UV nail lamps
2013-01-05 by dave_donlan
Archive for Homebrew_PCBs.
2013-01-06 by Vicent Colomar Prats
>quite cheap might be worth a llok
> Just been looking on flea bay and came across these
> 36W Nail UV Lamp Acrylic Gel Curing Light
> has anyone had any experience with these unit for producing pcbs - seem
> Dave[Non-text portions of this message have been removed]
2013-01-06 by designer_craig
>I ordered on a while back to make an expousure box. The one I go has 4 U shaped 8W tubes (36W total). As is, it would do a 4x4 board. I figured I wanted a little larger unit so the plan was to go with more tubes in a DIY box. Also wanted the ability to do both sides of the board at once.
> has anyone had any experience with these unit for producing pcbs - seem quite cheap might be worth a llok
> Dave
2013-01-06 by dave_donlan
> > Dave
> The replacement 8W bulbs are quite inexpensive, so I will just buy more bulbs. No need for bulb sockets, just RTV the bulbs in place and solder directly to the pins. The real issue is where to get low cost ballasts. The nail unit I got had one ckt board that powered 4 bulbs, best I could tell there was one main line chopper and 4 bulb current limiting inductors. If you don't want to roll your own ballast just hack some from old CFL cork screw bulbs -- they work fine. FYI inside the blastic base of the bulb each end of the tube has two filiment wires. One wire from each filiment is connected to the pin on the base of the bulb. The ohter filiment pins are joined together with a series capacitor. Thus the bulbs will appear open to dc and an ohm meter.
> Craig
2013-01-07 by Robin Whittle
2013-01-07 by Jeff Heiss
2013-01-07 by Boman33
2013-01-07 by Vicent Colomar Prats
> **[Non-text portions of this message have been removed]
> What are thoughts on exposure time vs. resolution? Pretend a 100w bulb
> gives a 10 minute exposure and a 200w bulb gives a 5 minute exposure. Is
> either better, worse, the same?
> Jeff
> -----Original Message-----
> From: Boman33 boman33@...>
> Sent: Monday, January 07, 2013 2:41 AM
> Subject: RE: [Homebrew_PCBs] UV nail lamps - sharpness of shadow,
> phototool-PCB contact closeness, 500W floodlamp
> Use thicker glass and let the PCB deform to lay flat against it. The force
> of the vacuum (air-pressure) is very large over the big area of the PCB.
> Bertho
> From: Jeff Heiss Sent: Monday, January 07, 2013 01:46
> I experimented with a ziplock bag and a vacuum pump. The transparency is
> held to the board very very well. Much better than glass can ever do.
> However, I found a drawback and that is the plastic forms imperfections and
> scratches from fingernails, stretching and pulling to get wrinkles out
> during vacuum, and around the transparency and copper clad edges.
> I question, as I have not tested, if these imperfections can cause
> diffusion
> of the light as it passes through and decrease results especially if the
> imperfections are over a thin trace or spacing between traces. I tried
> blanket storage bags, same problem. My conclusion is that very thin glass
> like microscope cover slide glass is the ideal material because it is thin
> enough to deform over the copper clad. I searched for glass as thin as
> cover slide glass but I could not find a place who sells it. Maybe
> something better than ziplock bag plastic can be used too that I am not
> aware of.
> Jeff
2013-01-07 by Harvey White
>I experimented with a ziplock bag and a vacuum pump. The transparency isI used furniture store vinyl, thin gauge, seemed to work just fine,
>I question, as I have not tested, if these imperfections can cause diffusion
>aware of.
>Jeff
> _____
>From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
>On Behalf Of Robin Whittle
>Sent: Sunday, January 06, 2013 9:17 PM
>Cc: Vicent Colomar Prats
>Subject: Re: [Homebrew_PCBs] UV nail lamps - sharpness of shadow,
>Hi Vicent,
>Some of the eBay ads which can be found by searching for:
>show that they contain four long U-shaped fluorescent lamps. This ad:
>http://www.ebay.com/itm/310556445104
>shows one of these types of lamp - and they have "365nm" written on
>them, which is most helpful! The Riston General Processing Guide at:
>http://www2.dupont.com/Imaging_Materials/en_US/tech_info/datasheets/index.ht
>ml
>indicates peak sensitivity is in the 350-380 nm near-UV range, with some
>sensitivity from 300nm (UV) to 450nm (blue).
