Re: [Homebrew_PCBs] Fw: The CHIP QUIK® SMT Rework Newsletter *NEW* (An Alternative To The Solder Iron)
2009-07-13 by leon Heller
From: "DJ Delorie" <dj@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Monday, July 13, 2009 5:24 PM Subject: Re: [Homebrew_PCBs] Fw: The CHIP QUIK\ufffd SMT Rework Newsletter *NEW* (An Alternative To The Solder Iron) > > The few times I've had to remove big SMT parts, I put a dime (or a > quarter, depending on size) on my hotplate (and two off the hotplate) > and place the board such that the dime is right under the part to be > removed. A dab of solder paste next to the part so I know when it > hits melting temp, and turn on the hotplate. A few minutes later, the > paste melts and I just lift the part off the board, then remove the > board from the dime. > > The chipquik idea seems useful, but (1) you still have to figure out > how to heat that area of the board, and (2) I worry about removing > enough chipquik paste to make the reworked solder joints reliable. > (not that I'm making boards that need *that* much reliability, but I > have enough problems without introducing more... ;) I've used it for years without any problems. Leon
