Re: [Homebrew_PCBs] Re: Questions about toner transfer method.
2004-10-07 by Alvin Rose
>A way to do make your own PCBs and be successful at it:
>1. A certain laminator previously mentioned on this forum.
>2. Staples paper.
>Just a reminder for people needing direction.
>Mike
>Be sure to visit the group home and check for new Bookmarks and files:
>http://groups.yahoo.com/group/Homebrew_PCBs
>Yahoo! Groups Links
2004-10-13 by Bob Weiss
2004-10-13 by Phil
--- In Homebrew_PCBs@yahoogroups.com, "Bob Weiss" <BWeiss@p...> wrote:
> Hello,
> I am trying to make a pcb using the toner transfer method and have a
> couple questions regarding it. I hope someone can shed some
> expertise on them for me.
> 1) I purchased the Staples picture paper and printed a pattern out
> on my Laser printer but I am unsure as to which side to print on. I
> am assuming that you print on the glossy side but after doing that
> and ironing it on a clean acetoned PCB the pattern seemed to
> transfer to it but its not as dark as I have seen on some websites
> and some traces are broken in the middle. My trace width is .020
> which is not that thin. So I thought maybe I am using the wrong side?
> 2) How long do you heat the paper for? I tried it for at least 1
> minute to where it was so hot it sizzled in the water. The back of
> the paper was turning yellowish from the heat but maybe it needs to
> be longer? It peeled off pretty easy and it left a whitish substance
> on the traces which I am assuming is paper. I scrubbed that off but
> the traces like I said are kindof weak.
> Thanks again for all your help!
--- In Homebrew_PCBs@yahoogroups.com, "Phil" <phil1960us@y...> wrote:
> I think people print on the shiney side. The transfered traces
should
> look black (well, actually a very very very dark blue). If you see
> copper through them, you aren't getting enough on.
> you should try etching the board. That's the real test. You will
> know if you are getting enough toner down.
> How "thick" is the toner on the paper before you iron? How much
toner
> is left on the paper after you peel it off? You should have
little to
> none left on the paper. I've had poor luck with the picture/photo
> paper - my traces were getting crushed and widened. I much prefer
> inkjet paper - much cheaper and very tolerant of different degrees
of
> pressure.
wrote:
> > Hello,
have a
out
on. I
that
websites
side?
of
to
substance
but
2004-10-14 by Phil
> Thanks for answering me, there was a couple spots very small that
> stayed on the paper when I pulled it off. I am assuming I didn't
> heat it long enough or press hard enough. When you say inkjet paper
> which brand are you using? Is it like regular white ream paper or
> special stuff?
2004-10-19 by Bob Weiss
> You've probably got a decent transfer. etch it, dano.
> For inkjet paper brands, look in the database section. There are a
> number of inkjet papers people have reported good results with.
I've
> used 2 brands, Georgia Pacific InkjetPlus+ and, iirc, office max
> inkjet paper. Both did well though I am very very happy with the
> Georgia Pacific stuff. Inkjet papers are coated to prevent the
ink
> from soaking into the paper and blooming. Its basically regular
> inkjet paper - I'd bet any brand will work fine. Just make sure is
> says "formulated for inkjet printers" or similar. Don't use laser
> printer, copier or general purpose paper. Typically <$4 for a ream
of 500.
that
paper
or
> > special stuff?
2004-10-19 by Earl T. Hackett, Jr.
Sent: Monday, October 18, 2004 11:24 PM
Subject: [Homebrew_PCBs] Re: Questions about toner transfer method.
I just made another "test" board using Staples Picture Paper and
this time used more pressure and time under the iron and I am amazed
at the quality you can achieve!! There is no going back to the "old"
way for me...this works great! Thanks for all your help.
I've
ink
of 500.
that
paper
or
> > special stuff?
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
http://groups.yahoo.com/group/Homebrew_PCBs/
b.. To unsubscribe from this group, send an email to:
Homebrew_PCBs-unsubscribe@yahoogroups.com
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2004-10-19 by mikezcnc
amazed
the "old"
a
> I've
> ink
is
ream
> of 500.
