Homebrew_PCBs
Archive for Homebrew_PCBs.
double layer question
2004-08-16 by preda mihai
How are those tiny metal cilinder named?i`m talking about the one
used to connect top layer to bottom layer.
Re: [Homebrew_PCBs] double layer question
2004-08-16 by Stefan Trethan
On Mon, 16 Aug 2004 09:17:59 -0000, preda mihai <myke_oltcit@...>
they are called plated (through-)hole, or via (but i think via only if
there is no
component wire soldered through them).
ST
2004-08-16 by Dwayne Reid
The term is "via".
If you are looking for the name of the parts used to make vias on homemade
PCBs, I can think of two: Harwin "track pins" and Multicore
"copperset". Track pins are a tapered pin that fits tightly into a #66
drill hole - you solder both top and bottom sides to make the
connection. Copperset vias are used to make real vias on a PCB - you wind
up with a plated through hole. But they are expensive and time consuming
to use.
dwayne
Dwayne Reid <dwayner@...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 20 years of Engineering Innovation (1984 - 2004)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
Re: double layer question
2004-08-17 by Mike
--- In Homebrew_PCBs@yahoogroups.com, "Leon Heller"
<leon_heller@h...> wrote:
> From: "preda mihai" <myke_oltcit@y...>
> To: <Homebrew_PCBs@yahoogroups.com>
> Sent: Monday, August 16, 2004 10:17 AM
> Subject: [Homebrew_PCBs] double layer question
> Eyelets?
Also called rivets:
http://www.megauk.com/through_hole_rivets.php
These seem to go down to 0.7mm hold diameter, 2.2mm length. £14:50
doesn't seem particularly cheap to me though.
Mike
Re: [Homebrew_PCBs] Re: double layer question
2004-08-17 by JanRwl@AOL.COM
In a message dated 8/16/2004 10:35:49 PM Central Standard Time,
yahoo@... writes:
£14:50 doesn't seem particularly cheap to me though.<<
Nope! Hmmm . . . One wonders what kind of firm or operation would be their
primary customers for this kind of pricing???
[Homebrew_PCBs] homebrew rotary multi-position switch
2004-08-30 by Stefan Trethan
has one of you ever tried making a multi-position switch directly on the
PCB like most handheld meters have?
I can't gold plate it (yet).
I think tinning would do for now.
I think of using a M6 screw as axis, just a washer on each side to make a
bearing
of a hole in the PCB. Then take a piece of FR4 and make the "wiper" with
contacts
of thin sheetmetal.
The M6 screw would fit into a knob on the front panel.
The "snap" action could be achieved by drilling holes in the PCB and
letting
some spring catch them.
What do you think of that? stupid idea?
It seems i can't get rotrary switches with enough positions.
Would be nice to be able to just make them how i want.
After all it works in meters...
tell me what you thik about that.
ST
Re: [Homebrew_PCBs] homebrew rotary multi-position switch
2004-08-30 by Roy J. Tellason
Not me!
> bearing of a hole in the PCB. Then take a piece of FR4 and make the "wiper"
> with contacts of thin sheetmetal. The M6 screw would fit into a knob on the
> front panel. The "snap" action could be achieved by drilling holes in the
> PCB and letting some spring catch them.
I wouldn't go that far. :-) But I wouldn't do that, either.
How many positions are you looking for? I've seen up to 11, maximum, with
very few exceptions -- one time I heard of 22, but that would be a
custom-made job like what you're talking about here.
Tinned contact on the board, and metal? Whether that will work out or not
depends on what you plan to switch with this.
Both of my meters here use rows of buttons. :-)
My old (as old as I am!) Simpson 260 is the only one with a rotary switch.
What are you switching? How many positions do you really _need_? Have you
noticed that rotary switches are in large part going away, or at least they
have been since the fifties? There's a reason for that. Feel free to take
this over to Electronics101 if we get too far off the topic for in here.
> you
> they
> take
I need 2*10 positions, and can only get 2*6 or 1*12.
