Homebrew_PCBs
Archive for Homebrew_PCBs.
laser ablation of paint on copper clad
2014-12-09 by Jeff Heiss
I’m mentally exploring the idea of spray painting copper clad with spray paint and drawing traces in the paint with a laser.  After the laser, the board is then placed in etchant and the copper exposed by the laser is etched away.   I understand this is possible with 20W CO2 lasers by Youtube videos but has anyone explored this with a laser diode?  Is the  abundant ebay 445nm, 1W laser or the 808nm, 3W laser up for the task paint ablation?
Jeff
Re: [Homebrew_PCBs] laser ablation of paint on copper clad
2014-12-09 by Camillus
Well i gues that depends on the heat you can produce with an 3W Laser. I know it is possible to pop a latex balloon, so that makes me wonder, if you use latex based paint like acryl then maybe, probably you have to go a couple of passes, but that is or should be no problem.
camillus
On 12/8/2014 10:44:24 PM, 'Jeff Heiss' jeff.heiss@... [Homebrew_PCBs] <homebrew_pcbs@yahoogroups.com> wrote:
Jeff
This email has been checked for viruses by Avast antivirus software.
www.avast.com
Re: laser ablation of paint on copper clad
2014-12-09 by Howard Chester
Jeff posted,
>I’m mentally exploring the idea of spray painting copper clad with spray paint and drawing traces in the paint >with a laser.  After the laser, the board is then placed in etchant and the copper exposed by the laser is >etched away.   I understand this is possible with 20W CO2 lasers by Youtube videos but has anyone >explored this with a laser diode?  Is the  abundant ebay 445nm, 1W laser or the 808nm, 3W laser up for >the task paint ablation?
>Jeff
Hello Jeff,
Just a few words of my musings...
Why not try to replace the high power LASER with a 400nm Ultra Violet Soild State Laser Diode combined with a CD/DVD optic sled unit to expose a UV resist PCB?
A few advantages;-
1) Lower power equals safer working enviroment
2) Ease of use, the CD/DVD has a constant correcting focus control loop. This would probably allow tracks in the sub mm range(0.2mm?). As the visable red dot shining through the prism bounces back from the PCB, mixing the nearly invisible UV beam on the opposite side of the prism assembly by delivering the beam via a short lenght of cladded fiber through the unpopulated side of the prism.
3) A secondry advantage of the visible red dot is easy and accurate registration when doing double sided PCB's.
4) By tapping into the beam control(constant amplitude loop that monitors the reflected beam power to compensate for impurities on CD/DVD's  (analog available at the red laser diode Anode-Cathode as a varying Current through  the red Diode)) would allow for a "Resist thickness vs stepping motor delay"  as well as slaving the UV LASER drive current.
5) Modern Micro-stepping Motor drive IC's would maximise the resolution of the optics, unless you use the optics of the "sled" control. In which case the resolution could be in the micro/nano meter range.
6) Cost, a UV LASER Diode module costs about 45 Bucks vs BIG bucks for a large LASER, Drive Electronics and the delivery optics.
 have pondered this concept for a while now but declining health has force my early retirement and as such, my access to the nessessary engineering tools.
As stated, just my musings...
Good-luck with you project, chester
2014-12-09 by Les Newell
I tried this with my 40W CO2 laser and didn't have much success. Even with air assist I couldn't get all of the paint off cleanly (or it re-deposited), preventing a clean etch. I tried a whole bunch of different paints and powers but in the end I wasn't happy with the results.
This guy <http://forums.reprap.org/read.php?133,235148> seems to have had some success with a 2W  laser diode.
Les
Jeff
Re: [Homebrew_PCBs] Re: laser ablation of paint on copper clad
why using the paint, this should also work with the presensitised clad boards. If you use a UV laser in the right wavelengt of the photoresist. I have being pondeingr over this myself, but never though to have a suitable beam that can be controlled in width from let say 0.1 to 0.5 mm. I was even thinking of making my boards myself, by submerging the board completely in UV cureable photoresist, and then centrifuge it with high speed, so that the centrifugal force would make the layer of resist so equal as possibe. A brushless motor from old drive would be good for this, just have to make a reliable holder to keep the board from flying away...LOL.
