brother 5250 laser and PnP blue
2010-01-11 by David Griffith
After getting poor results with Pulsar paper a while ago, I'm thinking of trying again with Press n Peel. I've heard that some people have problems with PnP blue and Brother printers. Mine is a Brother 5250DN. Does anyone here have anything to say about that combination? -- David Griffith dgriffi@... A: Because it fouls the order in which people normally read text. Q: Why is top-posting such a bad thing? A: Top-posting. Q: What is the most annoying thing in e-mail?
2010-01-11 by kimvellore@sbcglobal.net
I have not used Brother but used a samsung and xerox printers and found the ink sticks better to the blue than the pulsar. What I have noticed with the pulsar is the ink sticks weak. If I have a small image on top of the paper and stick a peice of Pulsar paper on top there is a slight second image that appears below the paper whichI assume is because all the ink from the drum did not stick to the paper and during the second rotation of the drum the remaining ink sticks below the paper. Kim --- On Mon, 1/11/10, David Griffith <dgriffi@...> wrote:
From: David Griffith <dgriffi@...> Subject: [Homebrew_PCBs] brother 5250 laser and PnP blue To: Homebrew_PCBs@yahoogroups.com Date: Monday, January 11, 2010, 10:47 AM After getting poor results with Pulsar paper a while ago, I'm thinking of trying again with Press n Peel. I've heard that some people have problems with PnP blue and Brother printers. Mine is a Brother 5250DN. Does anyone here have anything to say about that combination? -- David Griffith dgriffi@... A: Because it fouls the order in which people normally read text. Q: Why is top-posting such a bad thing? A: Top-posting. Q: What is the most annoying thing in e-mail? ------------------------------------ Be sure to visit the group home and check for new Links, Files, and Photos: http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links [Non-text portions of this message have been removed]
2010-01-11 by Brian Lalor
> thinking of
> problems
The only printer brand Pulsar says to stay away from is Brother:
"To date we have discovered only the Brother� brand of printers to be
incompatible with our system. They use a completely different type of
toner formulation requiring very high fusing temperatures."
http://www.pulsarprofx.com/PCBfx/main_site/pages/tech_support/instructions/PCB_Instructions.pdf
If PnP�s transfer method works at substantially higher temperatures
than Pulsar�s, you may have a shot�
Brian Lalor / blalor@...
You snooze, you lose
Well I have snost and lost
[Non-text portions of this message have been removed]2010-01-11 by Andrew Mathison
Dear David Griffith and All has anyone tried this? http://www.youtube.com/watch?v=i8IiVDaswEE&feature=related Could that be of any use in some way.....? regards Andy -------------------------------------------------------------- After getting poor results with Pulsar paper a while ago, I'm thinking of trying again with Press n Peel. I've heard that some people have problems with PnP blue and Brother printers. Mine is a Brother 5250DN. Does anyone here have anything to say about that combination? -- David Griffith dgriffi@... A: Because it fouls the order in which people normally read text. Q: Why is top-posting such a bad thing? A: Top-posting. Q: What is the most annoying thing in e-mail? [Non-text portions of this message have been removed]
2010-01-11 by Richard (lists account)
The brother I had problems with used fuser oil which messed up the adhesion of the toner to what I was ironing it onto. My new one doesn't, and it has been problem free. The old one was a brother HL-2400Cn, the new one a MFC-9420Cn
> -----Original Message----- > From: Homebrew_PCBs@yahoogroups.com > [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of Andrew Mathison > Sent: Tuesday, 12 January 2010 9:08 a.m. > To: Homebrew_PCBs@yahoogroups.com > Subject: [Homebrew_PCBs] brother 5250 laser and PnP blue > > Dear David Griffith and All > > has anyone tried this? > > http://www.youtube.com/watch?v=i8IiVDaswEE&feature=related > > Could that be of any use in some way.....? > > regards > > Andy > -------------------------------------------------------------- > After getting poor results with Pulsar paper a while ago, I'm > thinking of > trying again with Press n Peel. I've heard that some people have > problems > with PnP blue and Brother printers. Mine is a Brother 5250DN. Does > anyone here have anything to say about that combination? > > -- > David Griffith > dgriffi@... > > A: Because it fouls the order in which people normally read text. > Q: Why is top-posting such a bad thing? > A: Top-posting. > Q: What is the most annoying thing in e-mail? > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Be sure to visit the group home and check for new Links, Files, and > Photos: > http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links > > >
2010-01-12 by Derward Myrick
Brian, I found that using a rebuilt toner cartridge from Office Depot in my Brother printer would work OK. Derward Myrick
Sent: Monday, January 11, 2010 1:35 PM
Subject: Re: [Homebrew_PCBs] brother 5250 laser and PnP blue
> thinking of
> problems
"To date we have discovered only the Brother\ufffd brand of printers to be
If PnP's transfer method works at substantially higher temperatures
than Pulsar's, you may have a shot.
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links2010-01-12 by David Griffith
On Mon, 11 Jan 2010, Derward Myrick wrote: > Brian, I found that using a rebuilt toner cartridge from Office Depot > in my Brother printer would work OK. What model printer do you have? -- David Griffith dgriffi@...
2010-01-12 by Buddy
I have tried the PnP Blue with a Brother printer and can tell you that this combination did not work for me either. I used an HP printer for a while (until the cartridges ran out). It costs more for replacements than a new Samsung printer, which works very well also. By the way, both the HP and the Samsung printers are color printers since I use them for labels also. The Pulsar decal system works great for that. Buddy E-mail message checked by Spyware Doctor (5.5.1.322) Database version: 5.14110e http://www.pctools.com/en/spyware-doctor/ [Non-text portions of this message have been removed]
David: It was a 1440 I do not rember the prefix letters as I do not have it now. This was one of the first printers that used the high temp toner. I had the model just before the 1440 and it worked OK. When I bought the 1440 it drove me crazy trying to get it to make toner boards. I found out at that time that Brother had gone to a High temp toner and I did get some trannsfer by ironing for about 10 min. I believe that rhe HP toner is as good as any if not better. Derward Myrick KD5WWI
Sent: Monday, January 11, 2010 6:36 PM
David Griffith
dgriffi@...