For selecting cell count on a battery charger (no current at all).
Almost all handheld meters i've ever seen use rotary switches, and all i
took
apart had "custom" printed contacts. Oh, yes, there was one rotten piece
of bad engineering
that had four buttons instead. The damn thing had dozens of design flaws,
like blowing up
each time you pulled the current plug....
I could try to pull some mechanical stunt and stack 2 1*12 switches.
I don't know if that would be possibe with the switches i can get.
But then, one switch for 2.50eur is not exactly cheap, not speaking of 2...
ST
> > you noticed that rotary switches are in large part going away, or at
> > least they have been since the fifties? There's a reason for that. Feel
> > free to take this over to Electronics101 if we get too far off the topic
> > for in here.
Sounds about right. The way they used to do that was to stack two switch
wafers, not a big deal. I'm sure that such a part is out there and available
somewhere, though whether it's available at a reasonable cost to you with
where you're located is another issue that I can't really address.
> took apart had "custom" printed contacts. Oh, yes, there was one rotten
> piece of bad engineering that had four buttons instead. The damn thing had
> dozens of design flaws, like blowing up each time you pulled the current
> plug....
That *IS* cheap! What does it look like? The typical rotary switch I know of
has a metal front with mounting bushing that the shaft comes through, with
two "legs" that are crimped beyond the point where they go through the wafer.
The heavier-duty ones, and the ones that are designed for more than one
wafer, are done with longish bolts that go through the metal part and
through the wafers with spacers in between each wafer and between the last
one and the front metal, to space them out.
Wafers seem to be phenolic, typically, though I've also seen some that were
done in ceramic as well.
Contacts can be shorting or non-shorting, or all sorts of strange
configurations in some applications.
Maybe if you can find an old tv set that's good for scrap you can do something
with the tuner? It'll require some mechanical work, but it may give you a
usable multi-level rotary switch with (perhaps) enough positoins. Typical
here is channels 2-13 and a "UHF" position that selects a different
tuner,what's typical there?
Re: homebrew rotary multi-position switch
2004-08-30 by cybermace5
all i
> took
piece
> of bad engineering
flaws,
> like blowing up
of 2...
Would be nice to have a couple more details on the circuit this is
going to be connected to.
Are you changing a resistance? Could you use a potentiometer and then
work out some kind of mechanical detent? Why do you need a dual-pole
switch? Have you looked at analog multiplexer chips? Digital
potentiometer chips? Don't reject them without looking at them, they
are not all expensive. A 16:1 analog mux/demux CD74HCT4067 costs 90
cents in DIP, 48 cents in SOIC. Two of those give you your dual-pole
circuit if you need it. They accept a simple 4-bit input to select
which output goes where. You could provide that input with a
16-position hex switch, or a 4-bit counter (rollover at 12) operated
by pushbuttons. Another 50-cent 74HC154 4:16 decoder could give you an
LED feedback showing which output is selected.
It would be neat to have 12 LEDs surrounding a single central
pushbutton which increments the LED position.
Or maybe you could just go for a rotary switch with fewer positions,
like 6. Then you use a dual-pole switch to choose between high range
and low range. Though even 6-position dual-pole rotaries are all very
expensive unless you get lucky in surplus stores.
As for rolling your own? It'll just have to be trial and error.
2004-08-30 by ron amundson
--- Stefan Trethan <stefan_trethan@...> wrote:
> Hi,
Yes, but not at home with limited tools.... Its great
in volume production as its super cost effective, but
we would take care of the mechanical issues in the
molds.
Its a function of life span and environment. Gold is
pretty soft, but at least it doesn't corrode.
> bearing
> contacts
> of thin sheetmetal.
I think it would be trouble. We always used berylium
copper, and had them formed off site, even for
proto's. I don't think I would want to mess with it at
home. Its nasty stuff.
> panel.
> letting
FR4 can be pretty abrasive to use as a detent. (we
tired), then again we wanted 20,000 cycles.
Could you use a 360 degree pot, and then detents with
a cam and spring arrangement. It would make the
electrical wear and tear a lot less of a headache.
