printer
2013-05-18 by mcmurraygrouch57
Index last updated: 2026-03-31 12:10 UTC
2013-05-18 by AlienRelics
--- In Homebrew_PCBs@yahoogroups.com, "mcmurraygrouch57" <hamshack@...> wrote:
> whats a good printer to use to make pcb's.
> ron
2013-05-19 by Leon Heller
> whats a good printer to use to make pcb's.I get excellent results using an HP 5940 Deskjet printer, with Mega
2013-05-19 by MIKE DURKIN
2013-05-19 by Tony Smith
> Ill just give a blank stare ....How is Radio Shack doing these days?
2013-05-19 by Todd F. Carney / K7TFC
> Ill just give a blank stare ....What a good example, Mike, and in the face of such temptation, too! I was
2013-05-19 by ron
> doing toner transfer. looked in files section and did'nt find anything.Look in the database section for the lists of printers, papers & laminators
> thanks loen i'll see if i can find what you use.
> ron
2013-05-19 by AlienRelics
> ron
2013-05-20 by Will Price
2013-05-21 by AlienRelics
--- In Homebrew_PCBs@yahoogroups.com, "Todd F. Carney / K7TFC" <k7tfc@...> wrote:
> sorely tempted myself.
> 73,
> Todd
> K7TFC / Medford, Oregon, USA / CN82ni / UTC-8
> QRP (CW & SSB) / EmComm / SOTA / Homebrew / Design
2013-05-21 by MIKE DURKIN
> 73,
> Todd
--- In Homebrew_PCBs@yahoogroups.com, MIKE DURKIN <Patriot121@...> wrote:
> I managed to find lots of information ... with google before joining here ...
> From: alienrelics@...
> Date: Tue, 21 May 2013 04:08:47 +0000
> Subject: [Homebrew_PCBs] Re: printer
> Or you could remember what it is like when you were just learning something. Sometimes you don't even know what things are called or what options are available, so searching for them or even asking about them is difficult.
> This group is for newbies and experienced alike. If you are not here to help and be helped, why are you here?
> Steve Greenfield AE7HD
> Moderator Homebrew_PCBs
2013-05-21 by James Newton
>I'm sure you feel much better about yourself now you've made fun of someone else.
2013-05-21 by "Zoran A. Šćepanović"
> I managed to find lots of information ... with google before joining here ...Sooooo...
2013-05-21 by Phil@Yahoo
Sent: Tuesday, May 21, 2013 12:30 PM
Subject: Re: printer
> Hmmm...
> I'm a (relatively) new member here. I've been lurking. This is the first
> urination competition I've seen in this group but, human nature being what
> it is, I suppose they are inevitable. When I was in the first grade we
> used to see who could stand farthest back from the urinal. I could do more
> than six feet. Now that I'm almost 60 (yikes!) well, you don't want to
> know. A sad story.
> Anyway, the topic: This is in fact the reason I joined. I make double
> sided PCBs with plated-thru holes, but have trouble going beyond 2 or 3
> inches on a side because of the distortion caused by printing laser
> transparencies. I used negative file photoresist which works quite well,
> bit printing negatives exacerbates the distortion problem because of the
> large areas of black.
> The contrast of the laser printer (I have a Brother MFC8500) is fairly
> poor so I have to stack up 3 prints to make it dark enough. Last time I
> tried inkjet (HP 932C) the ink wouldn't stick well enough to the plastic,
> so large dark areas had lots of gaps (too much surface tension in the
> ink.) Recently I picked up a used Epson Workforce 630 for my wife [only
> $25 :-) but $70 for ink :-( ] and decided to try printing a mask on that.
> I was thrilled! It looked perfect, with excellent contrast. But the test
> was a positive image, no flood fill.
> Next board I made I printed on the Epson, but found the ink smearing and
> bleeding wherever there were large dark areas, and the fine traces
> (~12mil) tending to close up. Back to the laser. I know I could use flood
> fill to reduce the black areas on negatives, but that is not foolproof
> because the flood fill often cannot reach some spaces.
