GBC H535 Laminator report!
2009-05-19 by michael tenore
Well I finally tried my used GBC H535 Laminator on a board a about 20 minutes ago! Settings! Cold/Hot=HOT Type Material= BOARD Temp 328 F Speed=6 Warmup time 14 minutes Laminator rated max material thickness 100mils Paper used= HP Presenatation Paper Q2546A #Passes= Ist board =6 Second =Ten passes! Board size-4.5 x 6.5 inches Thickness= .062 single side fiberglass Vectorboard (I had these boards in storage 10 years). Traces mostly 25mil with some 30 an4 mil . Board has a 100 mil border ground bus! 1st attempt=6 passes 80 percent very good,20 percent no good! 2nd try =10 passes= Board 100 percent exellent ! All lettering and traces 100 pct!No pin holes in traces detected! I think 8 or nine passes would have been just as good! No Pad/Trace spreading detected! all traces and pads = nice and crisp outlines I will update the Database! Regards Mike