One could also use optocouplers and a mylar disk...
bit it gets spendy.
I've also seen a magnet, with a sphereical ball
actuator that handled the contact switching as it
rolled along.
> positions.
> want.
And other place, a rotary switch is generally not cost
effective, but it is the most intuitive, at least for
those of us in the older generation. The youngsters
may have grown up with bottom remotes etc, but I still
have a few tv sets with rotary volume and channel
select. EVen Fluke tried to go away from the rotary
switch in the late 80's.... the product failed. They
tried again with a lower priced model in the late
nineties. I don't think its doing to well sales wise.
DIY without extansive cad and proto facilities would
be a challenge, then agan the end result would be
pretty cool.
Ron
> ST
> $9.95 domain names from Yahoo!. Register anything.
http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/bGYolB/TM
> Be sure to visit the group home and check for new
> Bookmarks and files:
> Homebrew_PCBs-unsubscribe@yahoogroups.com
Do you Yahoo!?
Yahoo! Mail - 50x more storage than other providers!
http://promotions.yahoo.com/new_mail
> bit it gets spendy.
Not necessarily. I have a couple of motors equipped with such encoders. And
you have two of them in any given mouse that's out there -- it shouldn't be
too hard to adapt that technology to be used with a knob and a shaft, though
a good bit of weight behind the panel gives it a better feel.
This sort of thing was actually used, in a z80-based system to control most
all functions on the Moog Source -- you had what was basically a membrane
panel, where you selected what function you wanted to mess with, you had a
couple or three digits of LED display to tell you what the current value was,
and you had one big knob to fiddle with it.
Not bad...
2004-08-31 by Leon Heller
Sent: Tuesday, August 31, 2004 12:43 AM
Subject: Re: [Homebrew_PCBs] homebrew rotary multi-position switch
> > bit it gets spendy.
And
be
though
most
a
was,
Electro-mechanical encoders are quite cheap, they are made by ALPS and
Bourne. One of those with a small MCU and a display will do what you want.
Leon
2004-08-31 by ron amundson
> From: "Roy J. Tellason" <rtellason@...>
> disk...
> > > bit it gets spendy.
> And
> be
> a knob and a shaft,
> though
> better feel.
> most
> a
> was,
> Leon
So what I gather, is a guy could put a good sized
weight on the shaft to create inertia and give a
perception of quality, then use optical interrupters
to capture disc position?
I've looked at the mechanical rotary encoders in the
past, but even in volume they were a couple bucks. The
idea of using oprtical is quite interesting. I'd
completely forgotten that is the basic mouse concept.
All one would need to do, is add some type of position
encoding to the mouse wheel, and one would be all set.
Speaking of which, it would seem practical to use one
of those LED's that illuminates through a hole in the
board for the coupler section. Has any one had any
issues with pad sizing... it seems like it might be
somewhat dependant on laminate material, as you have
this big hole right under the part. Its so rare that
one can actually use the manufacturers recommended pad
size without tweaking. I'd like to know if anyone has
rules of thumb.
Ron
Do You Yahoo!?
http://mail.yahoo.com
2004-08-31 by Roy J. Tellason
On Monday 30 August 2004 10:41 pm, ron amundson wrote:
> So what I gather, is a guy could put a good sized weight on the shaft to
> create inertia and give a perception of quality, then use optical
> interrupters to capture disc position?
Capturing the _change_ in position is more like it, depending on where the
software that was dealing with it assumed was the position to start with.
> I've looked at the mechanical rotary encoders in the past, but even in
> volume they were a couple bucks. The idea of using oprtical is quite
> interesting. I'd completely forgotten that is the basic mouse concept.
I have a couple of dead ones here that I'm thinking about playing with at some
point...
It's interesting to note that the LED/Detector pair on these is discrete
components. I also have some optointerrupters I'm planning on trying to do
something with that I salvaged out of dead floppy drives. Also some similar
parts which apparently were designed to use a reflective principle.