> I recently picked up some Oracal to experiment with, but even with that I
> doubt TT will work for me because of inadequate contrast (too many
> pinholes in the black areas) though I am in the process of making a
> temperature controller for my Royal PL2112 laminator. I looked at
> replacing the thermostats but decided I'd rather have continuous control
> from hand-warmer to melt-down. Who knew a simple 1N4148 made such a swell
> temp. sensor? I have actually tried multiple applications of toner to a
> PCB. Too hard to align. But there are other interesting applications for
> TT.
> Anyway, I would be very interested in learning which printers produce the
> best contrast with little or no distortion. I can't afford to keep buying
> inkjet and/or laser printers till I get it right, and I don't want to
> spend a fortune on equipment or consumables. If I could just throw money
> at the problem I wouldn't bother with DIY. I have a pretty good supply of
> NuKote laser transparencies and would prefer to continue using those. They
> seem to work pretty well with the Epson inkjet, though I'd grant there may
> be something that works better. If so, I'd like to know why. But again, I
> don't want to accumulate a stack of useless transparencies searching for
> The One That Works.
> OT; FWIW, I've found that conductive ink made from Silver Acetate is very
> effective as a hole wall activator. After drying and annealing at ~92C it
> forms a layer of metallic silver with a very strong mechanical bond to the
> hole walls, and as such is impervious to solvents. It is more expensive
> than conventional DIY activators, and is quite toxic, but the shelf life
> is virtually indefinite, and I can make it in small batches. I thought
> about selling it in small vials but the toxicity argues against that. Some
> putz would probably sue me because his kid tried to snort it or something.
> Anyway, FWIW.
> Phil M.
2013-05-21 by Boman33
2013-05-22 by Aaron Turner
On Tue, May 21, 2013 at 4:41 PM, Boman33 <boman33@...> wrote:
> A year ago or so I started to test multiple printers, transparencies and
> ink
> settings but I got too busy to finish and I am still too busy to continue
> right now. I measured opacity vs. wave length to eventually select the best
> combination for creating artwork for photo resist development.
> Test artwork:
> http://www.vinland.com/USAF-1951.html
> Scroll down to the bottom for the PCB test pattern
> With that as a background, I recently got a new printer and just printed my
> standard test print without any tweaking and it looks very promising. It is
> a photo printer and it has three black-gray-light gray inks besides all the
> colors.. I have not done any measurements or other tests so no promises.
> It also looks like it can print 5 mil lines/spaces.
> Printer: Canon Pixma Pro-100.
> Regular price $500, Amazon sells it for $400 with a rebate of $200 and an
> extra $50 if one signs up for their credit card. So at the end I paid $150,
> got free second day shipping.
> As for Phil's comments on lack of laser transparency accuracy would suggest
> to use an inkjet instead. Going through the laser fuser's high temperature
> can easily distort the artwork.
> Also it is critical to get sufficient opacity that a single layer artwork
> can be used.
> Bertho
2013-05-22 by Mitch Davis
>Switch to metric. You can stand a lot closer, your feet stay drier,
> do more than six feet. Now that I'm almost 60 (yikes!) well, you don't want to know.
> I make double sided PCBs with plated-thru holesI'd be very interested to read more about that, do you have a blog
> a side because of the distortion caused by printing laser transparencies.Have you tried printing on drafting paper? Drafting paper is
2013-05-22 by don@...
2013-05-22 by Mark Harrison
and you can keep your vanity "score" the same :-)
page or web page showing what you do? I'm especially interested in
how you get registration between the two sides right.
transparent to UV, and I've had good success with it. I just bought a
pad at the stationery shop. And just as for transparency, the
printing should go against the board.
You can read about my method with drafting paper here:
http://capnstech.blogspot.com/2011/05/playpause-making-pcbs-at-home.html
All the best!