>I am not sure what wavelengths other photoresists are most sensitive to,
>such as positive photoresists.
>I think it is much better to have a relatively compact source of light
>than something broad like these.
>In some previous messages to this list, such as message 30440, I
>described using a 500 watt linear halogen incandescent lamp with
>reflector - a cheap hardware-store "floodlamp". Such lamps put out
>enough near-UV to give me a sun-tan when I extensively used an old
>process camera which had four of these lamps. Glass would reduce the
>tanning/burning shorter wavelength UV rays to some extent but I think
>would hardly affect the transmission of the 350-380nm light of interest.
>The 500 watt lamp radiates most of its energy in the visible and
>infra-red (with some being lost as hot air), and only a fraction of it
>is the light we are interested in. I couldn't find a suitable source of
>dark-violet-looking "Woods glass" to make a filter which would reject
>most of the visible and IR I don't want. This visible and IR energy is
>substantial and will warm the board, which might cause differential
>expansion of the phototool and board. However, this can be largely
>solved by blowing a fan on the board, with its phototool and glass or
>other surface which clamps the phototool to the board.
>This way, most of the light comes from an area about 10cm wide and 45cm
>away from the board. These rays of light are relatively parallel, so
>the shadow from the phototool remains relatively sharp even if the
>phototool is not completely flat against the photoresist.
>With a broader source of light, as would inevitably be the case with
>these less intense, larger, fluorescent lamps, the shadow would be much
>less sharp.
>It is difficult to get the phototool sitting flat against the PCB. The
>PCB is reasonably rigid and is not necessarily flat. If the top cover
>is glass or acrylic, then any dust or mismatch between the flatness of
>the glass and the PCB will cause a gap and loss of sharpness.
>It would also be possible to use a vacuum frame with a soft, flexible,
>top surface, such as clear PVC sheet (retailed at fabric and other shops
>as a table covering), which would press the phototool close to the PCB
>even if the PCB was not completely flat. This would also largely avoid
>problems caused by dust, since it would tend to stretch the phototool
>over the dust particle and so press it close even one or two mm away
>from the particle, whereas with the glass or acrylic approach, the dust
>particle would lift the phototool and glass off the board for a larger
>surrounding area.
>Another likely problem with fluorescent lamps of all types is that their
>output would vary considerably with how long they have been on for,
>which would be affected by their starting temperature and therefore how
>long they had been on for in the last 30 minutes or so. This would make
>it difficult to run them from a timer. This might be OK if you ran them
>all the time and had a way of simply placing them over the PCB with
>phototool etc. However, I prefer to place the phototool and my existing
>glass sheet arrangement together by a safelight (a bunch of red LEDs)
>and place it under the lamp, before turning the lamp on for a fixed
>time. The 500W incandescent lamp would have its near-UV output affected
>somewhat by mains voltage fluctuations, but I doubt if this is a
>significant problem.
>- Robin http://www.firstpr.com.au/pcb-diy/
2013-01-08 by Jeff Heiss
diffusion
>aware of.
calibrated exposure with the covering in place.
Did not use saran wrap or the equivalent, since it was too thin and
developed a static charge which tended to lift the positive from the
board and was messy to deal with. You could also use book cover
material, which may be equally nice.
Take something fluorescent, a black light, and see if it glows less
with the material between it and the light.
Harvey
>Jeff
> _____
<mailto:Homebrew_PCBs%40yahoogroups.com>
<mailto:Homebrew_PCBs%40yahoogroups.com> ]
>To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
>Hi Vicent,
t
>ml
>less sharp.
>surrounding area.
2013-01-08 by Missouri Guy
and
diffusion
glass
thin
>aware of.
Harvey
>Jeff
> _____
>Hi Vicent,
x.h
t
>ml
>less sharp.
>surrounding area.
