Cut FR4 with a band saw?
2010-04-14 by Steve
There have been discussions from time to time on this reflector about
techniques for cutting PCB material. I don't recall having seen mention
of a band saw.
Anyone use a band saw to cut FR4 as thick as 1/16 inch? Does it work
well? Or poorly? What kind of blade does it take? Other comments or advice?
I have occasionally considered buying a band saw for other applications
and was just wondering if its use in cutting FR4 might lend some weight
to that decision? Thinking about a table model.
Thanks.
Steve
Read The Patriot Post    Vertitas vos Liberabit
http://patriotpost.us/subscription/
Re: [Homebrew_PCBs] Cut FR4 with a band saw?
2010-04-14 by Harvey White
>of a band saw.
It can work well, but the following things can happen:
1) glass PCB can eat your blade
2) cutting a straight line can be iffy
I use a shear.  For odd shapes, like notches, I use a carbide rasp on
a mill.
Harvey
>Thanks.
>Steve
Re: Cut FR4 with a band saw?
2010-04-14 by bebx2000
Steve,
I use a 4" diamond saw (QEP 60084A 4-Inch Portable Wet Saw). Home Depot current price $52.00.  The last time I used it I didn't even bother using water, but I did use a respirator to avoid the dust. It cuts through FR-4 like a hot knife through butter.
The supplied blade is a bit thick, but you can get a slicing blade for $8.00 (0.008") here,
http://www.lopacki.com/sawblades/#f
I am very satisfied with the product. You can also cut tile with it  ...
Baxter
> of a band saw.
Re: [Homebrew_PCBs] Re: Cut FR4 with a band saw?
2010-04-14 by Alessio Sangalli
This is a really good info.
Right now I am using an utility knife to score both sides and snap it:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34866
But it requires a lot of effort and the cut is not very clean. If the
board has to be cut on all the sides it's a nightmare.
I wanted to get one of these, glass cutter:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96032
If it is enough to pass it a couple of times to score the copper layer,
it could be a good and cheap solution. Anybody has experience with a
tool like that?
Otherwise the wet saw is a great idea. On top of that... yes, I need to
cut tiles from time to time :) for my oven (I use saltillo tiles to cook
pizza)
bye!
as
2010-04-14 by DJ Delorie
I've used bandsaw, scroll saw, tin snips, a razor, and even a reground
table saw blade (for v-scoring).  The scroll saw does the best job
quality-wise, but they all eat through blades like there's no tomorrow.
  One of these days, I'm going to get some carbide or diamond scroll saw
blades and see how those work.  The only advantage the bandsaw has is
that the blade is so long the wear is spread more thinly.
Yeah, I should get a shear, but that only works if you want straight
lines...
2010-04-14 by daemons_ca
--- In Homebrew_PCBs@yahoogroups.com, Alessio Sangalli <alesan@...>
Thats the method I use. Works very well but you need to use a metal
ruler (I use a thick metal square, something like this
<http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=9541>
) and you need to match your cuts on both sides exactly. If they don't
match perfect, thats when you get uneven edges.
Put the portion of the board to keep under the ruler while holding it
down and snap the excess upwards. I get very clean cuts that way. Oh,
also get yourself a rubber cutting mat (like this one
<http://www.modelkit-builder.com/wp-content/uploads/2009/01/cutting-mat.\
jpg>  ) at an art supply shop. It'll save your furniture/kitchen
counters. :)
Marc
I have that same ruler, and a clamp , etc. No, when the boards are thick
and double copper and double-face it's a nightmare. I've done many
boards and the result is always: cut hands, a lot of effort and time wasted.
This is interesting. Unfortunately the link gives an HTTP 404
bye
as
2010-04-14 by Eddie Stassen
> <http://www.lopacki.com/sawblades/#f>
> <http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34866>
> <http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96032>
> tool like that?
I use a carbide tipped laminate scoring cutter, which works *really*
well.  Its far sturdier than a glass cutter. I suspect the glass cutter
will be ok, but those little wheels have a tendency to come off after a
while.
Eddie
2010-04-14 by Piers Goodhew
Line break in the URL, try this:
http://3.ly/EOe6
2010-04-14 by Roland F. Harriston
Band saws were designed specifically from scrolling, curved, complex
work, not straight-edge cuts. And, it costs a bit to replace a band saw
blade. I don't remember if we ever had a band saw
blade resharpened.. I recall we used to replace the  blade with a new
one when it got dull,
and we never cut epoxy glass material, it was always sheared.
Epoxy-glass base is nasty on virtually all types of blades and is best
when cut on a shear.
