> Thanks, Stefan,
> Yes, there are two worries that I mainly have about using a 3D router:
> burring and minimum trace width/clearance.
> I'm pretty sure surface mount would be "out"...but maybe not.
> On the other hand, once it's setup and debugged, it's repeatable, fast, and the automated hole drilling is not to be sneezed at; I find the hole drilling part by far the biggest hassle and would love to have it done automatically....I suppose, if nothing else, I could just have the 3D router just do the drilling, that would be a huge time and hassle saver....
> However, if the hole diameters were standardized to one size (in some circuits this is doable, even if it isn't optimal), one bit could do it all: routing and drilling...all in one multi-stepped set of passes. That would be pretty cool. It would have to be a carbide or even diamond bit, at a very high speed, maybe even with water cooling, but I'm sure it's achievable.
> And, now that I think about it more, actually larger holes would, of course, be achievable: just program it in to to mill the hole out larger. It might be useful to make the table 4D, with rotary capability as the 4th dimension.
> I was hoping someone on this list had already mastered the craft of routing boards instead of etching them. It might have to be me...
> Best, Charlie
> --- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan <stefan_trethan@> wrote:
> > You would just shift to another set of problems.
> > Instead of paper and stuff you will think about milling bits, burr,
> > milling depth, etc....
> > ST
> > On Sun, Sep 5, 2010 at 6:40 AM, gandolfreefer
> > <synchronousmosfet@> wrote:
> > > I really appreciate all the answers; very helpful, and I'm still rereading them all and ruminating on it all....
> > > ....part of figuring out what method I'm going to commit to is I'm now in the philipines, doing medical mission work and R & D, here for quite a while, and I have to consider local supplies, and it turns out getting all my PCB fab stuff sent to me is not as simple as I thought it would be.....
> > > So, I'm now considering building a 3D router table/stepper-controlled, and just route the PCB's....which would also include being able to drill the holes automatically...
> > > The nice thing about this, is that even though it's expensive to setup, once it's done, no worries about type of paper, type of printer, etchant, etc., etc....
> > > I just wouldn't be able to do very fine stuff, I presume...but I wasn't planning on making boards for surface mount IC's anyway...
> > > Suggestions?
> > > Best, Charlie