2013-01-09 by smilingcat90254
2013-01-09 by Rick Sparber
2013-01-09 by Jeff Heiss
--- In Homebrew_PCBs@yahoogroups.com, "Jeff Heiss" wrote:
> http://www.polymetaal.nl/siteUK/shopukwork/en-gb/dept_183.html
> The price is on the bottom of the page. The cost is 24" x 10' for $78 (60
> Euro). It costs 5.4 times as much as photoresist available on Ebay. I
> computed 5.4x using the resist I purchased which is 8.3" by 9.7' DuPont
> MM540 for $14.49.
> Jeff
> _____
> On Behalf Of Rick Sparber
> Sent: Tuesday, January 08, 2013 8:40 PM
> Subject: RE: [Homebrew_PCBs] photo resist. Slightly different material.
> Ms. Smilingcat,
> It looks like very interesting stuff. What bothers me is they said
> "affordable price" yet don't list the price. That usually means it ain't
> that affordable. So what DOES it cost?
> Rick
> On Behalf Of smilingcat90254
> Sent: Tuesday, January 08, 2013 6:13 PM
> Subject: [Homebrew_PCBs] photo resist. Slightly different material.
> Some of you have complained that the resist lifts off or gets damaged during
> handling. laying of the transparent image, static electricity causing the
> resist to lift off with the image, vacuum bagging causing more surface
> scratch and so on.
> and the use of chemicals.
> I just recently ordered a material called puretch from only US distributor.
> claims that the film is good down to 1 mil resolution provided your image is
> that good.
> links to the US distributor: www.capefearpress.com/puretch.html
> youtube videos on the product: www.youtube.com/watch?v=xkGt9nFER1s
> another link:
> Developer used is sodium carbonate (do not get it confused with sodium
> bicarbonate which is baking soda)
> capefear press has some good information on how to expose without creating
> shadows and the lamp recommended. Good solid information. Application at
> capefearpress is not electronics but rather arcane art form. Far more
> technical than most of us here or using toner transfer method.
> Some advantages: photoresist is protected from handling by a thin plastic
> layer. It is removed when you are ready to develop so that you can't scratch
> or lift off during handling and exposing.
> For photoimaging, they also sell stoufer exposure gauge to help you get the
> right exposure.
> For now I think I have Pulsar toner transfer system working well enough.
> Don't need to use lot of pressure. Too much pressure causes the toner to
> "bleed" on the edges. temperature to melt toner is around 100C anything more
> and the toner becomes too thin and the image "bleeds"/run.
> I may still switch over to puretch. Don't need to keep printing images for
> multiple board. higher resolution for use with TQFP with 0.5mm pitch. Pulsar
> is near the limit for 0.5mm pitch.
> (60 Euro). It costs 5.4 times as much as photoresist available on
> Ebay. I computed 5.4x using the resist I purchased which is 8.3" by
> 9.7' DuPont
> MM540 for $14.49.
> Jeff
> _____
> Ms. Smilingcat,
> ain't that affordable. So what DOES it cost?
> Rick
> during handling. laying of the transparent image, static electricity
> causing the resist to lift off with the image, vacuum bagging causing
> more surface scratch and so on.
distributor.
> image is that good.
> another link:
> creating shadows and the lamp recommended. Good solid information.
> Application at capefearpress is not electronics but rather arcane art
> form. Far more technical than most of us here or using toner transfer
method.
> plastic layer. It is removed when you are ready to develop so that you
> can't scratch or lift off during handling and exposing.
> get the right exposure.
> to "bleed" on the edges. temperature to melt toner is around 100C
> anything more and the toner becomes too thin and the image "bleeds"/run.
> for multiple board. higher resolution for use with TQFP with 0.5mm
> pitch. Pulsar is near the limit for 0.5mm pitch.
Photos:
2013-01-09 by Robin Whittle
> MM540 for $14.49.
> Jeff
> _____
> On Behalf Of Rick Sparber<mailto:Homebrew_PCBs%40yahoogroups.com>
> Ms. Smilingcat,
> Rick
> [mailto:Homebrew_PCBs@yahoogroups.com<mailto:Homebrew_PCBs%40yahoogroups.com>
> ]during
> handling. laying of the transparent image, static electricity causing thedistributor.