FR4 is easier to work with, but I don't recall ever having it cut on a
band saw.
Roland F. Harriston, P.D.
bebx2000 wrote:
> Steve,
> http://www.lopacki.com/sawblades/#f <http://www.lopacki.com/sawblades/#f>
> Baxter
> > of a band saw.
2010-04-14 by Wayne
This works.
<http://www.modelkit-builder.com/wp-content/uploads/2009/01/cutting-mat.jpg>
Wayne
Now that I am retired and no longer have access fine facilities, I use a
carbide-tipped hand
tool (scribe) that I believe I purchased from Edmund Scientific or some
place like that. I score the
PC material and snap it clean over the straight edge of my work bench. I
think carbide tipped
scribes or scoring tools are readily available, and they last a long
time, even when scoring
epoxy glass.
> <http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=9541>>
> thick
> wasted.
> <http://www.modelkit-builder.com/wp-content/uploads/2009/01/cutting-mat.>>>
> This works.
> <http://www.modelkit-builder.com/wp-content/uploads/2009/01/cutting-mat.jpg>>
> Wayne
2010-04-14 by Hal
> of a band saw.
> Thanks.
> Steve
You really need a diamond blade as FR4 is glass.
A glass cutting band saw like the Taurus 3 should work for irregular shapes too.  Try Glasscrafters or Delphi.  They are about $375 but cut glass like butter; should do the job on FR4 too.  They run wet so dust shouldn't be much of a problem.
2010-04-14 by awakephd
My experience is different from others have responded -- I cut the board with a band saw, and have not had any problem with blade life. Cuts very fast and no problem keeping it as straight as I need it to be. Leaves a tiny burr that cleans up easily with a file.
Two caveats: 1) I don't cut a lot of board, so perhaps I just haven't seen the deterioration of blades yet. BUT 2) I am using a metal cutting band saw, which uses a considerably slower blade speed than a wood cutting band saw, and I use a 24 tpi blade made for cutting metal. I suspect the high speed of a woodworking band saw is a major factor in destroying blades when cutting this material.
> of a band saw.
> Thanks.
> Steve
2010-04-14 by kabowers@NorthState.net
Same here. I use a blade designed for cutting metal. A 1/8" 10-tooth wood blade
isn't the way to go.
As far as keeping the cuts straight use the widest blade your
saw will take and adjust the blade tension and guides correctly.
If the saw is correctly adjusted it's not at all hard to cut a straight
line. If the guides are loose, etc. it's REALLY difficult.
Keith Bowers WB4LSJ- Thomasville, NC
2010-04-14 by Greg Kutzbach
For a nice straight cut I would think a high speed router would work very
well.  For that matter, you could use a router to make crazy cuts too.  I'd
go for a table router and a nice guide.
-Greg
> this material.
> >--- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>,
> blade
2010-04-14 by James
> of a band saw.
> Thanks.
> Steve
I've been using a hacksaw with some scraps of wood clamped in a bench vise as a guide, works ok so far.
I've cut it on a bandsaw before, but it's awfully hard on the blade.
> while.
Ok, but where did you get yours? How much does it cost? Do you have a
picture or a link?
bye
as
> carbide-tipped hand
interesting, but I could not find it on the Edmund Scientific site. Do
you have a picture or a link where it is depicted?
bye
as
2010-04-15 by Roland F. Harriston
I'll butt in and mention that you can get several varieties of carbine
scribes at (of all places)
Amazon.Com. Some are very inexpensive, a few bucks, some are a bit
pricier. The one I purchased from Edmund Scientific about ten years ago
cost about 2 bucks. At that time, I was doing very small quantities of
G-10 epoxy glass almost exclusively. The thing still works.
Roland F. Harriston, The Pedantic Douche (PD)
> > while.
> picture or a link?
> bye
> as
2010-04-15 by sailingto
I've used a scroll saw with wood blades, but boy was it hard on blades and hard to hold straight line.  I finally got a paper cutter and it works pretty good up to about .050", but 1/16" is harder, but does work. For .032" to .045" and cutting straight lines, hard to imagine anything better.
Not sure if I had got the larger size would have been any better for the 1/16" or not.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=9805
That is the one I got - I think I paid $12 or so - must have been on sale?  The larger one is now $25.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90874
Sorta wish I had got it.
Ken
2010-04-15 by bebx2000
Try Harbor Freight,
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97336
Baxter
> picture or a link?
> bye
> as
2010-04-15 by Paul Symansky
Hi guys,
Since we're talking about cutting FR4, I thought I would share my creation
with you.  I made a small "PCB table saw."
