Homebrew_PCBs
Index last updated: 2026-04-02 23:14 UTC
Piezo Print Heads and Oil Based Inks
2004-05-09 by gmanca101
I have a question regarding the Piezo Heads in Epson printers.
According to one of the links provided in the previous Inkjet
threads, the Epson inks are solvent-based. Now I have read that
solvent inks are non-water based inks. My question is if that can be
construed as oil based inks? If so, I think I have found some cheap
refillable inks that I will put into my Epson Ink cartridge and print
out on some aluminium as Stefan has suggested.
I feel that once we get the ink situated, a flatbed printer
conversion would help make the pcb printing process complete becuase
it would allow for component legends and double sided printing to
occur flawlessly.
Re: [Homebrew_PCBs] Piezo Print Heads and Oil Based Inks
2004-05-09 by Stefan Trethan
Why use oil-inks? Why not use solvent inks?
Take the ink for permanent markers known to work with pcbs.
Maybe dilute with alcohol.
I think the epson are alcohol based??
> occur flawlessly.
I feel the same. you could use the black for resist and the color for
other stuff.
(if you need more than the resist color)
but the conversion must be after the proof of concept.
st
Re: Piezo Print Heads and Oil Based Inks
--- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan
The issue here is that I am in the US and cannot find any of the
Staedler Refill Stations. Maybe if there was a way to remove the ink
from the pens themselves?
What I am wondering if solvent inks are oil inks?
Genaro M.
Re: [Homebrew_PCBs] Re: Piezo Print Heads and Oil Based Inks
get a "sharpie"
you need a ink that "wets" the metal. ohp pens do that, other flt-tip pens
not - why?
me too... reading shows it might well be.
are you sure that they are not water based, where to read?
ST
> get a "sharpie"
Hmm, maybe placing the sharpie in alcohol to "drain" it would work.
And I noticed that it tends to keep its permanence.
Well this site says that Water is different then solvent/oil based.
http://www.signweb.com/digital/cont/inkjetinks990602.html
Question is, are the Epsons a solvent based ink printer as says this
site: http://www.inkjetcartridges.com/_piezo-electric-technology.html
Genaro M.
>> get a "sharpie"
> Genaro M.
i've seen pages saying epson uses water but piezo can use both.
ST
A product that looks like what i have in mind,
the table is moved, making the modification of the printer a very easy
task.
I do not think we can get any more information on the printer, global
sources supplyers
are not cooperative if you don't buy a huge number (though they send me a
magazine
every few weeks - dunno why...)
the thing to note is that it can use solvent and water based:
<http://www.globalsources.com/am/article_id/9000000042033/page/showarticle?action=GetArticle>
I think water based is not much good because it won't dry on metal.
on the other hand acrylic paint would dry and would be water based,
and acts as a resist.
My best bet is still with the solvent type ink, like used by permanent
markers.
Someone here wrote "a collegue put a inkjet head on a flatbed and printed
permanent marker ink (1:1 diluted with alcohol) and it worked".
he wrote the marker was the same as they used to touchup boards.
You can for sure find it in the archives.
It is also quite well possible that the acrylic paint would work with
piezo,
it did NOT work with bubblejet, which is obvious as the heat "boiling" the
water
will make it clog terribly (which it did).
I guess i MUST try it, it would be a bit easier than TT and the quality
would be better.
Also i could possibly prevent buying a new laser (for resolution). Inkjet
printers
are MUCH cheaper.
ST
2004-05-09 by mikezcnc
Stefan, Not to disagree with you, but I recently experimented with
Epson 1520 which isa piezo printer and the printer doesn't like
anything different than original Epson printer. After using an
aftermarket ink the printer died and the printhead smoked (!)
I'will remind that my experience with floor wax killed few printers.
The feeding of PCB is easy the problem si the ink. I suggest that any
printer that has a printhead with the cartridge is better because if
something goes wrong it can be replaced...
Mike
easy
> task.
global
> sources supplyers
send me a
> magazine
permanent
> markers.
printed
with
> piezo,
heat "boiling" the
> water
quality
> would be better.
Inkjet
> printers
> are MUCH cheaper.
> ST
2004-05-09 by mpdickens
Floor wax is water based and further, quickly builds
up a film inside the print head that clogs it up. Most
Piezo print heads are not compatible with water or
substances that conduct. I'll bet if you get your
hands on the spec sheet for inks used in Piezo head
printers, the ink when in liquid form is
non-conductive and does not build up inside the print
head.
