KPR developer
KPR developer
2012-03-07 by lemar
i have some Kodak KPR photoresist left over from experimenting several years ago but I have not more developer. Any ideas for a substitute for the original? Something simple?
LeMar
Re: KPR developer
2012-03-08 by bebx2000
I think the Datak negative spray-on photoresist is the same as the old KPR. The resist and developer are listed at the bottom of this page,
http://shop.vetcosurplus.com/catalog/default.php?cPath=94_153
Baxter
> Thanks,
> LeMar
Re: KPR developer
2012-03-09 by lemar
Thanks, I'll give that a try. Any idea what the shelf life is for KPR?
> Baxter
> > Thanks,
> > LeMar
Re: [Homebrew_PCBs] Re: KPR developer
2012-03-09 by John Anhalt
KPR developer is listed here as a mixture of xylenes, ethylbenzene, and 2-methoxyethylacetate (cas110-49-6).  Another name for the latter is ethanol, 2-methoxy, 1-acetate.  In other words, it is ethyl acetate with a methoxy attached to the end of the ethyl group.
http://www.mgchemicals.com/msds/english/718.pdf
Shelf life is probably quite good.  The 2-methoxyethylacetate might hydrolyze a little, if any water is present.  As for making it, one might be able to omit the ethylbenzene entirely from a workable substititute, or substitute toluene for it.  If you eliminate the ethylbenzene, increase the amount of xylenes to compensate.  If you use toluene, I would consider reducing its concentration to about half of the ethylbenzene concentration and making up the difference with xylenes.
I suspect the methoxyethylacetate or something similar is essential.  Diglyme might work.  You won't be able to find either at a consumer store.  Since you will end up ordering something, it might as well be the original methoxyethylacetate.
John
  Sent: Thursday, March 08, 2012 7:13 PM
  Subject: [Homebrew_PCBs] Re: KPR developer
  > Baxter
  > > Thanks,
  > > LeMar
Re: [Homebrew_PCBs] KPR developer
2012-03-09 by VK3YV
Hi ,I used to use TRICHLORETHELENE for many years and it worked perfectly,
but I don't think you can get it now, been banned. KPR is also no longer
available either,
Don ....VK3YV
Sent: Thursday, March 08, 2012 4:37 AM
Subject: [Homebrew_PCBs] KPR developer
> Thanks,
> LeMar
> Photos:
