Etching note
Etching note
2010-06-10 by Mark Lerman
I don't make a lot of boards, and most of them are quite small, so
I've been looking for a simple, fast way to etch. After experimenting
with a few suggested recipes, I use a 1:1 ratio of  muriatic acid
(31.45%) to 12% hydrogen peroxide. The muriatic acid is available in
any hardware store, the peroxide is easily obtained from a beauty
supply store as "40 volume developer" - get the clear, not the creme.
They are both very inexpensive, and the etching takes 1-2 minutes
with a little hand agitation, no bubbling, no heat. DO THIS OUTDOORS
or with a chemical hood. Then use NaOH to neutralize.
For an etching container I use a polypropylene storage bin - they
sell them is many sizes and they are very inexpensive.
Mark
Re: [Homebrew_PCBs] Etching note
Whoops - I mean no bubbler or heater used - there is heat and
bubbling produced by the etching process.
>Mark
2010-06-10 by Dale J. Chatham
Just a note about agitation...
I used to use an aquarium aerator and an air stone for agitation.  It
had two problems.  First, sometimes the bubbles stuck to the copper.
This was a minor problem.
Second, though, it tends to aerosolize the etchant.  After a ver few
boards, I realized that the heads of all nails in my storage closet had
been etched away.
Get a small aquarium water pump.  The pump moter is very well sealed in
plastic and drives the impeller with a magnet.  No bubbles, no aerosol.
Salt water is corrosive and any metals dissolved in a saltwater aquarium
become toxic, so they are pretty careful to avoid anything that will
corrode.
Thanks for the info on the etchant.  It appears that this method is
superior to both FeCL and ammonium persulfate (or is it perchlorate)?
Never can remember, one etches, the other makes rocket fuel :)
> Mark
Our peculiar security is in the possession of a written Constitution.
Let us not make it a blank paper by construction."
    --Thomas Jefferson, letter to Wilson Nicholas, 1803
There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order.
  -- Ed Howdershelt (Author)
Re: Etching note
2010-06-11 by Frank P
Mark,
I checked at my local HomeDepot and, although they had muriatic acid for swimming pools, it came in a large, two-pack container. Have you found it in smaller quantities at other hardware store? If so, where and how small?
Also, where do you get your NaOH?
I have been vacillating between using FeCl and CuCl but I have concerned about storage and disposal for both. I am also trying to keep my quantities on hand small, so I am not storing a lot of potentially harmful liquids around my home.
Thanks.
> >Mark
Re: [Homebrew_PCBs] Re: Etching note
2010-06-11 by Dale J. Chatham
On 06/11/2010 10:20 AM, Frank P wrote:
> Mark,
Yes, but two bottles cost about $10.00.  If you find smaller amounts,
I'll bet it costs more.  I'd think that the prudent thing to do would be
to buy the 2 gallons, decant whatever amount you think you should use
and use the rest to clean your driveway :)  Or, neutralize it with NaOH
(carefully).  It's also useful for cleaning toilets :)
Try Drano.
> Thanks.
>>> Mark
2010-06-11 by Mark Lerman
I got my muriatic acid at the local hardware store - they have it in
quart and gallon sizes.  Drano is NaOH. I keep very small amounts
around, and mix as needed, without reusing. I'll bring the waste to
the hazardous substances dropoff in our county when I've accumulated a bit.
Mark
At 11:20 AM 6/11/2010, you wrote:
>Mark,
>and how small?
>Thanks.
> > >Mark
> and Photos:
Re: Etching note
2010-06-11 by James
> Mark
This is what I used to start with, it was very fast, the nice thing is it converts to cupric chloride after you use it enough and that stuff you can keep using over and over.
2010-06-12 by Donald H Locker
Most any hardware store should carry it.  Big box stores need to deal in large volumes to keep the margins up -- try a local hardware.
I'm not sure what you want the NaOH for.  You can use that to neutralise FeCl when you want to dispose of it, but for CuCl, all you need is H2O2 (hydrogen peroxide) from the druggist (3%) or beauty supply (12%) is better.
HTH,
Donald.
