Dry film, photo resist - progress and question...
2008-10-25 by lcdpublishing
Hi guys,
I got a chance to do some more experimenting with the dry film photo
process.  I did a "step" test doing various exposure times and found
out that the UV lamp I bought for this purpose simply isn't powerful
enough.  I have a regular light bulb of the right color range and
tried that with much better results - exposure time through
transparncy of only 3 minutes.  I have much more experimenting to do
to get it better, but was able to make my first board all the way
through the etching process.
A couple of questions...
1) When I used to have a black and white dark room, I discovered
that the developer would last a long time and could be reused over
and over again.  I realize the developer for negative resist film is
much different than photographic developer, but suspect that the
chemical will stay "active" and as such, I could be reusing it.  Has
anyone tried this?
2) While doing the exposure / developer tests, I realized very
quickly just how tough this resist is.  I was scrubbing with a
scotch brite pad vigorously without removing the resist. This leads
me to the next question. Should the resist be removed or can it be
left on the copper?  If you have to remove it, how do you do it?
Thanks in advance!
Chris
Re: [Homebrew_PCBs] Dry film, photo resist - progress and question...
2008-10-25 by leon Heller
Sent: Saturday, October 25, 2008 1:21 AM
Subject: [Homebrew_PCBs] Dry film, photo resist - progress and question...
> Hi guys,
> anyone tried this?
NaOH developer can be reused many times. NaCO3 is probably similar, as it
forms a weak solution of NaOH which actually does the development..
It can be soldered through, but it's best to remove it. Iso-propyl alcohol
works very well for positive resist - I rub it with a moistened paper towel.
It probably works for negative resist, as well.
Leon
2008-10-25 by DJ Delorie
"lcdpublishing" <lcdpublishing@...> writes:
> anyone tried this?
So far, my developer and stripper haven't "aged" and I use them very
infrequently.
> Should the resist be removed or can it be left on the copper?
In my case, I strip the film off with a NaOH solution, and tin plate
the copper to protect it.
2008-10-25 by Adam Seychell
lcdpublishing wrote:
> Hi guys,
Most people use those UV "insect zapper" florescent tubes, also known as
black lights ("BL") which emit a bluey violet colour. Don't waste your
money on filtered black lights used for special effects. You can get 20W
compact florescent blacklight lamps too these days.
> and over again.
There is no shelf life for sodium carbonate solutions, other than water
evaporation. The Na2CO3 is obviously consumed during development, but
its actually very small. The data sheet for my resists specifies a
developer loading capacity of about 9.4E-6 m^3 of resist per litre of
developer. For your average 40um dryfilm resist and double sided PCB
with 50% trace coverage then that works out to be 0.23 m^2 of PCB area
(485 x 485mm square) per litre of developer.
That's normal. You strip it off in 2~5% NaOH, in 5 minutes at room temp.
  Don't waste your energy scrubbing it off, just let the NaOH do its
work and it will lift off before your eyes.
Re: Dry film, photo resist - progress and question...
2008-10-28 by roel_cnc
tanning tubes (easy to get in europe) works great.
I'm glad to hear (read) that more and more dry film users are here.
for over a couple of years im working with it and found out that a
normal exposure unit isnt wath you want with negative films.
Specialy with small smt pwb, the lines that are close together melt
together with negative film.
Or with positive film they get real thin.
I lower the 12 tube's to 60/70cm 25in. and close to te glassplate a
collimar grid like think&thinkers idea.
i will shoot some pictures this week of it
gr Roel
--- In Homebrew_PCBs@yahoogroups.com, Adam Seychell <a_seychell@...>
> > Hi guys,
found
powerful
do
known as
your
get 20W
over
> > and over again.
water
but
of
PCB
area
temp.
its