> All one would need to do, is add some type of position encoding to the mouse
Nah, that'll all be handled in the software. As would the resolution, for
that matter.
2004-08-31 by mikezcnc
Could you use multiplexers? That would be more reliable and could
have as many switches as you want. Mike
-- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan"
<stefan_trethan@g...> wrote:
> Hi,
on the
make a
> bearing
with
> contacts
> of thin sheetmetal.
and
> letting
> ST
> that matter.
Could you elaborate as to how..... Especially in a
power down condition where upon one could loose track.
I take it, there is some trick, as many devices, use
relative rather than absolute positioning. WIthout a
home position to index off of, it would seem one could
loose the position of the pointer if it were turned
and power was off.... Or is it interrupt driven such
that the micro stays alive and wakes up should the
shaft be turned???
Ron
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
2004-08-31 by ben_englund
> shaft be turned???
> Ron
Maybe do like was already stated earlier and just use LEDs around the
dial to indicate position. Then don't put any position indicators on
the dial itself. Then when you turn the unit on, you could have it
start in the "home" position no matter how much the dial itself has
moved while off.
Or you could use a bunch of reed switches mounted in a circle and a
magnet mounted to a disc on the shaft, but I'm sure that would be
pretty pricy.
I've heard that green LEDs can act as photodetectors. They are cheap
if you could get them to work. Then just put a bunch in a circle a
detectors and one on a disc on the shaft as an emitter. Anybody have
any luck using LEDs as detectors?
Ben Englund
2004-08-31 by Stefan Trethan
> want.
> Leon
Thanks, but they are pretty useless for me.
I can't change what i need, the IC expects a 2*10 switch.
It is a charger, and meant to be "jumpered" for cell count, but i want
a universal charger.
ST
Re: [Homebrew_PCBs] optical encoder (was: homebrew rotary multi-position switch)
Weight makes it continue to spin too long.
Better a good fit of a shaft and a bushing with oil between, like
a 10-turn pot knob. This gives you resistance for fine setting, and
you can spin it relatively fast still.
ST
Re: [Homebrew_PCBs] thumbwheel (was: homebrew rotary multi-position switch)
On Mon, 30 Aug 2004 21:23:23 -0700 (PDT), ron amundson
>> that matter.
> shaft be turned???
> Ron
Usually "thumbwheel" encoders are only used incremental.
like up/down buttons. the absolute positions are stored in memory if needed
and often the thumbwheel is used to adjust many values, selected by
buttons.
ST
2004-08-31 by ballendo
Stefan,
I think your idea will work, but have concern about using "sheet
metal" for the wiper...
Is this for a production item, or just a few?
Because I'd sure use the phosphor bronze/beryllium copper/whatever of
a "real" wiper(s) from the switch you CAN get. Then use your pcb to
make the other half.
I believe you will have MUCH better success this way.
I'd also use an IGUS iglide circlip bushing for the switch "axle".
These are made for thin sheet stock, and again will improve the
smoothness and lifetime of your product/project. They're cheap and
available worldwide as well.
Hope this helps,
Ballendo
_need_? Have
> > you
least
> > they
free to
> > take
in here.
all i
> took
piece
> of bad engineering
flaws,
> like blowing up
of 2...
> ST
Garrett,
Good tack.
You could also use an encoder style "pot" and a PIC...
These encoders are getting pretty inexpensive, and the PIC can take
the input and "route" it as necessary.
Another option is the 0-9 thumbwheel switches. I see these in ALL the
surplus places these days, and they ARE a rotary switch, just a 90
degree orientation change. Most are stack-able, so the 2x10 need is
easily met...
They are available both with 11 pins, and more commonly with 4/5 pins
giving BCD output--which would work with your suggested parts.
Hope this helps,
Ballendo
then
an
very
Re: [Homebrew_PCBs] Re: homebrew rotary multi-position switch
2004-08-31 by smartdim@aol.com
In a message dated 8/30/2004 11:01:28 PM Pacific Standard Time,
ben_englund@... writes:
Ben Englund
Yes,
I have used "plain jane" red leds as photodetectors. A voltages is produced
across the leads in response to direct sunlight. It appears to be fairly
sensitive.
