silver coating
2013-08-15 by David
2013-08-15 by David
2013-08-15 by James
>There is basically that (tinnit, liquidtin), and a product called "Cool
> Hi
> Do any of you people here know of a quick and cheap way to tin copper
> PCB tracks before populating the board?
> With all the modern chemicals around these days theirs bound to
> something out there
> In the past have used the manufactured stuff which you just put in a
> bath for a while and job done but its to expensive.
2013-08-15 by David Pickering
On 15/08/13 18:00, David wrote:
> Hi
> something out there
Amp" http://www.cool-amp.com/cool_amp.html
I've never found any reasonable "home brew" recipe for such a product.
2013-08-15 by Stefan Trethan
On Thu, Aug 15, 2013 at 8:14 AM, David Pickering <satdaveuk@...>wrote:
> Hi
> Thanks for the quick response
> See what I mean by price, if you start using that then just as well buy
> ready made PCBs and forget DIY
> Lets see if theirs any other ideas out there
> From: James <bitsyboffin@...>
> Sent: Thursday, 15 August 2013, 7:04
> Subject: Re: [Homebrew_PCBs] silver coating
> > Hi
> > something out there
2013-08-15 by Jan Kok
On Thu, Aug 15, 2013 at 12:34 AM, Stefan Trethan <stefan_trethan@...>wrote:
> I've seen recipes for tinnit, they all contained thiourea.
> Nasty stuff so I didn't follow up on it.
> The other option is hot tinning, you can use either solder paste or some
> kind of immersion or roll transfer process.
> ST
> >wrote:
> > Hi
> > > Hi
> > > something out there
> Photos:
2013-08-15 by Rick Watson
On 8/15/2013 1:00 AM, David wrote:
> Hi
> something out there
> Thanks in advance
> Dave
2013-08-15 by Eddie Stassen
On Thu, Aug 15, 2013 at 8:00 AM, David <satdaveuk@...> wrote:
> Hi
> Do any of you people here know of a quick and cheap way to tin copper PCB
> With all the modern chemicals around these days theirs bound to something
> out there
> In the past have used the manufactured stuff which you just put in a bath
> Thanks in advance
> Dave
2013-08-15 by Rick Sparber
2013-08-15 by lists
> Hi Do any of you people here know of a quick and cheap way to tin copperI suspect it will always remain expensive because of the price of Tin.
> PCB tracks before populating the board? With all the modern chemicals
> around these days theirs bound to something out there In the past have
> used the manufactured stuff which you just put in a bath for a while and
2013-08-15 by James
On 15/08/13 19:27, Eddie Stassen wrote:
> I have had this bookmarked for years now, but have never got around to
> trying it:-
> http://translate.googleusercontent.com/translate_c?depth=1&hl=en&rurl=translate.google.com&sl=pt-BR&tl=en&u=http://www.py2bbs.qsl.br/banho_estanho.php&usg=ALkJrhj7fJXRaLTdNTmhinb2qUHkMr7fqg
> It describes tin plating before etching and seems quite simple.
2013-08-15 by Harvey White
>HiThe liquid tin that I use (MG chemicals) will last about a year's
>See what I mean by price, if you start using that then just as well buy ready made PCBs and forget DIY
>> Hi
>> something out there
2013-08-15 by <n0tt1@...>
> Hi
> something out there
2013-08-15 by Malcolm Parker-Lisberg
Date: Thursday, August 15, 2013, 3:18 PM
On Thu, 15 Aug 2013 07:14:57 +0100 (BST), you
wrote:
>Hi
year's
production of boards, so the cost per board is not horrible.
The same
size board (professionally done) is at least 22.00 USD,
I'm going to
guess that the tinning adds between 50 cents and a dollar to
the board
cost, and I suspect that this is a high cost based on a one
year use.
The other way (which I have not heard of being done at
home), is HASL,
Hot Air Solder Leveling. I can see several ways of doing
it, but I
would worry about the stress on the epoxy bond due to all
the heat.
The chemical tin plating is not a hot process.
Harvey
>> Hi
way to tin copper
theirs bound to
>> something out there
you just put in a
expensive.
2013-08-15 by James Sleeman
>That page lists the components as
> Make your own tin electroless tin plating solution, see:
> <http://www.voodooengineering.com/index.php/tinning/87-diy-tin-plating-solutiion>
> All chemicals available on ebay
2013-08-15 by Kerry Wentworth
> Hi
> Do any of you people here know of a quick and cheap way to tin copper PCB tracks before populating the board?
> With all the modern chemicals around these days theirs bound to something out there
> In the past have used the manufactured stuff which you just put in a bath for a while and job done but its to expensive.
> Thanks in advance
> Dave
2013-08-15 by Sam Rod
On Aug 15, 2013, at 11:55 AM, Kerry Wentworth <kwentworth@...> wrote:
> Silver coating? Have you checked the cloud? ;)
2013-08-19 by David Pickering
> trying it:-
2013-08-19 by Malcolm Parker-Lisberg
To: "Homebrew_PCBs@yahoogroups.com" <Homebrew_PCBs@yahoogroups.com>
Date: Monday, August 19, 2013, 6:13 AM
Hi James
Shall try that , got the acid in stock , any ideas on where
to get some cheap tin from?