Mitch.
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2013-05-22 by Phil@Yahoo
Sent: Tuesday, May 21, 2013 6:52 PM
Subject: Re: [Homebrew_PCBs] Re: printer
>> want to know.
> All the best!
> Mitch.
> Photos:
Sent: Tuesday, May 21, 2013 7:59 PM
Subject: RE: [Homebrew_PCBs] Re: printer
> Hi,
> We used drafting film for direct imaging UV sensitive PCB's with good
> results. It gave the best results for artwork plotted done by our old HP
> pen plotters.
> Unfortunately the pens were too thick for today's boards that require 8mil
> or 5mil track widths to suit modern semiconductors and connectors :-(
> It also took a LONG time to plot out boards with large filled areas
> (especially with thin pens, and it's probably one of the reasons why
> cross-hatch fills were invented :-)
> In case anyone is wondering, drafting film is generally a polymer film
> (not a paper, so it does melt!) that has silica powder added to the
> plastic mix (double side matt finish), or has silica powder pressed into
> one side (single matt). The idea is to print on the matt side where the
> silica absorbs the ink, and as others suggest, is the side that has to be
> in contact with the PCB resist during exposure.
> BTW, silica in drafting film is really good at blunting scissors!
> More recently I experimented with old Tektronix/Xerox Phaser printers
> (colour wax printers) directly onto adhesive backed copper foil.
> This worked quite well, although the adhesive starts to soften if you
> leave it in hot etchant too long.
> I then stick an adhesive polymer film over the top to hold the copper in
> place, and remove the foil's own backing to expose the copper's adhesive.
> Then I stick it all down on a blank board, and finally peel the top film
> off (being careful to leave the copper behind on the substrate).
> The process need refinement, but has produced a couple of prototype flex
> circuits to date. Unfortunately the foil's adhesive isn't designed for
> high temperatures so solder quickly! Some future experimentation with
> epoxy glues is in order.
> Cheers,
> Mark
> Bionics Institute
> Melbourne, Australia
> -----Original Message-----
> From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
> On Behalf Of Mitch Davis
> Sent: Wednesday, 22 May 2013 11:52 AM
>> want to know.
> All the best!
> Mitch.
> Photos:
> Photos:
2013-05-22 by Kirk McLoren
> Hi,
> pen plotters.
> Cheers,
> Mark
> Bionics Institute
>> want to know.
> All the best!
> Mitch.
> Photos:
> Photos:
2013-05-22 by cunningfellow
> Phil wrote:Have you had problems with tenting? How thick
> <SNIP>
> Before applying the film I fill the holes
> with a mixture of drywall plaster and sugar,
> let it dry, and sand the board lightly to
> remove any plaster from the surface. This
> provides a flat surface for the resist film,
> and is easy to remove with water and a
> water-pik (dental cleaner) after etching.
> The sugar resists the etchant in case any
> does come into contact, which otherwise
> would solidify the plaster making it
> difficult to remove.
> Phil wrote:If using a laser then vellum/drafting-film.
> <SNIP lots about lasers and tranny film>
Sent: Wednesday, May 22, 2013 1:19 PM
>> Phil wrote:
>> <SNIP>
> is negative active film you are using?
> Thicker film and a good contrast artwork should
> make a tent that is plenty strong enough to
> survive even vigorous hand developing/etching.
> Photos:
Sent: Wednesday, May 22, 2013 1:31 PM
> Lasers a transperency material don't work
> well together.
> Lasers do excellent black for thin lines but
> unless you have a new-car-priced laser then
> large black areas will be faded.
> Any cheap inkjet will give better results
> than any cheap laser for large black areas.
> The inkjet will also have better dimensionl
> accuracy / less-distortion.
> Now I have lost access to the fantastic
> Tektronix laser I had at work I have switched
> to using a random canon inkjet on gelatine
> coated inkjet transparencies.