Another alternative piezo style printers are use wax
that is melted and then deposited onto paper. Examples
of this printer include the Tektronix Phazer series of
printers.
Regards
Marvin Dickens
Registered Linux User No. 80253
If you use linux, get counted at:
http://www.linuxcounter.org
Do you Yahoo!?
Win a $20,000 Career Makeover at Yahoo! HotJobs
http://hotjobs.sweepstakes.yahoo.com/careermakeover
> Mike
I agree the problem is the ink.
I have found no piezo printer that uses cartridges.
The 1520 seems pretty new? i hope the older 400/600/800 stylus color will
have a more basic head and be easier to work with.
there are differences in printhead construction, not all have exposed
electric parts.
(i guess your printer didn't like conductivity).
thanks
st
> head.
Where to find data on epson(and other) heads and inks?
ST
Inkjets that used oil-based inks first began to appear on the scene in
1997 as printer manufacturers began to seek ways to boost throughput
speeds for inkjet printers. After a new generation of high-speed piezo
printheads shorted out when exposed to water-based inks, printer OEMs
began to investigate alternatives to water. Oil-based inks were appealing
because they provided an easy way to build inkjet printers that could
output graphics at higher rates of speed.
<http://www.bigpicture.net/index.php3?openchan=yes&channelnum=2&content=2173&displaynow=yes>
st
Re: Piezo Print Heads and Oil Based Inks - DYKEM
2004-05-09 by Dave Mucha
--- In Homebrew_PCBs@yahoogroups.com, "gmanca101" <gmanca101@y...>
ink
> Thanks,
> Genaro M.
Hi Genaro,
machinests use a metal blue paint for marking steel. Dykem is the
brand name and it cost less than $10.00 per 0.118 liters.
I was going to offer that in ounces, but I'm not sure if you would
prefer US ounce, or UK ounces.
I figured tablespoons might work well, but then it could be US
tablespoons, UK tablespoons or metric tablespoons...
Maybe quarts ? nope, UK or Anchent Hebrew quarts, German quarts and
then US dry or US liquid quarts.....
Cups ? nope, Canadian cups, US cups and Metric cups....
oh, fudge.
they sell it in Gallon containers. you gotta figue out if it UK
liquid or US liquid or US dry.
tru www.use-enco.com item 825-8320 Dykem 8 ounces, $5.53
here is the manufacturer's site
http://www.americanmarking.com/dykem.htm
Dave
> inks?
The makers of inks will probably give you the
specifications of thier various inks if you ask for
them: They want to sell ink and the competition is
fearce. OTOH, I bet the mfg's of heads are not going
to come off meaningful specifications. They will claim
trade secrets/competitive info and ect...
Regards
Marvin Dickens
Do you Yahoo!?
2004-05-10 by mikezcnc
Quite possible. I am using this opportunity to warn averybody against
buying an Epson 1520. It is a royal junk printer that has problems
printing on paper. Piece of $it if you ask me. I will also advise
everybody against buying a bulk feed system and I will advice against
morons like owners of www.posjet.com who claim an imagesetter
quality. Their ink dries out in the bottle. PCB printing is a nirvana
for a hobby market. Mike
printers.
any
if
> > Mike
color will
exposed
> electric parts.
> thanks
> st
2004-05-10 by Steve
If the printhead blew magic smoke, that is going to be due to ink
leaking into the electronics.
I run a 3rd party pigmented ink in a 1520 for Tshirt imprinting. Tens
of thousands at least use 3rd party dye and pigmented and dye sub
inkjet inks in Epson printers. They do tend to be touchier with non
dye inks.
Epson printheads are "solvent" but the solvent is alcohol. As
discussed here and on the Epson printers list, one big problem with
other solvents is they may attack other parts of the printhead like
the plastic leading up to the piezo heads.
Steve
> Mike
2004-05-10 by Steve
The Epson 1520 is an old and discontinued Epson. I have one, got it at
a thrift store for $26. Still going on eBay for around $200, because
it will print 13.6 inches wide and the piezo head can use 3rd party
pigmented and dye sub inks.
The 1520 is a pain. I am using it with a bulk ink system with
pigmented ink, and it is -very- sensistive to the height of ink in the
bottles. No way is it imagesetter quality, I only use it for Tshirt
and other fabric imprinting, I can even print directly on cloth with
it. But I have to keep fiddling with the height of the bottles as it
uses up ink.
If you get a 1520 and intend to use it to try printing on PCBs, don't.