> that
didn't
> paper
> or
> > > special stuff?
2004-10-19 by Phil
>You are so right mike. Its totally unreasonable that some people
> yes, that is quite amazing...
> Except for that paper is not politically correct because it offends
> the TT-feelings in some members...Mike
2004-10-19 by Phil
> If you have a vacuum pump (even a good shop vac or vacuum cleaner)you can put the board and the artwork in a Reynolds Aluminum 'Bake 'n
2004-10-19 by ballendo
> ----- Original Message -----method.
> From: Bob Weiss
>amazed
> at the quality you can achieve!! There is no going back tothe "old"
2004-10-20 by mikezcnc
2004-10-20 by Phil
--- In Homebrew_PCBs@yahoogroups.com, "ballendo" <ballendo@y...> wrote:
> Another similar idea which seems to have gotten lost in the mix when
> it was posted; about using an electric frying pan, washcloth and a
> lead brick instead of an iron.
> Good heat control, accurate, repeatable even pressure (if your brick
> of lead isn't flat you'll need something flat between it and the
> washcloth). The only thing remaining is time, and that's easily
> monitored/controlled.
One issue with those electric frying pans is hotspotting. I don't
know if that will cause problems but if it does, one could use a large
thermal mass (like a flat steel/cast iron plate) to even it out. It
would just take more heat up time.
I've often though of something along similar lines - use 2 flat
steel/cast iron plates, thick enough to not warp at the toner fusing
point. 4 holes, one in each corner. Using bolts and wingnuts, one
could create pretty good pressure. Pop it in the oven set for 350F
(or what ever is the right temp). Baking time would be determined by
experimentation.
I suspect the problem with this is that total time would be long -
30-45 minutes. The advantages are like you said - repeatable,
controllable temp and pressure.
A properly constructed laser printer fuser assembly would probably
yield the best results for the least amount of time.
2004-10-20 by Earl T. Hackett, Jr.
Sent: Tuesday, October 19, 2004 7:11 PM
Hello,
Although I like your idea...
The MOST force you can get from a vacuum is 14.7 lbs/inch. At sea
level. Most vac pumps are rated in inches of mercury, and this is
29.92 inches. Most "common" vac pumps will give about 25 inches--or
less-- of vacuum, so you're going to have even less pressure. I've
done a LOT with vacuum clamping over the years, and use 10-12 lbs per
square inch as a ROT (Rule Of Thumb<G>) I'm working near sea level.
So with a 2 x 4 inch board, we're gonna get 80 to 96 pounds of
pressure. I'm no "Arnold", but I can surely do that with an iron...
BUT, as I first mentioned, I like your idea. And I think that the
pressure attainable WILL be enough. But we CAN provide more with a
handheld iron, IMO.
Your setup duplicates this, and "could" provide equally repeatable
pressure. A brake bleeder tool--any Auto parts store-- will give you
a simple means of accurately repeating the vacuum.
Using an electric frypan/griddle (cheap new and even moreso at EVERY
salvation army/thrift store everywhere<G>) and a weight (doesn't have
to be lead, but diver's weights are resdily available, as are other
sources of lead or similar "heavy" things, like thick steel plate.)
is a simple effective way to avoid the need for a laminator, which
still seems to me to be the best overall answer.
But I DO like your idea!
Ballendo
--- In Homebrew_PCBs@yahoogroups.com, "Earl T. Hackett, Jr."
Bag", pull a vacuum and set the iron on it. That should generate
much more force (and much more unifom force at that) than you could
ever generate by hand.
> From: Bob Weiss
method.
amazed
the "old"
ADVERTISEMENT
Yahoo! Groups Links
2004-10-20 by Alexandre Souza
2004-10-20 by Phil
> - The last and MORE IMPORTANT STEP is to take a toothbrush,brush it in
> soap, and after brush the ENTIRE board to take out ALL the paperresidues.
