Homebrew_PCBs
Archive for Homebrew_PCBs.
Vintage PCB toner transfer problems
2017-07-06 by Brad
Hello,
A while ago I bought some vintage PCB stock from 1973.  I was really excited about this as it allowed me to go the last mile in making a reproduction look authentic.  However, I have discovered to my dismay that the toner transfer process is not working so well with these boards.
I’ve tried three media with my iron (I don’t have a laminator):
Blue PCB transfer sheets.  They stick wonderfully to the modern stock but not at all to this vintage stuff.
Yellow toner transfer paper.  Worked on the first two boards mostly, but now won’t stick to any of the others I have at all.
Magazine paper.  This sticks and I get 90% of the image, but that’s it.  And only with much greater effort than usual.
I have scrubbed these boards with comet and a scothbrite pad.  I note even after doing so I still get a fine red powder residue when wiping with acetone.  So I’m wondering if maybe this copper has just kinda gone bad over 44 years.
Another question – on a couple of boards I’ve used permanent marker to fill in gaps, but the etchant always eats it away like it wasn’t there.  Is there a particular brand I should be using?   This has happened with both vinegar/peroxide solutions and FeCl.
Thanks!
Re: Vintage PCB toner transfer problems
2017-07-06 by kbyrne10@...
Staedtler Lumocolor Red works well and the FeCI does not affect it at all.
Bought on E-Bay four colors 10.00 or so USD. Have only tried red so far but it works for touch up real well.
Re: [Homebrew_PCBs] Vintage PCB toner transfer problems
2017-07-06 by Keith B
I haven't been following the thread, so hopefully i'm not redundant.
That vintage board may be much heavier than you usually use
i.e. 2+ ounce copper etc. so you may need to heat it quite
a bit longer to get up to transfer temperatures.
That stuff may be WELL oxidized, to the point you have to get drastic
to clean it enough for tt. I have used a medium wire wheel on a bench
grinder in the past. The scratches may also help the toner to stick.
HTH
On Thu, 6 Jul 2017 08:40:06 -0700, you wrote:
>Hello,
>I've tried three media with my iron (I don't have a laminator):
>won't stick to any of the others I have at all.
>Magazine paper. This sticks and I get 90% of the image, but that's it. And
>acetone. So I'm wondering if maybe this copper has just kinda gone bad over
>44 years.
>Another question - on a couple of boards I've used permanent marker to fill
>in gaps, but the etchant always eats it away like it wasn't there. Is there
>Thanks!
This email has been checked for viruses by AVG.
http://www.avg.com
RE: [Homebrew_PCBs] Vintage PCB toner transfer problems
2017-07-06 by Brad
Yeah they are definitely pretty oxidized.. for example, where the sticker on the plastic packaging sat this is noticeable difference in color.  And I keep rubbing down with the acetone and still red dust comes off.  I’ll try a light sanding and see.. makes sense, these boards seem a little more discoloured than the others.
Sent: Thursday, July 6, 2017 11:27 AM
Subject: Re: [Homebrew_PCBs] Vintage PCB toner transfer problems
HTH
>Hello,
>44 years.
>Thanks!
http://www.avg.com
Virus-free. www.avg.com
RE: [Homebrew_PCBs] Re: Vintage PCB toner transfer problems
2017-07-06 by Brad
Okay I’ll get a few of those.  I thought Sharpie could handle it but apparently not.
I also purchased some dry-transfer PCB stuff.. has traces, pads, etc.. could use some of that.
Sent: Thursday, July 6, 2017 10:41 AM
Subject: [Homebrew_PCBs] Re: Vintage PCB toner transfer problems
2017-07-06 by allan.hale@...
Hi Brad,
On the severely oxidized portion of the boards you can try two items,  Straight, clear ammonia  NH4OH or sudsy ammonia with several applications it should clean off the old board but may take several applications tro achieve your desired results.
One other item to try is "Tarn-X" available at Walgreens and CVS stores.  This product is a thio-urea based cleaner and works wonders on PC boards based on personal experience. I'd avoid the sandpaper or emery cloth abrasive materials in favor of the liquid cleaner products.
When you get the copper mostly clean you could use "Brasso" to bring up a shine on the board, then wash with Dawn dishwashing detergent to remove any remaining oils followed by a clean water rinse and dryoff, before you proceed to the toner transfer process.  This practice should get your board almost surgically clean which is what you need for a really successful transfer process.
