Temp upgrades of lam's
2016-12-29 by kbyrne10@...
Archive for Homebrew_PCBs.
I own a TL902 Thermal Laminator By Scotch and viewed a different GBC post of a repair parts manual and need to know if any one can assist me in locating a parts type manual for mine so I may try to increase the heat of it up to 340 degrees. I have no idea what the heat is now as my manual and box does not state that only two settings available. One 3 mil second one 5 mil
with 5 mil I assume is hotter.
2016-12-29 by Rob
_
2016-12-29 by Kevin Byrne
2016-12-29 by Harvey Altstadter
Kevin,
Here is a link to a site that explains the difference between the thermocouple types: https://www.instrumart.com/MoreAboutCategory?CategoryID=742&gclid=Cj0KEQiAhZPDBRCz642XqYOCpb8BEiQANUcwTyWZq5RBUZO0rrRfC-M4AGxYj7g7muRGW_8__DDxp9kaAh1q8P8HAQ&gclsrc=aw.ds
Operationally, the type K covers a wider temperature rance, but for the laminator project, the temperatures are nowhere near the limits for either type. The thermocouple type has to match the type required by the instrument you are using. The thermocouples are available with several different structures. In my case, I use a bead type that allows me to touch the rollers without conducting away significant heat. I can then get a reading with the case closed, giving me the most accurate picture of what happens in use. E-bay has the thermocouple and the instruments at very good prices. If you are going to use the bead type, order a few, because they are a bit fragile.
Harvey
Another question If I may. I have a Digi-Sense Digital Thermometer Type J Thermometer. What if any is the difference between the two Type K and Type J probesor is it internal?
2016-12-29 by keith printy
It is just the materials used in the thermocouple and the output for whatever temperature you are reading.i think the k type can withstand higher temperatures but a j is good for at least 500 degrees
Sent: Thursday, December 29, 2016 12:11 PM
Subject: Re: [Homebrew_PCBs] Temp upgrades of lam's
or is it internal?
I use infra red at work.if you want to read the temperature of a pipe accurately you have to wrap black tape around it. in a laminator that won’t work!
Sent: Thursday, December 29, 2016 11:46 AM
Got the message loud and clear as all that I have is infrared. Off to E_Bay to buy meter. Best Kevin
2016-12-30 by AncelB
2016-12-30 by Rob
Non contact passive infrared rules...
Get one of these...
https://www.sparkfun.com/products/9570
2016-12-30 by Harvey Altstadter
Ancel,
In the Harbor Freight laminator, the rollers are almost completely surrounded by an aluminum structure that contains the heaters, and radiates the heat to the rollers. I have two non contact IR thermometers, one with a 1:8 ratio, and one with a 1:1 ratio. even the 1:1 unit has too wide a field to read the roller temperature through the narrow slots on the structure. My contact method shows that the structure is about 20°C hotter than the rollers. So, while the non contact method rules, it is not a general solution.Non contact passive infrared rules...
Get one of these...
Rob,
The Passive IR gun type thermometer is only used for making
initial measurements, not for a feedback type control system. The
PIR thermometers have a distance to spot ratio. The Sparkfun unit
mentioned previously has a ratio of 12:1, meaning that at a
distance of 12 inches, the detector is reading the temperature in
a 1 inch circle. The thermistor and thermocouple approaches
measure the temperature at the point of contact, a much smaller
area. With the PIR thermometer, I could not read the rollers in my
laminator at all because they are surrounded by the heater
structure except where the paper path is. Those slots were too
narrow for either of my PIR thermometers. Another issue with the
PIR thermometers, usually ignored in the advertising, is that the
emissivity of the surface being measured has an effect on the
readings. In plain English, this means that two surfaces made with
different materials could be at the same temperature, but give
different readings on the PIR. Surfaces with multiple materials,
if they fall in the reading area, will give a reading that
integrates the two readings, rather than providing a true reading.
I tried to use the RepRap thermistor in my original control circuit, and found that while it works, the resistance vs temperature curve is very flat near 200°C, making the controller action sluggish. I abandoned the thermistor approach in favor of a purchased controller with a type K thermocouple. This cost USD 8.99 on e-bay from China. I have not yet put it into service because of the melted gears.
