> tda7000
> Are you using the FBS-240E or the 12v version in the
> MB140/S ?, am thinking of getting the FBS-240E
> Also i note that the stand has a fence across the width of the
> base, can the fence be moved to the back of the base to allow
> larger pcb to be drilled ?
> Do you think that this drill\stand combination is good for
> using tungsten carbide bits ?
> Howard
> --- In Homebrew_PCBs@yahoogroups.com, "tda7000" <Tda7000@> wrote:
> > I use the Proxxon FBS rotary tool (You can also get the IB/E which is even better) in the MB 140/S Stand, after watching this: http://www.youtube.com/watch?v=1JyTf1tJXXo
> > Tool goes to 20,000 RPM so I think it's better for PCBs than the TBM drill press.
> > Also, with a router bit I can cut my PCB stock with it too.
> > Broken only one bit so far, because I accidentally moved the board while drilling.
> > --- In Homebrew_PCBs@yahoogroups.com, "Howard" <howard_g7lqy@> wrote:
> > > Hi All
> > > Am having some probs with my drill\stand setup.
> > > The stand is the type with a single slide piller,
> > > it is meant for a 240v work drill (i use a dremel drill )
> > > sometimes the stand will move from side to side and
> > > snap the drill bit !!.
> > > Can anyone suggest a good drill\stand combination, that
> > > will not give me these problems ?
> > > I think that some of you use Proxxon products
> > > any pros\cons ?
> > > Look forward for any comments
> > > Howard