View from the top: http://twitpic.com/19ewab
View from the bottom: http://twitpic.com/19ewi4
It's essentially a Dremel flex shaft attachment affixed to a plate of
aluminum.  I originally wanted to use standard cut-off wheels because of
their availability, but the flex shaft handle was too large, or the diameter
of the wheel was too small. depending on how you look at it.  I removed half
of the handle and created a bearing block to hold the axis of rotation as
close to the table as possible.
It works fairly well and the adjustable gate allows you to make rather
straight cuts.  The cutoff wheels, while cheap, are fairly thick and
non-planar, though.  I'm looking into using much thinner steel saw blades in
the future.
I have DWG/DXF files of most all of the parts and I wouldn't be averse to
sharing them.
Best regards,
Paul
P.S:
An outstanding job!
Overkill for just cutting PCB stock IMHO, but nevertheless,
good design and craftsmanship.
Paul Symansky wrote:
> Hi guys,
> View from the top: http://twitpic.com/19ewab <http://twitpic.com/19ewab>
> <http://twitpic.com/19ewi4>
> diameter
> half
> blades in
> the future.
> sharing them.
> Best regards,
> Paul
2010-04-15 by James
--- In Homebrew_PCBs@yahoogroups.com, "Paul Symansky" <symansky@...> wrote:
> Hi guys,
That's pretty nifty. Another approach that might work is to use a shaft and some ball bearings with a gear or belt drive to a motor mounted under the table, pretty much like a fullsized table saw. An advantage of that is the motor would not have to be a particularly high speed type, although I'm not sure how well the belt or gears would hold up and it would take more fabrication.
I've had such good luck with the drill I built that I might try something like this at some point, the hacksaw works but is not ideal.
2010-04-15 by Alessio Sangalli
Something like:
bye
as
2010-04-15 by awakephd
It might do a fine job of cutting, and if you use carbide bits you would probably get decent life. But I hate to think about all the dust!!!
--- In Homebrew_PCBs@yahoogroups.com, Greg Kutzbach <greg.kutzbach@...> wrote:
> -Greg
> > this material.
> > blade
2010-04-15 by James
You would probably want water mist or flow to keep the dust down. Perhaps one of those cheap little desk fountain pumps with a dishpan under the cutting surface? The router might fling water everywhere, I dunno.
2010-04-16 by Steve
Wow . . . I didn't anticipate so much discussion. Thanks everyone for
sharing your wisdom.
At least for the moment I am going to forgo the band saw idea and look
at the wet saw described below by Baxter.
Also going to archive this thread of messages, there's a lot to learn
from them :-)
Steve
On 4/14/2010 12:11 AM, bebx2000 wrote:
> Steve,
> Baxter
>> of a band saw.
2010-04-16 by Colin & Alma Lane
I use a Hegner Variable speed scroll saw with a 4/0 blade usually used
for jewellery saws.Works fine. Colin Lane
Colin Lane
Australia   
2010-04-16 by frankwinter1
Hi Steve,
Depending on how much room you have in your workshop, have a look at at the cheap chinese bandsaws (~US$200). They are a horizontal saw to cut pipes etc, and a vertical (traditional) bandsaw. I have one and it is extremly useful for many jobs. I got a "BIMETAL" blade with it and it cuts FR4 very well - clean and accurately and it stays sharp forever.
A valuable tool!!!!!
Frank
> from them :-)
> Steve
> > Steve,
> > Baxter
> >> of a band saw.
2010-04-16 by VK3YV
Hi, I second that, and the BI-Metal blade is essential and it lasts and
lasts....
Don....
Sent: Friday, April 16, 2010 5:35 PM
Subject: [Homebrew_PCBs] Re: Cut FR4 with a band saw?
> Hi Steve,
> Frank
>> from them :-)
>> Steve
>> > Steve,
>> > Baxter
>> >> mention
>> >> of a band saw.
>> > Photos:
> Photos:
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 9.0.801 / Virus Database: 271.1.1/2813 - Release Date: 04/16/10
04:31:00
2010-04-16 by VK3YV
Hi, I second that, But the BI-Metal blade is essential and it lasts and
lasts along with cutting any thing else that comes along. One thing to do
though is make sure the saw is setup well, there was an article a while back
in "MODEL ENGINEERS WORKSHOP" magazine with all the clues.
Don.....VK3YV....
> Hi Steve,
> Frank
>> from them :-)
>> Steve
>> > Steve,
>> > Baxter
>> >> mention
>> >> of a band saw.
>> > Photos:
> Photos:
04:31:00
RE: Re: Cut FR4 with a band saw?
2010-04-16 by Paul Symansky
@Roland, thanks!
