Table saw
2011-03-18 by Alessio Sangalli
2011-03-18 by Slavko Kocjancic
> Hi finally tonight I tried the table saw (Harbor Freight one) with theHuh... You can do better with freehand cutting.
> lopacki 8mil diamond blade.
> Unfortunately, all cuts were not parallel:
> http://www.manoweb.com/alesan/temp/tablesaw/test01.jpg
> http://www.manoweb.com/alesan/temp/tablesaw/test02.jpg
> Advices? I read I might have to go slower... will that do the trick? I
> used it wet. A bit splashy but no dust at all.
> bye
> as
2011-03-18 by David C. Partridge
2011-03-18 by Ryan Bray
> You need to use the cutting guide - read the instructions
> Regards,
> David Partridge
> -----Original Message-----
> From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
> On Behalf Of Alessio Sangalli
> Sent: 18 March 2011 07:17
> Subject: [Homebrew_PCBs] Table saw
> Advices? I read I might have to go slower... will that do the trick? I used
> bye
> as
2011-03-18 by Andrew Volk
>used
> Regards,
> David Partridge
> it wet. A bit splashy but no dust at all.Photos:
> bye
> as
> http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links[Non-text portions of this message have been removed]
2011-03-18 by Erik Knise
On Fri, Mar 18, 2011 at 9:31 AM, Andrew Volk <amvweb@...> wrote:
> NEVER, NEVER, NEVER free hand cut anything on a table saw! Always use a
> fixed fence set parallel to the blade (clamp a piece of wood to the top) or
> a sliding guide, with appropriate push sticks. I am a woodworker and free
> hand cut cause people to lose fingers.
> Andy
> On Behalf Of Ryan Bray
> Sent: Friday, March 18, 2011 5:46 AM
> Cc: David C. Partridge
> Subject: Re: [Homebrew_PCBs] Table saw
> you should have a guide attached you your table saw to prevent x-Axis slips.
> On Fri, Mar 18, 2011 at 3:47 AM, David C. Partridge <
>> Regards,
>> David Partridge
> used
>> bye
>> as
> Photos:
Erik L. Knise
Pacific Shipping Company
Seattle, WA
> NEVER, NEVER, NEVER free hand cut anything on a table saw! Always use aWhy do people even think I have not used read the manual:
> On 03/18/2011 09:31 AM, Andrew Volk wrote:It does look like the board is going under the fence while you are
> http://manuals.harborfreight.com/manuals/3000-3999/3733.pdf
> Or done a free hand cut without the "fence"; here the video of what I did:
> http://www.youtube.com/watch?v=MG61de0io6Q
> bye
> as
2011-03-18 by designer_craig
> bye
> as
or
bye
as
2011-03-18 by bebx2000
> First check that your blade is parallel to the fence. Then take someHm... I think I understand but I am not sure :) Could you make a drawing...?
> thin aluminum angle stock and mount it to the fence with one flange
> down against the table pointing to the blade. You place your board
> stock on top of the aluminum angle so it will not slip under the
> fense.
> Next thing is to push only on the secton of board between theIsn't that dangerous for the fingers?
> blade and the fence, forcing it to stay against the fence.
> All looksI will surely slow down next time.
> like you are trying to cut too fast, slow down your feed rate let the
> blade do the work.
2011-03-18 by casy_ch@tbwil.ch
Sent: Friday, March 18, 2011 10:08 PM
bye
as
2011-03-18 by Mark Mickelsen
> or
> bye
> as
That is why you use a push block. It allows you to push in the proper place
while getting your fingers out of the way. A tall block of wood with a
small lip on the back edge to push the board is all you need.
Andy
2011-03-19 by Eldon Brown
> Andy
2011-03-19 by Alessio Sangalli
> What happened to the good old High School Shop Classes??In my country at hihg scholl we only did:
> To align the first cut with the PCB art work, clamp the PCB between toI'll try to look for a video online to see if I have understood
> straight boards, align the art work with the scrap edge sticking out between
> the boards, use at least 4 screws from below for clamping. The boards should
> cover and be wider then the non-scrap side of the PCB material. Use the
> fence and Push Block to make a straight cut.
> In my country at hihg scholl we only did:Sorry for the typos. We also study English, but I was typing while
2011-03-19 by Andrew Volk
holding my son :)
PS apparently the table saw comes with something called "a pusg block"
it's made of plastic and it's the one depicted here:
http://www.harborfreight.com/media/catalog/product/cache/1/image/370x/9df78e
ab33525d08d6e5fb8d27136e95/i/m/image_9251.jpg
Do you think it's of any value?
bye
as
> better one to use. It doesn't have to be that long for the tile saw you arethanks.
2011-03-19 by Tony Smith
> PS apparently the table saw comes with something called "a pusg block"http://www.harborfreight.com/media/catalog/product/cache/1/image/370x/9df78e
> 33525d08d6e5fb8d27136e95/i/m/image_9251.jpgVery valuable if you like your fingers. You use that instead of your hands
2011-03-21 by Mike
> bye
> as
