CadSoft Eagle pads question
2008-07-10 by alan00463
Looked through the freeware Eagle 4.16's wirepads library.
Its thirteen thru-hole pads and four SMD pads are more than
adequate for what I'm doing.
However, in selecting pads for my thru-hole board, I got a couple
questions:
(1)   The numbers......does anybody know what the numbers
      in the pads library mean?   For example, the smallest thru-
      hole pad is marked 1,6/0,8 and the largest thru-hole pad
      is marked 3,81/1,4
(2)   When I add a pad, do I only add it to the board file, or is it
  necessary to also add a corresponding entity to the schematic?
Alan
Re: [Homebrew_PCBs] CadSoft Eagle pads question
2008-07-10 by Leon
Sent: Thursday, July 10, 2008 5:48 PM
Subject: [Homebrew_PCBs] CadSoft Eagle pads question
> questions:
>      is marked 3,81/1,4
That is similar to how I name my pads, the smaller number is the hole size
and the larger on is the pad diameter (in mm, of course).
I use Round (1.4, 3.8), for instance, with the hole size first, for round
pads. Rect (1.0 x 2.0) for rectangular pads (wdith x length), and so on.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
2008-07-10 by Mike Young
Alan,
The usual workflow is to first workup the schematic, and later drag the
parts into place on the board. You should find more part libraries on the
Cadsoft site than you can use. In general, the parts associate one or more
packaging options, each defining the appropriate copper, drill, soldermask,
and silkscreen. The limitation on the freeware is board size and complexity,
not the parts libraries.
Mike.
Sent: Thursday, July 10, 2008 11:48 AM
> questions:
>      is marked 3,81/1,4
> Regards,
> Alan
2008-07-10 by Harvey White
>questions:
>      is marked 3,81/1,4
	MM diameter and hole, IIRC
Add it to the schematic and it shows up on the board.  Especially
useful for test pads.
For mounting pads, try polygons.
Harvey
>Regards,
>Alan
Re: CadSoft Eagle pads question
Okay, thank you all for your quick replies.
Now I understand that a pad marked 3,81/1,4
would make a 1.1mm diam. hole inside a
3.81 mm diameter pad.    Likewise for the
other numbers.
I also realize I should put the pads on the
schematic.   Not sure what this will look like
on the schematic, but I'll give it a try and
see what happens.
Alan
> Harvey
Not exactly sure what you meant by that tip, Harvey
Do you mean mounting pads for connecting SMT parts?
-Alan
Re: [Homebrew_PCBs] Re: CadSoft Eagle pads question
>other numbers.
>see what happens.
>Alan
>> Harvey
Yes, or anything else you want to solder to the foil directly.  I also
use polygons for large ground planes.
Harvey
>-Alan
>>> Harvey
If you have special needs, sure, you could do that. For almost everthing
else, though, just place the part in the schematic, connect it up, and the
pads for the selected part show up on the board. If you selected, for
example, a transistor 2N2222 in a TO92 case, the footprint for the TO92 is
placed on the board. If it was an SOT23 package, the SMD for that would be
on the board. You'll almost always find it easier to design special pads as
an SMD's in the library editor than as polygons on the board. Ground and
power planes, of course, are exceptions.
2008-07-11 by alan00463
--- In Homebrew_PCBs@yahoogroups.com, "Mike Young" <mikewhy@...> wrote:
> From: "Harvey White" <madyn@...>
> >>> Harvey
everthing
and the
TO92 is
would be
pads as
and
Although I don't need a polygon now, I have used polygon to
create a groundplane in the past.    However, when doing so,
I could not figure out how to merge the filled polygon
with the adjacent ground trace.    Eagle always left an etched space
between the two.
2008-07-11 by Viper62pr
I have used polygons to make ground planes also, I would just rename the polygon as GND same as all of my GNDs, I use a polygon around the whole bottom layer.
Actually, I have only done it twice but they have turned out nice.
--- On Fri, 7/11/08, alan00463 <alan00463@...> wrote:
Subject: [Homebrew_PCBs] Re: CadSoft Eagle pads question
Date: Friday, July 11, 2008, 10:40 AM
> To: <Homebrew_PCBs@ yahoogroups. com>
> >>> Harvey
everthing
and the
TO92 is
would be
pads as
and
between the two.
2008-07-11 by Markus Zingg
There is an isolation spacing setting in the poligon propperties. You
can also change it on an existing poligon. This setting will define the
isolation distance between the poligon covered area and other signals.
Look up change -> isolate or the values you can enter while you create
the polygon.
HTH
Markus
> between the two.
2008-07-11 by Mike Young
That might be the step Alan is missing. Try changing the polygon's signal
name to GND. Eagle should then merge the ground traces into the ground
plane, and isolate around the other sigs.
Sent: Friday, July 11, 2008 9:28 AM
Subject: Re: [Homebrew_PCBs] Re: CadSoft Eagle pads question
bottom layer.
between the two.
2008-07-12 by warrenbrayshaw
Follow the instructions in the Eagle tutorial to understand how to
pour ground planes.
This subject should be discussed in the eaglecad@yahoogroups.com group.
Regards
> between the two.
2008-07-15 by Steve
It is acceptable to discuss it here, too.
Steve Greenfield
owner Homebrew_PCBs
--- In Homebrew_PCBs@yahoogroups.com, "warrenbrayshaw"
> pour ground planes.
> Regards
> > between the two.
