CD shaped PCB
CD shaped PCB
2011-04-13 by Boman33
Here is a crazy idea that might just work:
A first requirement is being able to cut out a PCB the to look just like a
CD.  It needs to be accurate and typically a lathe would be used.  Apply a
layer of paint or other protective coating over the copper.
Pop it into a CD burner that has the Light Scribe or whatever it is called
feature to mark CDs.  Take the layout and convert it to a JPG and use the
marking software to place it on the CD.  Several small SMT PCBs will fit on
a CD.  "Write" the picture to the "CD" and hopefully it will vaporize the
paint.  Afterwards etch the boards as usual.
If the power is controllable, it might also be used to expose a photoresist
as an alternative.
Bertho
Re: [Homebrew_PCBs] CD shaped PCB
2011-04-13 by Tim Hills
2 things come to immediately to mind.
CD/DVD recorders use Infrared lasers and most photoresist is UV sensitive.
I don't know if the resolution of a lightscribe would be fine enough.
Worth a shot though if you can find IR sensitive resist.
TIm
> photoresist
> as an alternative.
> Bertho
2011-04-13 by Zoran A. Scepanovic
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> as an alternative.
> Bertho
It sounds like "killing a bull for a steak" :)
Best Regards,
Zoran A. ??epanovi?
zastos@...
http://zastos.com
+381 63 609-993
Programmers don't die!
  They just GOSUB without RETURN.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJNpasEAAoJEIx1ZTLEcXHfy+AH/jppiIzy0I9prJiWUQ1U1FDu
nnbagrjqjfVxSJy4BauHyrajbIrx6kuWEDrTKNsFzy6JU2qKqiuAfjUD5PR30rDZ
9Lli1Em1vFyD7aeOdFJqhlh3mvSaOUekhJcRoE+9yNTHWv0/UkpUHl/9ppDzHwcu
CfNfYM/h1G3ypRD8BgcJCsTWCVkWjlMXNEGV8XmsrIMbQU7/JibrM9xGhSg5NvJg
wYvPdq8f2gAVi2ACH72QFpE6hIaXGUt5jQMvQ9BWgoqjpAgOKK3XNolsL1M/DDTA
WWbm7P2+Xik0K/bzosXa9UE1juxGya0p6MPvaZMJFkkuIBtkfSY6x+wrPXLaKB8=
=fPK1
-----END PGP SIGNATURE-----
RE: [Homebrew_PCBs] CD shaped PCB
From:  Zoran A. Scepanovic  Sent: Wednesday, April 13, 2011 09:54
How would you get the steak otherwise J
Bertho
2011-04-13 by Matthew Andrews
I suspect that without some sort of exhaust ventilation you'll have
problems with paint residue/vapor coating your optics, and most anything
else in the vicinity.
-Matt
> photoresist
> as an alternative.
> Bertho
2011-04-13 by Leon Heller
> as an alternative.
CD lasers don't have enough power.
Leon
Leon Heller
G1HSM
Re: CD shaped PCB
2011-04-13 by tda7000
I assume just like a writable CD, the lightscribe part also needs a pre-made spiral groove in the material for the laser to follow.
If this is not there I expect the drive will just say "no disc" and do nothing.
> > as an alternative.
> Leon
> Leon Heller
> G1HSM
Re: [Homebrew_PCBs] Re: CD shaped PCB
2011-04-13 by Pete Harrison
and in addition,the laser needs a mirror surface to carry out initial focusing
and tracking...without that,it will also say no disc,and reject the media.
Sent: Wed, April 13, 2011 10:41:11 PM
Subject: [Homebrew_PCBs] Re: CD shaped PCB
> > as an alternative.
> Leon
> Leon Heller
> G1HSM
RE: [Homebrew_PCBs] Re: CD shaped PCB
I never thought about the tracking and that the drive might reject it
knowing it is not a CD.
I was a cute idea even if not practical at all ......
From:  tda7000   Sent: Wednesday, April 13, 2011 17:41
nothing.
a CD. It needs to be accurate and typically a lathe would be used. Apply a
called feature to mark CDs. Take the layout and convert it to a JPG and use
the marking software to place it on the CD. Several small SMT PCBs will fit
on a CD. "Write" the picture to the "CD" and hopefully it will vaporize the
photoresist as an alternative.
Re: CD shaped PCB
There have been tests with laser cutters into burning off etch resist, Adafruit industries tried it (after first dismissing the idea of directly burning off the copper)
"well you need superhigh power to remove copper and even then, its very difficult. one thing we might try with the laser cutter ive got is doing photoresist WITHOUT a mask by 'exposing' the mask directly w/laser @ 600DPI. if so: ultra high precision without ironing/transfers/UV boxes/milling/etc.
stay tuned for our experiments!"
and then a few posts later:
"we tried it out, it was 'ok' but not as good as toner transfer (yet)"
(http://forums.adafruit.com/viewtopic.php?f=18&t=2807)
I guess it might be good if it were tweaked, but if it's not even as good as toner transfer I don't see much of a reason to bother (especially since my toner transfers work really well)
Even the UV method will be much cheaper than a laser cutter and no doubt even better quality again.
> nothing.
Re: CD shaped PCB
2011-04-14 by DmitriA
Sorry for shotting down an otherwise great idea, but having played with
these laser diodes quite a bit, specifically in terms of cutting with
the beam <http://elabz.com/category/laser-cutting/>  ,  I would have to
say that there is just not enough energy in the beam of a regular,
off-the-shelf DVD or even Bluray burner to evaporate paint off a
copper-clad  FR (or any other solid material for that matter). Copper
transfers heat away from the laser ablation point too well, in fact just
about any non-porous material does. That's why most of the stuff you'll
see cut with these laser diodes is foam.