 If you have more information about laser control, specialy the focus part, then please would you care to send it to me or post it here?
thanks.
Camillus
On 12/9/2014 7:25:07 AM, Howard Chester howard.chester@... [Homebrew_PCBs] <homebrew_pcbs@yahoogroups.com> wrote:
Jeff posted,
>Jeff
Hello Jeff,
A few advantages;-
www.avast.com
2014-12-10 by Will
Hi All,
Spray painting your own pcb material is much cheaper than pre-coated
photo resist board. The pre-coated also has a lifetime.
My US$0.02 worth or with the dropping NZ currency NZ$0.03
Cheers,
will,
ZL1TAO
On 10/12/14 06:57, Camillus camillus_blockx@... [Homebrew_PCBs]
> away...LOL.
> thanks.
> Camillus
>> Jeff posted,
>> >Jeff
>> Hello Jeff,
>> A few advantages;-
>> drive current.
>> range.
>> / have pondered this concept for a while now but declining health has
>> force my early retirement/ and as such, my access to the nessessary
>> engineering tools.
> <http://www.avast.com/>
> www.avast.com <http://www.avast.com/>
RE: [Homebrew_PCBs] Re: laser ablation of paint on copper clad
2014-12-10 by Jeff Heiss
I think there are two options to achieve a small spot size.  The first is a collimating lens.  The second is a fiber laser which is just a laser diode sold with a fiber attached.  I think both will achieve a spot size about 0.1mm (0.004”).  Can someone comment if this is correct?  Lenses are fiber lasers are sold on Ebay.  A microscope objective also works for a collimating lens.
I would like to avoid photoresist because –
No developing step
No preheating the developer
No developer required
No photoresist required
Quality of traces improves with no overdeveloping some areas and underdeveloping others
Cost is lower
No photoresist film application step – the most error producing step in the whole board making process from my experience
No laminator required for applying the photoresist
No modifying laminators for the correct photoresist application temperature
No guessing how good the photoresist is from age since the last time you used it
Jeff
Sent: Tuesday, December 09, 2014 12:57 PM
Subject: Re: [Homebrew_PCBs] Re: laser ablation of paint on copper clad
thanks.
Camillus
Jeff posted,
>Jeff
Hello Jeff,
A few advantages;-
www.avast.com
2014-12-10 by Slavko Kocjancic
Using photoresist and 20mW 405nm laser works nice.
I use cheap ebay laser and got spot under 0.08mm in one direction and 0.1 in other (spot is oval not round.)
Now I wait to get stronger laser to crank up speed. Now I need aprox 15minutes for 100x160mm board raster scanned. I do try to implement solder resist too but need 10x more power. (I slow down scanning 10 times and paint solidify) but that's inpractical. Hope that with new laser I got solder resist curing under 10 minutes and photoresist sensitizing undef 5 minutes (speed of mechanic is limiting factor and laser driver too as frequency approach 1MHz.)
Slavko.
No developing step
Cost is lower
Jeff
thanks.
Camillus
Jeff posted,
>Jeff
Hello Jeff,
A few advantages;-
www.avast.com
2014-12-10 by Cristian
Let me know, please the eBay number. 0.08x0.1 is very good.
Be careful that more power means more copper reflections=large traces.
>Slavko.
Cristian
2014-12-10 by Camillus
Verry interesting, but I had one more question. Did you ever tried to cover the pcb with vinyl used by signmaking?
Wouldthe laser be able to cut ( burn ) true the vinyl. That would be awesome, then just laser the outline, etching and then laser the solder pads. Clean it all up and pcb is ready, with vinyl soldermask.
cb
On 12/10/2014 1:46:29 AM, Slavko Kocjancic eslavko@... [Homebrew_PCBs] <homebrew_pcbs@yahoogroups.com> wrote:
Slavko.
No developing step
Cost is lower
Jeff
thanks.
Camillus
Jeff posted,
>Jeff
Hello Jeff,
A few advantages;-
www.avast.com
www.avast.com
My laser is that cheapo...
http://www.ebay.ie/itm/151023934656?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Will try with that when received
http://www.ebay.ie/itm/161132483080?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Not yet decided to order 0.7W as is not cheap...
>> Slavko.