As far as the location of the thermistor in the Royal laminator,
this is a mechanically simple location to use, and if we think
about it, we understand that there is no need to measure the
actual temperature of the rollers, at least in the original
application of the laminator. As long as the temperature drop
between the heater and the roller is known, the system can be
calibrated for proper operation with the thermistor mounted on the
heater structure. The Harbor Freight unit uses mechanical
thermoswitches mounted on the heater structure.
In our toner transfer case, it is not clear (at least to me) that measuring at the heater is sufficient. Since we are putting single or double sided thermally conductive boards of different sizes through the rollers, I am not sure that the temperature drop is sufficiently constant that we don't have to measure the temperature at the roller. I was experimenting with this when my gears turned to mush.
Harvey
Where do you mount this device without destroying it and melting solder on the supporting
chips in the toner work PCB heating path?
How far do you mount it from the desired location where you are pinpointing temperature measurment?
While I would agree that a Non contact passive infrared rules..........
I would like to some day compare the accuracy of the $20 passive infrared with
the K type thermocouple and a simple thermistor.
Noting that my ROYAL laminator heater control was done by a contact thermistor clamped to the aluminum heat shield
behind a roller heater.
When I was looking into thermocouple circuits and supporting chips it looked like about $15 gets that done
and
5 cents buys a thermistor....
or maybe a dollar if it has wires.
New Reprap NTC 3950 Thermistor 100K with 1 Meter wire for 3D Printer TSCA
Get one of these...
2016-12-30 by Rob
Rob,
The Passive IR gun type thermometer is only used for making initial measurements, not for a feedback type control system. The PIR thermometers have a distance to spot ratio. The Sparkfun unit mentioned previously has a ratio of 12:1, meaning that at a distance of 12 inches, the detector is reading the temperature in a 1 inch circle. The thermistor and thermocouple approaches measure the temperature at the point of contact, a much smaller area. With the PIR thermometer, I could not read the rollers in my laminator at all because they are surrounded by the heater structure except where the paper path is. Those slots were too narrow for either of my PIR thermometers. Another issue with the PIR thermometers, usually ignored in the advertising, is that the emissivity of the surface being measured has an effect on the readings. In plain English, this means that two surfaces made with different materials could be at the same temperature, but give different readings on the PIR. Surfaces with multiple materials, if they fall in the reading area, will give a reading that integrates the two readings, rather than providing a true reading.
As far as the location of the thermistor in the Royal laminator, this is a mechanically simple location to use, and if we think about it, we understand that there is no need to measure the actual temperature of the rollers, at least in the original application of the laminator. As long as the temperature drop between the heater and the roller is known, the system can be calibrated for proper operation with the thermistor mounted on the heater structure. The Harbor Freight unit uses mechanical thermoswitches mounted on the heater structure.
Harvey
and
Get one of these...
Rob,
The link that I purchased from is inactive, but this is the same unit:
http://www.ebay.com/itm/12V-24V-Digital-Temperature-Controller-Board-Thermostat-K-Thermocouple-Probe-/182145097075?var=&hash=item2a68b19d73:m:m-d0W2aqMiE7N3CDhyhvxFwIT
has the thermocouple in a bolt, but I also bought several pieces
of the bead type in case I need to have the thermocouple in
contact with the roller. The one I bought operates from 12 VDC. A
small wall wart would do, or as in my case, I bought a 110VAC to
12 VDC converter module from ebay. Very little current is needed.
One like this would do:
http://www.ebay.com/itm/85V-265V-to-6V-12VDC-6W-9W-2-3-x3W-900ma-12V-LED-Driver-Power-Supply-/251651394313?hash=item3a97978b09:g:CPcAAOSw1DtXI3rk
Which one?
RE:
On 12/30/2016 01:04 PM, Harvey Altstadter hrconsult@... [Homebrew_PCBs] wrote:
Rob,
Harvey
and
Get one of these...
2016-12-30 by keith printy
The lead wires on thermocouples usually are soldered with some type of lead based solder. In high heat conditions this can come loose or oxidize to where it is weak . when I worked in an electronics plant and we dealt with high heat we always used thermocouples. When we used a packaged temperature controller they were usually type j . when we used microprocessor control they were type k .
Sent: Friday, December 30, 2016 2:29 PM
Subject: Re: [Homebrew_PCBs] Temp upgrades of lam's NON CONTACT PASSIVE INFRARED
Which one?