Put it up on eBay and use the money to buy some old cheaper letter
size Epson printers and play with those. If you do a good auction,
you'll get well over $100 for a 1520.
Steve
2004-05-10 by gmanca101
--- In Homebrew_PCBs@yahoogroups.com, "Steve" <alienrelics@y...>
Steve,
I found out that Sharpie pens are alcohol-based, however, these pens
are susceptable to drying out without the cap. Would the print sponge
pad be enough of a "cap" to prevent this?
Secondly, anyone here happen to know the compoistion of Staedtler Red
Lumocolor Permanent Pens? I understand that they are dry-proof, but I
wonder what is based of.
2004-05-10 by ballendo
Hello,
Has anyone tried shellac? It is soluble in alcohol, in fact that's
what the dykem Dave mentioned is.
But I wouldn't use dykem as the pigments may create a problem.
Shellac is waterproof, and should make an excellent resist. It is
sold in different grades depending upon the level of refinement.
Ultra blonde is what you would want to use for this purpose, IMO.
The better grades are sold as flakes which are dissolved in alcohol.
You can mix it thick or thin, and woodworking stores as well as home
depot carry it. Get denatured alcohol at the same time.
It might even work in the thermal print heads.
BTW, it dries very fast.
I bet it will work in the print heads...
Ballendo
with
Tens
> dye inks.
> Steve
printers.
any
if
> > Mike
2004-05-10 by Stefan Trethan
most likely .... perhaps ;-)
would be a good idea to use some additional means of preventing drying.
the staedtler pens are "dry proof" meaning as long as some liquid
ink is in the pen the tip won't dry. it will thicken a bit. they say 2
weeks
open i think and it still must go.
oh, yes, i see you already understand they are dry proof... sorry for that.
I think it is alcohol based. it is solved by alcohol, and it is no stronger
solvent (plastic survives). It also has a light alcohol smell.
the labels on the refill are highly flammable and irritant.
Alcohol does not carry irritant normally, so it could be another solvent.
ST
Dave,
I used that method with scratch and etch consept developed by Jojn
Kleinbauer from www.kleinbauer.com
I used that paint in a spray can and I noticed that it is etch
resistant... to a degree. If left for too long my HCl based solved
lifted the paint but for regular times it etched nicely. Mike
--- In Homebrew_PCBs@yahoogroups.com, "Dave Mucha" <dave_mucha@y...>
> ink
> > Thanks,
> > Genaro M.
> Hi Genaro,
and
> oh, fudge.
> Dave
2004-05-10 by Jobet Claudio
Hi ! I read from an old issue of radio electronics one of the ways they used shellac in preparing PCB's. They first dyed the stuff so that it would be visible when applied. Then, they loaded the thing into a technical drawing pen and used that to directly apply the shellac as an etch resist onto the blank pcb.
Jobet
Sent: Monday, May 10, 2004 8:48 PM
Subject: [Homebrew_PCBs] Re: Piezo Print Heads and Oil Based Inks
Hello,
Ballendo
with
Tens
> dye inks.
> Steve
printers.
any
if
> > Mike
Be sure to visit the group home and check for new Bookmarks and files:
http://groups.yahoo.com/group/Homebrew_PCBs
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
http://groups.yahoo.com/group/Homebrew_PCBs/
b.. To unsubscribe from this group, send an email to:
Homebrew_PCBs-unsubscribe@yahoogroups.com
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
On Mon, 10 May 2004 22:35:29 +0800, Jobet Claudio
> Jobet
I'm suspicious towards shellac.
I admit i have never seen it in solved state, but it somehow is linked
to a "sticky" image.
Please keep in mind that in the past it was a much more popular stuff than
it
is today, maybe because there was no better ink around. After all we
*have* resist
pens now, and do not longer fill schellac into drawing pens.
I tried colophony solved in alcohol in a plotter pen once. sticky mess.
not sure if schellac is that sticky or not.
ST
2004-05-10 by Leon Heller
Sent: Monday, May 10, 2004 3:35 PM
Subject: Re: [Homebrew_PCBs] Re: Piezo Print Heads and Oil Based Inks
onto the blank pcb.
Nail varnish is supposed to work quite well, also.
Leon
> Leon
yes, to put on your nails maybe. ( ;-) )
And of course you can smear it on a pcb and then etch it.
But this does not mean you can use it in an inkjet.
You can probably use butter or tar to make a pcb, but not with a inkjet.
