About holes
2010-06-15 by Alessio Sangalli
Hi, I think I am becoming good at making holes even for vias and of course for through-hole components. I can make tiny holes, the results are very satisfactory, but part of the procedure is complicated. First of all, I bought these: http://www.harborfreight.com/20-piece-solid-carbide-micro-bit-grab-bag-44924.html but they looked so fragile, I do not have a press, just a regular dremel. So I returned them and bought: http://www.harborfreight.com/30-piece-hss-mini-drill-set-94606.html for 4 dollars, 30 bits that work fairly well!!! The only problem is that the dremel can only take rather big bits. For this reason I roll some tape around the bit up until the diameter is compatible with the dremel collet, and then I drill. Sometimes I can only make one hole, other times I can make 20 but eventually the bit will "slide in" and I have to remove it, replace the tape and start again. This takes a lot of time. Suggestions? bye as