> Cristian
> Posted by: Cristian <crissstian@...>
> Yahoo Groups Links
Just one tought. If I move focal point for 1mm the trace goes quite narow.
I focused now at about 80mm
>> Slavko.
> Cristian
> Yahoo Groups Links
No more than 120mW for uv photoresist exposure, otherwise you will
experience strong reflections.
Cristian
With 20mW I can work pretty fast. But still the power is limiting
factor. With 100mW laser I think I will hit other bariers like speed of
scanning and even more the speed of laser modulation. With 100mW laser I
need to switch it on and off at 1MHz rate. I search the net but didn't
find the working driver. Now I have driver from BJT transistors and
works nice at over 100kHz but the current is little dependent of room
temperature.
I tried to modulate LM317 but in some cases seems that it resonate and
miss pulse. OPAMP seems to be too slow (at least with amplifiers I tryed).
I don't know what is best for laser. To turn it ON/OFF completly or just
change the current from minimum lasing current to max current.
And I have little different approach in mechanic... need to make video
how I did it...
Slavko.
> Cristian
>With 100mW laser I
BJT is slow. Use fets.
Also, "pre-heat" the laser diode with some 10% current with a resistor.
Why that speed? I guess you expose point by point.
I suggest you to convert the normal Gerber output to HPGL (that means
lines instead of points)
and to use it as in a plotter. No speed problem here.
I've bought such a program. If you think to go that way, you can mail
me your Gerber and I'll send you
back, for free, the converted HPGL.
By your name you are from ex-Jugoslavia. I'm Rumanian.
Cristian
On 10. 12. 2014 12:05, Cristian crissstian@... [Homebrew_PCBs] wrote:
>> With 100mW laser I
Well I dissagre. BJT when used right can be pretty fast. At least 1MHz
That's the question. I didn't find any data how fast is laser response
to current. Is in real beter to have "preheated" laser or is same? With
new driver I wan't to have ability to set current too.
Yes. I do raster imaging and one dot lasting 1.5 us. (calculated for new
system right now is 15us)
I try with vector imaging but came out just to slow. And when trace is
bent at 90 degre the laser motion need decelerate and then accelerate in
other direction. And thus point in corner get more laser energy and burn
bigger spot. It works but result is not so good as raster imaging. I
tried both.
Why to complicate? Gerber is already vector format. Just need to make
some subs for flash items and to manage line thickness correctly. Of
course HPGL is even better for that and most PCB programs can do output
to HPGL directly. For now I export image in bitmap image at resolution
at least 800DPI.
Thanks for offer but I don't need that (at least not now)
> Cristian
The answer is yes.. I'm from Slovenia.
Slavko.
Just make a crapy video to show how I do that.
Instead to use CNC XY table and get 1200mm/min
I add A rotational axis and got 30159mm/min scan rate and use only Y
axis to advance board every revolution of arm by 0.01mm.
The laser is mounted in aluminum arm to the stepper motor. Powering
stepper motor with 16 or 32x microstep was total disaster. Now I drive
motor in full step but picked speed where inertia of arm just coencide
with resonance so motion is wery smoth.
http://youtu.be/8ekioGZOkb4
What solder resist do you use?  Are you using photoresist as solder resist?
Jeff
Sent: Wednesday, December 10, 2014 2:46 AM
Slavko.
No developing step
Cost is lower
Jeff
thanks.
Camillus
Jeff posted,
>Jeff
Hello Jeff,
A few advantages;-
www.avast.com
Jeff
I use locally produced photoresist (liquid) and striped out after etching by scrubbing.
For now I just apply rosin (colophony) dissolved in isopropil alcohol as it helps with soldering too and 10 years old boards seems like new.
But I do some tests with UV curable solder mask from ebay
http://www.ebay.ie/itm/180917181008?ru=http%3A%2F%2Fwww.ebay.ie%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D180917181008%26_rdc%3D1
and works nice but need at least 10x more laser power to cure.
I tested to slow down motion 10 times but got some strange bubles in paint. Probably related with nitrogen exhaust from paint itself. But if I do it fast and do 10x repeat then harden as should. (I scan same line 10 times and after that advance to next line)
For now with laser I have is just inpractical as it take to long time.
Slavko.