ST
Sent: Monday, May 10, 2004 4:12 PM
> > Jobet
> it
> *have* resist
Shellac should be OK, it's quite hard when it dries. It was used for
varnishing wood a long time ago, and for 'french polishing'.
Leon
> Leon
yes, but is it sticky when solved / half drying?
colophony is also hard when dry.
ST
[Homebrew_PCBs] solder "tweezers" or hot air pencil?
2004-05-11 by Stefan Trethan
What is better for smd (de-)soldering?
solder tweezers or hot air pencil?
As the last hot air pencil attempt failed i now need to build a better
one (with a workig heater) or i could build solder tweezers.
I want to be able to exchange smd parts.
I have worked with neither so i hope to find what is better...
thanks
ST
EPSON MSDS:
<http://files.support.epson.com/pdf/msds/s020108.pdf>
<http://files.support.epson.com/pdf/msds/s191089.pdf>
<http://files.support.epson.com/pdf/msds/s020089.pdf>
The above are for the COLOR 800.
But you can get them all at epson support page (sorry no link possible).
I have looked at a few and they are all the same.
I't doesn't say much, but it DOES say it is aqueous ink.
I still think alcohol solved ink may work quite well.
ST
Re: solder "tweezers" or hot air pencil?
2004-05-11 by Phil
Is it really a question of either? each has their appropriate
applications. I think the tweezers are good for 1206/805/603 but not
so good for soics and bigger. Hot air with the appropriate nozzle
can do just about anything soic and up.
better
> thanks
> ST
Re: [Homebrew_PCBs] Re: solder "tweezers" or hot air pencil?
talking only about bipedals here.
(I don't think a small hot air pencil is good for ICs? enough volume?
i thought i will continue to use the hot air gun for the ICs, but it is
clumsy
for the tiny ones...)
it is a question of "i have only time to build one - which one is better".
I hope to use the same compressor as i use for the solder paste dispenser,
so the air source would have a nice regulator. I also plan to use
the other side of the compressor for a vacuum (for now only manual) PnP.
I tried to use it as a "solder sucker" already, and it works.
By the way, another question, why is there no aluminium used for
desoldering tips?
is it not making enogh contact to heat the joint? it would not be consumed
like copper and those rivets are just the right size... (good thing there
are
ones of copper too... exchangeable and VERY cheap solder sucker tips: pop
rivets.)
Well, i will see if i can make a appropriate heater for the hot-air...
ST
Hot stations: Hakko and clones...
2004-05-11 by Phil
I see a lot of hakko 850b clones on ebay for 130-160. does anyone
have this station? Is this a reasonably good product? any
experieces with it would be appreciated.
Phil
Re: [Homebrew_PCBs] Hot stations: Hakko and clones...
2004-05-11 by Alexandre Souza
I got one here in Brazil - works flawlessly. I have a Hakko at work and
a Sunkko 850A at home.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.681 / Virus Database: 443 - Release Date: 10/05/04
Re: Hot stations: Hakko and clones...
2004-05-11 by wheedal99
> Phil
I've got a Atten 850 dropped shipped direct from china. Works
great. You can get these in the states now fairly easy for the same
price (~$150)... Circuit specialists carries them now.
-Dal
2004-05-11 by mpdickens
> 130-160. does anyone have this station?
If you can find a Pace that was made in the last 10
years, buy it. No other rework station even comes
close to the over all dependability or ease of
reproducable results that a Pace gives.
Regards
Marvin Dickens
Do you Yahoo!?
Re: [Homebrew_PCBs] solder "tweezers" or hot air pencil?
2004-05-12 by Paul Davis
If all you're changing is caps and resistors you can do it with a plain soldering iron easily enough. You can remove sot-23 parts too but it's a little trickier.
Paul Davs
> better one (with a workig heater) or i could build solder tweezers.
> thanks
> ST
2004-05-12 by Stefan Trethan
> a little trickier.
> Paul Davs
How do you do that? without ripping off the contacts?
ST
You just heat one side up until the solder melts, then heat the other side but leave the heat on for an extra half second then heat the other pad and push of the part with the iron. The important thing is to have a clean iron tip and to get as much of the iron on the pad as possible so that you get good heat transfer. Until you get skilled at it you may have to move the iron from pad to pad a few extra times. if you have problems just add some extra solder to one side as it'll help to contain the heat longer. it's also easier with 60/40 rather that 63/37 solder. You won't rip contacts as long as both sides are still liquid. just don't force it. done right the part will slide right off.
