[Homebrew_PCBs] pcb picture techniques
2010-03-23 by Mark Lerman
How do you get good quality pictures of pcbs? Would a good macro lens and ring lighting be best, or is there a better way? Mark
2010-03-23 by Stefan Trethan
A scanner, use a flatbed scanner. ST
On Tue, Mar 23, 2010 at 8:46 PM, Mark Lerman <mlerman@...> wrote: > How do you get good quality pictures of pcbs? Would a good macro lens > and ring lighting be best, or is there a better way? > > Mark >
2010-03-23 by Leon Heller
On 23/03/2010 19:46, Mark Lerman wrote: > How do you get good quality pictures of pcbs? Would a good macro lens > and ring lighting be best, or is there a better way? I get quite good results with my Nikon D80 with the stock zoom lens, handheld, with the built-in flash. I have a macro lens, but I usually can't be bothered to fit it and set up the tripod, etc. A light tent or cube and a couple of suitable lamps is probably the best way to light small objects. Leon -- Leon Heller G1HSM
2010-03-23 by DJ Delorie
I use a macro setting on the camera, with flash, but one unusual trick - I put a piece of white paper in front of the flash, angled down to face the PCB. That way, instead of getting flare from point reflections of the flash, I get a uniform ambient light. For unpopulated PCBs, I usually end up using my scanner, although gEDA's pcb layout package has a photorealistic output exporter that is a lot easier to use.
I tried a scanner, but the image seems out of focus. Any special settings? Mark At 03:51 PM 3/23/2010, you wrote:
>A scanner, use a flatbed scanner. > >ST > >On Tue, Mar 23, 2010 at 8:46 PM, Mark Lerman <mlerman@...> wrote: > > How do you get good quality pictures of pcbs? Would a good macro lens > > and ring lighting be best, or is there a better way? > > > > Mark > > > > >------------------------------------ > >Be sure to visit the group home and check for new Links, Files, and Photos: >http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links > > >
I have a macro setup I use for insect photography - a 200mm Canon macro with a two head macro flash with diffusers - that I might try. Mark At 03:54 PM 3/23/2010, you wrote:
>On 23/03/2010 19:46, Mark Lerman wrote: > > How do you get good quality pictures of pcbs? Would a good macro lens > > and ring lighting be best, or is there a better way? > > >I get quite good results with my Nikon D80 with the stock zoom lens, >handheld, with the built-in flash. I have a macro lens, but I usually >can't be bothered to fit it and set up the tripod, etc. A light tent or >cube and a couple of suitable lamps is probably the best way to light >small objects. > >Leon >-- >Leon Heller >G1HSM > > >------------------------------------ > >Be sure to visit the group home and check for new Links, Files, and Photos: >http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links > > >
2010-03-23 by awakephd
This is a trick that DJ has shared before, and it really works well. I just wish I had known it long, long ago! --- In Homebrew_PCBs@yahoogroups.com, DJ Delorie <dj@...> wrote:
> > I use a macro setting on the camera, with flash, but one unusual trick - > I put a piece of white paper in front of the flash, angled down to face > the PCB. That way, instead of getting flare from point reflections of > the flash, I get a uniform ambient light. > > For unpopulated PCBs, I usually end up using my scanner, although gEDA's > pcb layout package has a photorealistic output exporter that is a lot > easier to use. >
2010-03-23 by James
--- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@...> wrote: > > I tried a scanner, but the image seems out of focus. Any special settings? > Mark > All scanners are not equal. I tried one of those new super slim LED flatbed scanners and found it was useless for scanning anything that had any depth. My *ancient* Scanmaker E3 which is the old style with a fluorescent tube does a great job, I can even scan the faceplate of moving coil meters without disassembling the meter
2010-03-24 by alienrelics
--- In Homebrew_PCBs@yahoogroups.com, "James" <jamesrsweet@...> wrote: > > > > --- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@> wrote: > > > > I tried a scanner, but the image seems out of focus. Any special settings? > > Mark > > > > All scanners are not equal. I tried one of those new super slim LED flatbed scanners and found it was useless for scanning anything that had any depth. My *ancient* Scanmaker E3 which is the old style with a fluorescent tube does a great job, I can even scan the faceplate of moving coil meters without disassembling the meter > Agreed. I have an old HP 4P SCSI scanner, I can set a stuffed circuit board part side down on it and it is all in focus. Then I bought an 8 year newer thin scanner, and the -folds- in a letter are out of focus. Horrible. I now have a newer HP USB scanner, almost as thick as my really old 4P, and it has good depth of field. And you don't have the worries of the flash or room lights causing highlights that blow out all the details. Steve Greenfield
2010-03-24 by Stefan Trethan
I thought you mean a bare PCB! ;-) Anyway mine does stuffed ones just fine, it is also an old thick model. But it tends to look strange with high components, maybe because the perspective is moving. ST
On Tue, Mar 23, 2010 at 9:30 PM, Mark Lerman <mlerman@...> wrote: > I tried a scanner, but the image seems out of focus. Any special settings? > Mark > > At 03:51 PM 3/23/2010, you wrote: >>A scanner, use a flatbed scanner. >> >>ST >> >>On Tue, Mar 23, 2010 at 8:46 PM, Mark Lerman <mlerman@...> wrote: >> > How do you get good quality pictures of pcbs? Would a good macro lens >> > and ring lighting be best, or is there a better way? >> > >> > Mark >> > >> >> >>------------------------------------ >> >>Be sure to visit the group home and check for new Links, Files, and Photos: >>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links >> >> >> > > > > ------------------------------------ > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links > > > >