Best of luck in your endeavors!
Allan,   WA9IRS
2017-07-06 by keith printy
We used to use fine steel wool to clean the oxide off
Sent: Thursday, July 06, 2017 2:54 PM
Subject: RE: [Homebrew_PCBs] Vintage PCB toner transfer problems
HTH
>Hello,
>about thi! s as it allowed me to go the last mile in making a reproduction
>44 years.
>Thanks!
http://www.avg.com
Lemon juice may work also have seen it used as flux for soldering pc boards
Sent: Thursday, July 06, 2017 3:42 PM
Hi Brad,
Allan,   WA9IRS
Re: [Homebrew_PCBs] Re: Vintage PCB toner transfer problems
2017-07-07 by Harvey Altstadter
Brad,
A couple of thoughts:
I have used Bar Keeper's Friend on some stubbornly oxidized boards. It contains some oxalic acid, so wear gloves.
When a board is completely clean, it will support a continuous film of water. If you hold the board horizontal, and pour enough water on it to cover it, the water spreads out, and will pull away from any place that is not clean.  Pat the board dry with clean paper towels.
Harvey A
On 7/6/2017 12:41 PM, allan.hale@... [Homebrew_PCBs] wrote:
Hi Brad,
Allan,   WA9IRS
2017-07-07 by Brad
Thanks guys.  Going to take another run at it.
Question for those that iron – I have read competing schools of thought.. some say you need tons of pressure, others say you just need consistent heat.  Thoughts?
Sent: Thursday, July 6, 2017 8:09 PM
Subject: Re: [Homebrew_PCBs] Re: Vintage PCB toner transfer problems
Brad,
Harvey A
Hi Brad,
Allan,   WA9IRS
2017-07-07 by leeleduc@...
I use "Tarn-X". It's a cleaner for copper bottom pans and silverware. You can find it in the cleaners isle of the supermarket. Another brand that works well is Wrights Copper Cream.
Re: Vintage PCB toner transfer problems IRON pressure
2017-07-07 by Rob
I could not get consistent results with a clothes iron so I resorted to steel plates:
http://www.learnmorsecode.com/laminator/hotcakes.html
Brad,
Harvey A
Hi Brad,
Allan,   WA9IRS
RE: [Homebrew_PCBs] Re: Vintage PCB toner transfer problems IRON pressure
2017-07-08 by Brad
Will do.  In the last day I have managed to pull off two perfect transfers with magazine paper and my iron.  I clean the boards more heavily.  When ironing, I take a 10 minute pause and then resume.. for some reason it seems to help.
However one issue I’m seeing and had before with the magazine paper is that the printer is not putting enough toner down.  You can see a pixelation that looks just like what you see if you look really close at a magazine photo.  In spots, even though it has clearly lifted all the toner from the paper the toner is thin enough to leave micro traces of visible copper, which in turn gets attacked or pitted by the etchant.  Not sure how to get a thicker toner down or if maybe my ‘compatible’ toner is part of the problem.
Sent: Friday, July 7, 2017 6:56 PM
Subject: [Homebrew_PCBs] Re: Vintage PCB toner transfer problems IRON pressure
Brad,
Have a look at the videos in the files section of my project:
https://hackaday.io/project/3363-apache-al13p-tl-320b-one-pass-pcb-toner-xfer
2017-07-08 by Howard Chester
I no longer use the toner transfer method to produce my PCB's(I use UV exposure), I remember using "Orange scented household cleaner" as an adhesive to help the toner to adhere to the PCB with consistant results.
Orange scented spray household cleaners contain Citronella Oil. This is a slow solvent for the Toner when heated.
Prepare to PCB as usual, spray a small amount of cleaner on a paper kitchen towel. Apply a thin film to the PCB and carefully rub with a a clean paper towel until you have removed the cleaner(no trace on the paper towel). Iron as usual.
The fine layer of cleaner left behind after wiping clean dissolves a fine top layer of the toner and "sticks" the toner to the PCB.
A point to note, when removing the cleaner check the paper for any black deposists. Deposists indicate that the board still needs cleaning properly.
Hope this helps, chester
Re: [Homebrew_PCBs] Re: Vintage PCB toner transfer problems IRON pressure
2017-07-08 by Rob
Check out your print image quality options.