2014-12-10 by Boman33
Very nicely done!!
What software are you using to do the bitmap or vector to rotary
control/firing?
Bertho
Sent: Wednesday, December 10, 2014 09:06
Instead to use CNC XY table and get 1200mm/min I add A rotational axis and
got 30159mm/min scan rate and use only Y axis to advance board every
The laser is mounted in aluminum arm to the stepper motor. Powering stepper
motor with 16 or 32x microstep was total disaster. Now I drive motor in full
step but picked speed where inertia of arm just coencide with resonance so
2014-12-11 by Slavko Kocjancic
Hello...
Didn't tryed. But I don't think that is good idea. The vinil will melt vhen board is soldered. And 20mW laser isn't strong enought to cut with ussable speed.
Slavko.
cb
Hello..
It's written in video description. The data is provided by python script.
Well the workflow is like that:
-Draw board.
-export board to 800 or 1000DPI BW image
-pass that image to python script to get bitfile
-load bitfile into LinuxCNC
-Push start
Slavko.
p.s.
It's possible to pass just BW image to Linuxcnc but the power of my
computer is just little to low to provide data in realtime. So I do
preproces data. Maybe just better algorithm can solve that...
On 11. 12. 2014 00:43, 'Boman33' boman33@... [Homebrew_PCBs] wrote:
> Very nicely done!!
> control/firing?
> Bertho
> -----Original Message-----
> Posted by: "Boman33" <Boman33@...>
> Yahoo Groups Links
2014-12-11 by Boman33
Thanks Slavko for responding.
Do you have a link where I can see the video description you mentioned?
Bertho
Sent: Thursday, December 11, 2014 02:30
Hello..
-Draw board.
-export board to 800 or 1000DPI BW image -pass that image to python script
to get bitfile -load bitfile into LinuxCNC -Push start
Slavko.
p.s.
It's possible to pass just BW image to Linuxcnc but the power of my computer
is just little to low to provide data in realtime. So I do preproces data.
> Very nicely done!!
> control/firing?
> Bertho
> clad
> and got 30159mm/min scan rate and use only Y axis to advance board
Photos:
> Yahoo Groups Links
Yahoo Groups Links
youtube link posted below..
> Bertho
> Hello..
> -Draw board.
> Slavko.
> p.s.
>> Very nicely done!!
>> control/firing?
>> Bertho
>> clad
> Photos:
>> Yahoo Groups Links
> Yahoo Groups Links
> Yahoo Groups Links
I saw your video previously and I understand how it works.
Maybe I misunderstood your comment in your previous email:
"> Hello.
> It's written in video description."
It sounds like you have a written description of video processing.
By the way, another member did a similar setup but for film and he wrapped
it around a drum like an ancient fax machine.
There was also a member that converted an inkjet printer to a direct photo
plotter.
I really like your solution.
Bertho
Sent: Thursday, December 11, 2014 04:01
> Bertho
> clad
> Hello..
> -Draw board.
> script to get bitfile -load bitfile into LinuxCNC -Push start
> Slavko.
> p.s.
preproces data.
wrote:
>> Very nicely done!!
>> control/firing?
>> Bertho
>> clad
>> axis and got 30159mm/min scan rate and use only Y axis to advance
>> drive motor in full step but picked speed where inertia of arm just
>> coencide with resonance so motion is wery smoth.
> Photos:
>> Yahoo Groups Links
Photos:
> Yahoo Groups Links
Photos:
> Yahoo Groups Links
Yahoo Groups Links
I saw few attempts too.
Well wraping pcb to drum is near inposible.
Using simple homemade CNC with laser attached has some drawback. If it's
accurate then is probably slow. Acceleration and deceleration cause
problems with vector drawing so the best is to use raster style. When
you are in raster then you need smal dot, and even smaller stepping or
angled traces will be fuzzy.
I see the machine of one german freak that use poligon mirror to scan
one axis. Seems very nice but since there are no F Theta lenses they
have different dot size depending on position. And difference of 1mm out
of focus is unusable. So I thinkering how to scan fast and to have laser
in same distance from board and that idea arrive. It works. Now after
few hours working even little problems caused by brushes seems to
dissapears. Seems that brushes align with slip ring and now the contact
is good. If you didn't realyzed the laser got power from 4 carbon
brushes as laser rotate but driver is stationary.
