Homebrew_PCBs
Archive for Homebrew_PCBs.
brass tube vias
RE: [Homebrew_PCBs] brass tube vias
2017-10-30 by Paul
At the same place, there is also :
#TW002  .011" internal ..020" external   (.3 mm - .5 mm)
#TW003  .015" internal ..023" external   (.4 mm - .6 mm)
#TW004  .023" internal ..031" external   (.6 mm - .8 mm)
#TW005. .031" internal ..039" external   (.8 mm -  1 mm)
Good find, but how easy will this be to solder?  There also this place in Hong Kong :
https://www.ebay.com/itm/Brass-Copper-Round-Tube-Rod-Various-Diameters-0-8mm-0-4mm-1mm/252463752113?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D41375%26meid%3D6d4883ab395d4891935e709e981deddb%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D122716829812&_trksid=p2047675.c100005.m1851
NB :  copy past link
J J
From: Homebrew_PCBs@yahoogroups.com [mailto: Homebrew_PCBs@yahoogroups.com ]
Sent: Monday, October 30, 2017 1:07 PM
Subject: [Homebrew_PCBs] brass tube vias
I found brass tube that fits component leads that could be used as vias.
https://www.ebay.com/itm/121507489010
Alliance Model Works 1:24/35/48/72 1:350/700 Precision Brass Tubing 1.2mm #TW006
2017-10-31 by Tony Smith
OT but you can shorten eBay links by deleting the description and everything after the ?.
You just need https://www.ebay.com/itm/ and the actual item number, so https://www.ebay.com/itm/252463752113
Tony
Sent: Tuesday, 31 October 2017 5:04 AM
Subject: RE: [Homebrew_PCBs] brass tube vias
NB :  copy past link
J J
Re: [Homebrew_PCBs] brass tube vias
2017-10-31 by James
Without rivet heads, is it really any different than solid core wire of appropriate thickness?
That aside, and against my own reservations, I've got some of these in my Aliexpress cart currently when I get around to clearing it out next
(in case the listing goes, title is "1 Black Jar Boxed Bar Design 0.5mm Thickness Rivets Studs Gold Plated Metallic Japanese Style 3D Nail Art Decoration Accessories")
I have absolutely no idea if they are solid, brass, copper, or maybe even plastic, but for $2 I figure it's worth a look.
On Tue, Oct 31, 2017 at 6:06 AM, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
I found brass tube
2017-10-31 by Rob
We were having some banter earlier this month about how to get ..what to use... for vias through
a two sided PCB.
I found this particular tubing to be the correct size for component leads.
Your mileage may vary.
My experiments with two sided PCBs has been limited to
TWO single sided finished PCBs bolted together.
2017-10-31 by James
On Tue, Oct 31, 2017 at 3:44 PM, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
a two sided PCB.
I use (indeed, I sell locally) 0.8mm rivets, but they have heads, tin the pads, insert rivet, squish the tail, solder both sides ( not the best example, but anyway https://imgur.com/a/uH4Jy )
My point was what's the difference, for a via at least, of using a brass/copper tube of 0.x mm and just a couple mm length of solid copper wire 0.x mm diameter, same thing really isn't it.
If you want to insert component legs through for a diy plated through hole rather than just  a diy via then that's true of course, but that's not something I've had to do myself, I just solder the component leg on both top and bottom side when necessary
NB: I've been looking around to try and get 0.5mm rivets, but I have not found a (chinese) supplier of them in bulk.
2017-10-31 by Dale Chatham
The one thing one could do with the brass tubing is to make a conical tool for both sides which will flange the tubing.  Done right, it would produce an airtight seal and solder would be superfluous (though highly advised).
I found brass tube
Re: [Homebrew_PCBs] brass tube vias tooth press
2017-10-31 by Rob
I like that idea.
I may play with that idea.
I pretty much stick to 70 mm by 100 mm etching so perhaps a C clamp or a large jaw pliers that can reach 40mm (half way across the PCB.... would be good to hold the teeth cones.
I found brass tube
Re: brass tube vias
2017-10-31 by Paul Alciatore
I have seen boards made with brass tube eyelets that were not plated for
easy solderability. These eyelets worked about 99% of the time or, in
other words, 99 out of 100 of these eyelets gave no trouble. But that
last one, the one in a hundred had a little corrosion on it and the
solder did not take. But it was covered with the solder so you could NOT
see that it was a bad connection. After some time (years?) the
mechanical connection that initially worked, accumulated some more
corrosion and began to give trouble. It was a real PITA to try to
troubleshoot a board that had all good components and absolutely no
visible indication of the real problem. I spent many, many hours working
on those boards.
I do NOT like boards made with brass eyelets or terminals unless those
brass components are heavily plated with SOLDER. Not a thin layer of tin
or some other "compatible" metal, but actual SOLDER.
