today's problem...
2008-07-04 by DJ Delorie
Anyone see these extra bits of photomask after developing? http://www.delorie.com/pcb/inkjet/mask-bits.jpg This is at 200x, the gap is only 6 mil. I've tried extra developing, rinsing under high-pressure water, and scrubbing with a sponge. I can get them out one at a time with a pin, but that's not an acceptable solution. I'm even exposing a step less than usual in case it's from a pinhole. (if the above url complains, use http://www.delorie.com/pcb/inkjet/mask-bits.html) Also, I discovered that my laminator is too hot for this film. If I run a heat-gun-heated board through the laminator, it comes out all bubbly and wrinkled.