A different voltage (lower) was read with the LED exposed to light, but in
the shade opposed to direct sun light.
Ken
> > for that matter.
> Could you elaborate as to how..... Especially in a power down condition
To what, keep track of the "switch position"? Store a value in a ram chip
somewhere. If it needs to stick around store it in a battery-backed ram.
You can stuff an awful lot of info into a pretty small (2048 byte) part...
> I take it, there is some trick, as many devices, use relative rather than
It's just a matter of keeping track of "where you were" and using the
direction of rotation to figure out "where you're going" and how fast. What
happens when you fire up software that uses a mouse? I see a lot of stuff
assuming that the pointer should be in the center of the screen...
> WIthout a home position to index off of, it would seem one could loose the
> position of the pointer if it were turned and power was off.... Or is it
> interrupt driven such that the micro stays alive and wakes up should the
> shaft be turned???
I think this is getting into system design now. What you'd do depends on what
you were trying to use this idea for...
> > shaft be turned???
> > Ron
> moved while off.
Just like a mouse pointer starts in the middle of a screen.
> pretty pricy.
Radio Shack used to sell a bundle of those for a fairly low price, as I
recall.
I've never tried this, never saw the need. If you want some cheap (free?)
photodetctors and emitters, take any trashed floppy drive (that people would
normally just throw away) and grab the sensors out of it. Some will use a
mechanical switch for the ones along the edge of the disk package, some will
use optical parts, but almost all that I can figure will use an optical pair
for the index sensor, so you get at least one. There can be as many as four
pairs in there (disk type, write protect, index, and home position). Or take
apart a dead mouse, there will be at least four pairs of sensors in there...
> easily met...
I have some of these, and have yet to come up with something I want to use
them in...
2004-08-31 by cybermace5
--- In Homebrew_PCBs@yahoogroups.com, "Roy J. Tellason"
> > easily met...
to use
> them in...
Handy for setting a device ID. Good when you have several devices on a
bus, or wireless, that you want to identify.
> > want.
> > Leon
What IC is this? Do you have a link for a data sheet?
> > > easily met...
> > to use them in...
Yeah, but that's a lot of bulk and panel space (and rectangular holes needed
which I can't cut just yet :-) for something you'd set once and forget about,
which is why those functions normally seem to use jumper blocks...
2004-08-31 by Dwayne Reid
<http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=26211&item=3836083832&rd=1>
<http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=26211&item=3836173808&rd=1>
There are others as well . . .
<http://search.ebay.com/rotary-switch_W0QQcatrefZC6QQfromZR7QQnojsprZyQQpfidZ0QQsacategoryZQ2d1QQsacqtyopZgeQQsacurrencyZ0QQsaslopZ1QQsatitleZrotaryQ20switchQ2aQQsocolumnlayoutZ3QQsofocusZbsQQsopostalZT5SQ201K8QQsorecordsperpageZ50QQsosortorderZ1QQsosortpropertyZ1QQsspagenameZhQ3ahQ3afitemQ3aUS>
dwayne
<http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1666>
i found another solution.
I will hardwire the chip for one cell, and then use a voltage divider for
the cell number.
I could use a 1*12 pos. switch with a resistor chain, or i could use a
10-turn
pot (helipot), which is what i will do because i have one already.
The result it not only a solved problem, but i can also use this voltage
for a treshold voltage for a discharge circuit, which i couldn't if i use
the chargers internal divider.
I thought about the homebrew switch, and even made a layout.
one could wire the switch as needed from only one component in the library.
The bad thing is it is relatively big (around 6cm diameter).
Assembly would be as follows:
take a M6 screw.