Works nice for now. Just need to add index sensor to know position of
laser (as til now I align laser by eye)
Slavko.
> "> Hello.
> plotter.
> Bertho
>> Bertho
>> clad
>> Hello..
>> -Draw board.
>> Slavko.
>> p.s.
> preproces data.
> wrote:
>>> Very nicely done!!
>>> control/firing?
>>> Bertho
>>> clad
>> Photos:
>>> Yahoo Groups Links
> Photos:
>> Yahoo Groups Links
> Photos:
>> Yahoo Groups Links
> Yahoo Groups Links
> Yahoo Groups Links
2014-12-11 by Brad Thompson
On 12/11/2014 10:28 AM, Slavko Kocjancic eslavko@...
> Hello--
I dimly recall that many years ago a company manufactured a drum-based
PC-board engraver
(or perhaps "carver" would be more appropriate. The system used very
thin copperclad
board that wrapped around the drum.
A horizontal carriage moved the carving head in parallel with the drum's
axis, and a solenoid
moved the carving bit into (and out of) the copperclad board.
Again, I very dimly recall that the carving bit moved under the control
of a black-and-white
image of the desired traces-- likely using a photoelectric sensor of
some sort? if
you've seen a pattern-tracing wood lathe in operation, you'll have a
better idea of
how the machine worked.
When the copperclad board was finished, the user affixed the board to a
thicker piece
of epoxy-fiberglass (unclad) board and drilled through-holes for
component leads.
I saw one of these things in operation and it made a dreadful racket and
produced
low-resolution boards.
73--
Brad AA1IP
2014-12-13 by Jeff Heiss
At certain locations in the rotation angle, the laser does not fall directly
in the center of the pixels. How are the pixels in the bitmap mapped to
their position in the arc? Is the Bresenham algorithm or a similar
algorithm used?
Sent: Thursday, December 11, 2014 2:30 AM
Hello..
-Draw board.
Slavko.
p.s.
> Very nicely done!!
> control/firing?
> Bertho
> clad
Photos:
> Yahoo Groups Links
Yahoo Groups Links
2014-12-13 by Tony Smith
At 1,000 DPI, the laser isn't going to be anywhere near it's supposed to be
anyway. Close enough thought.
The beam of the laser will be probably bigger than a dot a 1,000 DPI (which
is good as the overlap fills in the gaps) depending on a bunch of things.
Dunno how LinuxCNC does rastering, but often the laser is left on between
dots so that evens things out. Sometimes you want dot - dot - dot lasering,
but not in this case.
Tony
> Sent: Saturday, 13 December 2014 4:27 PM
> Subject: RE: [Homebrew_PCBs] Re: laser ablation of paint on copper clad
directly in the
> center of the pixels. How are the pixels in the bitmap mapped to their
position
> algorithm used?
> Hello..
> -Draw board.
to
> Slavko.
> p.s.
computer is
> wrote:
> > Very nicely done!!
> > control/firing?
> > Bertho
> > clad
> Photos:
> > Yahoo Groups Links
Photos:
> Yahoo Groups Links
> Posted by: "Jeff Heiss" <jeff.heiss@...>
Photos:
> Yahoo Groups Links
2014-12-13 by Slavko Kocjancic
As I'm not so strong on math so I go with hard way.
As Linuxcnc output is restricted to change with base_period the timing
for the laser is in same range. So I just convert the laser position on
arc (actulay polar coordinate) for each position when can change (for
each 15us) to cartesian and check image what is in that position. If
there is a trace (black) then laser is off else the laser is on.
So the preprocesor is like this
for yboard=0 to boardHeight step 0.01
for angle = 0 to PI step arclenPer15us (scan only half of arc)
convert polar (angle/arm length) to cartesian (x/y)
if image at x,y+yboard = black
laser off
else
laser on
next
next
It's not perfect but works.
As pixels on the edges get more laser energy I expect some overexposure
and wider laser track but in practice I doesn't see any problem with
that. But maybe I just didn't hit the limit yet. As for now I do boarda
only 10cm wide I don't use the most distorted area.
Slavko.
On 13. 12. 2014 06:27, 'Jeff Heiss' jeff.heiss@...
