Laser Printer shrinks pcb size
2010-04-21 by w6mikk
My old trusty HP LaserJet 5P printer  slightly shrinks the printed pcb image on paper when I printed a pcb image from a PDF file. On screen pbc measures 5.2 cm (2 inch)  on paper is 5.0. On screen measures 8.1 cm (3inch) and  7.7 cm on paper.
Does KICAD  software contain a method to compensate Laser printers so the printed image is almost identical to the image size on screen?
I have not installed KICAD but have studied a tutorial.
The printed image size differing from screen size concerns me since I will be using Toner Transfer.  For 2 by 3 inch pcbs is this shrinkage going to cause SIGNIFICANT errors when drilling holes for IC sockets? For slightly larger pcbs, is error going to be more severe?
Do other LASER PRINTER users have this same problem?
How are you compensating? Does software like Paintshop Pro X10
provide small size adjustments when printing  jpg files?
This my first post. Thanks for any help.
Dave_s
Re: [Homebrew_PCBs] Laser Printer shrinks pcb size
2010-04-22 by DJ Delorie
My laser printer does the same thing.  PCB (gEDA) has a place to put in
printer calibration numbers to compensate for this, because yes, it does
mess up large components (headers, DIPs).  Note: when calibrating,
laminate the paper onto a PCB before measuring it, as the lamination
also changes the size slightly.
For other packages, I suppose you could print to postscript and use
ghostscript to turn that into a raster image, at a suitably calibrated
DPI setting.
2010-04-22 by michael tenore
You can try running your paper through the laser printer with a document with a period (.) printed in the upper left corner, This will pre-shrink your paper! Then run it through with the toner image.
I found that you will have little problem with up to 24 pin Dip without pre shrinking.
I did a board recently that had a forty pin Dip. and It only had a minor misallignment error. I did not preskrink that paper!
regards
mike
--- On Wed, 4/21/10, w6mikk <group78@...> wrote:
> From: w6mikk <group78@dslextreme.com>
> Subject: [Homebrew_PCBs] Laser Printer shrinks pcb size
> Date: Wednesday, April 21, 2010, 7:54 PM
> X10
> Dave_s
Re: Laser Printer shrinks pcb size
2010-04-22 by awakephd
Hmmm ... as far as I know I have not had any shrinkage like this; I need to do some tests to see! But to answer your question, yes, KiCad does have the ability to adjust the scale. When you plot your board, there are two boxes to the right for X-Scale and Y-Scale. (Note that in KiCad, you MUST use the "Plot" command rather than the "Print" command to get usable output; the "Print" command just gives an approximation.)
> Dave_s
2010-04-22 by andrewmv@ymail.com
I know Eagle also provides a mechanism to rescale the printer output, though I've never had to use it.
-Andrew
> Dave_s
2010-04-22 by Leon Heller
The Easy-PC software I used to use had an adjustment for that. I'm not
sure if the current version has it, though.
Leon
Leon Heller
G1HSM
2010-04-22 by Stefan Trethan
Target 3001 also has correction factors, seaparate ones for x and y.
ST
> Leon
> Leon Heller
> G1HSM
2010-04-24 by Ben L
Believe Dip Trace can rescale, never needed to use it so I could not say if it would work well for this.  I prefer photo process myself, get much better and repeatable results with photo process than I ever did with Toner Transfer.  I know some seem to find the photo process too much trouble, Myself I fine getting good toner process to be more trouble.
Ben
--- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan <stefan_trethan@...> wrote:
> ST
> > Leon
> > Leon Heller
> > G1HSM
Re: [Homebrew_PCBs] Re: Laser Printer shrinks pcb size
2010-04-24 by Piers Goodhew
I'm phenominally late to this party, but you are aware that Acrobat's default behaviour is "shrink to fit"? Turn that off and you should be in business (albeit missing some stuff at the sides if your pcb's really big, but that would be asking for trouble).
Being a snob, I don't totally trust windows for accurate printing, but between them Adobe and HP should have it all working nicely.
PG