RE:
Rob,
Harvey
and
New Reprap NTC 3950 Thermistor 100K with 1 Meter wire for 3D Printer TSCAOn 12/30/2016 09:02 AM, AncelB mosaicmerc@... [Homebrew_PCBs] wrote:
Get one of these...
2016-12-31 by Rob
Which one?
RE:
approach in favor of a purchased controller with a type K thermocouple. This cost USD 8.99 on e-bay from China. I have not yet put it into service because of the melted gears.On 12/30/2016 01:04 PM, Harvey Altstadter hrconsult@... [Homebrew_PCBs] wrote:
Rob,
Harvey
2016-12-31 by Harvey Altstadter
Thermocouples are made by welding two wires of different
materials together. That's what makes the bead on the bead type.
The other terminations are just methods for making rugged ways to
mount and protect the bead, which is kind of fragile. The wires
will stay together over the entire operating temperature range of
the TC. Thermistors are usually soldered into their circuits. The
temperature at which the joints will fail is a function of what
type of solder was used. Depending on the type of lead material
used on the thermistor, it may also possible to weld them. The
RepRap glass bead thermistors that I bought have magnetic leads,
telling me that they are probably weldable, and I would expect
that the thermistor that comes with the cable attached is probably
welded.
How HIGH is what you say is high heat conditions that weaken the soldered thermocouple ?
Considering that some are rated at over 2,000 F degrees
while others only are rated to 400 F.
Which one?
RE:
Rob,
Harvey
2016-12-31 by AncelB
2016-12-31 by David C. Partridge
But, but the heaters are concentric with the rollers (or at least they are in my laminator) so
stopped/forward/reverse should make no difference.
Dave
2016-12-31 by Rob
Dave
Ancel,
I am not sure I understand why slowing the rollers causes them to
pick up more heat energy. In my laminator (Harbor Freight) there
are two heaters, placed on opposite sides fo the rollers. The
heaters are attached to aluminum structures that enclose the
roller assembly all around, except for the slots for the paper
path. Slowing down the rollers does not change their exposure to
the heat source when there is no board traversing the path. With a
board in place, the board would act as a heat removal path,
changing the temperature of the rollers. I would think that slower
speed would allow more heat to bleed out the otherwise closed
heater area. Does the Apache/Trulam have an open structure that
allows visibility by the FLIR camera? It would be difficult to get
a good reading on the Harbor Freight unit because of the close
spacing (~1/8") of the paper path. The rollers are recessed far
inside, and the slots are actually a fairly deep aluminum
structure.
Less accurate control systems in the cheap units is an understatement. The temperature control for my unit is a thermoswitch mounted on the heater. This is a single heat unit, so no more control is needed for normal lamination. I got curious to see what temperature the thermal fuse is rated for. This fuse is clamped to one of the aluminum heater fins, and is covered by a flexible plasticized glass fiber filled sleeve. The fuse is marked as 185°C. By mounting it in the thermally insulating sleeve, the heater temperature can go higher without tripping the fuse. I had it operating at approximately 210°C for an extended period without any complaint from the fuse. The only thing that fuses was the gears.
I have not yet had the time to determine the softening
temperature of the structural plastic that supports the roller
assembly. This outcome will determine whether there is any point
in continuing with this particular laminator. The Brother toner
supposedly fuses around 370°F, or 188°C. I have measured a 20°C
temperature difference between the heater fins and the roller,
making operation around 210+°C a necessary condition for my use of
this laminator.
When a laminator's net roller speed is modified, you also modify the
heat energy transfer to the rollers as the same surface of the roller
sees more radiant heat in a given time. Thus it gets hotter without even
upgrading the heater.
Now if you run the rollers too slow, the roller area being heated vs the
roller area being sensed will have a hi temperature delta and you could
burn the rollers. If the gears are exposed to some of this heat
conducted by the roller shaft, thermoplastic gears can 'become' plastic
and fail.
I encountered this heat delta effect when I was developing & monitoring
my Apache/Trulam mod with a FLIR camera. To eliminate this heat spike,
whenever the mod. reverses the roller it cuts the heater. This seems to
work well to date with no roller damage and good transfers. Thus running
the laminator at 'normal' speed during the heat up phase and then
'slowing' the rollers just for the Toner Transfer phase and returning
the laminator to normal speed afterward keeps the rollers from seeing
too much of a heat delta cycle and they suffer less degradation.