> scratch and so on.
> claims that the film is good down to 1 mil resolution provided your imageis
> that good.scratch
> another link:
> or lift off during handling and exposing.the
> right exposure.more
> and the toner becomes too thin and the image "bleeds"/run.Pulsar
> is near the limit for 0.5mm pitch.Photos:
> http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links[Non-text portions of this message have been removed]
2013-01-09 by Bob AD5VJ
On Jan 8, 2013, at 10:25 PM, "Jeff Heiss" <jeff.heiss@...> wrote:
> I have a Pan American Tool cobalt drill set. Like yours, real cobalt steel,
> not Chinese stuff, but not TiN coated. What brand of drills do you have?
> Tektronix over Agilent and Lecroy? Just kidding;)
> Jeff
> _____
> Sent: Tuesday, January 08, 2013 10:29 PM
> Subject: [Homebrew_PCBs] Re: photo resist. Slightly different material.
> Yes E-bay is cheaper.
> At Capefear, cost for 10' x 24" film is $59.00 with S/H I think it was. they
> have much smaller size for sampling but it is pretty pricy!! $19 for 12" x
> 24".
> I pay premium over E-bay because I prefer to have a "regular" supplier. It's
> the reason I order from DigiKey, and buy Tektronix and HP equipment.
> My sample order from Capefear came very prompt. Well packed, looking very
> reputable.
> I do not care for grey market items or suppliers where you can't trace back.
> As a reference of how I view things: Some of my cutting tools are cobalt
> steel with TiN coated material. Not some high carbon steel. Tools
> themselves, I prefer Dewalt, Bosch, Makita... Prefer it is MADE IN USA or
> Germany or Japan and not just the label saying USA/German/Japanese company.
> Most recent outburst was over 6-32 tap. Ordered a replacement tap. Broken
> one was a cheapie from Craftsman high carbon steel. Flute on the tap was cut
> so irregular, one of the cutting surface was less than 1/32" wide.
> Replacement is a cobalt steel, TiN coated 6-32 H3 tap from Ghurring. cost is
> about $15.00 each.
> Been looking for a lathe and mill and I think I'm going to invest in Taig.
> Not so hot on Smithy or Grizzly. Both are not that accurate. I used Smithy
> and wasn't impresed. Even their technical spec was bit of a yawn.
> smilingcat,
> > MM540 for $14.49.
> > Jeff
> > _____
> > Ms. Smilingcat,
> > Rick
> during
> > scratch and so on.
> distributor.
> is
> > that good.
> > another link:
> scratch
> the
> > right exposure.
> more
> Pulsar
> Photos:
2013-01-11 by fetbrat
> > Dave
> Craig
2013-07-04 by fred27murphy
2013-07-05 by Vicent Colomar Prats
> An old thread but I thought I'd contribute something with my first post. I
> got one of these UV nail lamps to use for solder mask film - inspired by
> this: http://www.instructables.com/id/Dry-Film-Solder-Mask/
> It works really well. As others have mentioned, the outside two lamps are
> lower so I removed these to help prevent light getting under the
> transparency.
> I tried it briefly with positive photo resist for board etching but found
> that the UV output was too high and a normal fluorescent worked better for
> this.
> Fred
2013-07-05 by fred27murphy
--- In Homebrew_PCBs@yahoogroups.com, Vicent Colomar Prats <vicentecolomar@...> wrote:
> Can you tell us what kind of solder mask film have you used? Brand and
> model? Cheers.
> It's the same one used in the Instructable but as I'm in the UK I tracked
> down a European supplier. It's Dynamask 5000 and I ordered a roll from from
> octamex.de
> So far I found it easier to work with than photoresist boards! However
> I've only used the solder mask on simple CNC-milled through-hole boards.
> I managed to get my first SMT board etched last night. The quality is good
> enough for TSSOP20, but I believe it could be better. I'll let you know how
> well the mask works for SMT when I get round to soldering it.
> Fred
> > model? Cheers.