@James, I initially thought of doing something like that, but the complexity
of the project would have been greater by an order of magnitude.  Aligning
shafts and making provisions to tension belts is a huge hassle.
Paul
2010-04-18 by Steve
Hi Frank,
I took a look today at Home Depot for a saw such as you describe. Did
not see one . . . although I might have walked by it and not recognized it.
Is there one on the Home Depot web site you could point me to? Or
perhaps eBay?
Thanks.
Steve
On 4/16/2010 3:35 AM, frankwinter1 wrote:
> Hi Steve,
> Frank
>> from them :-)
>> Steve
>>> Steve,
>>> Baxter
>>>> of a band saw.
2010-04-18 by sailingto
Here is a link to the home depot site with the saw:
http://tinyurl.com/y826qf5
> Hi Frank,
> perhaps eBay?
2010-04-18 by Steve
I did find that saw . . . or close to it. They had a 7-inch version, I
decided to wait a bit to see if the 4-inch model shows up.
But the link I was look for was for the "cheap chinese bandsaws
(~US$200)". Any of those on Home Depot?
Thanks.
Steve
>> Hi Frank,
>> perhaps eBay?
2010-04-19 by awakephd
Steve, Home Depot does not carry these, to the best of my knowledge, nor does Lowe's. Instead you need a Harbor Freight or similar store:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93762
You can find similar saws through Grizzly and maybe also Northern Tool. I'm sure there are many other import companies that carry them as well.
When I bought mine a few years ago, I think I paid around $160 -- I guess the price has gone up a bit. OTOH, if you look through woodworking magazines, and/or Home Shop Machinist or similar, you can often find 20% off coupons for Harbor Freight. So maybe I got it with one of those coupons, and that's why I'm thinking $160 ...
> Thanks.
> Steve
> >> Hi Frank,
> >> perhaps eBay?
2010-04-20 by Steve
Thank you. There's a Harbor Freight nearby, I'll take a look.
Steve
>> Thanks.
>> Steve
>>>> Hi Frank,
>>>> perhaps eBay?
2010-04-21 by sailingto
Those are nice bandsaws - but sure seem a bit of "overkill" for tiny little PCB - well, my boards anyway are always less than a 4"X6" size.  I use the HF paper cutter - cheap, and does a good job on anything up to .062".
This is the one I have:
it was on sale, but thinking about getting this larger one:
$20USD vs $25USD isn't much difference.  When I purchased my paper cutter at HF I think there was over $10 difference.
Ken H.
> Steve
2010-04-21 by Steve
Does the paper cutter warp the piece of PCB that you cut off? Just
wondering if both sections that result from a cut remain flat?
Steve
> Ken H.
>> Steve
2010-04-21 by James
> Steve
I've used the similar but much bigger heavier paper cutter at work to cut FR4 when the receptionist is not nearby. It works fine and does leave both pieces flat, fiberglass is very resilient, but it can't be doing any good for the blade, I have to really slam it down.
Good to know the HF cutters work ok, I wonder how well they'll hold up.
Well, if I cut a very narrow 1/8" sliver off, yea it curls a lot... even a 1/4" slice will curl some, but for normal cuts, both sides stay flat.
As to how long it will hold up?  I wouldn't think in a factory production where it makes hundreds of cuts/day it would last long, but for home use where 5 or 10 cuts/week are done, I expect it to last a good while.... years? The blade can always be sharpened if need be.  The $25 should hold up longer.  I think that is the one I would get now.
For the cost and ease of cutting - these are my choice, and if the PCB is the .032" to .040" it just "slices thru" really good.  Only the heavier .062" do I have to really hold tight when cutting.
Ken H>
2010-04-22 by awakephd
Ken, you are entirely correct -- getting this saw just to cut a few PC boards would seem like major overkill. In my case, I already had the saw to support my home machine shop and welding activities. If you need to cut metal very often, this saw will be a very welcome change from a hacksaw!
> Ken H.
> > Steve
2010-04-22 by sailingto
Paul, I must commend you on a job well done. That is a NICE setup....  maybe "one of these days" when i get time I might try something like that.  Good work!
73 de Ken H.
2010-04-24 by Ben L
The best type of saw I have used for cutting PCB's is a bench size or small table saw with a wet/dry diamond blade.  You'll need a good Vac system with a fine filter also put a filter over the air intake of the motor or the motor with be full of fine dust and not last long.
I also have one of the old Kepro shears, it works good but really can get better and more repeatable cut on the table saw.
If you are cutting FR4 with a standard steel blade it is not going to last very long.  You need either Carbide blade or the Diamond Blade.
Ben
> > Ken H.
> > > Steve
