and pushing
it to a dedicated uC for each drive motor can
greatly simplify the implementation.
2005-06-22 by Steve
Please trim the quoted parts.
To be specific, that is true only of the 1N4007. It's my understanding
that the other lower voltage 1N400x series are not the same.
Steve Greenfield
structure used
the bias.
Another benefit of closed loop control is the ability to
detect/correct positioning errors which isn't possible
with an open-loop stepper approach. If the stepper-driven
drive mechanism hits a friction snag and misses a step(s)
you are going to be cutting somewhere you'd rather not.
Additionally it is possible (perhaps even preferable) to
avoid direct drive of the lead screw by the DC motor and
pick up low speed torque in the process. This speed reduction
can be implemented as a "belt drive" from motor to lead
screw with no loss in positional accuracy when the encoder
remains on the lead screw. Note depending upon the torque
required the "belts and pulleys" can be as low-tech as
those found in consumer electronic devices. i.e.: scavenging
a few scrap VCRs will supply the needed prototype components.
On Wed, 22 Jun 2005 16:30:02 +0200, derekhawkins <derekhawkins@...>
Imagine that, i did photoetching for years and moved to toner transfer,
and couldn't be happier about it.
DC servos are not the answer to a simple drilling machine for sure, as the
controllers are unnecessary complicated.
But we all have our opinions.
ST
2005-06-22 by Phil
is
> not ok.
Agreed. I use them for relays and haven't blown a driver yet (famous
last words). I think the reason is because there is very little
mechanical energy in the relay. A motor with permanent magnets acts
as a generator so you have both the field collapse emf and the rotor's
mechanical energy. Given a high speed stop, I'd bet there is more emf
from the mechanical energy than the field collapse. Again, its not
just about switching speed but about the amount of energy that doesn't
get shunted off.
What I don't know is how to calculate when its safe to use slower
diodes and when not. So I err on the side of safety.
2005-06-22 by Roy J. Tellason
On Tuesday 21 June 2005 03:49 pm, uhmgawa wrote:
> BTW the discussion of external suppression diodes for mosfets is likely moot
> for devices where an internal parasitic diode is present. The main reason
> to add an external schottky in SMPS designs is that of efficiency as the
> voltage drop across the internal diode is typically greater than available
> via the external schottky.
This is the second post I've seen so far that seems to suggest that it's okay
to rely on the internal diodes in mosfets. The general consensus in other
lists seems to be that this is _not_ a real good idea, for a number of
reasons. One of those is that those internal diodes don't have very
consistent characteristics, and another is that they turn on too slow, and
turn off too slow, which will tend to make the device run hot. Since heat
is an enemy of semiconductors, I'd tend to go with the external diodes,
myself.
2005-06-22 by lcdpublishing
There is no question about it, servo motors are better than
steppers, but at a cost. True servos are much more expensive than
steppers of equal power. Servo drives are much more complicated to
build (or purchase) than stepper drivers. Steppers natural
attribute of "Stepping" is perfect for easy control via logic. Most
of the low-end servo drives try to replicate the functionality of a
stepper drive (Step and direction).
I will convert my router to servos someday, but when I finally hit
the limitations of my current stepper motor driven system.
For a simple drilling (and even milling) machine for circuit boards,
you really can't beat a stepper system for simplicity and cost.
Heck, if my $50.00 200 Oz. In. stepper motors can drive my router
(chewing through hard maple), milling a circuit board or drilling
one is a piece of cake.
<derekhawkins@y...>
someday
DC
me.
transfer,
sure, as the
> ST
2005-06-22 by Phil
that's a decent solution but I hate the L298's pin arrangement - makes
prototyping a PITA. Prototyping with mosfets is pretty easy as long
as you get the drivers right.
By the way, I'm a big fan of using SPICE to figure out what this stuff
does. I can read theory till I'm blue and not get it but fiddling
with a SPICE emulation gives me a real feel for how the theory
relates. Highly recommended, in some way, better than putting
together real components - a LOT cheaper, changes are fast and you can
see how current and voltage interrelate in your circuit. It helped
demystify mosfets for me. Wish I knew how to simulate BEMF, though.
--- In Homebrew_PCBs@yahoogroups.com, "Steve" <alienrelics@y...> >
> Steve Greenfield
2005-06-22 by Phil
as the
While I'm reluctant to recommend servos for cost reasons, I think they
can be done at about the same complexity level provided one is
conversant with microcontroller design and programming. They are more
reliable as open loop steppers can miss steps in some circumstances
and the encoder always tells you where you are.
