poor output from Eagle
2010-01-09 by Brian Lalor
I’m finally trying to make this board!  And the frustration mounts…
Aside from printer and tool issues (the adapter Dremel sent me for the
model 210 drill press I spent way too much for on eBay doesn’t fit my
tool), I think I’m making incremental progress; I just hope the final
increment is done before I run out of supplies!
I’m having a weird issue printing from Eagle; fortunately there’s a
workaround.  Check out the picture here: http://www.flickr.com/photos/blalor/4259310618/
When I print directly from Eagle, it looks like the pads are shifted a
few mils (maybe even 10 or more) down and to the left; this is causing
some of the pads to attach to the ground plane.  When I export a PDF
and print that from Preview (I’m using OS X) the output appears to be
perfect.
Has anyone seen this before?  I’m using an HP LaserJet 4050TN.
As an aside, the printing issues I was talking about yesterday do
appear to be caused by the toner cartridge; I swapped in the other one
and, although the toner’s still way too thin and uneven, the massive
white line down the left side is gone.  The Pulsar green TRF seems to
fill the gaps, however.  I’m going to try etching one of these
transfers before cracking open the other printer I bought yesterday or
paying full retail for a new toner cartridge.
Brian
Brian Lalor / blalor@...
     Stewardess: We know you have your choice of bankrupt carriers and
we
     appreciate you choosing us.
Re: [Homebrew_PCBs] poor output from Eagle
2010-01-09 by Stefan Trethan
Eagle 4 does not have that error, at least I've never seen it.
But I'm really not surprised, Eagle is crap after all (my right to say
as I think, free speach and all). When I need accurate output I often
export gerber files and print those, gerber output is mostly correct
and it gives me the chance to check the gerbers before production.
For toner transfer (my own private use) I always print with Target,
because the printing dialog gives me the (easy to use, functioning,
including preview) options to position the printout where I want it on
the page (I use half sheets). It also has options to correct printer
scaling errors separately for x and y axis, as well as mirror, "hard
black", and "guide holes only for drills". Even If I have Eagle files
I will import into Target for the toner transfer ouput.
I guess it's to a large extent a matter of what you are used to, if
you have the correct settings worked out for one software it's best to
stick to that for something a bit fiddly like toner transfer:
Good to hear it wasn't the printer after all, I really think you are
in for a good chance with a HP cartridge.
ST
> perfect.
> Thanks,
> Brian
2010-01-09 by cary heestand
--- On Sat, 1/9/10, Stefan Trethan <stefan_trethan@...> wrote:
Subject: Re: [Homebrew_PCBs] poor output from Eagle
Date: Saturday, January 9, 2010, 8:02 AM
               <snip>
ST
Stefan, does Target create Gerber files like Eagle?   I'm new to PCB's and haven't learned any of the programs yet.
 I eventually want to CNC mill my boards and was going to start with Eagle, but the learning curve is getting me.  Target on first glance is simpler, so if it produces Gerber files I will go with that.
If Target can't do Gerber, do you know if Diptrace or PCBArtist does?
Thank you in advance, Cary
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
Of course Target does Gerber.
In the following lineup you can see all licensing options, the free
"discover" version includes a text comment in the gerber files "only
for non-commercial use" or something like that, to discourage
commercial use. All versions can also import gerber files.
<http://server.ibfriedrich.com/wiki/ibfwikien/index.php?title=Editions_and_prices>
(There is only version of Target that doesn't do Gerber, the unlimited
one you can download from PCB-Pool. This version is only licensed with
PCB-Pool for production, understandable if they give away software
that usually costs 3000eur for free they don't want you to make your
boards elsewhere).
There are also several special milling oputput formats in Target (for
isolation milling). I have not milled myself but you can read about
them here:
<http://server.ibfriedrich.com/wiki/ibfwikien/index.php?title=Engraving_insulation_channels>
Don't know about PCBArtist or Diptrace.
ST
2010-01-09 by Leon Heller
> boards elsewhere).
> them here:
> ST
PCB Artist is a special version of Easy-PC, supplied by Advanced
Circuits. It doesn't generate Gerbers (Easy-PC does, of course) but I
believe that AC supplies them on request after the first order for a board.
Leon
2010-01-09 by Piers Goodhew
Yep, I have seen exactly that with Eagle on OS X (and recall another lister seeing it). Further, I now (under Snow Lep) get super-fat outlines on pads/holes etc (appears fine in Preview, fat on HP 4MP output) so I now copy the file to my 10.3.9 G4 and then print.
It's all a hassle, but on a value-for-money basis I still swear by Eagle!
PG
Could be an OS X specific problem then?
Best to ask Cadsoft support about it, they reply timely, even if it is
just a no can do sometimes.
(Things are gonna stay like they've been, in terms of support, what
whith Farnell buying them and all.)
ST
> PG
2010-01-09 by Peter Harrison
The offset pad/hole thing happens on my Snow Leopard with a Samsung 1640 printer as well.
Printing to a PDF gets around it and also leaves you with a ready-to-print copy without firing up Eagle to mess with the layers again.
Peter Harrison
> ST
>> PG
2010-01-10 by Andrew Mathison
Hi Stefan Trethan
  you could be right, but I have a feeling that the problem is from the printer driver. It could also be the printer firmware, so I would recommend checking the internet for updated drivers and firmware.....it may be a combination of both even -old driver, new firmware or the opposite....
  If they are still available, even trying older versions may provide a fix....as it is not completely unknown for problems to be added as an update......
  If it looks good on the screen, then I would definitely suspect the printer. Another printer from a different manufacturer may provide some helpful  infos.....
  I did not see a mention as to which version of Eagle is in use.......!!
  Best wishes for 2010
  Andy
  ST
  > PG
Greetings from
Andy Mathison
2010-01-10 by Piers Goodhew
Seems to be common to Eagle OSX printing across quite a wide range of printers (several manufacturers), so I doubt it's the driver. Given that OS X prints the PDFs just fine, I don't think it's OS X.
I would raise it with them if it was a significant problem for me, but ...
PG
On 10/01/2010, at 9:41 PM, Andrew Mathison wrote:
> Hi Stefan Trethan
> Andy
> ST
> > PG
> Greetings from
> Andy Mathison
2010-01-10 by cary heestand
Stefan,  thank you for the answer.  I'm not very computer literate, so I will start with Target.  Seems to have it all, schematic, board layout and simulation in one package.
Cary
Date: Saturday, January 9, 2010, 12:45 PM
<http://server. ibfriedrich. com/wiki/ ibfwikien/ index.php? title=Editions_ and_prices>
boards elsewhere).
them here:
<http://server. ibfriedrich. com/wiki/ ibfwikien/ index.php? title=Engraving_ insulation_ channels>
ST
2010-01-10 by Stefan Trethan
Personally, I think it's the best choice in the "low end" market. I've
used it for years.
It's user friendly enough that I also make front panels and many types
of other drawings with it. (It has front panel features like placement
of angular scales and such).
It's easily equal to Eagle, but one should not forget it is not a
professional tool like Altium, Pulsonix, Mentor, .... which play in a
different ballpark. But unless you make really complex designs with
several engineers you are well served with Target.
If you want to buy a small license mind that they have regular
discount sales of 20 or 25% off, about 4 times a year (I expect the
next will be around Easter).
ST
> Cary