> Gives almost as good a result with $100 worth
> of printer than a $30K+ printer did. Only
> downside is that the transparencies cost $2
> a sheet rather than $0.30 a sheet. So I am
> frugal with them and do a test print on paper
> and then cut out a small rectangle of tranny
> to tape over the test print.
> Photos:
2013-05-22 by Russell Shaw
>What model number is the Canon? Is it using the standard genuine ink?
> well together.
2013-05-22 by designer_craig
--- In Homebrew_PCBs@yahoogroups.com, "Phil@..." <yahoo@...> wrote:
> I haven't started to document the process yet because I'm still
> experimenting. I got my initial ideas and encouragement watching some
> youtube videos bye by a guy with a channel named "pathetic-computing." You
> can find out about conductive ink at http://jordanbunker.com/archives/41
> Because the holes are drilled and plated before etching, and I use negative
> dry film photoresist, the masks are clear where the pads will be, so you can
> see the holes to align the mask on either side. Before applying the film I
> fill the holes with a mixture of drywall plaster and sugar, let it dry, and
> sand the board lightly to remove any plaster from the surface. This provides
> a flat surface for the resist film, and is easy to remove with water and a
> water-pik (dental cleaner) after etching. The sugar resists the etchant in
> case any does come into contact, which otherwise would solidify the plaster
> making it difficult to remove.
> Phil M.
> From: "Mitch Davis" <mjd@...>
> >> want to know.
> > All the best!
> > Mitch.
> > Photos:
Sent: Wednesday, May 22, 2013 2:41 PM
> Phil,
> I have been a DIY board maker for years, though lately I have been lazy
> and ordered my boards as the price as really come down. Anyway, I have
> always wanted to do PTH boards.
> I have been tracking the DIY PTH technology for some time now. This is a
> new one and I may have to give it a try. I had been looking at Tollen's
> reagent (used to silver mirrors) but did not have any success. This silver
> acetate process is a variation on the Tollens.
> The processes I have looked at so far are the the multi step "Palladium
> activation" (too costly and complex) the "black hole" (has potential but
> messy), the "Copper Hypophosphite activation" (looks very nice but has
> chemical sourcing issues with the DEA). So this may be the answer.
> Please keep posting the results of your PTH processing.
> Craig
>> You
>> negative
>> can
>> I
>> and
>> provides
>> a
>> in
>> plaster
>> Phil M.
>> >> want to know.
>> >> transparencies.
>> > All the best!
>> > Mitch.
>> > Photos:
> Photos:
2013-05-23 by Mark Harrison
> Hi,
> pen plotters.
> Cheers,
> Mark
> Bionics Institute
>> want to know.
> All the best!
> Mitch.
> Photos:
> Photos:
2013-05-23 by Phil@Yahoo
Sent: Wednesday, May 22, 2013 8:38 AM
you can get frosted tempered glass?
I thought messing with the surface of tempered glass causes it to shatter.
Sent: Wednesday, May 22, 2013 12:20 AM
Can you be specific? I've looked at drafting paper and tracing paper at
Office Max etc and found them to be either too thin or ridiculously
expensive. I've tried printing on parchment paper but the toner comes off if
you even touch it. I've considered making glass masks by multiple layers of
toner transfer to the glass to get the contrast. I'm thinking the Oracal
might work for that. Sand-blasting one side of the glass should provide
enough "tooth" to allow the toner to stick. Not sure if the glass would
stand the thermal shocks. Tempered glass maybe. If someone has already
followed that road to failure, please advise.
All I want is something quick, easy and cheap.
Well, also I'd like less to do, more time to do it, and more money for not
getting it done.
Phil M.
> Hi,
> pen plotters.
> Cheers,
> Mark
> Bionics Institute
>> want to know.
> All the best!
> Mitch.
> Photos:
> Photos:
2013-05-23 by cunningfellow
> Russell Shaw wrote:i865 using genuine BC3/CL6 carts.