2005-06-22 by Phil
--- In Homebrew_PCBs@yahoogroups.com, "Roy J. Tellason"
it's okay
other
slow, and
Since heat
diodes,
> myself.
agreed. even if they switched fast, there would be dissipation IN THE
MOSFET. Distributing the heat dissipation is a good thing.
2005-06-22 by Dave Hylands
For what it's worth I'm using unipolar (6 wire) steppers (the stock Sherline
steppers) on my milling machine, and they're being driven by a Xylotex board,
which uses the Allegro 3977 chip (bipolar driver) using 1/8 steps.
I have them wired up such that I'm only using 2 of the 4 coils. I'm currently
running the X & Y axis at 20 IPM which corresponds to 400 RPM (cause I have
20 tpi leadscrews). This works fine for machining purposes, so it should be
more than adequate for drilling.
If you decide to go with two coils in series, then you need to drop the
current by half (you wind up getting the same amount of torque, but the
increased resistance lowers your high end speed).
By adding some vibration dampeners (see the files section of
http://groups.yahoo.com/group/ComputerControlledMotion/) Jeff was able to get
90 IPM using a similar configuration.
> -----Original Message-----
> From: Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of Alan King
> Sent: Wednesday, June 22, 2005 6:37 AM
> Subject: Re: [Homebrew_PCBs] Unipolar stepper motor driver wiring
> as 2 phase
> > ST
> of two, so you
> well. More than a
> Alan
> lists seems to be that this is _not_ a real good idea...
It depends upon the design. Certainly the intrinsic
diode isn't typically as well characterized as a
discrete diode (though I've seen exceptions to this)
nor typically as fast as schottky types.
But unless there is a overriding cost/performance
reason reason to add an external shunt diode the
intrinsic diode is often sufficient.
The energy being dissipated by any diode in an
inductive shunt role is going to be much less
than a diode used to free-wheel current in a
switching regulator application when the switch
device is off. It is the latter case where the
total switch device package heat dissipation is
of consequence and indeed where external diodes
are routinely employed.
>as the controllers are unnecessary complicated.
I wouldn't consider three ICs complicated...Even simpler than most
stepper drives. No doubt you're thinking of yesterday's controllers
like the ever popular Geico 320.
<derekhawkins@y...>
someday
DC
transfer,
as the
> ST
> as the
Agreed. I was assuming we are talking about
"midnight engineering" here rather than looking
for a $ervo motor off the shelf. I'd expect the
lab-built "digital motor" approach to be less
than the cost of a roughly equivalent stepper
solution as viewed by total system cost.
Heck, if you can do a 3 IC circuit to drive servo motors, please post
it! That would be simple and cost effective and I for one would love
to see it (make it & use it).
Thanks!
Chris
>I'd expect the lab-built "digital motor" approach to be less
A new shaft encoder can be had for $19.00 these days. Adding
a "second shaft" to any surplus DC motor is a piece of cake if you
have access to and know how to use a mini-lathe...Or buy a surplus
motor with encoder. H-bridge ICs are around $5.00, microcontroller
around $3.00...Here's what's missing....Good PID code for the
micros....Right now it's under lock and key but will soon trickle
into the public domain.
sure,
> > as the
they
more
circumstances
No way, there's money to be made. BTW, one of the ICs is just a chip
resistor.
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
most
controllers
post
love
> Thanks!
> Chris
Do you have a source for those shaft encoders that are $19.00 each?
The cheapest I have found is from US Digital and they are around
$35.00 or so.
Chris
Well I guess that won't help anyone else will it, so it's a mute
point.
post
love
chip
> resistor.
> most
> controllers
> post
> love
> > Thanks!
> > Chris
Same place but they're limited to 300 CPR;
http://www.usdigital.com/products/e4p/
> $35.00 or so.
> Thanks
> Chris
> motor with encoder.
For lead screw applications I'd keep the encoder on
the screw. Doing so allows the screw to be driven
indirectly and velocity/torque/rotational-precision
to be scaled via simple friction coupling without
introducing slippage error.
You can cut an encoder disk with a lathe but it would
be easier to print such on transparency film via laser
printer. Postscript programs to do so are floating
around. Tap Don Lancaster as he is a likely source
for such sundries.
Though I wouldn't bother initially. 36-segment photo
interrupter disks and associated dual element quadrature
IR detectors can be ransacked from a cast off PC mouse.