> If you miss this step, you'll have problems corroding some fine tracks.congrats on a good transfer - there is something really satisfying
2004-10-21 by mikezcnc
> Hi Mikefiles:
> What is the best proven laminator to use for good circuit boards
> and what staples paper is used.
> A.R
> >2. Staples paper.
> >Mike
> >Yahoo! Groups Links
2004-10-21 by Phil
>This unit works pretty well but you should be aware the if you are
> Alvin,
> The laminator is made by GBC and model that I use and recommend is
> H200, 8.5x11" about $100.
> Good luck.
> Mike
2004-10-21 by Stefan Trethan
2004-10-22 by Thomas P. Gootee
> What is the best proven laminator to use for good circuit boards<snipped>
> A.R.
>Scrub the pcb with any abrasive household bathroom/kitchen cleaner
>>I get %100 consistancy from spray-on PRP (green).
> I'vw tried the electrolube PRP spray (green) without any luck.
> Minutes after I've applied the spray over the surface of the board,
> the coating starts to corrupt, first appearing bubbles on the
> surface. Could you explain what procedure do you use?.
> Thanks.
> P.D.: I've tried Seno photoresist with great results.
2004-10-25 by mikezcnc
> Alvin,at:
> The details of the Staples "Picture Paper" are on my pcb webpage,
>that way, it never failed. But, none of my boards used to be larger
> http://www/fullnet.com/u/tomg/gooteepc.htm
> I haven't yet acquired an H200 laminator, but am planning to.
> I still use a clothes iron. Once I had a "feel" for how to do it,
>modified, and used as pcb-pattern laminators, the fuser roller
> There are also apparently quite a few people who have successfully
> Good luck!
> Tom Gootee
> tomg@f...
> http://www.fullnet.com/u/tomg
2004-10-26 by Stefan Trethan
>Now we know why you are so insistent on advertising that combination :-)
> H200 and Staples paper- the winning commbination.
> PS I just acquired 10000, shares each of Staples and GBC. That means
> that everybody purchasing those products invests in my future! Mike
2004-10-26 by mikezcnc
2004-10-27 by grantfair2001
> The details of the Staples "Picture Paper" are on my pcb webpage, at:
2004-10-27 by millerdl
>Tom -[Non-text portions of this message have been removed]
>I went looking for some Picture Paper at my local STaples. It turns
>out that American SKU numbers are different than Canadian SKU numbers
>for the same product, at least that's what the manager told me.
>So I took a chance on 30 sheets of Staples "premium photo paper". The
>SKU is #33128-CA. The UPC is 7 18103 02239.
>The paper is a brilliant white, and shiny, and almost feels like
>plastic in texture. Does this sound like it might be the same as the
>US Picture Paper?
>I tried it on one small PCB. The paper did not float, away after
>sitting in hot water for 10 minutes. But I was able to pry it off most
>of the PCB, and rub off the small partion which was left after ripping
>off the rest. The toner transfer was excellent, with sharp and
>complete traces, with a notable thickness to them. It looks great.
>There were no pinholes, but there were no large areas.
>Thanks to Thomas and the list for bringing the Staples paper to my
>attention.
>Grant
>--- In Homebrew_PCBs@yahoogroups.com, "Thomas P. Gootee" <tomg@f...>
--- In Homebrew_PCBs@yahoogroups.com, millerdl <millerdl@t...> wrote:
> I believe the Canadian equivalent of the paper Tom's site identified
has
> the SKU of #33133-CA. The bar code is the same as the US version: 7
> 18103 02238 5. It's the "Picture Paper" rather than the premium photo
> paper. I've had excellent results with it and it's cheaper than the
> premium if I remember correctly.
> Dennis
> grantfair2001 wrote:
> >Tom -
> >US Picture Paper?
> >attention.
> >Grant
2004-10-27 by Alexandre Souza
> Count yourself lucky - I haven't been able to find it at all in the UK.All I
> got from the sales staff was the classic deer-in-headlights "Dummy ModeON!"