"Plain Text" email -- it's an accessibility issue
()  no proprietary attachments; no html mail
/\  ascii ribbon campaign - <www.asciiribbon.org>
----- "Frank P" <qz9090@...> wrote:
> Mark,
> and how small?
> Thanks.
> experimenting
> in
> creme.
> OUTDOORS
> > >Mark
> Photos:
> Photos:
2010-06-12 by Norm
It's been 60 years since Chem 101, and I don't recall  - do I add the
acid to the H2O2 (water), or the other way around?
Also - someone mentioned a magnetically coupled aquarium pump for liquid
agitation.  Is this an easily found item?  All I've seen in pet stores
are the air bubbler pumps.
Norm
W6NIM
2010-06-12 by Leon Heller
NaOH is often used for developing the resist after UV exposure. I buy
mine from the local hardware store.
Leon
Leon Heller
G1HSM
2010-06-12 by Slavko Kocjancic
Disposal note...
I had to say we are wery 'eco friendly'.
I etch my board with Hcl and H2O2. For 10x10cm board I use aprox 5ml of
H2O(tap water), 1ml of HCl(30%) and 1ml of H2O2(30%).
So aprox 2 to 3 years I need to buy new bootle (1 liter) of both.
Now look to disposal problem.
The average household drain HCl in sinks/toilets as cleaner(near all
cleaner use HCl) in amount much larger that mine is. The quantity is so
smal so if someone throu up (maybe to much beer) the HCl pollution is
bigger. So I don't care and throw that into sink. The other content
H2O2. You may look in two sides. The all hair paint use H2O2 in large
quantity and throw that stuff into sink directly. Every unnatural
blondie use much more H2O2 than I. In the other way if we let H2O2 on
sun few day they completly disentigrate into H2O and O2. So I can say
that source chemical used is so small that we can just sink em. ..and
use a loot of watter to dilute it. The worst contaminant is byproduct
CuCl. And again. The content is so small and we can throw it. The
average wineagre yard near me use so much CuCl so my quantity is way way
lower. And someone will say that all that sink output goes into sea.
CuCl is extensively used to paint boat's to prevent algae sticking on it.
But if you think that we must be the 1'st one to preserve planet then
you have simple solution how you can dispose the used solution.
Just get one glass jar as low and flat as you can. Put it onto sun and
pour all chemicals used from pcb etchng into it. Then cover it with
glass plate little raised. So all thing will evaporate on sun and leave
the worst (CuCl) as little blue/green sand. When you collect much of
that than just dispose that in chemichal dispossing containers. But for
100grams you need to etch a lot of boards.(years)
...But this work's just if you use smallest quantity possible. I see a
lot of folks use just to much etchant. If you check youtube you can see
that a lot of users use so big quantity of etchant. So the key is smal
quantity and smal bath. I use the plastic kontainers for food / ice
cream. It should have flat bottom and be just right size. (I have 4
different size) So just use smalest one and use as little etchant as I
can. ..just to cover the PCB not more. And etch it outside with wind
blowing in you back. When etching the small content of chlorine gas is
developed. You don't want to breath that. The etching time is 2 to 3
minute. And use cold watter. As reaction is exotermic (release heat) the
solution wil heat up itself. If you use hot watter in start the solution
will boil when etching and that exesive heat may destroy your image etched.
Thanks for reading and sorry for my ugly english.
Re: Etching note
2010-06-13 by sailingto
do I add the
ALWAYS add the acid to the H2O2 - MUCH safer.
Ken H>
2010-06-13 by DJ Delorie
Do as you ought'er
add acid to water
If you add a small amount of water to a large amount of acid, the water
almost immediately boils and the steam bubbles will throw acid all over
the place.  Very bad.
I use Na2C03 (sodium carbonate, or washing soda) for developing, and
NaOH for stripping.  NaOH is also used in titration, to determine the H+
concentration in CuCl etchant.
2010-06-13 by Norm
Ken & DJ -
Thanks.  I knew one way was liable to cause trouble, but it's surprising
how much one can forget in 70+ years!  Just getting back into PC fab.
My experience was with negatives, UV exposure,  KPR and FeCl3 back in
the '70s, but the toner transfer and CuCl looks interesting, especially
now that the volatile resists and developers are considered
environmentally unfriendly.
