Copy/Paste and Toner Transfer
2009-05-31 by macmyke01
Hi everyone,
I don't know if this has been already posted, but I thought it might be helpful to anyone who just wants to whip out a quick board without paying a premium in materials.
I used to use the old rub on transfer method of etching, but if anyone has tried to find those today they're pretty much impossible. I was told the one place that made these stopped a while ago and so now the options are limited to toner transfer or some sort of light based photo process. Either way, you usually need some sort of PCB layout application to make your board and these can be pricey. I use a Macintosh and a lot of those applications are only made for Wintel.
Hey, I'm old school. I just want to whip out a board every now and then without making it a big production. What I did was scan an old rub on transfer template and then using Photoshop I created a circuit by cutting, pasting, flattening and repeating that process. It worked! All I had to do then was print it on to some Press-n-Peel and I was good to go.
I published the scan of the rub on transfer template along with some documentation about the process. Anyone should be able to use this method to make a board. You don't need Photoshop. I found you can open the template with Gimp (open source) and even NeoOffice (also open source). If anyone is interested here's the link to the files:
http://web.me.com/mackmike/macmike.net/Electronics.html
Let me know if anyone finds this useful. I'd be interested in hearing about how this worked for you.