> stare, followed by "Uhm, we've got our ownbrand photo paper but that'sabout
> it".Always the same blah blah blah...Use couchê paper (a bright, wax-coated
> Has anyone managed to get the Staples Picture Paper in the UK?
2004-10-27 by Philip Pemberton
> Dennis - thanks. The store I was in only had Picture Paper in 100Count yourself lucky - I haven't been able to find it at all in the UK. All I
> sheet packages. Have you found it in 30 page packs?
2004-10-27 by Stefan Trethan
> Count yourself lucky - I haven't been able to find it at all in the UK.You needn't staple's.
> All I
> ON!"
> about
> it".
> Later.
2004-10-27 by Thomas
Sent: Wednesday, October 27, 2004 5:44 PM
Subject: [Norton AntiSpam] Re: [Homebrew_PCBs] Re: Canadian "picture paper" at Staples?
All I
ON!"
about
> it".
paper) of high thickness, and it will work flawlessly, if you dissolve the
paper in water instead of peeling it from the board.
Wait for the photos...
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.783 / Virus Database: 529 - Release Date: 25/10/04
ADVERTISEMENT
Yahoo! Groups Links
> It sounds like the stuff glossy magazines are printed on. It mightactually
> be similar to the paper Microchip et al use for their flyers - glossy,about
> 100gsm, like thin card.around
> The stuff magazines are printed on tends to be much thinner - probably
> 70gsm.Exactly that. I use 150gsm paper, and let the board soak in water. I
>It sounds like the stuff glossy magazines are printed on. It might actually
> <Snip>
> Use couchê paper (a bright, wax-coated paper) of high thickness, and it will work flawlessly, if you dissolve the
> <unsnip>
> please Do tell us more about this paper, a google search on this has few worth while results..... :)
> Thomas
2004-10-27 by mikezcnc
>the UK.
> > All Iheadlights "Dummy Mode
> > ON!"that's
> > aboutopen
> > it".
> > Later.
> Perhaps you can get Zweckform/Avery paper.
> Many brands of matt inkjet photo paper will work just as well,
> you only need the coating to prevent the good bond with the long,
> fiber structurelaminators,
> of normal paper.
> Don't go through too much trouble finding staples paper or GBC
> there are plenty
> of options.
> ST
>Not backing paper. photo paper.
> Avery was a problem for me: 8.5x11" Avery lables backing paper is
> precut, ie the backing paper cannot be used unless one makes
> unusually small PCBs. As far as transfer capability is ocncerned, I
> did not notice any greatness in it. Mike
> By 'corroding' you really mean 'etching' right? I didn't know thatSmall oxidized points in the final board makes the etching (sorry!)
> oxidized copper makes a difference in etching process. Is that what
> others observed? It may take a bit longer but does it really cause
> etching problems? Mike
> > It sounds like the stuff glossy magazines are printed on. It mightglossy,
> actually
> aboutprobably
> aroundwater. I
> > 70gsm.
> brush my fingers in the paper to take the "first layer" of paperout, let
> some time more to soak the second layer, and brush it again withfingers to
> take all the paper out. After that, a good toothbrush with soap toclean
> everything, and the board is ready to be IMEDIATELY corroded - ifyou let it
> oxidize, it will be a nightmare to corrode.
2004-10-27 by Phil
>open
> of normal paper.
> there are plentyST is right. inkjet paper works great. The good news is you can use
> of options.
> ST
2004-10-28 by millerdl
>Dennis - thanks. The store I was in only had Picture Paper in 100[Non-text portions of this message have been removed]
>Grant
>has
>>Dennis
2004-10-28 by Philip Pemberton
>I think I may have tracked the stuff down. It's listed as "Staples Glossy
> I believe the Canadian equivalent of the paper Tom's site identified has
2004-10-30 by grantfair2001
> Yes, the package I have is a 30 sheet one.
> Dennis