Mine defaults to NORMAL and had the option for DRAFT...which uses less toner and is lighter.
Perhaps your default is set to DRAFT.
You can always print again on the same paper to lay more toner layers.
Noting that toner will ALWAYS have microscopic pitting that can be attacked and etched
so I have resorted to always using the widest traces possible ... not the thinnest traces possible
and...
always tracing over the toner with a black Sharpie or EDDING 404  or STAEDLER LUMOCOLOR PERMANENT
marker.
It might be time consuming but I am not manufacturing items to sell.... its just a hobby.
 http://www.learnmorsecode.com/regen/00regen.html
Brad,
2017-07-08 by kbyrne10@...
I have found that only genuine HP Laser ink works not replacement ink.
Do you have software with printer to set density to 1200 times 1200 DPI?
2017-07-09 by Malcolm Parker-Lisberg
If your HP printer is newer than the one I have, you can use LJConfig to control the amount of toner laid down
<http://ljconfig.soft112.com/>
Malcolm
I don't suffer from insanity I enjoy it!
Mene, mene, tekel, upharsin
The writing is on the wall.
Ha-ktovet al ha-kir
On Sat, 7/8/17, kbyrne10@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Date: Saturday, July 8, 2017, 4:59 PM
not replacement ink.Do you have software with
#yiv4326670882 #yiv4326670882 --
#yiv4326670882ygrp-mkp {
0;padding:0 10px;}
#yiv4326670882 #yiv4326670882ygrp-mkp hr {
border:1px solid #d8d8d8;}
#yiv4326670882 #yiv4326670882ygrp-mkp #yiv4326670882hd {
0;}
#yiv4326670882 #yiv4326670882ygrp-mkp #yiv4326670882ads {
margin-bottom:10px;}
#yiv4326670882 #yiv4326670882ygrp-mkp .yiv4326670882ad {
padding:0 0;}
#yiv4326670882 #yiv4326670882ygrp-mkp .yiv4326670882ad p {
margin:0;}
#yiv4326670882 #yiv4326670882ygrp-mkp .yiv4326670882ad a {
#yiv4326670882 #yiv4326670882ygrp-sponsor
#yiv4326670882ygrp-lc {
font-family:Arial;}
#yiv4326670882ygrp-lc #yiv4326670882hd {
margin:10px
#yiv4326670882ygrp-lc .yiv4326670882ad {
#yiv4326670882 #yiv4326670882actions {
#yiv4326670882 #yiv4326670882activity {
#yiv4326670882 #yiv4326670882activity span {
font-weight:700;}
#yiv4326670882 #yiv4326670882activity span:first-child {
text-transform:uppercase;}
#yiv4326670882 #yiv4326670882activity span a {
#yiv4326670882 #yiv4326670882activity span span {
color:#ff7900;}
.yiv4326670882underline {
text-decoration:underline;}
#yiv4326670882 .yiv4326670882attach {
0;width:400px;}
#yiv4326670882 .yiv4326670882attach div a {
#yiv4326670882 .yiv4326670882attach img {
#yiv4326670882 .yiv4326670882attach label {
#yiv4326670882 .yiv4326670882attach label a {
#yiv4326670882 blockquote {
margin:0 0 0 4px;}
#yiv4326670882 .yiv4326670882bold {
#yiv4326670882 .yiv4326670882bold a {
#yiv4326670882 dd.yiv4326670882last p a {
#yiv4326670882 dd.yiv4326670882last p span {
span.yiv4326670882yshortcuts {
margin-right:0;}
#yiv4326670882 div.yiv4326670882attach-table div div a {
#yiv4326670882 div.yiv4326670882attach-table {
width:400px;}
#yiv4326670882 div.yiv4326670882file-title a, #yiv4326670882
div.yiv4326670882file-title a:active, #yiv4326670882
div.yiv4326670882file-title a:hover, #yiv4326670882
div.yiv4326670882file-title a:visited {
#yiv4326670882 div.yiv4326670882photo-title a,
#yiv4326670882 div.yiv4326670882photo-title a:active,
#yiv4326670882 div.yiv4326670882photo-title a:hover,
#yiv4326670882 div.yiv4326670882photo-title a:visited {
#yiv4326670882 div#yiv4326670882ygrp-mlmsg
#yiv4326670882ygrp-msg p a span.yiv4326670882yshortcuts {
#yiv4326670882 .yiv4326670882green {
color:#628c2a;}
#yiv4326670882 .yiv4326670882MsoNormal {
margin:0 0 0 0;}
#yiv4326670882 o {
