Picture of device for holding SMDs while soldering
2003-09-14 by Mike Cowlishaw
My ASCII art obviously wasn't adequate, judging by the number of people
e-mailing me for more details :-), so I have put a picture on the web.  It
is at:  http://www.speleogroup.org/SMD-holder.jpg
It's simply a length of 'coat hanger' or similar wire, attached to a block
of scrap wood by a screw.   The photo shows it being used to hold a
capacitor to a PCB for soldering, leaving both hands free for solder & iron.
All the components on the board (see:
http://www.speleogroup.org/attinya.html for a close-up picture of a slightly
later version of the board) were soldered this way.
Mike Cowlishaw
Re: [Homebrew_PCBs] Picture of device for holding SMDs while soldering
2003-09-15 by Stefan Trethan
i think with that wire and that tip it is quite difficult to hold down a
0805 case?
or do you hold it on one end of the case while soldering the free one?
there are two small resistors on the headlight board so it must work
somehow...
i like the idea because it is so simple.
regards
st
On Sun, 14 Sep 2003 21:09:08 +0100, Mike Cowlishaw <mfcowli@...>
> It
> block
> iron.
> slightly
> Mike Cowlishaw
> Be sure to visit the group home and check for new Bookmarks and files:
> Homebrew_PCBs-unsubscribe@yahoogroups.com
2003-09-17 by Adam Seychell
Looks simple to make. Thanks for the photo.
I will make one of these tools when I start my next SMD project.
I've actualy got a bunch of 1.0 mm spring wire laying around
somewhere.
Re: Picture of device for holding SMDs while soldering
2003-09-17 by Mike Cowlishaw
> down a 0805 case?
Yes, that's the idea.   With the small devices, I place and solder one end
of all of them, using the hold-down wire.   Then I just use the hold-down
to steady the PCB while solder the other ends of all the devices.
> somehow...
Yes, no problems with 0603 devices. I haven't tried smaller than that.
It's helpful to file the end of the wire square.  If pointed it could
perhaps damage or tip the component instead of holding it flat against
the board.
Mike Cowlishaw
>> block
>> & iron.
> somewhere.
You're welcome.  Let us know how it works for you...
I'm now an SMD convert; it's so much faster to assemble a board
like this than to use through-hole...
Mike Cowlishaw
Re: [Homebrew_PCBs] Re: Picture of device for holding SMDs while soldering
2003-09-19 by Adam Seychell
I'm a SMD convert too :). Even with the small amount of practice
so far, I'm finding it a lot better overall to build home
projects in SMD. Honestly, I don't understand why it is taking so
long for the hobby store retailers to catch on with SMD, well at
least in Australia.