And two are employed for use in X and Y axis encoding.
While 36 segment seems rather coarse, it is quite usable
directly with a lead screw pitch of 24-28TPI.
Other sources for interrupter substitutes would be gears
reclaimed from defunct consumer items (mechanical clocks,
VCRs, walkmans, etc..). The more difficult thing to
scrounge is the dual channel IR photo-interrupter used
for quadrature detection thus my suggestion of using
a mouse.
Don't hang onto that key too long. Experience has
proven the benefit of community development and
support
2005-06-23 by derekhawkins
A DC gearhead motor is best for lead screw applications as it allows
the screw to be driven "directly" without any complications provided
speed and torque requirements are met. It doesn't get much simpler
than this;
http://www.pbase.com/eldata/image/45200286
http://www.pbase.com/eldata/image/45200509
2005-06-23 by uhmgawa
> than this;
Depends upon what one is trying to accomplish.
A direct coupled gear head approach is certainly
straightforward if somewhat of an expensive option.
Then again there is the backlash in the gear train
which needs to be factored-in when making fine
adjustments via changing direction to minimize
over travel. There is also the need to align both
axises within a given tolerance to minimize bearing
wear. These tend to be non-issues with frictional
coupling.
BTW what type of rotational velocity are you
getting out of this setup? Actually the linear
velocity is of more interest. Hard to gauge from
the jpg but the lead screw appears to be ~10TPI?
I wouldn't consider $15.00 - $30.00 for a gearhead motor expensive.
You can get one with encoder for $29.00.
A fraction of the lead screw backlash. Better than using belts
(toothed or friction). Backlash at reversal is handled in software.
This is a drilling setup, spurious movement in the backlash dead
zone like with milling or routing isn't an issue.
>wear.
Use shims and a dial indicator or use a flexible coupling. I prefer
proper alignment and rigid couplings. Yeah, machining and metal
working savvy is beneficial.
>Actually the linear velocity is of more interest.
20 IPM for a 12" X 8" travel. The milling table weighs 64 lbs.
Drills 18 holes per minute (6" X 4" matrix).
allows
provided
simpler
> > than this;
> coupling.
A flexible coupling will introduce error as
the encoder in this example is on the motor shaft
rather than the lead screw.
Coaxial alignment of two shafts is at best an
approximation irrespective of the machinist's
savvy or methods.
That's why rigid couplings are preferred and being used in this case.
>savvy or methods.
Have you really looked at your advice and comments?....They're a
hodge-podge of discrepancies....On one hand you're suggesting that
one make their own encoder including the disk itself, and now here
you seem to be critical of shafts aligned within the runout of the
shafts themselves...Yes, plus or minus one or two thou is an
approximation...In terms of specifications and tolerances, we live
in an approximate world....LOL!
prefer
> savvy or methods.
2005-06-23 by lcdpublishing
> than this;
Sure it does, eliminate the ball screw and coupling and switch over to
a linear motor - that is much simpler! However, in reality, much more
expensive too :-(
Yes.
> They're a hodge-podge of discrepancies....
They were intended to be a set of alternatives.
> On one hand you're suggesting that one make their own encoder
I offered that as a realistic possibility. It is.
Not everyone in this forum is able to reach for
a shaft encoder off the shelf. If you are able
to do so that's swell.
> and now here you seem to be critical of shafts
> aligned within the runout..
I didn't say it was not possible. But rather was
contrasting the pros/cons of the available approaches.
You are obviously quite proud of your handiwork and
I did not intend to pooh-pooh your implementation.
On a general note, I'd like to point out the "homebrew"
nature of this group. The intention here is to exchange
ideas and resources with the intent of finding viable
solutions within the means of the "midnight engineer".
I think most here would agree off-the-shelf
preengineered components when available make
for a fine solution. But this is not always feasible
and perfectly suitable homebrew approaches do exist.
Finding them is the collective goal here.
>to a linear motor - that is much simpler! However, in reality, much
>more expensive too :-(
So you consider $25.00 for a 250 RPM gearhead motor with 250 oz-in
stall torque expensive too? That's what was paid for the one's I'm
using.
allows
provided
simpler
> > than this;
over to
more
> expensive too :-(
> using.
No, I don't think $25.00 for that motor is too expensive. I am saying
that your way is not the MOST simple way to create linear motion. A
linear motor has no moving parts- it doesn't get any simpler than that.