For the different laminators being modified, cheaper units seem to have
cheaper materials in them, with less accurate controls. Thus it's trial
and error as to how slow and how hot you can go before you exceed the
design spec enough to destroy the laminator and make a fire hazard.
Rob's approach eliminates this risk but is not 'over the counter'
repeatable for everyone and is certainly more time consuming when you
have a batch to run!
I shipped a built Apache/Trulam mod. to Italy yesterday based on the
newer layout with the SMT PIC. It uses low ESR SMT bypass caps and wider
power rail traces as well to mitigate PIC resets due to transient power
spijes as are generated from the relay and heater switching.
Rob,
The Harbor Freight unit is "concentric" in the sense that the
heat is provide from all around the roller assembly. It is not
concentric with either roller. There are two heaters mounted on
opposite sides of the rollers, and an aluminum structure that is
manufactured to fit around the rollers. The aluminum structure is
actually two pieces that are separated to form the slots for the
paper path.
The BOM for this unit is mostly irrelevant. By the time the mod
is done, not much of the original circuitry or wiring remains. The
temperature control thermoswitch is removed,and replaced by the
temperature controller I referenced yesterday, the thermal switch
that controls the ready light is removed because it operates at a
temperature that is irrelevant. What remains is the small circuit
board that holds the ready LED and the power indicator LED, and
the ON/OFF switch. This board has two rectifiers, two resistors
and two LEDs. The motor remains, the heaters remain and the
thermal fuse remains.
There are some photos of the interior of the laminator here:
https://www.flickr.com/photos/15304611@N03/sets/72157635447779272/
This mod is one that adds a dimmer in series with the motor, so
most of the pics have to do with modifying and mounting the
dimmer, but there a few that show the motor, the heater and the
circuit board. The heater control thermoswitch is on the underside
of the heater assembly, and not in view in these pics.
Really? This grabs my attention.
What make and model?
Can you take a picture and share?
Is there an online parts list we can eyeball that shows how concentric heaters are mounted?
On 12/31/2016 11:53 AM, 'David C. Partridge' david.partridge@... [Homebrew_PCBs] wrote:
Dave
2016-12-31 by Rob
Rob,
The Harbor Freight unit is "concentric" in the sense that the heat is provide from all around the roller assembly. It is not concentric with either roller. There are two heaters mounted on opposite sides of the rollers, and an aluminum structure that is manufactured to fit around the rollers. The aluminum structure is actually two pieces that are separated to form the slots for the paper path.
The BOM for this unit is mostly irrelevant. By the time the mod is done, not much of the original circuitry or wiring remains. The temperature control thermoswitch is removed,and replaced by the temperature controller I referenced yesterday, the thermal switch that controls the ready light is removed because it operates at a temperature that is irrelevant. What remains is the small circuit board that holds the ready LED and the power indicator LED, and the ON/OFF switch. This board has two rectifiers, two resistors and two LEDs. The motor remains, the heaters remain and the thermal fuse remains.
There are some photos of the interior of the laminator here: https://www.flickr.com/photos/15304611@N03/sets/72157635447779272/ This mod is one that adds a dimmer in series with the motor, so most of the pics have to do with modifying and mounting the dimmer, but there a few that show the motor, the heater and the circuit board. The heater control thermoswitch is on the underside of the heater assembly, and not in view in these pics.
Harvey
Dave
2016-12-31 by Malcolm Parker-Lisberg
On Sat, 12/31/16, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Subject: [Homebrew_PCBs] Temp upgrades of lam's Harbor Freight hack
Date: Saturday, December 31, 2016, 8:31 PM
thanks
I had not seen that dimmer hack yet.
Those pictures show the guts of the laminator.
Looks a lot like my APACHE AL9
http://www.learnmorsecode.com/laminator/al9.html
http://www.learnmorsecode.com/laminator/gbc/index.html
On 12/31/2016 02:38 PM,
Harvey
Rob,
assembly.
are two
rollers, and an
around the
two pieces
paper path.
By the time
circuitry or
thermoswitch is
controller I
controls the
a
is the small
power
board has two
motor remains,
remains.
laminator
here: https://www.flickr.com/photos/15304611@N03/sets/72157635447779272/%c2%a0
with the
modifying and
the motor,
control
assembly,
Harvey
On
12/31/2016 11:10 AM, Rob roomberg@...
attention.
eyeball that
mounted?
