HELP: D\Side Photo resist pcb
2008-07-17 by Howard
Hi
Just had a thought about a board i have to do soon
it needs to have a ground plane on the top side.
Now i have got some d\side photo resist board, and
i was thinking that if i do not expose the side that
is going to be the ground plane to UV, and just develop
it, would that keep it covered so that after etching i
have got a ground plane ??
Thanks in advance for any input
Howard
Re: [Homebrew_PCBs] HELP: D\Side Photo resist pcb
2008-07-17 by KeepIt SimpleStupid
If it's solid copper, then yes.  If it has thu-hole components, then no.
It also depends on whether your using positive or negative resist.
----- Original Message ----
Sent: Thursday, July 17, 2008 10:09:46 AM
Subject: [Homebrew_PCBs] HELP: D\Side Photo resist pcb
Hi
Howard
Re: HELP: D\Side Photo resist pcb
--- In Homebrew_PCBs@yahoogroups.com, KeepIt SimpleStupid
> From: Howard <hj.payne@...>
> Hi
> Howard
Hi
yes it is solid copper and positive resist pcb
it has thu-hole components, but i can clear these with a
drill bit, the rest of the components ground are to the
top side of the board.
Howard
Re: [Homebrew_PCBs] Re: HELP: D\Side Photo resist pcb
There is a small PC, router like bit you can buy which will remove the copper foil.
Vector Electronics, maybe.  It's used for prototyping.
Hi
Howard
2008-07-17 by Leon
Sent: Thursday, July 17, 2008 3:09 PM
> Hi
That's how I make RF boards that need a ground plane on one side.
Leon
2008-07-17 by Leon
From: "KeepIt SimpleStupid" <keepitsimplestupid@...>
Sent: Thursday, July 17, 2008 3:19 PM
Subject: Re: [Homebrew_PCBs] HELP: D\Side Photo resist pcb
Through-hole parts are OK, you just have to relieve the copper on the ground
plane where the connections aren't grounded with a drill.
Leon
--- In Homebrew_PCBs@yahoogroups.com, "Leon" <leon355@...> wrote:
> From: "Howard" <hj.payne@...>
> > Hi
> Leon
Hi
Spot on Leon !!
its a transverter for 4m that i am making
hows it going with the timer project ?, could do with one soon
mad a mess with a few boards (over exp) lol
Howard
2008-07-17 by Harvey White
On Thu, 17 Jul 2008 14:09:46 -0000, you wrote:
>Hi
One trick I used with a ground plane was to print just the pads on the
ground plane side, but reverse the artwork black for white.  That
gives you holes where the pads are, ground everywhere else.
Registration should not be a problem.
Harvey
>Howard