Now thinking what can I scrap that contains Tin
Regards
Sent: Thursday, 15 August 2013, 13:43
http://www.youtube.com/watch?v=w-YL6VmXvW8
never got around to
> trying it:-
simple.
2013-08-19 by fred27murphy
2013-08-19 by Rick Sparber
2013-08-19 by Charles R Patton
2013-08-21 by David Pickering
2013-08-21 by Charles R Patton
> Thanks charles
> After reading your findings I may well not bother with it, just keep
> to the copper surface.
> Normally when building equipment like metal detectors which are out in
> all sorts of environments I spray the finished populated board copper
> clad surface with electrical pvc spray.
> Will just spray all boards lightly when the projects are finished to
> keep the shine there.
> If you need to do any soldering at a later date it doesn't present
> much of a problem.
> Thanks again
> From: Charles R Patton <charles.r.patton@...
> <mailto:charles.r.patton%40IEEE.ORG>>
> <mailto:Homebrew_PCBs%40yahoogroups.com>
> Sent: Monday, 19 August 2013, 18:23
> A bit of anecdotal info on liquid tin plating. Some decades ago at a
> company I was with we were doing PCBs that we tin coated with a
> commercial electroless solution. The coating seemed fine and we
> thought, "Great!" We would screen print a large lot of boards, etch
> them, tin plate, and put on the shelf for later part stuffing by hand,
> then solder by hand dipping the bds in a solder pot.
> Now the down side. Within a relatively short time, the tin coating
> seemed to get dull, and the solderbility with rosin based fluxes dropped
> drastically (even worse than the bare copper) leading to faulty
> soldering. You can observe the same phenomenon if you've ever found
> some old resistors and try to solder the leads. It can be a bad
> experience.
> I attributed the problem to oxidation of the thin tin coating (or
> tin/lead coating of the resistor leads) from the electroless tinning
> process . Those oxides just don't solder well.
> The solution we began using:
> There are liquid organic acid fluxes designed for PCB soldering. We
> switched to those. But several important steps must be strictly followed.
> 1) Press the soldering side of the board with components onto a sponge
> soaked with the acid flux.
> 2) Immediately dip solder the board.
> 3) Then immediately drop the hot, just soldered board into a tub of
> water. (Do not wait or store the boards, the consequences can be severe.)
> 4) Blow off the water and rinse again and blow off again. (Removing
> excess water is important if using tap water as we were.)
> 5) Oven dry.
> At this point I can immediately hear purists screaming, "Acid flux???"
> Just let me say a few things. We were doing RC filters that required
> extremely good surface resistance of the PCB before we coated the board
> with solvent thinned epoxy to obtain and maintain the high resistance.
> The process above gave us better results: bright, solid, well filleted
> solder connections and incredibly consistent, very good surface
> resistance of the PCB assemblies.
> (Just a side tip, the best thing I ever found for moisture resistance
> at that time on those PCBs was a solvent based silcone wax. However
> the down side of that was that it was always a bit tacky and these
> boards could end up in dusty environments, so we decided not to use it
> in production. This whole area of moisture vs. resistance has come back
> multiple times in my design career and could be thread in another
> discussion list.)
> Regards,
> Charles R. Patton
2013-08-21 by Stefan Trethan
> wrote:[Non-text portions of this message have been removed]
> Dave,
> I agree with your conclusion. Spray coating the copper just after the
> resist has been removed is a good look and what I did with acrylic spray
> at times in the past. The epoxy we used made rework almost impossible.
> I haven't done much in the area of things that need re-work once built,
> but generally I understand that acrylic or urethane spray coats are also
> good and allow reasonable reworking. I do know that there was (still
> is?) a patented PCB production process where after the resist was
> removed, silk screening added, the board was coated with a "protective"
> coating. The coating was thin, and basically a flux, but it also acted
> as an oxygen barrier so the copper remained solderable for some period
> of time. Personally I always felt this could be duplicated by using an
> alcohol/rosin solution. (A cheap source of rosin is dance supplies.
> Dancers put rosin on their ballet shoes.) Paint/dip your newly cleaned
> board with the solution and you will have pre-fluxed it and protected
> the copper surfaces from oxidation. Rosin by itself is dry and
> non-sticky (be sure the alcohol is pure and not drug-store rubbing
> alcohol which often has some mineral oil as a percentage of the
> solution). A disclaimer here -- I've never done this myself as my
> personal PCB needs have changed drastically from the days described
> above. I make a one off prototype using toner transfer that I
> immediately assemble by hand or I send off the files and have a board
> house make a bunch.
> Regards,
> Charles R. Patton
2013-08-24 by Andrew Leech
> > Hi
> > something out there