Norm
2010-06-13 by Alessio Sangalli
The "eco-friendliness" is honestly irrelevant. I think the new methods
are just so much more effective and reliable.
bye
as
Re: Etching note
2010-06-13 by Frank P
Donald,
Please see my responses below...
I called an old hardware store (now an Ace Hardware) in my area and they told me they carry muriatic acid in one quart containers! Thanks.
The muriatic acid/H2O2 solution is used for etching, is it not?
If you can "re-charge" the etching solution by adding H2O2 whenever you get ready to etch a board (I think someone else said this), I guess you may not need the NaOH (Drano) to neutralize the solution for a while.
Of course, that raises the question, when should I be disposing of my etching solution? How do I know it is "spent" and is no longer useful?
For storage, I believe a glass bottle is best (taking great care in protecting the metal cap).
Unless things change, it looks like I'm going to be using muriatic acid/H2O2 as an etching solution. Although, the 1:1 ratio stated by Mark seems a bit strong. I have to check on this....
2010-06-13 by Harvey White
On Sun, 13 Jun 2010 19:35:34 -0000, you wrote:
>Donald,
Quite strong.  I use 30% Muriatic acid, and the 3% H2O2 mixed in a
ratio of one part acid to four parts H2O2.
It will die after about 4 weeks, be weak after 2.  Adding H2O2 will
help, so will bubbling air through it.  After a bit of use it converts
to CuCl etchant, which always needs air bubbled through it, but lasts
virtually forever.
I like glass bottles, but not with metal caps.  Plastic food
containers work well, though.
Harvey
2010-06-13 by Jim Tonne
About the use of muriatic acid and H2O2:
It looks like most of you use 30% muriatic acid
added to 12% H2O2.
Do you then use that mixture as-is, or dilute that
mixture down with water?  If so, how much?
- Jim W4ENE
2010-06-13 by mlerman@ix.netcom.com
I think many concentrations and mixtures will work. I've used 2 parts 3% H2O2 to 1 part HCl (30%) and it works fine, but it often takes 20-40 minutes to etch. I usually do my etching outside in between doing other things, so I like it done fast. The 1:1 of 12% H2O2 to 31% (approx) HCl is very fast, and suits my personality <smile>. I would suggest you experiment and see what works best for you.
Mark
>From: Jim Tonne <tonne@...>
>Sent: Jun 13, 2010 4:48 PM
>To: Homebrew_PCBs@yahoogroups.com
>Subject: Re: [Homebrew_PCBs] Re: Etching note
>added to 12% H2O2.
>- Jim W4ENE
2010-06-14 by Donald H Locker
I think others have covered the bases pretty well.  Until you stop doing etching, I don't see any reason to dispose of the HCl/H2O2 brew.  Regenerate it with more H2O2 (or oxygen) and use again.
Donald.
> Donald,
> Thanks.
> a while.
> useful?
> Photos:
2010-06-14 by Dale J. Chatham
Petsmart typically has them.
If you can't find them there, try:
http://www.drsfostersmith.com
<http://www.drsfostersmith.com/?ref=4397&subref=AA&mkwid=SGISyNsuF%7Cpcrid%7C4214695761&cmpid=PPC-_-G-_-4397>
Specifically:
http://www.fosterandsmithaquatics.com/fish-supplies/aquarium-pumps/ps/c/3578/4587
And, as a suggestion:
http://www.fosterandsmithaquatics.com/product/prod_display.cfm?c=3578+4587+4671&pcatid=4671
<http://www.fosterandsmithaquatics.com/product/prod_display.cfm?c=3578+4587+4671&pcatid=4671>
Note, the above is after a pretty quick search, but you want something
on the low end of gallons / hour.
> Norm
> W6NIM
In my opinion:
H2O2 doesn't stay H2O2 for long.  It is likely mostly H2O by the time it
reaches the sewer plant.
HCl?  As you say, not a huge problem, it tends to lower pH, which may be
precisely what the sewer plant wants and I'd not be surprised if they
didn't use the stuff themselves.
The worst thing in the effluent from etching may well be CuCl, which is
pretty toxic to crustacea, snails and perhaps (guessing) bacteria, which
is why some folks neutralize it with NsOH (Drano) before dumping it.
Of all the things you could poor down your drain, HCl is likely the most
innocuous.
On 06/12/2010 02:38 AM, Slavko Kocjancic wrote:
> Disposal note...
On 06/13/2010 02:35 PM, Frank P wrote:
> Donald,
Wondering that myself.  I suppose the easy answer is "when it stops
etching to your expectatins".  Also is probably a reason bubbling air is
better than H2O2, but bubbling creates corrosive aerosols.
It depends on your metric.  Glass breaks easier than plastic.  There is
nothing intrinsically wrong with plastic.  There are reasons the stuff
is distributed in plastic bottles.  Anything should be better than a
metal cap.
Re: Etching note
2010-06-14 by James
--- In Homebrew_PCBs@yahoogroups.com, "Dale J. Chatham" <dale@...> wrote:
> In my opinion:
> innocuous.
It will corrode the crap out of *any* metal fittings, even stainless. Trust me on that one, I rinsed off a PCB in the sink and the tiny amount that dripped off the board left rust spots on the drain surround. I now mix up a pitcher of water with some baking soda in it and use that to rinse things off.
Anything with dissolved copper should not be dumped down the drain, at least if you live in a coastal area like I do where the water eventually ends up in the ocean.
Re: Etching note
2010-06-14 by James
They both work fine. Once it's turned into cupric chloride, it doesn't matter of the peroxide breaks down. You just add a capfull prior to etching if you don't want to wait around for air to regenerate it. It's cool, it almost instantly changes from very dark brownish-green to light green.
On 06/14/2010 12:09 PM, James wrote:
> --- In Homebrew_PCBs@yahoogroups.com, "Dale J. Chatham"<dale@...>  wrote:
>> In my opinion:
>> innocuous.
Well, I thought we were talking about environmental impact.  I stand by
my statement that HCl is probably the most innocuous thing you can dump
down the sink, in that regard.  It's difficult to make myself remember
that folks have metal pipes for drainage :)  Even when my goosenecks
were metal, I'd replace them with PVC just 'cause.
This is my understanding of the process, I could be terribly wrong.
Etching produces
2 Cu + 2 HCl -> 2 CuCl + H2.
Adding the H2O2 gives the following:
H2 + 3 H2O2 -> 4 H2O + O2
You also wind up with this one if there is any "head space" in the
container:
2 H2O2 -> 2 H2O + O2.
Adding H2O merely regenerates the source of quickly available Oxygen
molecules.
I can't make the H2O2 produce HCl, but it's been a while.
Hence, my assumption that sooner or later, you're gonna need to dump the
stuff and start over.
Re: Etching note
2010-06-14 by James
HCl is consumed, you don't need to dump the stuff and start over, you simply add a bit more HCl and you're on your way again. I've etched a lot of boards and haven't had to add any yet though.
2010-06-14 by Malcolm Parker-Lisberg
An estimated 0.34 billion metric tons of copper currently exists in the ocean’s waters based on a concentration of 0.25 ug/L and a volume of 1.338 x 109 km3
From MadSci Network, Internet site,
“www.madsci.org”
That's a lot of printed circuit boads
I don't suffer from insanity I enjoy it!
--- On Mon, 6/14/10, James <jamesrsweet@...> wrote:
Subject: [Homebrew_PCBs] Re: Etching note
Date: Monday, June 14, 2010, 6:09 PM
> In my opinion:
> innocuous.
Re: Etching note
2010-06-14 by Frank P
Harvey,
Would you give some examples of the "plastic food containers" you mentioned? And, how long it could be stored in those containers?
Thanks.
> >Donald,
> virtually forever.