font-size:0;}
#yiv4326670882 #yiv4326670882photos div {
float:left;width:72px;}
#yiv4326670882 #yiv4326670882photos div div {
border:1px solid
#666666;min-height:62px;overflow:hidden;width:62px;}
#yiv4326670882 #yiv4326670882photos div label {
#yiv4326670882 #yiv4326670882reco-category {
font-size:77%;}
#yiv4326670882 #yiv4326670882reco-desc {
font-size:77%;}
#yiv4326670882 .yiv4326670882replbq {
margin:4px;}
#yiv4326670882 #yiv4326670882ygrp-actbar div a:first-child {
#yiv4326670882 #yiv4326670882ygrp-mlmsg {
sans-serif;}
#yiv4326670882 #yiv4326670882ygrp-mlmsg table {
font-size:inherit;font:100%;}
#yiv4326670882 #yiv4326670882ygrp-mlmsg select,
#yiv4326670882 input, #yiv4326670882 textarea {
#yiv4326670882 #yiv4326670882ygrp-mlmsg pre, #yiv4326670882
code {
font:115% monospace;}
#yiv4326670882 #yiv4326670882ygrp-mlmsg * {
line-height:1.22em;}
#yiv4326670882 #yiv4326670882ygrp-mlmsg #yiv4326670882logo {
padding-bottom:10px;}
#yiv4326670882 #yiv4326670882ygrp-msg p a {
font-family:Verdana;}
p#yiv4326670882attach-count span {
#yiv4326670882 #yiv4326670882ygrp-reco
#yiv4326670882reco-head {
#yiv4326670882 #yiv4326670882ygrp-reco {
#yiv4326670882 #yiv4326670882ygrp-sponsor #yiv4326670882ov
li a {
li {
ul {
margin:0;padding:0 0 0 8px;}
#yiv4326670882 #yiv4326670882ygrp-text {
font-family:Georgia;}
#yiv4326670882 #yiv4326670882ygrp-text p {
margin:0 0 1em 0;}
#yiv4326670882 #yiv4326670882ygrp-text tt {
font-size:120%;}
#yiv4326670882 #yiv4326670882ygrp-vital ul li:last-child {
border-right:none !important;
#yiv4326670882
2017-07-09 by AncelB
Genuine or non oem HP toner works for me. For the pitting problem I
transfer craft metallic foil on top of the toner before etching. It's a
well known practice and reliable.
Rather than using acetone or citronella to prepare/clean the copper I
use 220 grit sandpaper and an iso-propyl wipe which makes the toner
'grip' the oil free copper. Even fingerprints can interfere so handle
the edges of the PCB. As a test I polished/lapped copper and tried the
identical transfer with poor results all other things being the same.
Also, before I did the metal foiling, I used to use a silver sharpie to
'fill' in the toner transfer for any breaks or potential pitting and
then etch.
I have done literally hundreds of double sided boards and even boards
for RF use to 1Ghz with toner transfer. It works.
Ancel
Re: [Homebrew_PCBs] Re: Vintage PCB toner transfer problems ios-propyl wipe
2017-07-09 by Rob
I had not tried alcohol.
I've been using 220 grit sandpaper per your advice...since  a year ago?
Then I used acetone to clean up the fingerprint oil and sanding dirt.
Not that fingerprints are a problem... I always wear heavy 9mil nitrile gloves when playing with PCBs.
Is the iso-prpyl wipe anything more than or different than using a tough paper towel and 91% alcohol?
I had experimented with transfer craft metallic foil but really didn't need the foil after using a Sharpie.
I can see using the foil for massively complicated or detailed  circuits that would test patience tracing a whole board with a Sharpie. But nothing I do is that complicated.
then etch.
Ancel
2017-07-09 by michael tenore
I have been using Toner Transfer with very good results!
I scrub my boards with very fine scotch-brite pads. They are grey colored and they are available
at auto parts stores. They are finer than 220 grit and give good tooth for the toner to attach to.
The green ones in the supermarket are usable but they are a coarser grit.
I use Isopropyl alcohol or acetone. the other cleaners are ok also but you have to rinse the board well.
