take off soldermask green
2009-10-28 by ralph
hello i need to take off solder mask to see the connection about processor amd ...
please someone know how to take off that green coat ?
thank you very much
RE: [Homebrew_PCBs] take off soldermask green
2009-11-01 by Brian Thorp
Good luck with out industrial chemicals
Date: Wednesday, October 28, 2009 10:20 am
Subject: [Homebrew_PCBs] take off soldermask green
thank you very much
Re: [Homebrew_PCBs] take off soldermask green
2009-11-01 by leon Heller
Red fuming nitric acid should dissolve it, as it is a resin, but it will
also dissolve the copper and the fibreglass resin, if you aren't careful.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
2009-11-01 by Simao Cardoso
> will
> careful.
All the care in red fuming nitric acid will destroy any solder, pads,
pins and tracks under soldermask.
Normal people simple scratch it with a not sharp tool when repairing a
damaged track. But the exposed problem is understandable.
If one wants a chemistry, hot desmear (or etchback) solutions used in
PTH (or multilayer) production before plating activation seems to fit.
Like permanganate, or better, ethanolamine based solutions. But there
are also epoxy glue cleaners on the marked.