On
But,
with the
my laminator)
so
should make no
difference.
Dave
#yiv1213773308 #yiv1213773308 --
#yiv1213773308ygrp-mkp {
0;padding:0 10px;}
#yiv1213773308 #yiv1213773308ygrp-mkp hr {
border:1px solid #d8d8d8;}
#yiv1213773308 #yiv1213773308ygrp-mkp #yiv1213773308hd {
0;}
#yiv1213773308 #yiv1213773308ygrp-mkp #yiv1213773308ads {
margin-bottom:10px;}
#yiv1213773308 #yiv1213773308ygrp-mkp .yiv1213773308ad {
padding:0 0;}
#yiv1213773308 #yiv1213773308ygrp-mkp .yiv1213773308ad p {
margin:0;}
#yiv1213773308 #yiv1213773308ygrp-mkp .yiv1213773308ad a {
#yiv1213773308 #yiv1213773308ygrp-sponsor
#yiv1213773308ygrp-lc {
font-family:Arial;}
#yiv1213773308ygrp-lc #yiv1213773308hd {
margin:10px
#yiv1213773308ygrp-lc .yiv1213773308ad {
#yiv1213773308 #yiv1213773308actions {
#yiv1213773308 #yiv1213773308activity {
#yiv1213773308 #yiv1213773308activity span {
font-weight:700;}
#yiv1213773308 #yiv1213773308activity span:first-child {
text-transform:uppercase;}
#yiv1213773308 #yiv1213773308activity span a {
#yiv1213773308 #yiv1213773308activity span span {
color:#ff7900;}
.yiv1213773308underline {
text-decoration:underline;}
#yiv1213773308 .yiv1213773308attach {
0;width:400px;}
#yiv1213773308 .yiv1213773308attach div a {
#yiv1213773308 .yiv1213773308attach img {
#yiv1213773308 .yiv1213773308attach label {
#yiv1213773308 .yiv1213773308attach label a {
#yiv1213773308 blockquote {
margin:0 0 0 4px;}
#yiv1213773308 .yiv1213773308bold {
#yiv1213773308 .yiv1213773308bold a {
#yiv1213773308 dd.yiv1213773308last p a {
#yiv1213773308 dd.yiv1213773308last p span {
span.yiv1213773308yshortcuts {
margin-right:0;}
#yiv1213773308 div.yiv1213773308attach-table div div a {
#yiv1213773308 div.yiv1213773308attach-table {
width:400px;}
#yiv1213773308 div.yiv1213773308file-title a, #yiv1213773308
div.yiv1213773308file-title a:active, #yiv1213773308
div.yiv1213773308file-title a:hover, #yiv1213773308
div.yiv1213773308file-title a:visited {
#yiv1213773308 div.yiv1213773308photo-title a,
#yiv1213773308 div.yiv1213773308photo-title a:active,
#yiv1213773308 div.yiv1213773308photo-title a:hover,
#yiv1213773308 div.yiv1213773308photo-title a:visited {
#yiv1213773308 div#yiv1213773308ygrp-mlmsg
#yiv1213773308ygrp-msg p a span.yiv1213773308yshortcuts {
#yiv1213773308 .yiv1213773308green {
color:#628c2a;}
#yiv1213773308 .yiv1213773308MsoNormal {
margin:0 0 0 0;}
#yiv1213773308 o {
font-size:0;}
#yiv1213773308 #yiv1213773308photos div {
float:left;width:72px;}
#yiv1213773308 #yiv1213773308photos div div {
border:1px solid
#666666;height:62px;overflow:hidden;width:62px;}
#yiv1213773308 #yiv1213773308photos div label {
#yiv1213773308 #yiv1213773308reco-category {
font-size:77%;}
#yiv1213773308 #yiv1213773308reco-desc {
font-size:77%;}
#yiv1213773308 .yiv1213773308replbq {
margin:4px;}
#yiv1213773308 #yiv1213773308ygrp-actbar div a:first-child {
#yiv1213773308 #yiv1213773308ygrp-mlmsg {
sans-serif;}
#yiv1213773308 #yiv1213773308ygrp-mlmsg table {
font-size:inherit;font:100%;}
#yiv1213773308 #yiv1213773308ygrp-mlmsg select,
#yiv1213773308 input, #yiv1213773308 textarea {
#yiv1213773308 #yiv1213773308ygrp-mlmsg pre, #yiv1213773308
code {
font:115% monospace;}
#yiv1213773308 #yiv1213773308ygrp-mlmsg * {
line-height:1.22em;}
#yiv1213773308 #yiv1213773308ygrp-mlmsg #yiv1213773308logo {
padding-bottom:10px;}
#yiv1213773308 #yiv1213773308ygrp-msg p a {
font-family:Verdana;}
p#yiv1213773308attach-count span {
#yiv1213773308 #yiv1213773308ygrp-reco
#yiv1213773308reco-head {
#yiv1213773308 #yiv1213773308ygrp-reco {
#yiv1213773308 #yiv1213773308ygrp-sponsor #yiv1213773308ov
li a {
li {
ul {
margin:0;padding:0 0 0 8px;}
#yiv1213773308 #yiv1213773308ygrp-text {
font-family:Georgia;}
#yiv1213773308 #yiv1213773308ygrp-text p {
margin:0 0 1em 0;}
#yiv1213773308 #yiv1213773308ygrp-text tt {
font-size:120%;}