I gave up on using an iron! I found a top of the line GBC H525 laminator  on line and I got it with
shipping for less than $100 on ebay. I pass my boards through 10 times.
regards
Mike
On Sunday, July 9, 2017 11:07 AM, "Rob roomberg@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
then etch.
Ancel
2017-07-10 by Harvey White
>at auto parts stores. They are finer than 220 grit and give good tooth for the toner to attach to.The green ones in the supermarket are usable but they are a coarser grit.I use Isopropyl alcohol or acetone. the other cleaners are ok also but you have to rinse the board well.
What I use:
scrub the boards with 1000 or 1200 grit wet/dry paper. Using it wet
is fine.
use something like bon-ami to clean the boards.
rinse them.
wipe with acetone to eliminate oil. You may see some copper dust.
Print and then run through laminator.
What you want is enough heat to make the toner adhere. For small
boards (less than 4x6 inches) I use about 6 to 8 passes. For larger
boards (perhaps more than that) I'd do 8 or so.
What you want is the board to be hot enough to soften the toner, make
it sticky, and let it adhere to the board.
I then (after the board runs through 6 or 8 times, 3 or 4 upwards, 3
or 4 downwards), dump it directly into room temperature water.
blow dry with hair dryer
run through same laminator twice with green foil (not tried other
ones).
Let that cool
peel off
etch
sand off toner with wet/dry paper, 1000 grit is fine.
(keeps acetone dissolved toner from discoloring board. Your choice.)
Tin as needed,
rinse!!!
(tin/lead is nasty stuff)
Dry in sun, etc
rinse and use.
10/10 is reliable with this. Never tried 8/8.
Harvey
>I gave up on using an iron! I found a top of the line GBC H525 laminator  on line and I got it withshipping for less than $100 on ebay. I pass my boards through 10 times.
>regards
>Mike
> then etch.
> Ancel
> #yiv9591100991 #yiv9591100991 -- #yiv9591100991ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv9591100991 #yiv9591100991ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv9591100991 #yiv9591100991ygrp-mkp #yiv9591100991hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv9591100991 #yiv9591100991ygrp-mkp #yiv9591100991ads {margin-bottom:10px;}#yiv9591100991 #yiv9591100991ygrp-mkp .yiv9591100991ad {padding:0 0;}#yiv9591100991 #yiv9591100991ygrp-mkp .yiv9591100991ad p {margin:0;}#yiv9591100991 #yiv9591100991ygrp-mkp .yiv9591100991ad a {color:#0000ff;text-decoration:none;}#yiv9591100991 #yiv9591100991ygrp-sponsor #yiv9591100991ygrp-lc {font-family:Arial;}#yiv9591100991 #yiv9591100991ygrp-sponsor #yiv9591100991ygrp-lc #yiv9591100991hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv9591100991 #yiv9591100991ygrp-sponsor #yiv9591100991ygrp-lc .yiv9591100991ad {margin-bottom:10px;padding:0
0;}#yiv9591100991
>#yiv9591100991actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv9591100991 #yiv9591100991activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv9591100991 #yiv9591100991activity span {font-weight:700;}#yiv9591100991 #yiv9591100991activity span:first-child {text-transform:uppercase;}#yiv9591100991 #yiv9591100991activity span a {color:#5085b6;text-decoration:none;}#yiv9591100991 #yiv9591100991activity span span {color:#ff7900;}#yiv9591100991 #yiv9591100991activity span .yiv9591100991underline {text-decoration:underline;}#yiv9591100991 .yiv9591100991attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv9591100991 .yiv9591100991attach div a {text-decoration:none;}#yiv9591100991 .yiv9591100991attach img {border:none;padding-right:5px;}#yiv9591100991 .yiv9591100991attach label {display:block;margin-bottom:5px;}#yiv9591100991 .yiv9591100991attach label a
