Homebrew_PCBs
Index last updated: 2026-03-31 12:10 UTC
Copper foil
Copper foil
2013-03-18 by lex allen
could copper foil be stuck to fiberglass boards to make PCB's?
RE: [Homebrew_PCBs] Copper foil
2013-03-18 by David C. Partridge
That's how they *are* made. Also how the Cir-Kit repair sets sold by Pace work.
D.
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of lex allen
Sent: 18 March 2013 15:38
Subject: [Homebrew_PCBs] Copper foil
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
Re: [Homebrew_PCBs] Copper foil
2013-03-18 by Leon Heller
I thought that was how they were made!
Leon
Leon Heller
G1HSM
2013-03-18 by r.d. terramir
well yeah sort of but the way they are bonded is specific just using copper
foil will be kinda flakey unless the adhesive you use is heat resistant so
you can solder the contacts otherwise it will just lift up all over the
place.
terramir
> Leon
> Leon Heller
> G1HSM
Respectfully,
R. Daniel Borkan
727 S. Coronado St. 201
Los Angeles, CA 90057
H: (213) 739-1863
C: (213) 271-6721
2013-03-18 by Norm
> copper
> place.
> terramir
The foil (comes in varying widths) made for stained glass artwork has
heat resistant adhesive - it's made to be soldered after sticking to glass.
Norm
W6NIM
2013-03-19 by Tony Smith
> > copper foil will be kinda flakey unless the adhesive you use is heat
> > resistant so you can solder the contacts otherwise it will just lift
> > up all over the place.
> > terramir
> The foil (comes in varying widths) made for stained glass artwork has heat
It's not that heat resistant.
In stained glass it's bent around the glass forming a U-shape, and once
that's covered in solder it doesn't matter if the adhesive fails, it's not
going anywhere.
Tiffany used beeswax to hold the foil in place until it was soldered. Some
of the glass in his lamps rattle because the beeswax evaporated over time.
The OP may find this interesting:
http://hackaday.com/2011/09/12/glass-pcbs/. He was just gluing the copper
foil to the glass, but he did try the foil method as suggested. Can't
remember his outcome...
Tony