2017-10-31 by keith printy
When I worked in an electronics plant ,they had a hollow rivet they used for this. I saw many boards come back in for service where the rivet was no longer soldered to the pad. They used these where connectors were put in the board to strengthen it. I would at the very least wash the brass tubes in a mild acid to clean them and rinse well before using . lemon juice may work as I have seen it used for flux in a wave solder machine.
Sent: Monday, October 30, 2017 10:44 PM
Subject: Re: [Homebrew_PCBs] brass tube vias
a two sided PCB.
2017-10-31 by Bertho
Nice round eyelets are not want if you are using double sided PCBs. See Keith post below and read mine again.
Repeating my previous post:
Note: For joining top to bottom layers as is normally done, you do not want perfect little tubular eyelets. You should use eyelets that are formed from a strip and rolled into the eyelet shape. It will have a desirable vertical slit in it.
I know it sounds backwards but the reasons are very valid.
Many decades ago Motorola used eyelets on PCBs instead of through hole plating. Originally nice round eyelets were used and there were a lot of field failures. The solder properly solders the bottom section to the bottom runner, it wicks up through the eyelet and solders the component lead but there is no capillary action to draw the solder over the eyelet’s top edge onto the top runner so it only makes mechanical contact. The eyelets with a vertical slit avoids that problem.
Bertho
Sent: Tuesday, October 31, 2017 16:22
2017-11-01 by Karl Ireland
This is Fantastic!
I had no idea.  I struggle to find schematics and info.  Sometimes I cant find anything.
I must join this.
Thanks!
mosaicmerc@... [Homebrew_PCBs] wrote:
I just used component lead wires and solder both sides.
https://hackaday.io/project/7938-pcb-smt-maker-lab-home
                                    From
                                             Karl
                                                        Primatesfather@...
2017-11-01 by Tony Smith
If you don’t need the holes that’s the easiest way.
If you’ve a bunch of them then you can get a long pieces of copper wire, thread it though all of them, solder one side then flip it over to do the other, and finally trim the excess off.
Although finding a long piece of suitable copper (or tinned) wire can be surprising difficult at times.
Tony
Sent: Wednesday, 1 November 2017 1:16 PM
2017-11-01 by Harvey White
Bare wire is available, I used #26 gauge.
RULE: no vias under surface mount chips, and careful with the ones
under sockets. All through hole parts connect on bottom only. (some
parts cannot be soldered on the top layer). Does work, though.
Harvey
>Tony
Re: brass tube vias
2017-11-01 by Paul Alciatore
You may think that you have a good connection. The top manufacturing company who made the bad boards that I had to repair over and over again certainly did. But you can not trust it. PERIOD. The brass is swagged over the copper trace with a solder coating on it. Both brass and solder alloys are soft metals and expansion/contraction cycles will open a gap large enough for oxygen and other corrosive gasses in the air to penetrate. You will get oxidization and other forms of corrosion and eventually the joint may/will fail. And it will be HELL to find and repair especially with low level, high impedance signals. You could wind up completely replacing a PCB that cost hundreds, thousands, or even tens of thousands of dollars. I have seen it. I have fought it. Brass tubing or hollow brass rivets MUST be soldered for reliability and there is NO way to inspect that solder joint. It will look perfectly normal on the outside while it is was never a proper joint underneath and corrosion sets in. That is, assuming that the brass was not coated with corrosion before it was inserted in the hole.
USE soldered Z wires so you can see and inspect the solder joint if you want a dependable joint. Or get a board made with plated holes.
: "Dale Chatham
said,
advised).
Re: brass tube vias
YES, it is different than solid wire. Solid wire is copper and usually
plated with tin or solder so that it takes solder easily. Brass, if left
standing for any amount of time can acquire a coating of oxide which
resists solder adhesion. And most electronic fluxes are not formulated
to handle this. You would have to scrupulously clean the brass
immediately before inserting it and soldering it if you want reliable
connections. I have a lot of experience with brass that was "soldered"
to PCBs.
James said,
Re: [Homebrew_PCBs] Re: brass tube vias DONT DO IT
2017-11-02 by Rob
WOW!
That was a very educational discussion pretty much settling on DON'T DO IT.
I was not having anything lined up now that required vias.
I had just stumbled onto the brass tubes in a hobby shop and remembered someone posting questions
about vias here so I bought a few and checked out their mechanical fit..... never actually soldering anything.
Thanks for the education!
"Dale Chatham
said,
conical
it would
(though highly
> advised).
to PCBs.
James said,
_
2017-11-03 by AncelB
I ordered some of these vias from Ali express..
Seems to be a reasonable item providing that they are soldered in
directly. They also look good for creating non slip test points for
scope probes.
Ancel
2017-11-03 by Rob
Hi Ancel,
Can you be more specific.....which..... some of these vias?
Is there a look you could point to?
scope probes.
Ancel
 WOW!
"Dale Chatham
said,
> advised).
> to PCBs.
> James said,