> algorithm used?
> Hello..
> -Draw board.
> Slavko.
> p.s.
>> Very nicely done!!
>> control/firing?
>> Bertho
>> clad
> Photos:
>> Yahoo Groups Links
> Yahoo Groups Links
> Yahoo Groups Links
On 13. 12. 2014 11:39, 'Tony Smith' ajsmith1968@...
> Tony
The laser dot is just little under 1000dpi in size. But I have limited
on off timings so the width I can controll is about 700DPI. But this is
true only for rotation axis. I advance board for only 0.01mm each
revolution so there are plenty of overlap. And I do leave laser on if
there are more same dots in a row.
My preprocesor program just crunch the coordinates and make file stream
of '1' and '0' for laser for each 15us. The linuxcnc with component
'streamer' then stream this each 15us to the laser. And here is
bottleneck as I can't go faster (but I want) and I need to make some
special hardware to stream much faster than 15us/pulse.
I think to use some AVR with plenty of ram and to upload entire stream
on it, and after that just stream bits. At 1 bit per 1us the AVR will
work hard. But seems that static ram is just too small to fit entire
image, I will probably use dinamyc ram (4Mbits *4). As I calculated I
don't need to worry about refresh as cycling as streaming is fast
enought to keep memory refreshed. But need to cary refresh when data is
uploading and waiting start of operation where is enought time to proper
manage refresh cycle.
2014-12-13 by Camillus
Hi, maybe you should consider double addressable ram, is a bit more expencive, but it can be written and read at the same time, ( has two address counters in it ), I'm not shure but they call it LIPO or something likethat.
Anyway it is sure fast enough and wile your avr is pumping bits in it the cnc can read them. It depends now on what you need be the fastest.
cb
On 12/13/2014 11:06:25 AM, Slavko Kocjancic eslavko@... [Homebrew_PCBs] <homebrew_pcbs@yahoogroups.com> wrote:
> Tony
Yahoo Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/Homebrew_PCBs/
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/Homebrew_PCBs/join
(Yahoo! ID required)
Homebrew_PCBs-digest@yahoogroups.com
Homebrew_PCBs-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
Homebrew_PCBs-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
https://info.yahoo.com/legal/us/yahoo/utos/terms/
www.avast.com
2014-12-13 by Harvey White
Another way is to multiplex the address and data from application to
application, so that half of the time, the AVR is writing to the RAM,
and the other half of the time, the CNC can read it.
This is relatively easy to do, but requires the memory to be twice as
fast as your cycle time, if not a bit faster for safety. I'd use a
CPLD or FPGA to do the multiplexing, just because it's easier. If you
don't have the tools to do this, then counters/registers and
multiplexers work just fine. You'll have to play games with the AVR
if you're using direct memory access, because the memory access cycle
is not absolutely in phase with the clock.
Just because you have the clocks for the processor and the clocks to
the CPLD in phase does not guarantee that the two requests would be
synchronized.
Your best bet would be to have the whole cycle time so short that the
processor can write at any time, then expect to get/write data
correctly.
Strangely enough, writing with using a port (Programmed I/O) is easier
to synchronize (you can loop and wait on a status) than direct memory
write/read synchronized to the processor clock. If your FPGA/CPLD
has dual port memory (Xilinx 3AN series do...) then this can help if
your assumed buffer size is small enough.
Harvey
>cb
>> Tony
>Yahoo Groups Links
2014-12-14 by Camillus
I was thinking that the propeller would be a good device for this project, it hass 10 cogs ( independent cores you may say ) and one master that controls the IO I think. I'm just stating what I remember from reading. The only drawback is the language,, not a common  ....
cb
On 12/13/2014 5:49:32 PM, Harvey White madyn@... [Homebrew_PCBs] <homebrew_pcbs@yahoogroups.com> wrote:
synchronized.
correctly.
Harvey
>cb
>> Tony
>Yahoo Groups Links
www.avast.com
2014-12-14 by Slavko Kocjancic
Just need to do some more calculations.
The other one options is to use AVR with biggest ram to fit at least one
scanline. So when buffer has at least one line in then seek for index
pulse from laser position and start scanning. After half a rotation the
line is ended and buffer can be updated. If buffer doesn't fill until
next index is reached then just wait to data arrive and try on next
index cycle. But this approach will probably result with speed reduction
(only to get half speed).