> Some inks won't soak into the gelatine film.
2013-05-23 by Mitch Davis
> Can you be specific? I've looked at drafting paper and tracing paper atNot sure you're asking me, but FWIW I just grabbed some tracing paper
> you even touch it.
> Phil wrote:33um (1.3 mil inch) is the thickness of stuff
> I haven't measured the film, but I'd guess
> about 1 or 2 mils thick.
> Phil wrote:Random brand here.
> Exactly what I have found. Do you have a brand
> name for the gel-coat transparency film?
> <SNIP>
2013-05-23 by Boman33
> Phil wrote:transparency film?
> Exactly what I have found. Do you have a brand name for the gel-coat
> <SNIP>Random brand here.
2013-05-23 by Russell Shaw
>I think the gelatine coating only absorbs and quickly dries with dye ink.
> I have tried CL8 carts in a newer printer
> and are the same results.
> Have not tried any of the disposable printhead
> ones.
> Russell Shaw wrote:I think (but am not sure) that my phototool
> The i865 has both pigment and dye ink black
> tanks, though the aftermarket cheap replacement
> for the pigment tank is usually a dye one too.
> The colour tanks are all dye.
> When printing with text, the pigment tank is
> used. Pigment ink stays wet on the gelatine
> surface because the ink is oil/wax based to be
> waterproof. The gelatine only absorbs water,
> and dye inks are more "watery" based.
> <SNIP URLS>
> A pigment ink gets its colour from the colour
> of the suspended solids. They usually fade
> less in UV light.
> A dye ink has no solids. The colour comes from
> the liquid. They usually break down and fade
> more in UV light (i can't say for certain about
> modern formulations though).
> Boman33 wrote:The base material is a dimensionally stable
> That is an interesting piece of information
> about drying the film before printing. One
> more variable to test.
> I worry though that the artwork will change
> dimensions as it reabsorbs humidity but I do
> not know how significant it is. Of course
> that also depends on the size of the artwork.
> Maybe dry it again before imaging onto the
> PCB.
Sent: Wednesday, May 22, 2013 8:13 PM
> that the manufacturer of the stuff I use says
> is unsuitable for "tenting"
> 50um (2 mil inch) is listed as good for tent
> So 1..2 mil could make a difference.
> I nice high contrast phototool makes a diff
> too. Getting the tent all UV'd up before the
> develop step.
> Photos:
Sent: Wednesday, May 22, 2013 8:19 PM
>> <SNIP>
> Random brand here.
> HOWEVER here is the big tip. They have probably
> absorbed a lot of moisture from the air.
> Put them in the oven for 10 mins at 140c before
> hand to dry em out. They soak up heaps of ink
> and get plenty dark then :D
> My full procedure is
> Print artwork in draft mode onto sheet of A4
> Cut tranny to cover artwork with few cm border
> tape tranny to paper along one edge with 3M tape
> put in oven for 10 mins
> remove from oven and tape opposite edge
> run through printer (mode = tranny+high)
> Photos:
2013-05-24 by AlienRelics
> I guess I don't know what "tenting" means.
> Phil M.
> From: "cunningfellow" <andrewm1973@...>
> > develop step.
> > Photos:
2013-05-24 by Boman33
> PCB.
2013-05-24 by Russell Shaw
>> Russell Shaw wrote:Ok, sounds like pigment.
>> <SNIP URLS>
>> less in UV light.
> printing is being done with the BC-3 (pigment)
> cart.
> The print was told to do "B&W only"
> I will try do some tests making sure different
> carts are used to see.
> BTW - the ink DOES stay "wet" for a long time on
> the gelatine surface. However after the oven
> treatment it does not "pool" when wet so makes
> nice solid dark (temporarily wet) blacks.
> I have read that yellow ink is sometimes more
> UV blocking than black because of anti-fade
> UV blockers used. I have not tried this myself
> yet.