>{text-decoration:none;}#yiv9591100991 blockquote {margin:0 0 0 4px;}#yiv9591100991 .yiv9591100991bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv9591100991 .yiv9591100991bold a {text-decoration:none;}#yiv9591100991 dd.yiv9591100991last p a {font-family:Verdana;font-weight:700;}#yiv9591100991 dd.yiv9591100991last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv9591100991 dd.yiv9591100991last p span.yiv9591100991yshortcuts {margin-right:0;}#yiv9591100991 div.yiv9591100991attach-table div div a {text-decoration:none;}#yiv9591100991 div.yiv9591100991attach-table {width:400px;}#yiv9591100991 div.yiv9591100991file-title a, #yiv9591100991 div.yiv9591100991file-title a:active, #yiv9591100991 div.yiv9591100991file-title a:hover, #yiv9591100991 div.yiv9591100991file-title a:visited {text-decoration:none;}#yiv9591100991 div.yiv9591100991photo-title a, #yiv9591100991 div.yiv9591100991photo-title a:active, #yiv9591100991 div.yiv9591100991photo-title a:hover,
>#yiv9591100991 div.yiv9591100991photo-title a:visited {text-decoration:none;}#yiv9591100991 div#yiv9591100991ygrp-mlmsg #yiv9591100991ygrp-msg p a span.yiv9591100991yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv9591100991 .yiv9591100991green {color:#628c2a;}#yiv9591100991 .yiv9591100991MsoNormal {margin:0 0 0 0;}#yiv9591100991 o {font-size:0;}#yiv9591100991 #yiv9591100991photos div {float:left;width:72px;}#yiv9591100991 #yiv9591100991photos div div {border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}#yiv9591100991 #yiv9591100991photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv9591100991 #yiv9591100991reco-category {font-size:77%;}#yiv9591100991 #yiv9591100991reco-desc {font-size:77%;}#yiv9591100991 .yiv9591100991replbq {margin:4px;}#yiv9591100991 #yiv9591100991ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv9591100991 #yiv9591100991ygrp-mlmsg
>{font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv9591100991 #yiv9591100991ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv9591100991 #yiv9591100991ygrp-mlmsg select, #yiv9591100991 input, #yiv9591100991 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv9591100991 #yiv9591100991ygrp-mlmsg pre, #yiv9591100991 code {font:115% monospace;}#yiv9591100991 #yiv9591100991ygrp-mlmsg * {line-height:1.22em;}#yiv9591100991 #yiv9591100991ygrp-mlmsg #yiv9591100991logo {padding-bottom:10px;}#yiv9591100991 #yiv9591100991ygrp-msg p a {font-family:Verdana;}#yiv9591100991 #yiv9591100991ygrp-msg p#yiv9591100991attach-count span {color:#1E66AE;font-weight:700;}#yiv9591100991 #yiv9591100991ygrp-reco #yiv9591100991reco-head {color:#ff7900;font-weight:700;}#yiv9591100991 #yiv9591100991ygrp-reco {margin-bottom:20px;padding:0px;}#yiv9591100991 #yiv9591100991ygrp-sponsor #yiv9591100991ov li a {font-size:130%;text-decoration:none;}#yiv9591100991 #yiv9591100991ygrp-sponsor
>#yiv9591100991ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv9591100991 #yiv9591100991ygrp-sponsor #yiv9591100991ov ul {margin:0;padding:0 0 0 8px;}#yiv9591100991 #yiv9591100991ygrp-text {font-family:Georgia;}#yiv9591100991 #yiv9591100991ygrp-text p {margin:0 0 1em 0;}#yiv9591100991 #yiv9591100991ygrp-text tt {font-size:120%;}#yiv9591100991 #yiv9591100991ygrp-vital ul li:last-child {border-right:none !important;}#yiv9591100991
2017-07-10 by don@...
I first used toner transfer paper purchased at Digikey over 20 years ago.
Discovered the whole process to be RUBBISH...
So it seams still is.
Digikey discontinued to carry it after everyone else failed too.
I get 98% success with presensitsed photo etch with a clear positive image on film.
Don Matthys
dba Don's Light and Magic
www.dlmparts.com
don@...
John Adams wrote that the Fourth of July "...ought to be celebrated by pomp and parade, with shows, games, sports, guns, bells, bonfires, and illuminations from one end of this continent to the other..."
The clear film transfer is something I've not had a lot of luck with.
The Pulsar paper, once you understand the limits of the process, will
work.
Photoetch is the best method, but it has problems as well, a good
opaque pattern is key, and a good coated board is also key.
Harvey
>Don Matthys
>www.dlmparts.com
>don@...
2017-07-11 by Brad
Are you using an iron or a laminator?  I’m finding I get very good results with iron if I do the prep properly, but there’s always that one spot that no matter how much heat or pressure you put on it, the toner doesn’t stick.
Sent: Sunday, July 9, 2017 7:29 AM
then etch.
Ancel