> Harvey
2010-06-14 by Kerry Wentworth
Malcolm Parker-Lisberg wrote:
> An estimated 0.34 billion metric tons of copper currently exists in the ocean\u2019s waters based on a concentration of 0.25 ug/L and a volume of 1.338 x 109 km3
> \u201cwww.madsci.org\u201d
Cu and CuCl are two different things.  There's plenty of copper and
plenty of chlorine in the oceans, but there's plenty of carbon and
plenty of nitrogen in the atmosphere, but thankfully, not much CN (cyanide)
Kerry
OK, that works.  But, you just can't keep on adding HCl and I rather
suspect that eventually, you decant some of the stuff and get rid of it,
else given enough boards you'd be swimming in it.  Er, maybe not
literally :)
Copper is death to invertebrates in the ocean. Primarily, that means
coral, shrimp, crabs, ... While your concentrations are correct as an
average, close to the places where the effluent water (and I mean
processed and safe as far as sewage is considered) will have higher
concentrations.
The stuff really should be kept out of the ocean. Of course, if you live
near Louisiana, Mississippi, Alabama or Florida right now, it probably
doesn't reall matter all that much.
2010-06-14 by Harvey White
On Mon, 14 Jun 2010 17:56:35 -0000, you wrote:
>Harvey,
Rubbermaid cereal container, holds roughly 1 1/2 gallons.  Has stored
Ferric Chloride for over a  year, CUCL for a month or three.
Ferric Chloride did eat the rubber gasket on one container (walmart,
not Rubbermaid), these are plastic to plastic.
Harvey
>Thanks.
>> >Donald,
>> virtually forever.
>> Harvey
Copper chloride is produced in the sea and a high concentrations is  indeed a roblem, at less than lethal concentrations it reduces growth. One published paper demonstrates how Krill have adapted to its presence and secrete it. It is high concentrations on an industrial scale that causes problems not low concentrations from litre quantaties.
Cc: "Malcolm Parker-Lisberg" <mparkerlisberg@...>
Date: Monday, June 14, 2010, 7:31 PM
> “www.madsci.org”
concentrations.
Each to their own and I'd never asign any morality factor in such a thing.
For me, a little Drano, a coffee filter and it won't wind up in the ocean :)
Hey, I'm just hoping I'll still want to take my trip to the Florida Keys
next year :)
On 06/14/2010 02:01 PM, Malcolm Parker-Lisberg wrote:
> Copper chloride is produced in the sea and a high concentrations is\ufffd  indeed a roblem, at less than lethal concentrations it reduces growth. One published paper demonstrates how Krill have adapted to its presence and secrete it. It is high concentrations on an industrial scale that causes problems not low concentrations from litre quantaties.
Re: Etching note
2010-06-15 by sailingto
Hmmmm, a 1/3 billion metric tons of copper is in the oceans?  Does that take into account the 3 oz of etching solution I dumped this week?
Seriously - I do think this thread has went long enough on the impacts of dumping etching solutions - we've all made our points known, and now simply repeating.
I should not have commented, Let's have fun and etch some boards!!
73 de Ken H.
Re: Etching note
2010-06-15 by garydeal
     The problem with the copper is more likely at the sewage treatment
plant, for the same reasons that used photographic fixer (silver ions) is
something they'd rather not have going down the drain. Those metal ions
kill off the microorganisms (and not so micro) they use to digest the
sewage. The tour through the hyperion in Huntington Beach many years ago
was quite interesting.
     I've been waiting for someone else to point this out but haven't
seen it yet, so...
     DO NOT store HCl/H2O2 (hydrochloric/muriatic acid and hydrogen
peroxide) etchant in sealed glass bottles. As the peroxide decomposes it
produces oxygen gas and the resulting pressuure can cause the bottle to
burst. The pressure can also cause an acid spray when you open it, not
good for the eyes.
     I like to use the brown plastic bottles that drugstore ~3% peroxide
comes in, I don't fill them more than half full and I squeeze them before
capping so there's plenty of room for expansion. Still, I've seen them
bulge and show a line up the side where the pressure has stretched and
nearly burst the bottle.
     Seems to me that the "40 Volume" on the higher concentration
peroxide bottles means it will decompose to 40x it's liquid volume as
gas. If that's correct, then one cubic inch (unit) will become 40 cubic
inches (units) of gas while you're not looking.
     Leave plenty of room for expansion, store the bottle in another
larger container, and just because it hasn't happened to you yet doesn't
mean it won't happen twenty minutes from now.
     -Gary
