Brad,
I looked at your artwork scans. WOW. Has anyone
suggested that you might be a glutton for
punishment?
I noticed that the first two scans are much
cleaner than the others. If you have access to the
pages that they were scanned from, you should
re-scan with the lines square to the scanning
direction. This will produce much cleaner results.
Before you invest too much time is trying to make
clean artwork using the scans as a basis, make
sure that the scanning process didn't distort the
dimensions in one direction or the other. I have
found small differences in the scaling between the
x and y axes that make assembly of 40 pin ICs, or
long connectors impossible.
These boards will be difficult to etch. The
combination of large open spaces and very narrow
traces may make it difficult to keep the traces
from over etching.
To answer your question about plated through
holes, they can be done, but it is a bit involved.
There are a number of tutorials on making plated
through holes on YouTube. Here are two of them:
Process 1:
https://www.youtube.com/watch?v=KTNuTv_IQp4
Process 2:
https://www.youtube.com/watch?v=s3GY-j4Gh0E
https://www.youtube.com/watch?v=9rME-XGCcCo
I have not tried either of these processes, but
they do seem possible.� The difficulty I see
with your boards is the sheer number of holes. The
possibility that one or more of the holes,
especially the small via holes, not getting plated
through is very great. Finding an open would be
very difficult, not to mention time consuming.
One thing to remember: The holes are drilled and
plated before the board is etched. This means that
the holes need to be protected during the etching
process. It seems to me that the best process for
doing this would be the photoresist process. The
photomask used for resist exposure would need to
have the drill holes omitted, so the resist will
tent over the holes during etching. Drilling
before photomasking has the benefit that it makes
the mask easier to align. I would suggest that
some extra pads with holes should be included on
the masks to assist with alignment. These pads
would include the drill holes. This also improves
the probability that two sided boards would have
proper alignment between sides.
Harvey
My TV Typewriter project
is getting close to the finish line so I�m
working on lining up a new project.
What I�d like to do
next is a replica of the SOL terminal
prototype that appeared in Popular
Electronics in July of 1976.� I have the
artwork for it here:
http://www.sol20.org/articles/img/PE_SOL.pdf
As you can see, the
quality of the scan is pretty lousy.�
There�s no other sources for this that
I�ve found.� I can clean it up manually
with Photoshop or Illustrator (and in fact
have started on the former) but that will
take hours (months, probably).� I�m
wondering if there�s a better technique
than endlessly using the rectangle tool to
remake the traces and remote the
�noise�.
I expect there will be
other challenges, being that this is a
double sided board.� There *isn�t*
a way for a home PCB maker to do thru-plate
without third party help is there?� I
don�t want to send this off to a board
house because of the likely cost but also
because that�s not how a hobbyist would
have done it back then.� Since this
artwork was sent to those that wrote in for
it, I�m assuming they just created it as a
two sided board the usual way and then
soldered in the connections between sides
via ICs, jumper wire, etc.
I also don�t want to
completely redraw the thing.� For me, that
would lose the spiritual connection to the
original artwork.� I�m trying to leave
as much of it as original as possible.
Anyway, thoughts and
suggestions here are most welcome.