For the sot-23 you can remove the solder form the single pin and then heat and lift the part just enough so that that pin is no longer connected. it's then easy to remove the other two pins.
Paul Davis
>> too but it's a little trickier. Paul Davs
> ST
> ------------------------ Yahoo! Groups Sponsor ---------------------
> ~--> Yahoo! Domains - Claim yours for only $14.70
> http://us.click.yahoo.com/Z1wmxD/DREIAA/yQLSAA/bGYolB/TM -----------
> files: http://groups.yahoo.com/group/Homebrew_PCBs Yahoo! Groups
> Links
Ok that's how i do it all the time... didn't love it too much.
(there is no secret trick)
thanks
ST
2004-05-13 by Leon Heller
Sent: Tuesday, May 11, 2004 9:27 PM
Subject: Re: [Homebrew_PCBs] Hot stations: Hakko and clones...
Metcal equipment is much better, IMHO. It's very expensive new, but often
available at reasonable prices on eBay.
Leon
2004-05-13 by mpdickens
Hello Leon!
I've had poor experiences with metcal equipment. When
it works, it works well, but it does not hold up as
well as pace. The metcal stuff has very modern
ergonomics. In fact, the ergonomics are better than
than any other equipment available. However, it's not
as well made as pace and cannot hold up in an
industrial environment (Which is why you rarely see it
in production centers that really turn out a lot of
work...).
As far as a feature for feature comparision, metcal
offers everything that pace does (And visa versa), but
the quality is just not there with the metcal gear and
when it fails, your done for the day (Which we cannot
afford). FWIW, we have 5 pace stations and we have
never had a station fail. Now, thats not to say we
have not had minor failures like a solder pin breaking
after 5 to 7 years of being on for 12 hours a day, but
nothing major: Nothing expensive or anything that
would shut us down for a day. I cannot say the same
for the metcal units we have used (And subsequently
gotten rid of).
Now, pace has been selling rework stations for 30
years. They have a HUGE install base. Metcal has been
in business for 10 to 15 years (I think...). Even so,
for every 30 metcal units you see on ebay, your lucky
if you see one pace unit. Everybody that owns a pace
keeps it forever or until it dies from old age. The
same thing can be said gear made by ERSA (Out of
Germany. They invented and patented the first
soldering iron in the 1920's). Everybody that owns an
ERSA keeps it forever.
My two cents.
Best
Marvin
Do you Yahoo!?
Yahoo! Movies - Buy advance tickets for 'Shrek 2'
http://movies.yahoo.com/showtimes/movie?mid=1808405861
2004-05-13 by Stefan Trethan
Well, then i better never throw it away...
I though we are talking about some "does the work on it's own" magic
soldering station. If you say the ersa tools are good then i'm lucky...
By the way, many ERSA stations use the heater as sensing thermistor.
Not sure if the very last generation does.
You can buy the 60W 24V irons for 50 eur, making the control electronics
isn't
hard...
ST
> My two cents.
> Best
> Marvin
> Do you Yahoo!?
2004-05-15 by Ron Amundson
Pace vs Metcal
My experience is just the opposite, however it is dated a few years.. We got
rid of all the Pace equipment and switched to Metcal. We had way too many
breakdowns with Pace. My gut feel says that most outfits go with Pace as its
cheaper upfront, rather than Metcal, but in the long term scheme of things,
the Metcal was cheaper and was much less of a hassle, especially when you
don't have the staffing to repair and fiddle with the Pace units.
However.... The newer Pace equipment is still much cheaper than Metcal, and
according to a friend of mine, their quality has improved multifold. He
bought a couple of them last year and was pretty impressed. As such, he just
bought 25 new Pace rework stations. If he is still happy with them in
another year, looks like I'll have to change too. Those Metcal rework tips
at $50-$75 each do get spendy.... He told me the Pace ones were about half.
I sure hope they work out well... that would be a big savings!!!
Ron
[Homebrew_PCBs] inkjet printer
2004-05-15 by Stefan Trethan
bought a stylus pro.
Will take a few days until i have it, then i let you know what it does.
is it safe to use alcohol to clean the head?
I have no windex and the ammonia i have was no much good with the hp
printer.
ST
Re: inkjet printer
2004-05-16 by Steve
> printer.
Isopropyl is safe. But not very effective. Mix nonsudsing household
ammonia half and half with 50% isopropyl alcohol. Cuts through just
about any ink.
Don't leave it in the printer, though, as ammonia eats metal for dinner.
Steve