Make the "wiper" from a piece of pcb, solder on suitable spring contacts
(like
the fingers from a GND shield spring - sheetmetal) in the right places.
drill a 6mm hole in the center and solder to the screw (all the way up
against
the screwhead. Put a washer on the screw, then stick it through the PCB.
put another washer on this side, a nut. now take another strip of FR4,
solder
a "ball" type item on the end, and affix it with another nut to the screw
(which
also counters the first nut).
the PCB would have two concentric rings of contacts, which are connected by
your contact, and outside of them a ring of
holes which suit the "ball" as a snap-in mechanism. To set endstops you'd
simply
put a M3 screw in the appropriate holes.
If you couldn't picture the instructions above note that the contact wiper
is on one side of the PCB, and the "snap in" mechanism slides on the other
side.
this is required if you don't want your snap in to slide over connecting
tracks.
Not too hard to manufacture, and i bet it would work, but as said i will
probably
not need it for this project any more.
ST
On Tue, 31 Aug 2004 08:40:44 -0600, Dwayne Reid <dwayner@...>
> dwayne
Thanks, but ebay was the first i looked.
I assume you either don't know i'm not in the US or you don't know what
i'd have
to pay for shipping and taxes...
Nothing useful at ebay in a country where i'm willing to buy.
ST
>moved while off.
Modern digital audio consoles do this - the Yamaha PM-1D uses 32 LEDs per
rotary encoder to indicate 64 discrete positions (all off, 1 on, 1+2 on, 2
on, etc). Its darned cool to punch up a different preset scene and watch
all the indicators snap to their new positions.
dwayne
RE: homebrew rotary multi-position switch
2004-08-31 by Thomas P. Gootee
Stefan,
ALPHA makes a 2P12T rotary switch that is $1.57 for quantity 1, at www.mouser.com, with Mouser part number 10WR212.
That one is make-before-break ("shorting"), with solder lugs. I don't see any 2P12T (or 10T) Alpha-made (i.e. low-cost) switches at mouser.com that are non-shorting, or that are pcb mount.
For a lot more $, both Electroswitch and NKK have many models that would probably meet your need. They have switches listed at mouser.com that go up to (just to name some of the extremes) 2P23T, 4P17T, 6P12T, 9P4T, 8P6T, 12P4T, and even have a model that will handle 30 Amps that goes up to 5P11T (for only $114.00!).
I am sure that you could eventually get your homebrew pcb-based rotary switch idea implemented. But the Alpha switch would be much cheaper/easier/faster, assuming that it meets your specs.
Tom Gootee
http://www.fullnet.com/u/tomg
From: Homebrew_PCBs@yahoogroups.com[SMTP:Homebrew_PCBs@yahoogroups.com]
Sent: Tuesday, August 31, 2004 8:55 AM
Subject: [Homebrew_PCBs] Digest Number 801
Date: Mon, 30 Aug 2004 21:12:52 +0200
Subject: homebrew rotary multi-position switch
bearing
contacts
of thin sheetmetal.
letting
ST
Re: homebrew rotary multi-position switch - Fluke
2004-08-31 by Dave Mucha
> > positions.
> > want.
The fluke meters were just too feature poor. I don't need much for
field work, voltage, continunity and current readings from contorl
signals. But they didn't offer 4-20mA as an input when they came out.
The scaled down units had less features than the radioshack models at
the time.
I remeber looking for an AMP unit at about the same time. It had a
smaller case and digital display, but no one carried it.
Dave
RE: [Homebrew_PCBs] homebrew rotary multi-position switch
2004-08-31 by Alex Hay
Electroswitch has 12-position switches that take a stop to reduce the
available positions -- you can use a 2x12 as a 2x10 by moving the stop a
couple of positions. You might be able to get a free sample from your local
distributor.
-Alex
2004-09-01 by Dwayne Reid
>i'd have to pay for shipping and taxes...
I had assumed that you were not from North America from your email
address. That's why I included links only to sellers who ship
worldwide. In particular, the 2nd link above is selling from Lithuania.
dwayne
2004-09-01 by Stefan Trethan
> dwayne
i see.. thanks.
ST
Re: multi-position switch [eBay]
2004-09-02 by cybermace5
> i see.. thanks.