#yiv1213773308 #yiv1213773308ygrp-vital ul li:last-child {
border-right:none !important;
#yiv1213773308
2017-01-01 by Harvey Altstadter
Rob,
It looks like it is similar to the Apache that you have, but it
lacks the second thermoswitch mounted directly on the heater. I
don't understand the wiring in parallel of the two thermoswitches
in your schematic. I assume that they are normally closed, opening
on reaching their specified temperature. Since they are in
parallel, and wired in series with the heater, the only one that
would have any effect would be the higher temperature one. I could
understand if they were in series. Then the lower temperature
switch would be the controller, with the higher temp switch acting
as a protection in case the lower temperature switch failed short.
The effect on the green light would be the same as it is in your
description.
The HF unit has an additional thermoswitch mounted on the heater
in a thermally insulating mount. That switch is normally open, and
is in series with the resistor, rectifier and the green LED, and
turns on the ready light when the unit has reached temperature.
The HF unit is also somewhat larger, with a larger heater
assembly. The rest is empty space.
Harvey
thanks
On 12/31/2016 02:38 PM, Harvey Altstadter hrconsult@... [Homebrew_PCBs] wrote:
Rob,
Harvey
Dave
2017-01-01 by Rob
Rob,
It looks like it is similar to the Apache that you have, but it lacks the second thermoswitch mounted directly on the heater. I don't understand the wiring in parallel of the two thermoswitches in your schematic. I assume that they are normally closed, opening on reaching their specified temperature. Since they are in parallel, and wired in series with the heater, the only one that would have any effect would be the higher temperature one. I could understand if they were in series. Then the lower temperature switch would be the controller, with the higher temp switch acting as a protection in case the lower temperature switch failed short. The effect on the green light would be the same as it is in your description.
The HF unit has an additional thermoswitch mounted on the heater in a thermally insulating mount. That switch is normally open, and is in series with the resistor, rectifier and the green LED, and turns on the ready light when the unit has reached temperature.
The HF unit is also somewhat larger, with a larger heater assembly. The rest is empty space.
Harvey
thanks
Rob,
Harvey
Dave
2017-01-01 by David C. Partridge
It’s a Vivid IP-330 described as having “hot roller” technology.
I need to dig it out as I can’t remember what I did to increase the Temp range (probably just changed a resistor in the op-amp circuit that used a 1N4148 as a Temp sensor).
Can’t find a parts list …
Sent: 31 December 2016 18:11
Subject: Re: [Homebrew_PCBs] Re: Temp upgrades of lam's HOW high is high heat conditions
Dave
2017-01-01 by mosaicmerc@...
>>I am not sure I understand why slowing the rollers causes them topick up more heat energy. In my laminator (Harbor Freight) there are two heaters, placed on opposite sides fo the rollers. The heaters are attached to aluminum structures that enclose the roller assembly all around, except for the slots for the paper path.<<
Ancel,
That makes sense. I am beginning to see why the laser printers I
have looked at use heaters inside the rollers.
Harvey
Harvey asked :
>>I am not sure I understand why slowing the rollers causes them to pick up more heat energy. In my laminator (Harbor Freight) there are two heaters, placed on opposite sides fo the rollers. The heaters are attached to aluminum structures that enclose the roller assembly all around, except for the slots for the paper path.<<
During development of the Apache PCB mod, I effectively slowed the rollers to a net zero movement.
