Re: [Homebrew_PCBs] Who uses photocopiers for their TT prints?
2010-06-24 by Andrew Villeneuve
Maybe instead of a photocopier, you could bring in a PDF and have them print it out on a laser printer? LPs almost always have manual feeds that will accomodate a much wider variety of media that copier. Photocopiers can have remarkably complex paper paths intended to accommodate large paper supplies. -Andrew On Thu, Jun 24, 2010 at 12:55 PM, catamountman67 <bignick270@...>wrote: > > > How many of you use photocopiers at Staples or UPS stores? > > I have heard bits and pieces on other guides/boards that Staples employees > can be picky with allowing certain paper types into the photocopiers. I was > wondering if Staples would allow the Toner Transfer Paper from Pulsar since > it says Laser paper on the package. > > How do you manually feed the copiers at Staples? > > > [Non-text portions of this message have been removed]