Additionally, as others pointed out, the optics of the drive are
designed to be focused at a point in a middle of the CD's thickness and
even though the lens do adjust floating on the electromagnetic mount,
the adjustment would most likely be not enough to focus on the surface
(plus the pain layer thickness) instead.
But I do like the idea in principal and I am planning on upping the
energy quite a bit by installing a 1W laser diode (IR or blue) and
trying  paint evaporation again. It may just work on a thinnest (0.7
mil's the thinnest?) PCB I can find...
like a
Apply a
called
fit on
photoresist
> as an alternative.
> Bertho
2011-04-14 by Kip Shaffer
Here's a variation on your idea that may work well.
Some inkjet printers (e.g. the Epson R320) will print on CDs.  They already
have the straight-path and clearance built-in.   By using a CD shaped
circuit board, or a board that approximates the CD carrier, the printer may
be fooled into printing "Resist" directly onto the board!
> like a
> Apply a
> called
> the
> fit on
> the
> photoresist
> > as an alternative.
> > Bertho
Re: CD shaped PCB
The burning laser diodes in CD recorders are near-IR (780nm), DVD recorders are red (~650nm) and Bluray recorders are, well, blue (405nm) with the latter getting sort of kinda close to UV though probably not close enough.
I've never seen Lightscribe resolution mentioned anywhere but, given that the stepper-driven worm cannot position the diode sled better than approx. 0.15mm (20 steps per rev stepper directly coupled to a 3mm lead worm) the resolution would have been probably OK for PCB printing. Looks like it converts to 169 dpi which is decent enough. In fact, given that the DVD-R/RW optics are usually spec'ed as "better than 0.05mm beam" and the lens can adjust itself relative to the stepper-driven sled, the actual resolution may even be better than 169 dpi but I doubt they use precise adjustments for such a crude operation as burning a visible image on the back of a CD...
> TIm
> > photoresist
> > as an alternative.
> > Bertho
2011-04-14 by Mark Lerman
There's a guy on eBay selling 1 watt fiber optic coupled diodes that
might do the job. The fiber is very small diameter (can't quite
remember) so it can be used without a lens to cut lines  <5 mil if
the fiber is placed very close to the pcb. I was going to use a cnc
router to control the laser path. It seems very workable, but I have
gotten sidetracked with other techniques for making pcbs. I may get back to it.
Mark
>like a
>Apply a
>called
>the
>fit on
>the
>photoresist
> > as an alternative.
> > Bertho
2011-04-14 by Dave
Having dome my induction at FabLab Manchester can I say that even their
fairly high power laser cutter (it does 4mm plastic) won't cut PCB because
the surface is too shiny and the copper conducts the heat away . They make
PCBs either by milling and drilling with a Roland Modello or by cutting glue
backed copped strip. I want to try a milling head in a normal flat bed
plotter.
> -----Original Message-----
> From: Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of DmitriA
> Sent: 14 April 2011 16:09
> To: Homebrew_PCBs@yahoogroups.com; Homebrew_PCBs@yahoogroups.com
> played with these laser diodes quite a bit, specifically in
> terms of cutting with the beam
> to say that there is just not enough energy in the beam of a
> regular, off-the-shelf DVD or even Bluray burner to evaporate
> paint off a copper-clad  FR (or any other solid material for
> that matter). Copper transfers heat away from the laser
> ablation point too well, in fact just about any non-porous
> material does. That's why most of the stuff you'll see cut
> are designed to be focused at a point in a middle of the CD's
> thickness and even though the lens do adjust floating on the
> electromagnetic mount, the adjustment would most likely be
> not enough to focus on the surface (plus the pain layer
> thickness) instead.
> upping the energy quite a bit by installing a 1W laser diode
> (IR or blue) and trying  paint evaporation again. It may just
> work on a thinnest (0.7 mil's the thinnest?) PCB I can find...
> like a
> Apply a
> called
> JPG and use
> the
> fit on
> will vaporize
> the
> photoresist
> > as an alternative.
> > Bertho
> Files, and Photos:
Re: CD shaped PCB
2011-04-15 by eric
as i'v e emailed someone on here ..  my concern is .. the media .. i had a lightscribe dvd on my hp laptop and i never used lightscribe.. the media is $1 each maybe more this is 5 to 10 times more than reg.
and i guess it takes 30 to 45 minutes to do it .. i dont know what the media is like that gets 'burned ' off in lightscribe ...
this sounds like a great idea, but like the printing ink using an epson cd printer like an R200, -- its not all its supposed to be ..
you have to get special ink ? or use a hybrid process of toner and heat with ink ..
also the cd tray tends to hit something if the printer up against a wall and then the mechanism doestn work so well, in fact not at all for me .
> > TIm
> > > photoresist
> > > as an alternative.
> > > Bertho
Re: CD shaped PCB
2011-04-21 by James
I think you'd have a lot better luck with the laser on an X-Y gantry. Even then I don't think you could burn off resist with even a 1W diode, but I've thought about trying to make a photo plotter for UV resist.
2011-04-22 by Kevin Impson
Hi James,
Here is a youtube vid for a 1 watt blue laser.
http://www.youtube.com/watch?v=4Rl3w8nG1kU
Kevin I.
Sent: Thu, April 21, 2011 3:55:17 PM