Before long the rollers' area closest to the heaters started to smoke a lot.
When I powered down cooled and dismantled the rollers they had developed a white powdery surface which shed when wiped. After cleaning this sediment the rollers had become oval shaped and frangible.
I swapped them out with the 'cold rollers' (quad roller laminator) and wrapped them in kapton tape to keep them serviceable.
In summary; the reflected heat from the metal enclosure is not as much as the direct radiant heat from the heater coils and (with an almost parked roller) this creates a temperature on the roller surface than can exceed the roller's spec, if the roller does not rotate away from the heater and cool off.
Because the temp sensor is on the exposed side of the roller away from the heaters, it depends on the hot side of the roller rotating into contact with it, if this doesn't happen fast enough, the temp sensor sees a temp well below the hottest part of the rollers and does NOT shut off the heater, resulting in overheating.
2017-01-01 by Rob
Dave
Rob,
It does, but the maximum operating temperature is 200°C for the
4148. With ~-2mV/°C tempco, it is difficult to build a controller
that works well up to that temperature. You also need to calibrate
it because the tempco is not constant over the full temperature
range, nor is it exactly -2 mV/°C. I was unhappy with the way it
worked when I did it, so I switched over to the RepRap thermistor.
Unhappy with the poor performance at hot temperature, I bought the
thermocouple based temperature controller.
The linearity of diode type temperature sensors is pretty good for short temperature ranges, but going from room temperature to the temperature ranges we are using didn't give me satisfactory performance.
For me, the thermocouple is the best route. Thermocouples are
tricky because their terminations make additional thermocouples in
series with the measurement couple, screwing up the readings. A
packaged solution that takes care of the termination issues is the
easiest way. At $8.99, a bargain! No fuss, no muss, no bother. And
digital readout, too.
Harvey
Always learning something new here.
1N4148 + LM741 makes a temperature sensor
On 01/01/2017 07:11 AM, 'David C. Partridge' david.partridge@... [Homebrew_PCBs] wrote:
Dave
2017-01-01 by keith printy
I have an old heathkit digital thermometer. It used 1n4149 diodes 2 of them in series to make the temp sensors . the voltage across the diodes changes with temp that seems to be how it works. Might be a little hot in a laminator though for this type of sensor.
Sent: Sunday, January 01, 2017 11:57 AM
Dave
2017-01-01 by Kevin Byrne
2017-01-01 by Rob
2017-01-01 by Cecil Bayona
>You do realize that diodes and transistors can not handle the
> Wow
> all sorts of web sources explaining how to measure temp with diodes and
> transistors.
> https://youtu.be/fvjDWfRpdAI
> A transistor with two of three legs soldered together makes a
> temperature probe. Is
> the temperature inside of lam too hot? Google for temperature probe
> circuits like I
> do for other projects.
> Posted by: Rob <roomberg@...>
2017-01-01 by Rob
On 1/1/2017 2:31 PM, Rob roomberg@... [Homebrew_PCBs] wrote:
> Wow
> transistors.
temperatures involved while they have power. Most Silicon transistors
can handle up to 100C which is much lower than the temperature of the
rollers.
Cecil - k5nwa
http://thepartsplace.k5nwa.com/
That will work just fine, but unless you use a transistor with a
metal case, your upper temperature will be limited to 150°C, or
possibly lower. If you use a metal case transistor, remember that
the collector is connected to the case, and this may cause a
grounding problem. Temperature limit with the metal can is 200°C
or lower. Look at the datasheet for the maximum storage
temperature, and use the lowest current through the transistor you
can.
A transistor with two of three legs soldered together makes a temperature probe. Isthe temperature inside of lam too hot? Google for temperature probe circuits like Ido for other projects.
2017-01-01 by me@...
They work fine up to 250C no problem!
Dave
2017-01-01 by alan00463@...
> For exactly one pass through the laminator, what would be the optimal temperature?My modified laminator runs up to 250C and even than needs multiple passes for a large 11” x 8” double sized 1.6mm PCB (thermal capacity of PCB too high). A small 0.8mm PCB will work in one pass at 250C.
It is unless you need to go to a higher temperature range. The
metal can, TO-46 part only goes to 148.5°C. The other plastic
packages are even lower. The LM34AH metal can part sells for USD
19.41 at Arrow.
There is a whole family of these simple thermometers, but all
suffer from the same limitations.
A LM34DZ is a HELL of a lot more simple than trying to use a diode or transistor to measure temperature.
The other possibility would be an in line pre heater. In that
case, the rollers wouldn't have to get so hot, as the board could
be at or close to the fusing temperature upon entering the
laminator.
Even with a metal case this is pushing the limits (I had to recover the rollers with glass fibre shrink-fit and cover that with PTFE shrink-fit).
Overall a single pass temperature setting for a large board would be so high as to kill even PTFE covered rollers, and would probably overcook the first part of the board.
There are more exotic roller coverings than PTFE but the price would make your eyes water copiously (think hundreds of pounds).
I think that a solution similar to Ancel’s where the roller speeds are modified and driven in a forward/backward manner is probably the best.
FWIW I only do laser transfer now for the LARGE boards that would be too costly from a PCB supply house.
Dave
2017-01-02 by Mark Lerman
On Jan 1, 2017, at 3:31 PM, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Wow
all sorts of web sources explaining how to measure temp with diodes and transistors.
2017-01-02 by Rob
Why not just use a thermistor? It's made for that purpose, already calibrated, costs a dollar or so, is tiny snd rugged, and can be read with a simple ohmmeter.
Sent from my iPhoneWow
2017-01-02 by David C. Partridge
And for clarification Pace/Vivid laminator uses a 1n4148 as temp sensor.
Dave
Sent: 02 January 2017 01:45
Yesssss yes....
thermistor is where I started with all this...
http://www.learnmorsecode.com/laminator/index.html
http://www.learnmorsecode.com/laminator/pic/index.html
we landed on the diode discussion because the PACE PP330 circuit
can be hacked by for higher toner melt temps by changing out two resisters
http://www.learnmorsecode.com/laminator/gbc/pp330.jpg
2017-01-02 by Rob
2017-01-02 by James
On Mon, Jan 2, 2017 at 4:35 PM, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:What is the component labeled K1 1mH 400 ohm on the right side of this
schematic?
http://www.learnmorsecode.com/ laminator/gbc/pp330.jpg
2017-01-02 by Rob
I would say it is a relay.
The box is the coil which has 400 Ohm resistance and 1mH inductance
I don't know why they specified the inductance of the coil, I can't imagine it's really important, probably it's just what they had.
Since said coil is shown as powered from 12v, and we know it's 400R, it will be around 25-30mA when the transistor below it is saturated.
schematic?
2017-01-02 by keith printy
The transistor is being used as a diode. I’ve seen this on amplifiers to monitor the power transistors and adjust the bias so it don’t go into thermal runaway. In all heater circuits I have dealt with we always used a temperature control with a thermocouple. These withstood the higher temperatures . they also had some form of high limit protection in case of a shorted thermocouple or controller failure.if the thermocouple failed open the controller simply shut the heat off altogether.
Sent: Sunday, January 01, 2017 2:12 PM
Subject: RE: [Homebrew_PCBs] Re: Temp upgrades of lam's HOW high is high heat conditions
Relay, the Bulb shown on the schematic is a stand in to the heaters
Sent: 02 January 2017 03:36
Subject: [Homebrew_PCBs] WHAT is K1 1mH 400 ohm
schematic?
2017-01-02 by Edward Brown
On 2 Jan 2017, at 6:06 PM, 'David C. Partridge' david.partridge@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
schematic?
The transistor is being used as a diode. Iâve seen this on amplifiers to monitor the power transistors and adjust the bias so it donât go into thermal runaway. In all heater circuits I have dealt with we always used a temperature control with a thermocouple. These withstood the higher temperatures . they also had some form of high limit protection in case of a shorted thermocouple or controller failure.if the thermocouple failed open the controller simply shut the heat off altogether.
From: Homebrew_PCBs@yahoogroups.com [ mailto:Homebrew_PCBs@yahoogroups.com]
2017-01-02 by Howard Chester
It’s the relay driving the heater (shown as a 12V lamp in the schematic).
Sent: 02 January 2017 17:41
Subject: RE: [Homebrew_PCBs] WHAT is K1 1mH 400 ohm
schematic?
2017-01-03 by Mog