And another news. I just wonder how I didn't burn out my laser.
I ordered same one for spare and 120mW to test if I can get more speed.
The laser of choice was:
and there are stated 3V <280mA. But I quickly realised that I can't
modulate the laser as there are some DCDC converter in module. So I
remove them and connect LD to power supply with current limiter. I
slowly increase current and observe laser output and current and
voltage. It's need around 20mA and 4.5V to start working. After that
when I increase current to 50mA the voltage is around 5V and just little
higher with 100mA. So As I don't have laser datasheet (doesn't know what
diode is in) I just recalculate the input of DC/DC (3V @ 280mA) is same
power as (5V @ 168mA) and assume 90% of efficiency of DCDC converter and
I got 151mA. My BJT driver feed 150mA when it's total cold and 140mA
after it's heated up with hairblower.
After I got stronger laser
the data says <450mA and 3 to 5V voltage. I connect the laser to my PSU
set voltage to 5V and limit current. Then I crank up the current and
when I hit around 25mA at 3V the diode start to lase. After that when I
crank up current up to 390mA voltage stay around 3V and just little
higher current there are strange jump of voltage to 5V and decrease of
current to 120mA (like negative resistance). It was so strange to me
that I remove DCDC from that laser too and connect 6x1N4007 diodes and 1
ohm resistor in series (aka laser dummy load) and check the output what
circuit feed to laser. And I got that device try to feed 110mA to the
laser whatever voltage is. But efficiency of DCDC vary from 60% to 95%.
Then I test the circuit from smaller laser and I was surprised. They
output is just 30ma! I checked other one and got same result!!!
So the DCDC has less than 20% efficiency. And I run diode instead on
30mA with 145mA and didn't dye. I just wonder how long will work..
Well long letter to learn that this kind of diode output is close that
current consumed in mA, or at least that powering diode with asme mA as
mW is is safe.
...and 20mW diode give me same power as 100mW diode if feed with 145mA.
On 14. 12. 2014 00:49, Harvey White madyn@...
> synchronized.
> correctly.
> Harvey
>> cb
>>> Tony
>> Yahoo Groups Links
> Posted by: Harvey White <madyn@...>
> Yahoo Groups Links
2014-12-15 by Slavko Kocjancic
On 14. 12. 2014 06:09, Camillus camillus_blockx@...
> cb
I didn't work with propeller at all. But now I do quick check. And if I
understand correctly the 8 cogs are interleaved by hub. The cog operates
at 20mips (like AVR) but hub rotate by half of that frequency. So more
or less the pixel generation should be done by one cog. other cog may be
used as refresh generator and data upload routine. I think that is not
best suited for that application.. maybe some of ARM chips is better?
Slavko.
2014-12-19 by jeff.heiss@...
The Bungard drum plotter has laser spot size of 0.005mm/0.0002inches.  This is a resolution of 5,000 dpi.  The laser inside is a red 670nm laser.  How do they achieve this?  What laser and lenses are used?
Is red sensitized photoresist film common?  Where can it be purchased?
Photoplotter
Jeff
2014-12-19 by Camillus
HI, jeff
On this page : http://www.beamtech-laser.com/en/proInfo.aspx?m=20101216100729203892&n=20101222115304745038&protype=20101216101714765927
they speak of that kind of laser spot resolution.
But only by the looks of it I think its going to be a $$$$$$ digit number ...LOL
camillus
On 12/19/2014 10:43:29 AM, jeff.heiss@... [Homebrew_PCBs] <homebrew_pcbs@yahoogroups.com> wrote:
Photoplotter
Jeff
www.avast.com
2014-12-20 by Tony Smith
They’re YAG lasers, so yeah $$$$$ is right.
Spot size starts with wavelength, smaller wavelength = small spot, so UV < Visible < IR.
A YAG will be 1/10th the size of the typical IR CO2 lasers simply due to frequency of the light.
A lens with a short focus is next, a problem there is scanning and short focus don’t get along well.
“How big is the spot” varies depends on a lot of variables, including defining just what the spot itself actually is (scatter etc).