> ST
A big lesson: there is no such thing as "I already checked eBay." It's
like watching a road for a certain car to go by, you can't look once
and then say you've already checked.
Re: [Homebrew_PCBs] Re: multi-position switch [eBay]
2004-09-02 by Stefan Trethan
On Thu, 02 Sep 2004 14:17:43 -0000, cybermace5 <cybermace5@...>
wrote:
>> i see.. thanks.
>> ST
I can stop looking.
also, when i know the car takes 4 to 10 days to pass, from the moment
i can first see it, and i need the switch *now* i can say with one look
it isn't going to come around the next 4 to 10 days.
I already said in another post the problem is solved in another way
and the switch is no longer required.
I constantly monitor ebay austria and ebay germany for things i might like,
and quite regularly buy.
you surely understand my reluctance to import a simple switch from abroad.
Again, the problem is solved without the switch. thanks.
ST
[Homebrew_PCBs] Removing copper at one side
2004-09-08 by Stefan Trethan
I tried to peel off the copper at one side of a glassfiber pcb.
I used a knife to separate the first layer of glass (with the copper)
from the rest, at the edge, and then peeled.
It is a bit tedious but it is possible to do it.
You must be careful not to let the edges break.
I think it might help to bash the edges with a hammer, to break up the
bond, and later cut off 5mm, but i haven't tried.
You end up with a (slightly thinner) single sided pcb and a very thin, very
nice, flexible pcb.
The surface has the "glassfiber matt" structure of course, which looks
quite nice but is not useable for TT of component legend, which is the
reason why i won't use that method. The grain is so course you can't
really get the transfer stick, and the toner is squeezed into the
low areas, which makes it unreadable.
Peeling the copper alone doesn't work well, it just breaks into smaller
flakes which can't be removed at all.
The only other method to use i can think of is etching the copper.
I would have liked to find another way because it uses a lot of etchant,
and
a lot of time, covering the one side and all.
Until now i just made the transfer on one side, and had both sides etched
at once,
the unwanted one simply completely. the downside of that is i can't
transfer
the component legend before etching. It takes longer, and is much harder
to align.
I would like to do the "simple" PCBs (one layer, and component legend on
top) with
one transfer run.
Well, let me know if you have found a better way.
ST
Re: [Homebrew_PCBs] Removing copper at one side
2004-09-08 by Leon Heller
Sent: Wednesday, September 08, 2004 10:32 AM
Subject: [Homebrew_PCBs] Removing copper at one side
> Hi,
I've removed small areas of copper by heating it with a large bit on my
soldering iron, after scoring it with a Stanley knife. It peeled off very
easily.
Leon
> easily.
> Leon
That could just be a little bit too tedious for big areas.
I tried heating with the heat gun and wasn't really convinced by the
results...
I guess i will etch the boards, further mechanical attempts were not
leading
to good results.
I'll see if sticky tape is tight enough where it overlaps or if i need to
use paint...
ST
Sent: Wednesday, September 08, 2004 4:17 PM
Subject: Re: [Homebrew_PCBs] Removing copper at one side
very
> > easily.
> > Leon
> results...
> leading
> to good results.
> use paint...
I've used both paint and masking tape. The latter allows some leakage, so a
waterproof tape
would be better. I've also used double-sided material with the unexposed
side as a ground plane. That
works very well.
Leon
Re: Removing copper at one side
2004-09-09 by Dave Mucha
on my
off very
> > easily.
> > Leon
> results...
not
> leading
> to good results.
need to
> use paint...
> ST
I found that FR-4 has an extreemly tight bond with the copper and
some phenolics will allow you to peal away huge sheets.
With my etcher I route the traces isolation and then peal away huge
areas of copper. Time consuming to say the least.
My very white phenolic allowed me to peal the copper with minimal
effort and the sufrace is smooth and looks untouched.
IF I had to do a large board of FR-4 I'd considder spray paint or
floor wax. both would be easy to put on and remove enough for future
etching.
Dave