Save your pennies and get one of these: http://www.youtube.com/watch?v=mzmjGz0_joM. My reaction to seeing that was “That’s awesome!” – most lasers can’t etch copper, indeed some systems use copper mirrors for that reason.
Tony
Sent: Saturday, 20 December 2014 5:40 AM
HI, jeff
camillus
Photoplotter <http://bungard.de/index.php?option=com_content&view=article&id=43&Itemid=60&lang=english>
<http://bungard.de/index.php?option=com_content&view=article&id=43&Itemid=60&lang=english> Image removed by sender. image
<http://bungard.de/index.php?option=com_content&view=article&id=43&Itemid=60&lang=english> Photoplotter
Filmstar-Plus is the name of the next generation of our bitmap photoplotter series. Optimized for inhouse production of high end film layouts at reasonable p...
<http://bungard.de/index.php?option=com_content&view=article&id=43&Itemid=60&lang=english> View on bungard.de
Preview by Yahoo
Jeff
_____
<http://www.avast.com/> Image removed by sender.
2014-12-20 by Jeff Heiss
The Bungard photoplotter uses a red 670nm laser diode.  The spot size is 0.005mm/0.0002inches which produces 5,000 dpi resolution.  How is a 0.005mm spot size achieved with a laser diode?
Jeff
Sent: Saturday, December 20, 2014 5:02 AM
Tony
HI, jeff
camillus
Preview by Yahoo
Jeff
_____
2014-12-22 by Tony Smith
Because 670nm is smaller than 0.005mm, 0.00067mm to be exact.
That 0.00067 is the smallest possible spot size, you’ll never achieve that due to blah blah blah. 0.005mm is very good.
Their description gives the hint:
“A highly focused red light laser diode is moving step-wise alongside that drum, driven by a precise stepper motor with worm and gear drive.”
They’re using a lens with a very small focus length, say 10mm or so. Shorter the lens, the smaller the dot, but also has a very small depth of field. There is only a small distance from the lens where the spot size is at is smallest (the beam is hourglass shaped).
Using a scanning mirror means the distance between the lens and the film varies, so the spot varies in size too; they use a stepper to move the laser back & forth to keep the beam in focus and have a consistent spot size.
You also need to read the fine print, especially where it talks about the gaps between two lines. They state 0.01mm (ie twice the line size) and that’s because the lines aren’t solid, they have blurry edges due to scatter. If you try to draw two lines close to each other the blurry edges overlap and you get one thick line.
Tony
Sent: Sunday, 21 December 2014 4:17 AM
Jeff
Tony
HI, jeff
On this page : http://www.beamtech-laser.com/en/proInfo.aspx?m=20101216100729203892 <http://www.beamtech-laser.com/en/proInfo.aspx?m=20101216100729203892&n=20101222115304745038&protype=20101216101714765927> &n=20101222115304745038&protype=20101216101714765927
camillus
Photoplotter <http://bungard.de/index.php?option=com_content <http://bungard.de/index.php?option=com_content&view=article&id=43&Itemid=60&lang=english> &view=article&id=43&Itemid=60&lang=english>
<http://bungard.de/index.php?option=com_content <http://bungard.de/index.php?option=com_content&view=article&id=43&Itemid=60&lang=english> &view=article&id=43&Itemid=60&lang=english> Image removed by sender. image
<http://bungard.de/index.php?option=com_content <http://bungard.de/index.php?option=com_content&view=article&id=43&Itemid=60&lang=english> &view=article&id=43&Itemid=60&lang=english> Photoplotter
<http://bungard.de/index.php?option=com_content <http://bungard.de/index.php?option=com_content&view=article&id=43&Itemid=60&lang=english> &view=article&id=43&Itemid=60&lang=english> View on bungard.de
Preview by Yahoo
Jeff
_____
The film would be like regular camera film, sensitive to visible light. It won’t be photoresist.
It’s for doing PCBs (or whatever) with photoresist; film over PCB, expose, etch.
Years ago I used to make film masters of bar codes for the printing industry the same way, a PC controlled a little XY plotter that used a red laser to ‘draw’ on film.
Tony
Jeff
Tony
HI, jeff
camillus
Preview by Yahoo
Jeff
_____
